Connector
Max sampling rate
DAC / ADC Chip
Amplifier chip
Class
Power (W)
5 - 165
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Connectic
Length
1 m - 2 m
Conductors material (Cable)
Contacts Plating (Connector)
Channel
Input
Output
Remote Control
Networking
Transmission / Reception protocol
Streaming services
Color
Conductors Plating (Cable)
Shielding
Peter H.
Noticeable positive effect on the sound
Like one of the other reviewers, I'm using this power filter together with a Matrix Element H USB card. The reason I...
Jürgen L.
The product description is incorrect — these are not copper‑core connectors
These Female RCA Connectors are not gold‑plated copper contacts. I removed the galvanic gold layer, and underneath it’s the...
claude B.
excellent petit steamer
bonjour, je suis ravi du rendu sonore en écoute via rca numérique.
Mais aucun son par les sorties usb
et je ne comprends pas...
Headphone amplifier / Preamplifier
Découvrez notre gamme complète d'Amplificateur casque et de Préamplificateur audio. De l'ampli casque mobile à l'ampli casque sédentaire, vous trouverez l'appareil HiFi pour casque audio correspondant à vos attentes et vos besoins.
Soyez également certain de la qualité des Préamplificateurs HiFi que nous vous proposons, qui saurons sublimer et améliorer considérablement votre rendu sonore.
  • Mobile HP Amplifiers
    Discover our range of portable headphone amplifiers, designed for use both at home and on the move, thanks to a compact form factor and an adapted design. Enjoy the best sound quality, wherever and whenever you want.
  • Desktop headphone amplifiers
    Want to enjoy optimal headphone listening at home? Our range of sedentary headphone amplifiers is made for you. A wide selection of headphone amplifiers for both sensitive headphones and high-impedance models.
  • Preamplifiers & Volume Controllers
    Discover our selection of preamplifiers and volume controllers, powerful models to promote excellent sound reproduction for your audio system.
  • Vinyl Preamplifers
    Vinyl Preamplifers
    Do you want to go back to the roots of analog HiFi and enjoy the warm sound of your turntable? A phono preamplifier is then a must to provide your system with the necessary gain to enjoy your equipment at its best.
