iouri C.
Au final déçu.
Antoine S.
CD Player Upgrader
Michel R.
Parfait pour mon usage
Jean-pierre M.
très bon connecteur de très belle fabrication, exige pour le montage une clef à Lenn de 1,27mm
Sandy Clémence B.
Wiring Cable OCC Copper PTFE Sheath 0.5mm² Ø1.4mm Transparent This Ø1.4mm wiring cable is composed of an OCC 6N copper conductor with a cross-section of 0.5mm². This conductor itself is made up of 19 strands of 0.18mm each....
Belle Qualité
A l'écoute, le résultat est patent.
Sandy Clémence B.
Aeticle De Qualité
Qualité Avérée
Sandy Clémence B.
ELECAUDIO LI-23GB IEC C13 Connector Gold Plated 24k 3x5mm² Ø15mm This IEC C13 Elecaudio LI-23GB connector is ideal for creating quality power supply cables. It uses 24k gold-plated copper alloy contacts of 5mm², which provides a very...
Article de Qualité
Qualité Avérée
Sandy Clémence B.
Article de Qualité
KONSTANTINOS L.
AUDALYTIC HP70 Headphone Amplifier Preamplifier Balanced Silver The Audalytic HP70 is a high-end headphone amplifier and preamplifier designed to deliver exceptional sound quality thanks to its fully balanced and discrete architecture....
Very satisfied
I use it only as a headphone amplifier. The 4 different headphones - three dynamic and one planar - perform excellently. After hours of listening, it does not heat up much. I noticed a big difference when I used the audiophonics lpsu25 power supply instead of the mains supply. As if I were listening to two different audalitic! The minuses - expected at this price - are the lack of presets, e.g. for gain and the absence of equalizer, crossfeed. With power from a linear power supply, the amplifier performs excellently.
Alexandre p.
Perfect avec un raccordement sur un pixel
Je l'alimente et l'utilise avec du courant propre de mon smartphone avec un cable belkin 240watts.
La sortie est meilleure que sur le 5v de ma tour.
Pour la sortie Toslink a priori, c'est très bon aussi.
Le tout sur des monitors en class D.
Balazs D.
SYITREN R300 CD Player on Battery Bluetooth 5.3 Black / Wood The Syitren R300 is a small CD player with a nice retro design. Equipped with a Toslink optical output and a Jack 3.5mm headphone output, it will allow you to enjoy your CD...
Nice surprise, plays gapless
I really like the design of this device, but I was reluctant to buy it due to the information that it doesn't have a gapless function, which is very important for me. It turned out that it does play continuous albums without adding gaps between the tracks, very nice surprise!
Lars H.
Being an audiophile I'm all about vinyl, CD and cassette tape. Meaning, when I can't get a hold on an album on CD, vinyl or studio recorded tape, I buy it on FLAC download. so I use this cable for recording FLAC files of albums I buy. I play from my Chromebook via a usb dac through the cable. I use a high end tape deck and can monitor the source and recording as it record. I hear minor differences in the recording from the FLAC source, even compared to listing to the FLAC music direct from the PC via the DAC to my headphones. So the minor differences are due to the dynamic range of the tape. So basically no signal degradation from the cable. Highly recommended if you need quality sound from one source to another.
Stephane R.
MINIDSP ADEPT ADC ES9842 Phono Preamplifier with DSP 32bit 192kHz miniDSP ADept is an ADC with phono preamplifier and DSP. It is based on an XMOS interface and an ESS ES9842 Pro conversion chip. This enables it to convert analog signals up to...
ADC complet, transparent, unique pour upgrader à petit prix.
J’utilise le MiniDSP Adept pour le studio sous Cubase 14 en 24/88,2 via Toslink, avec ma vieille carte son RME AIO version 1.0 (PCIe), qui reste dans le top‑10 niveau latence et charge CPU/VSTs. La latence supplémentaire est nulle, puisque le signal passe plus court que le tampon ASIO.
Ne pouvant pas investir dans une RME ADI‑2 Pro FS à 1700 €, ce petit module, de la taille d’un Roland Sound Canvas 55, me permet de connecter en XLR mes préamps et DI (comme l’Avalon U5). Je peux même enregistrer via RCA des signaux vintage, comme le Chisound AY d’un Amstrad CPC, en stéréo à 192 kHz (gain = H).
