DUNU DN242 In-Ear Monitors
The Dunu DN242 are hybrid in-ear monitors, designed to distribute the audio spectrum across eight specialised drivers (2 dynamic, 4 balanced armature, 2 planar magnetic), utilising a five-way hybrid crossover that combines physical separation and electronic management to ensure a smooth transition between frequency ranges whilst minimising phase interference. This configuration maintains tonal consistency across the entire frequency range, whilst preserving the clarity of subtle details in overlapping frequency bands.
By buying this product you get 34 loyalty points
Reference : 21948
349,00 €tax incl.
290,83 € tax excl.
Dunu DN242 In-Ear Monitors IEM Dynamic Balanced Armature Planar Magnetic 35 Ohm 125dB 5Hz-40kHz
Dunu DN242 : Front view
Dunu DN242: Dual dynamic transducers
The DN242 entrusts the reproduction of low frequencies to a dual dynamic driver configuration, featuring a 10mm driver dedicated to sub-bass to ensure extension and depth, whilst the 8mm driver handles the upper bass by controlling impact and resonance, thereby maintaining a structured physical foundation without compromising the clarity of the lower midrange.
Dunu DN242 : dynamic transducers
Dunu DN242 : balanced armature drivers
Dunu DN242: 4 balanced armature drivers
The DN242 uses four balanced armature drivers for the midrange and treble, arranged in such a way as to separate the vocal frequencies from those dedicated to the instruments; this approach ensures accurate tonal reproduction whilst minimising distortion caused by mechanical movement.
Dunu DN242: Two planar magnetic transducers
The DN242 utilise two planar magnetic micro-transducers for the extreme high frequencies, employing a low-inertia diaphragm to extend the frequency response up to 40kHz, thereby allowing for the reproduction of higher harmonics and ambient details with greater finesse, whilst maintaining a smooth and non-aggressive sound in the upper frequencies.
Dunu DN242 : planar magnetic transducers
Dunu DN242 : Cable and termination
Dunu DN242: Silver-plated copper cable
The DN242 takes this approach a step further by transmitting the signal via a silver-plated, single-crystal copper cable with a Litz structure, minimising losses caused by the skin effect and internal interactions between conductors, whilst the 0.78 mm 2-pin connectors, combined with an interchangeable terminator, ensure maximum compatibility with all your sources.
Product typeIn-ear monitors
Drivers2x Dynamic
4x Balanced armature
2x Planar magnetic
Frequency response5Hz-40kHz
Sensitivity110dB/mW @1kHz
125dB/Vrms @1kHz
Impedance35Ω
Total harmonic distortion (THD)<0.5% @1kHz
Cable typeDetachable
Cable conductor materialSilver-plated copper
Cable connectors0.78mm 2-Pin
Cable termination1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
Weight6g by side
ColorRed
Package1x Dunu DN242
1x Storage pouch
1x Earphones cable
1x 3.5mm jack termination
1x 4.4mm jack termination
10x Pairs of ear tips
ColorRed
Impedance (Ω)35
Efficiency / Sensitivity (dB)125.0
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
DUNU DN242 In-Ear Monitors IEM Dynamic Balanced Armature Planar Magnetic 35 Ohm 125dB 5Hz-40kHz
The Dunu DN242 are hybrid in-ear monitors, designed to distribute the audio spectrum across eight specialised drivers (2 dynamic, 4 balanced...
