DDHIFI DJ30SE 4.4mm Balanced Male Jack to 3.5mm Single-Ended Female Jack Adapter
The DD HiFi DJ30SE is an audio adapter designed to connect headphones or earphones equipped with a 3.5mm single-ended plug to a source featuring only a 4.4mm balanced output. Designed to provide reliable signal conversion without short-circuiting the negative channels of the balanced signal, it ensures safe operation with compatible devices.
Reference : 22183
29,91 €tax incl.
24,92 € tax excl.
Shipping date: 24-11-2026.
ddHiFi DJ30SE 4.4mm Balanced Male Jack to 3.5mm Single-Ended Female Jack Adapter Gold Plated
DDHIFI DJ30SE
The ddHiFi DJ30SE is an audio adapter designed to connect headphones or earphones equipped with a 3.5mm single-ended plug to a source featuring only a 4.4mm balanced output. Designed to provide reliable signal conversion without short-circuiting the negative channels of the balanced signal, it ensures safe operation with compatible devices. Its compact CNC-machined aluminum alloy housing, gold-plated 4.4mm male jack connector, and 3.5mm female jack socket provide excellent durability and low contact resistance. Furthermore, its internal silver-plated OCC copper wiring ensures excellent conductivity and high-quality signal transmission, minimizing losses while preserving audio signal integrity.
Unlike a simple mechanical adapter, the DJ30SE is specifically engineered to correctly convert a 4.4mm balanced output to a 3.5mm single-ended connection without directly linking the negative poles of the left and right channels. This design preserves the integrity of the output stages of compatible devices and ensures safe operation with equipment featuring only a 4.4mm output.
DDHIFI DJ30SE
Please note that this adapter is not compatible with 4.4mm jack sockets that do not feature a ground pin, nor with Sony Digital Music Players / Walkman devices.
Technical Specifications
Product TypeJack Adapter
Connectors1x 4.4mm Balanced Male Jack
1x 3.5mm Single-Ended Female Jack
Contact PlatingGold
Internal WiringSilver-plated OCC Copper
Housing MaterialL6063 Aluminum Alloy, Titanium Gray Sandblasted Finish
Dimensions16.4 × 16.1 × 10mm
Weight5.2g
Package Contents1x DDHIFI DJ30SE
ConnecticMale & Female
ConnectorJack 4.4mm
ConnectorJack 3.5mm
DDHIFI DJ30SE 4.4mm Balanced Male Jack to 3.5mm Single-Ended Female Jack Adapter Gold Plated
The DD HiFi DJ30SE is an audio adapter designed to connect headphones or earphones equipped with a 3.5mm single-ended plug to a source featuring...