La qualité de prise semble meilleure qu’avec une carte son de 17 ans. Je ne l’ai pas encore utilisé dans une vraie session complète, mais les transitoires me paraissent très précis, ce que je considère plus important que la linéarité pure. De toute façon, il n’existe pas d’autre solution abordable : au‑dessus, il faut compter trois fois le prix, et j’ai cherché un an une alternative d’occasion, sans succès.
Michal D.
RAMM AUDIO ELITE 8 RCA Cables OCC Copper Cryo Gold Plated 1m (Pair) RAMM Audio Elite8 cables offer an exceptional design quality, using only high quality materials for a perfect transmission of the audio signal and a transparent, pure and...
Traits of this cable
3dimensional, ethereal, more pleasant (and lush) midrange sound. Reveals a lot of details in high region. Creates beautiful soundstage character.- expansive soundstage, with increased depth and size. But: less bass resulting in less weighty sound.
Schuko ETI sur mon ampli Nupime
Bonsoir j avais deja une ETI sur mon alimentation de mon phono , la je les installé sur mon ampli ( vondita ,iec 004 ) elle remplace une schuko 004 , ETI est plus precise ,transparente,rapide, le timbre est plus doré , ETI n a pas une grosse basse ,ni un gros bas medium mais elle fait le job. Je conseille de marier 004 et ETI ( la 004 est lisse ,un poil plus ronde et plus punchy du bas ) ETI en transparence ,timbre, precision,rapidité , finesse du haut ,j ai jamias entendu mieux !
ERIC C.
Magique !!!
Acheté à la mi-décembre en remplacement de 2 Nuprime STA-9 que j'utilisais en mode ponté mono, la magie a opérée dès les premières notes, connaissant déjà la classe D je ne m'attendais pas à une telle différence entre ces 2 générations d'ampli en classe D, déjà niveau poids 2 kg de moins sur la balance, la qualité des borniers carbone donne le ton, très imposants et surtout acceptant du câble de très grosse section, la finition est irréprochable le pied central avant déroute au début mais c'est très stable, les multiples réglages pour la sensibilité de sortie par le biais de petits switchs permet de caler correctement l'ampli au pré-ampli niveau volume
ERIC C.
VIABLUE FILTER 11 Filtering Ferrite Reducer Ø10.5mm to Ø10mm Viablue Ferrite Reducers eliminate high-frequency electromagnetic interference (EMI) and the noise it induces within your audio cables. This is essential for designing high...
Des ferrites de qualité
Très belle fabrication, j'en utilise dans des dimensions différentes et j'avoue que ces ferrites sont d'excellente qualité.
ERIC C.
Heatshrink Braided Tubing 2:1 Ø20-22mm Black This 20mm diameter heat-shrinkable Nylon braided sleeve gives your cables a clean finish. The 2:1 ratio of this sleeve means that when heated to between 80 and 120°C, the...
Essai de cette gaine
Pas encore utilisé mais l'aspect me parait correct, à voir à l'usage.
ERIC C.
Heatshrink Braided Tubing 2:1 Ø12-14mm Black This 12mm diameter heat-shrinkable Nylon braided sleeve gives your cables a clean finish. The 2:1 ratio of this sleeve means that when heated to between 80 and 120°C, the...
A voir à l'usage !!!
L'aspect visuel et le touché sont bon, je n'ai pas encore utilisé ce genre de gaine, mais ça ne serait tardé !!!!
Alexandre p.
Approbation mitigée mais validé
Il tourne chez moi sous linux (Fedora, Arch) Carte pcie USB externe, alimenté ou pas pour envoyé un peu plus d'ampères. Inécessaire sachant que ce dac a été conçu pour accepté une très faible alimentation en entrée. Il reste évidemment le bruit, mais tout est traité en électronique pour garantir un bon fonctionnement sur tout entrées, notamment l'usb.
Je ne connais pas les caractéristiques de l'AKM mais il semblerait que je sois perplexe face à un ancien dac WM8741.
