Tolerance (%)
20 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Rated voltage (V)
Pierre Marie S.
AVIS SUR QUALITÉ ET MONTAGE
Rien à dire sur la qualité des matériaux et l’usinage. La plaque inférieure du boîtier aurait pu être un peu plus...
Gregory O.
Not copper
Waste of money. No copper anywhere on this plug as I filed it down and no copper.
Guillaume D.
Oubliez tous les autres
Ayant récemment acquis une paire de Chario Aviator Nobile, j'étais à la recherche d'électroniques à la hauteur de...
Electrolytic capacitors
Discover our selection of electrolytic capacitors, essential for optimizing the performance of your electronic circuits and improving the audio quality of your equipment.
Electrolytic capacitors are key components in many electronic devices, particularly prized for their ability to deliver high capacitance values in compact formats. They play a crucial role in power regulation, signal filtration and voltage stabilization, making them indispensable to circuit designers and audio enthusiasts alike.
  • Mundorf MLytic Audio Grade Capacitors
    Immerse yourself in sonic excellence with our selection of Mundorf MLytic Audio Grade capacitors, designed for audiophiles and professionals seeking ultimate performance.
    Mundorf MLytic Audio Grade capacitors are renowned for their exceptional ability to enhance the sound quality and precision of your audio systems. Designed with rigorous standards and high-quality materials, they are specially developed to deliver unrivalled audio performance. In particular, this range is designed for use in small power amplifiers and preamplifiers.
  • Mundorf MLytic High Voltage capacitors
    Discover the power and precision of Mundorf MLytic High Voltage capacitors, designed for demanding applications where performance and reliability are paramount.
    Mundorf MLytic High Voltage capacitors are specially developed for high-voltage environments, offering outstanding quality for audio equipment and electronic circuits requiring increased robustness and stability. These capacitors are the ideal choice for projects where high-voltage management and sonic fidelity are crucial.
  • Mundorf MLytic High Current capacitors
    Elevate your audio performance with Mundorf MLytic High Current capacitors, designed for applications requiring superior high-current handling and unsurpassed audio precision.
    Mundorf MLytic High Current capacitors are specially developed to meet the needs of high-performance audio systems and demanding electronic circuits. Thanks to their ability to handle high currents while offering exceptional stability, these capacitors are ideal for applications where power and sound quality are crucial.
  • Panasonic capacitors
    Discover our selection of Panasonic capacitors, synonymous with reliability and performance for your electronic projects.
    Panasonic is a world-renowned brand, renowned for the quality and durability of its electronic components. Our Panasonic capacitors are ideal for a wide range of applications, from high-end audio circuits to complex electronic projects. Whether for filtering, voltage stabilization or power management, these capacitors offer a reliable, high-performance solution for all your technical needs.
  • Nichicon capacitors
    Nichicon capacitors
    Explore quality and precision with our range of Nichicon capacitors, designed to meet the most demanding requirements of your electronic projects.
    Nichicon is a leading brand in capacitors, renowned for its commitment to innovation, quality and reliability. Whether you're working on high-end audio projects, power supply circuits or other complex electronic applications, Nichicon capacitors are designed to deliver outstanding, long-lasting performance.
  • Cornell Dubilier capacitors
    Rely on the proven quality of Cornell Dubilier capacitors, designed to deliver optimum performance in a wide range of electronic applications.
    Cornell Dubilier is a benchmark brand in the capacitor industry, renowned for its expertise and commitment to quality. Whether you're an electronics engineer, audiophile or technician, Cornell Dubilier capacitors are designed to meet the demands of the most complex projects and guarantee long-term reliability.
