Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Antonio C.
Amazing device
I recently purchased the Eversolo T8 and have been thoroughly impressed with its performance. When paired with my Denafrips...
sven m.
A real asset for the Buchardt Audio P300
Fast delivery and smaller than expected. So far, everything looks great and sounds fantastic. Thanks Audiophonics.
Thomas R.
Danach habe ich schon lange gesucht und hier endlich gefunden!
Ich habe schon länger nach so einem Umschalter gesucht der genau das kann.
Im Heimkinobetrieb nutze ich den RCA pre-out...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 5720
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. It is therefore possible to achieve better inductances while maintaining low internal impedance and zero...
    28,90 € 24,08 €Ex.
    In Stock
  • Ref : 5723
    In Stock
    32,90 € 27,42 €Ex.
    In Stock
  • Ref : 4196
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion. For this reason, Mundorf produces coils with a large wire diameter for purists. It is therefore possible to achieve better inductances while maintaining low internal impedance and zero distortion.
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 4197
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 4198
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4195
    In Stock
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 4199
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 4200
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 4201
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 4202
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4203
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 4204
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 4205
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 4206
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 4208
    In Stock
    35,90 € 29,92 €Ex.
    In Stock
  • Ref : 4209
    In Stock
    38,90 € 32,42 €Ex.
    In Stock
  • Ref : 4210
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 4222
    159,90 € 133,25 €Ex.
    In Stock
  • Ref : 4207
    In Stock
    32,90 € 27,42 €Ex.
    In Stock
  • Ref : 4212
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 4213
    61,90 € 51,58 €Ex.
    In Stock
  • Ref : 4211
    In Stock
    48,90 € 40,75 €Ex.
    In Stock
  • Ref : 4215
    In Stock
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 4216
    In Stock
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 4214
    In Stock
    53,90 € 44,92 €Ex.
    In Stock
  • Ref : 4217
    In Stock
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 4218
    In Stock
    99,90 € 83,25 €Ex.
    In Stock
  • Ref : 4219
    In Stock
    109,90 € 91,58 €Ex.
    In Stock
  • Ref : 4220
    In Stock
    119,90 € 99,92 €Ex.
    In Stock
  • Ref : 4975
    In Stock
    Mundorf BS100 coils are high performance models for low frequency filtering. The core is made of Feron which is heat treated after production. This treatment gives it an optimal internal structure for good magnetic characteristics with very low losses and low distortion.
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 4987
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 4988
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 4977
    Out of stock
    25,00 € 20,83 €Ex.
    Out of stock
  • Ref : 4981
    In Stock
    27,40 € 22,83 €Ex.
    In Stock
  • Ref : 6118
    In Stock
    Mundorf BS140 coils are high performance models for low frequency filtering. The core is made of Feron which is heat treated after production. This treatment gives it an optimal internal structure for good magnetic characteristics with very low losses and low distortion.
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 2765
    In Stock
    60,90 € 50,75 €Ex.
    In Stock
  • Ref : 6119
    In Stock
    85,00 € 70,83 €Ex.
    In Stock
  • Ref : 6117
    In Stock
    42,90 € 35,75 €Ex.
    In Stock
  • 49,90 € 41,58 €Ex.
    In Stock
  • Ref : 2763
    In Stock
    58,90 € 49,08 €Ex.
    In Stock