Je choisis donc [Seabound - Beyond Flatlines] pour session d'écoute sous strawberry en accès PCM à -21 LUFS pour normalisation. Les basses sont assez dynamiques voire punchy et les textures sont un peu en retrait. Le spectre a tendance a shifter légèrement. Il y a un peu de sibilance mais ça semble assez cohérent dans l'ensemble. Des micros détails sont facilement perceptible, la stéréo semble cependant restreinte en terme d'ampleur. Je me pose la question d'une éventuelle stabilisation à la chauffe de l'appareil. Attention, j'ai une tendance à baisser le volume fréquemment pour atténuer certaines phrases des titres.
Je me suis aperçu que j'avais opacifier le rendu avec de la mousse dans mes Adam audio T7v, la lecture est meilleure sans la mousse à l'intérieur et un rapprochement au mur.
Après avoir lu les deux premiers titres en entréé USB, je passe en alimentation externe et Toslink. Il semblerait que le son favorise une autre dynamique et que l'image sorte un peu au dela des enceintes, moins contenu donc.
La lecture n'est pas tout à fait la même, l'architecture du son différemment interprété mieux ressenti, plus vivante, moins gênante j'aurais tendance à dire, des timbres mieux respectés.
Le respect du master est meilleur, malgré une petite baisse de 2db sur le haut du spectre de mes Adam Audio T7v.
Plutôt pas mal pour ce prix la. Il me reste à envisagé à opacifier le local d'écoute qui marque trop de clarté.
Antoine S.
Le plaisir est au RDV :-)
Au déballage on constate que ces câbles transpirent la qualité de fabrication. Les fiches banane dispose d'un excellent dispositif de serrage.
Ces câbles viennent remplacer des ELECAUDIO HP-25OCC.
A l'écoute on ressent de la fluidité, avec une excellent image 3D qui fourmille de détails. On ressent un message précis et équilibré, avec de la douceur en permanence, et des basses médiums et aigus de hauts niveaux, le tout sans fatigue.
Le plaisir est au RDV, je recommande vivement :-)
Bertrand H.
CLOUDYX CL-BOX PRO Audio Streamer WiFi DLNA AirPlay Bluetooth 5.2 Multiroom DAC ES9018K2M Transform your audio setup into a true high-fidelity wireless system with the CloudyX CL-BOX Pro. This compact audio streamer enables multiroom broadcasting via WiFi and...
CLOUDYX CL-BOX PRO Lecteur Réseau Audio WiFi DLNA AirPlay Bluetooth 5.2...
Mes premiers pas dans la musique dite dématérialisée !
Convaincu du caractère raisonnable du produit et de son rapport qualité /prix en ayant lu l'essai publié dans https://www.on-mag.fr/index.php/topaudio/actualites-news/27446-lecteurs-reseau-hifi-a-moins-de-120-eur-les-meilleures-options-pour-profiter-de-la-musique-connectee
Très facile à prendre en main en dépit de l'absence de notice française ( à savoir pour les réfractaires à l'anglais)
Très bien pourvu en branchements divers dont une HDMI ARC qui m'intéressait au plus haut point...
Boitier métallique de belle facture , les ingénieurs de la silicon vallée chinoise de SHENZEN ont réussi leur coup.
Bon maintenant question "SON"cela demeure avant tout et pour tout du son compressé qui même avec mon abonnement QOBUZ n'équivaut en rien un bon petit système ampli / CD ATOLL et ROTEL mais c'est très sympa et super bien placé pour franchir ce cap raisonnablement .
Je recommande vivement surtout à ce prix sur ce très bon site www.audiophonics.fr
Lionel B.
Canare L-4E6S : Neutralité pro à prix choc
Le câble RCA Canare Star Quad offre un rendu sonore étonnamment neutre, grâce à sa conception professionnelle sûrement.
Celui-ci n'ajoute ni enlève quoi que ce soit au signal.
Rendu transparent qui respecte scrupuleusement le message original : pas de coloration, d'éclat artificiel ou d'atténuation dans les graves, médiums ou aigus.
Gros plus : le câble est très souple et très bien fabriqué.
Le sens du câble est indiqué.
Excellent RQP !
Lionel B.
3E AUDIO A7 Class D Stereo Amplifier PBTL 2xTPA3255 2x250W 4 Ohm 3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A7 amplifier is based on two TI TPA3255...
Le petit ampli qui envoie du lourd !
J'utilise le 3E Audio A7 comme bloc de puissance. Il est compact avec une alimentation externe 48V GaN, conçu pour un fonctionnement simple en bloc de puissance avec un préamplificateur.
