This section presents all our exciters, allowing the creation of a sound wave by the vibration of a surface. Many brands are represented, allowing everyone to find a model that will suit his project. The filters on the page allow you to make a more precise selection according to your needs.
Dayton Audio's EX30HESF2-4 IMS™ is a high-output 30mm exciter, among the most powerful in the brand's exciter line, supporting 40W of power. A pre-attached 3M VHB™ adhesive ring and interchangeable mounting system combines with four screw-in mounting lugs for maximum energy transfer.
Exciter technology offers a universal and affordable alternative to conventional speakers, allowing sound reproduction virtually anywhere you want it. Dayton Audio's 2-hole mounting vibrators can be used in a multitude of DIY applications.
This EX32HDRS-4 exciter from Dayton Audio is an alternative to conventional loudspeakers, in fact it is capable of effectively sounding many different types of space. The exciter is part of the IMS™ range, and therefore features the brand's quick-fix and interchangeable technology: EX2HMP-5 IMS™. This exciter accepts 30Wrms of power at 4 ohms,...
The Dayton Audio EX32HRDS-4 lets you add a dynamic sound source to almost any surface or object. Exciter technology offers a universal, cost-effective alternative to conventional loudspeakers, enabling sound reproduction virtually anywhere. Problems such as weather conditions, space constraints, vandalism or visibility can be avoided or minimized through...
The Dayton Audio EX32VBDS-4 exciter has been meticulously designed to optimize performance in the often challenging low-frequency spectrum. This state-of-the-art exciter exceeds the limits of its counterparts, while preserving high-frequency reproduction. With its simple 4Ω load and 40W power handling, the EX32VBDS-4 integrates effortlessly into a...
A weatherproof electrodynamic exciter that can be placed virtually anywhere, Dayton Audio's HDN-8 literally makes any surface "ring". The product is screw-mounted using the screw head molded into the speaker.
The Dayton Audio HDN-8B will add a dynamic sound source to almost any surface or object. Exciter technology offers a universal and cost-effective alternative to conventional drivers, enabling sound reproduction virtually anywhere. Issues such as weather conditions, space constraints, vandalism, or visibility can be avoided or minimised through the use of...
The Dayton Audio SMRK-2 is a mounting kit for the TT25 PUCK vibrator (exciter). It allows quick and convenient installation of the vibrator on flat surfaces, eliminating the need for a mounting hole.
Dayton Audio's TT20-8 is a small, 8-ohm exciter or mini bass shaker that transfers low-frequency sound waves directly to the listener by exciting surfaces with which the listener's body is in contact. This can represent a significant improvement in terms of immersion within a home-cinema installation.
This Douk Audio BS-1 bass shaker delivers deep, powerful bass. Combined with a suitable support and thanks to its perfectly controlled vibrations, it offers a particularly immersive rendering of low frequencies. More than just being heard, these frequencies can be felt for a listening experience of a whole new dimension. This type of vibrator is...
This bass shaker, with a power output of 50W at 4Ω, delivers deep, punchy bass across a frequency range of 20Hz to 80Hz. Mounted on a suitable support, this shaker delivers controlled, immersive bass that is not only audible but also physically perceptible. Ideal for home cinema or gaming, where immersion makes all the difference.
This electrodynamic exciter Visaton EX 80 S allows to have a sound reproduction by vibrating a surface. The fixation to the contact surface can be done by contact or screwing. This model has a vibrating surface of 80x80mm, an impedance of 8Ω and supports powers up to 50W.
The XCITE XBS100-4 is a vibrating speaker designed to convert an audio signal into mechanical vibrations that are transmitted directly to a surface. It delivers 100 W under 4 ohms, utilising an FEA-optimised, low-mass neodymium magnetic circuit and a dual 11.4 cm voice coil to ensure rapid and controlled movement of the inertial mass.
The XCITE XBS200-4 is a vibrating speaker designed to convert an audio signal into mechanical vibrations that are transmitted directly to a surface. It delivers 200W under 4 ohms, utilising an FEA-optimised, low-mass neodymium magnetic circuit and a 17.8cm dual voice coil to ensure rapid and controlled movement of the inertial mass.
The XCITE XBS25-4 is an vibrating speaker designed to convert an audio signal into mechanical vibrations that are transmitted directly to a surface. It delivers 25 W under 4 ohms, utilising an FEA-optimised, low-mass neodymium driver and a 5.3 cm dual voice coil to ensure rapid and controlled movement of the inertial mass.
The XCITE XBS50-4 is a vibrating speaker designed to convert an audio signal into mechanical vibrations that are transmitted directly to a surface. It delivers 50 W into 4 ohms, utilising an FEA-optimised, low-mass neodymium magnetic circuit and a 7.2 cm dual voice coil to ensure rapid and controlled movement of the inertial mass.
The XCITE XBS50MK is a mounting bracket designed specifically for the brand’s XBS50-4 exciter. It is designed to provide a mechanically stable mounting whilst optimising the transfer of vibrational energy to the host structure. It is built on a glass-fibre-reinforced ABS base incorporating copper inserts, which provide long-lasting protection for...
The XCITE XT19 is a compact vibrating driver designed for space-saving installations; its ultra-slim 14 mm profile makes it easy to fit into confined spaces whilst retaining significant excursion capability. It features a dual N42 neodymium magnetic circuit combined with a 4-layer voice coil, increasing sensitivity by more than 3 dB whilst maintaining a...
The XCITE XT25 is a vibrating speaker designed to extend the frequency response into the high frequencies, optimised up to 19 kHz. It features a dual N42 neodymium magnetic circuit delivering high sensitivity, whilst its 3.0 mm Xmax, combined with a linear excursion of 1.4 mm, enables controlled movement, ensuring a balance between refined reproduction...
The XCITE XT32-4 exciter features a unique combination of large travel and low inductance, guaranteeing vibrations with the lowest distortion across the entire frequency range. The XT32-4 is equipped with a double neodymium magnet motor, offering excellent power and precision. The XT32-4 is extremely reliable. It has been designed to avoid level drops,...
The XCITE XT32-8 is a exiter driver featuring a unique combination of long excursion and low inductance, guaranteeing vibrations with the lowest distortion across the entire frequency range. It is equipped with a dual neodymium magnet offering excellent power and precision. The XT32-8 is extremely reliable, designed to avoid level drops and equipped with...
The XCITE XTB40 is a vibrating speaker designed for low-frequency reproduction, with an architecture that optimises bass extension down to 25 Hz. It features an extended excursion of 5.0 mm Xmax for 2.5 mm of linear displacement, enabling it to generate significant mechanical energy whilst maintaining distortion control, whilst the combination of a dual...