Choix bypass ou volume sur la face arrière, réglage de gain en deux positions pour une meilleure adaptation avec le préamp.
Bouton principal pour allumage/arrêt (appui long) et commutation RCA/XLR (appui court).
Boîtier légèrement chaud en fonctionnement, conforme et rien de rédhibitoire pour ce type d'appareil.
Au niveau rendu, celui-ci et globalement neutre avec de la transparence, sans coloration notable : grave contrôlé, médiums nets, aigus précis sans dureté. Timbre vocal naturel et texturé.
La scène sonore est étendue avec une bonne séparation stéréo et suivi instrumental clair, même à faible volume où l'équilibre tonal persiste.
Petits bémols : alimentation externe volumineuse. Une version avec alim intégrée serait un gros plus (pour une meilleure intégration etc..).
Absence de trigger 12V sur la version française, contrairement à aux modèles US (voir photos du test ASR).
Indicateur rouge pour RCA/XLR, couleur potentiellement trompeuse (rouge = erreur) par rapport au vert standard.
Pierre B.
JJ ELECTRONIC ECC82 / 12AU7 GOLD Twin triode tube (Matched Pair) The ECC82 / 12AU7 GOLD tube from JJ ELectronics is a double triode offering good performance, smooth tones and clear definition. It is designed to provide two balanced triodes...
Super détaillées
Montées en lieu et place sur un préampli maison ( Base schéma Quad année 70 cascode) pour remplacer des anciens tubes de chez National USA de 40 ans d'âge plus pas curiosité que par nécessité car les Nationals donnaient de super résultats.
Dès les premières écoutes il me semble que j'ai perdu en peu en gain mais c'est pas grave car j'ai gagné sur la définitions et la précision ainsi que sur les attaques les graves sont profonds mais ne bavent pas (contrairement au Nationals qui trainaient u peu) l'aigue monte haut sans crier j'aime beaucoup , passé 3 jours pas de gain notable on verra dans 2 semaines mais j'ai toujours des doutes quand à la nécessité de rodage je pense que c'est plutôt l'auditeur qui s'habitue au nouveau son.
Deux points qui m'empêche de mettre 5 étoiles :
- Son moins tube, plus froid, le prix de la clarté sans doute et des enceintes haut rendement qui ne pardonnent rien mais la sensation d'espace le positionnement des instruments l'extinction des notes sublimes propres aux tubes sont bien là.
- Le prix un peu élevé bien que la qualité ressenti notamment au niveau des contacts or puisse le justifier.
Si dans 2 semaines le rodage fonctionne je posterai un nouvel avis.
Conclusion je conseille
Jean Pierre M.
Jadis DA30
Sur jadis DA30 odeur de brulé . J ai remis les GEKT Shugang .
Igor C.
Male Jack DC 3.5/1.3mm Connector Gold Plated Ø6mm This DC 3.5/1.3mm male jack connector will allow you to design your own power supply cables. It offers a nice design quality, with a metal body and gold-plated contacts ensuring...
Igor
Excellent jack, solid contact
Igor C.
Igor
Excellent power supply, no noise, does not heat up, unlike the original adapter
Jean-Luc S.
Excellent pour le prix
Habitué des casques Sony haut de gamme, j'ai été agréablement surpris par la qualité phonique de ce casque ayant de bonne caractéristiques techniques même si je m'attendais à un rendement encore supérieur compte tenu du chiffre annoncé (113 db). Un seul regret : le coffret de transport rigide bien pratique gagnerait à être un petit peu plus grand pour y mettre le casque sans être obligé de retirer à chaque fois les câbles de chaque oreillette pour qu'ils ne soient pas pliés de façon exagérée.
Daniel D.
NEOTECH NEP-3002G Power Cable Graphene Copper G-UPOCC 4.17mm² Ø15mm Neotech NEP-3002G is a mains cable made up of 3 multi-stranded conductors in G-UPOCC copper, a combination of OCC copper and graphene, with a total cross-section of 4.17mm²...
Du dépit...au plaisir d'écoute
Après avoir acheté le petit frère en 2,5mm, j'ai tenté ce diamètre pour alimenter ma source car le fréro entre mur et barrette avait été superbe d'entrée de jeu... totalement séduit.
L'ajout d'un 2ème cordon Néotech graphène sur mon lecteur m'a entrainé dans une période de rodage particulièrement désagréable. Ca a saigné dur et ça a été la valse des prises pour rendre l'écoute acceptable car beaucoup trop d'aigu (comme si on avait rajouté 4 prises rhodium au système), sonorité métallique, effacement du grave, manque de profondeur par contre rapidité et gain en transparence/ouverture évident. Il a vraiment fallu que je me raisonne pour ne pas mettre ce nouveau cordon au rebut. Après 80H00 c'était un tout petit poil mieux mais je doutais encore de pouvoir garder ce cordon. J'ai donc agit un peu sur mon traitement acoustique et mis en commande une nouvelle prise schuko ETI legato avec une amélioration dès la mise en place.
Après plus de 250H00 (il me semble un peu en dent de scie) les choses sont revenues à la normale avec un retour du grave et des aigus non montants, de la profondeur et toujours cette superbe ouverture/rapidité/placement/matière. Les voix sont magnifiées (plus de lisibilité). Dans mon salon "cathédrale" sur les enregistrements adéquats la scène sonore par loin derrière, monte à 7,50, et, si enregistré ainsi, passe derrière mes oreilles niveau ouverture. On tape du pied du début à la fin... C'est vraiment du tout bon. Peut-être un très léger manque de musicalité, à voir dans le temps... Pour info si ça peut donner des idées :(enceintes Thiel CS 3.7) blocs monos Aesthétix, en direct du tableau avec câble Tornado Audio + IEC Iégo cuivre/or 8085, Mur/barette, Néotech graphène en 2,5 schuko ETI legato + IEC oyade C004, barette/ source câble Neotech graphène en 4 mm schuko ETI legato + Viborg cuivre/argent/rhodhium, barette/préampli câble Furutech FP 3 TS 762 schuko ETI legato + IEC oyade C004.
Je répète, quelque soit le système les prises ont aussi beaucoup d'importance. Je vais tenter prochainement l'introduction d'une IEC Viborg full argent. Musicalement
Fernández Bendito S.
Excepcional sonido
Un DAC R2R que dicen son algo oscuros, pero este tiene un montón de detalle, separación y una escena sonora excepcional. Lo puede mejorar aun mas aportando mas detalle y resolución con un reloj externo. En mi caso uso un reloj dedicado GPS que se llama Leo Bodnar Reference y el aparato suena aun mejor.
Delacour j.
Un câble équilibré.
Sur mes JM Lab 706 Opale "drivées" par un Arcam P25, les câbles Athom Zef son t équilibrés, le grave est beaucoup plus présents qu'avec les Hi-fi Câbles&Co Puretrans 2 et l'aigu moins brillant mais tout aussi défini. Si tout cela doit encore s'améliorer à l'usage, alors ce câble mérite au moins ses cinq étoiles.
Pedro A.
XANGSANE XS-5N Bi-Wiring Banana Speaker Cables Silver Plated OCC Copper 1m (Pair) Xangsane's XS-5N bi-wiring speaker cables feature 12 strands of silver-plated, single-crystal OCC 5N copper to ensure electromagnetic impermeability and perfect conductivity.
Bon rapport qualité‑prix. Je recommande
Pedro A.
Robuste et bien construit
Un équipement avec une construction robuste et soignée, qui a entièrement répondu à mon besoin ; je ne peux donc que le recommander.
Hervé N.
Excellent Ampli
D'abord j'ai été agréablement surpris par le poids de ce petit carré de 15cm très lourd, ce qui n'est certes pas un argument de qualité sonore mais gage de qualité de construction.
Connecté en USB sur mon vieux MacBookPro de 2012, les premiers essais ne furent pas bons, mais il faut jouer sur les seules réglages possibles "Bass and Trebble".
Pour mon installation secondaire de bureau (enceintes biblio Highlands Oran 430I et petit caisson de grave BW) j'ai mis -4 en aiguë et +8 en basse et là je fus très agréablement surpris par la qualité sonore globalement.
En résumé, je suis très satisfait de mon achat et merci à Audiophonics !
Fortuné M.
Au delà de mes attentes
En commandant ce DAC, je ne m'attendais pas à une telle qualité... Le montage est un jeu d'enfant pour qui est un tantinet bricoleur et précautionneux. Le résultat est vraiment classe. L'installation de Volumio et son utilisation sont vraiment simples. J'ai testé toutes les entrées, le résultat est extraordinaire, du détail, spatialisation, richesse des timbres... Pour avoir mieux et clé en main, il faut investir vraiment beaucoup plus. Ça vaut vraiment le coup, mais il ne faut pas hésiter à investir dans une alimentation de qualité. Audiophonics propose des modules qui donnent d'excellents résultats audibles avec plus de détails, par exemple le PSU S4-HP. Malgré toutes mes éloges, j'ai quand même une préférence pour l'entrée coaxiale, avec comme source, le RaspTouch DigiOne qui donne à mes oreilles, de meilleurs résultats en termes de restitution avec des timbres plus riches qu'avec le RPI du DAC pour lire mes CD numérisés sur disque dur. Je recommande particulièrement ce DAC et remercie l'équipe Audiophonics pour ses conseils et sa disponibilité.
La fiche qui donne la banane !
Excellent produit avec quelques limites à respecter. Ces petites fiches de construction légère en cuivre de haute qualité ont beaucoup de charme. Elles ne sont pas neutres mais quelle finesse, elles sonnent encore mieux que les Viborg c'est tout dire. Attention cependant, a réserver aux câbles fins et légers du fait de leur construction à ailettes qui semble fragile (mais c'est le son qui compte et c'est tout bon). Bravo l'équipe Elecaudio pour ce produit intéressant et abordable.
Aurélien M.
Heatshrink Braided Tubing 2:1 8mm Black This 8mm diameter heat-shrinkable Nylon braided sleeve gives your cables a clean finish. The 2:1 ratio of this sleeve means that when heated to between 80 and 120°C, the...
Un coup de main à prendre
Très bonne gaine de finition, mais comme le précédent commentaire le précise, il y a une technique et il faut prendre le coup de main. De ce fait mon câble est un peu brouillon en début de chauffe, mais vers la fin il y a du mieux ! À terminer aux extrémités avec une gaine thermo plastique pour éviter que ça s'éffiloche.
Maurizio L.
AUDIOPHONICS HPA-S450ET Power Amplifier Class D Stereo Purifi 1ET6525SA 2x450W 4 Ohm The Audiophonics HPA-S450ET power amplifier is based on a Class D architecture, using a pair of Purifi 1ET6525SA amplification modules, a Hypex SMPS1200A400 power supply and an...
AUDIOPHONICS HPA-S450ET Power Amplifier Purifi 1ET6525SA
Ricevuto ieri, con gli opa di serie, ai primi ascolti mi sembra ottimo. Lo utilizzo usando come pre un atoll st 300 signature impostando il guadagno a 25 db. Unica nota negativa, benché non ce ne sia gran bisogno, nell' imballo non c'è nemmeno una pagina di istruzioni per l'apparecchio.
Jukka S.
TUNG-SOL 12AX7 Tubes Triodes (Matched Pair) The Tung-Sol 12AX7 are high-gain dual triode tubes of superior quality with ultra-low microphonic effects and ensuring a wide soundstage and warm, musical sound reproduction....
Immediate improvement in voice
I replaced these tubes in the Project Tube Box SE turntable preamplifier in place of the original tubes. The change was immediately more airy and much more dynamic, the instruments stand out clearly more and the stereo image became more precise in all aspects. However, the bass was the biggest change, its different layers are now distinct where before they were one. Overall, a really significant improvement in the sound so I highly recommend these tubes!
Maurizio C.
Un cavo digitale eccezionale di gran fattura.
Non credo serva spendere molto per un cavo digitale a 75 ohm ma siccome gli audiofili sono "bestie" rare non si accontentano e cosi ci sono persone che spendono anche 200 € per un cavo spdif...pazzesco!! Questo cavo dall'aspetto professionale è tutto ciò che basta e avanza per collegare un lettore digitale a un dac esterno (o integrato nell'amplificatore come nel mio caso), sostituisce il Mogami 2964 campione di qualità prezzo ma qui signori siamo su altri livelli, credo che il potenziale del mio impianto (cd Marantz, ampli Audiolab e diffusori Triangle) si sia espresso al top, questo significa che per il segnale spdif bisogna rispettare la normativa : cavo da 75 ohm e connettore da 75 ohm tutto di casa Canare che crea una linea di trasmissione pura e aderente alle specifiche. Il Mogami era valido ma un pelo troppo tranquillo, questo Canare con un solido core come conduttore mette a disposizione tutto quello che esiste nella registrazione ma i medi (come tutto il resto) sono eccellenti. Un grazie ad Audiophonics per la fattura di questo cavo che resterà con me per sempre. Assolutamente stra-consigliatomsenza spendere oltre per cavi blasonati che hanno poi un rca non aderente alle specifiche, con questo L-5CFB non si sbaglia, basta farlo suonare qualche oretta.
Jean-Claude L.
Mon tuner Magnum Dynalab à adoré !
Remplacement d'un tube sans référence.
le Génalex Gold Lion 6922 m'a redonné l'envie d'écouter mon tuner MD 90T.
Tout est amélioré : Les voix. La musique.
Livraison parfaite.
Mikael M.
CRINEAR DAYBREAK In-Ear Monitors IEM Dynamic Balanced Armature Planar Magnetic 20 Ohm 105dB 2Hz-40kHz With Daybreak, CrinEar presents a pair of in-ear earphones combining five drivers per side in a hybrid configuration that brings out the best in each technology. Designed to...
Phénoménal !
J'ais demandé conseil à l'équipe d'audiophonics pour une écouteur ayant comme critère de bon timbre.
Àu départ j'été impressionner par ces timbres réaliste .
Mais j'était déçu par sa sonorité froide , clinique , pas de basse , manquant d'ampleur , de chaleur et se se sentiment enveloppent .
Avec le DC07pro , rien a faire , c'est trop analytique , cela semble être une association pour l'analyse , sans vie , avec un cayin Ru6 , cela semble s'améliorer mais manque toujours des basse , mais apporte une certaine chaleur , malheureusement c'est une association movaise pour les autre fréquences .
Vien a le brancher sur un E1DA 9039s . Woaouuu !!!
La gifle ! Les basse sont apparue , le son est enveloppant , sa claque , les grosse caisse frape fort et nette , dynamique , les reste des fréquence s'affiche clairement ... Tout est magnifique .
C'est comme un ampli de classe A de bureau mais d'une grande propreté . Un truc haut de gamme ce 9039s .
Utilisation sur android via UAPP + Qobuz .
J'ais une certaine expérience dans la hi-fi ayant essayé de nombreuses associations : Buchard , sonus faber , rotel , cambridge , BW , Nuprime , Focal et plein d'autre depuis plusieurs anné ...
Tout cela pour vous dire que vous avez la un quite qui vous coûtera trés peut , mais d'une autre musiqualité et performance .
Je conseille donc cette association . 9039s + Daybreak .
Ps : on entend dire que le nouveaux lot comprend les embouts " coffé " .
Faux ! J'ais commander les embouts coffé ( KBEAR ) et elle ont un alésage différant . Et le rendu est moin bon que celui fournie par Crinear . Ceux fournie par le fabriquant ressemble de très prêt au coffe , mais on plus de présence en lbasse. ( Pour mon oreil ) .
Le casque est à son plein potentiel après une 30 ene d'heures d'utilisation. Soyer patient , puisque les basse prennent du temp à se lâcher , ( même chose qu'avec les Focal élégia ) .
Merci à audiophonics et à YHWH d'avoir conçu nos oreils aussi merveilleusement !
GEORGIOS C.
ELECAUDIO LI-07GB IEC C7 Connector Gold Plated 24k 3x5mm² Ø15mm This IEC C7 Elecaudio LI-07GB connector is ideal for making quality power supply cables. It uses 24k gold plated copper alloy contacts of 5mm², allowing to obtain a very...
A life saver
The availability of good quality C7 connectors for DIY cables is limited. This one is a gift from Elecaudio and Audiophonics at a very affordable price. Bad reviews often come from users who do not have the necessary experience in tightening screws and using tools for such purposes. The connector is reliable, sturdy and without particular difficulty in using it. I tightened the conductors with high force without a problem. Also, all metal parts are non-magnetic. I wish Elecaudio would release this connector in a C5 (Mickey Mouse) version.
Jean-Pierre B.
MUNDORF LL60 7 Strands Copper Wire Coil 1.8mH Using a set of 7 wires twisted then varnished, this type of coil has a larger wire surface compared to a single-stranded conductor. This technique gives a better conductivity in...
Simplement EXCELLENT !
J'ai voulu tenter ce type de Self dans le registre médium/Aigu, et bien m'en a pris !..
Le résultat est au-delà de mes espérances. Le son s'est littéralement bonifié, plus d'agressivité, bel équilibre rétabli entre tous les registres...
Bref, que du bonheur, je recommande.
Merci AUDIOPHONICS pour toutes vos pépites qui nous tirent vers l'excellence.
Mathieu V.
FOSI AUDIO K5 PRO DAC Headphone Amplifier NE5532 24bit 192kHz With the K5 Pro, Fosi Audio offers a compact, versatile and affordable DAC/headphone amplifier. With its microphone input on the front panel, the K5 Pro is designed to fit into...
Un dac fonctionnel et plein de ressource
Un dac acheté il y a peu de temps pour remplacer le fait de me brancher en direct sur mon PC avec un casque HyperX Cloud Alpha filaire. J'ai gagné en équilibre avec des médiums mieux maitrisé. Le fait de gérer à la volé le grave au l'aigu un MUST. J'ai aussi plus de puissance et ça ne bave pas sur les graves.
J'ai aussi testé sur mon casque de salon beyerdynamic DT770 80ohms je suis surpris de ce produit je recommande.
Jean-Pascal B.
FIIO SR11 Streamer WiFi Airplay Roon Ready 32bit 768kHz DSD256 Silver FiiO's SR11 network player is a compact, high-performance streamer designed to work in conjunction with the K11 DAC/headphone amplifier. Based on an X2000 processor, it is...
Fiio sr11
Sur le papier ça avait l air d être un bon petit serveur,mais apparemment je ne suis pas le seul petit problème de connexion a ma box.Que ce soit avec câble rj45,ou sans câble il ne veut pas se connecter
? Et après avoir consulté plusieurs sites aucune solution ?
FABIEN G.
ELECTRO HARMONIX 6V6 Power Tubes Tetrode (Matched Pair) The Electro Harmonix 6V6 is a robust and musical tetrode power tube that operates smoothly up to 475V. It is an excellent choice for single-ended amplifiers or for amplifiers...
Époustouflant
Achat de cette paire de lampes en remplacement de tube el34 sur un ampli guitare Randall. Le remplacement apporte plus de rondeur, de chaleur et une overdrive plus naturelle. Le petit plus c'est de faire travailler une entreprise proche de chez moi, avec des prix concurrentiel et réactive !
Je recommande le produit et audiophonics.
AIYIMA T20 Tube Balanced Preamplifier 2xECC83 The Aiyima T20 is a simple yet elegant balanced preamplifier. It features two ECC83 tubes combined with LME49720 and OPA1612 chips to deliver the warm, smooth sound typical of...
Bon rqp
D’ origine, sans tweak, c’ est deja un bon élément au vu du tarif. Rca et xlr dans un preampli a tube, c’ est rare et merite d’ etre souligné. Les aop lme49720 sont tres bon. Les tubes assez punch pas mauvais mais il peut y avoir mieux.
J’ ai essayé des jj ecc83s gold, bof... des pavane série art ecc83s doivent coller a merveille.
Un bonheur
Ces connecteurs bnc sont facile a souder, mécaniquement impeccables et transmission du signal parfaite.
Serieux
Minimaliste mais bien faites- ces bananes s’ enfin honte avec assurance et le son reste transparent. Recommandable.
ETI LINK BANANA Banana Plugs Gold Plated Tellurium Copper Ø9mm (Set x4) The ETI Link Banana plugs offer a very nice design quality, ensuring an excellent signal transmission. The contacts are made of gold-plated tellurium copper with a very good...
Pourquoi ?
Pourquoi les développeurs ETsi sont si tordus ?
Ils font des connecteurs mag ifique mais mécaniquement dysfôcolonnes.
Ici, un emplacement pour loger le cable tres petit avec une vis dans un conduit réduit et une autre dans la partie la plus large.
Résultat, suivant la section du cable , une seule vis pourra faire contact.
Un tarif stratospherique pourû équivalent bien moins cher et tres fôctionnel chez aeco par exemple. Je déconseille.
Niels G.
Recommend these
These are a very good match with Duelund copper interconnect wire - at a good price.
