didier N.
ok
Benoit d.
Robert C.
It is difficult to...
Customers reviews - There are 19629 reviews.
Peter H.
A clear upgrade over ~€200 power distributors
This is my first star wired power strip/distributor. I have previously used models from Supra, both versions with tinned copper wiring inside and the black models with silver plated copper. I have also used a Ludic Asgard (which I preferred over the Supra distributors). This Audiophonics power strip is head and shoulders better than all the previous distributors I have owned. It definitely sounds more like every device is plugged straight into the wall, ie every device has a more relaxed and effortless delivery of sound. In a normal power strip where devices are wired in series, all the devices interact with each other. I own two iFi AC filters, and if I plug them into the last two sockets on a normal power strip it dramatically affects the sound of the devices placed ahead of it in series. By using a star wired power strip, this interaction is minimized and everything clearly sounds better. I'm talking treble that is not as brittle and more pleasant, much better separation of sounds, and generally a slightly warmer more powerful sound. Basically, a cheaper power strip is a compromise that changes how devices work for the worse, whereas a power strip like this one allows every device plugged into it to work as intended without being affected by other devices plugged into the power distributor. Highly recommended. But why only 4 stars out of 5? Because mine arrived with loose screws inside. I opened it up and could screw them down without issue, and aside from the loose screws the finish and quality was impeccable both inside and out.
Eric H.
Au niveau sonore câble neutre, fidèle et sans coloration, qui ne rajoute rien aussi bien dans le grave que dans l’aigu
Artis R.
Pack WiiM Ultra Streamer Grey + Audiophonics AP300-S250NC amplifier + Audiophonics Wire RCA Cables 30cm + Trigger Cable We offer you a WiiM x Audiophonics product pack comprising the Wiim Ultra Network Player, an AP300-S250NC amplifier, a pair of RCA modulation cables and a trigger cable. This...
Good price performance
I would say a good combo which competes with more expensive integrated amps. There is a noticeable burn in period. At first there was a very high noise, which disappeared after few hours of listening.
Gregory P.
[GRADE B] AUDIOPHONICS HPA-S500ET Power Amplifier Class D Stereo Purifi 1ET7040SA 2x500W 4 Ohm Refurbished product - Grade B The Audiophonics HPA-S500ET power amplifier unveils a Class D architecture based on a pair of Purifi 1ET7040SA modules and a custom-designed...
Parfait pour un ensemble TAD
Aucun "pop" à la mise en route ou à l'arrêt, le boitier reste tiède, et quel plaisir d'utiliser cet interrupteur (c'est bête, mais ça compte). En bref, très content d'avoir choisi les 1ET7040SA dans l'ensemble Audiophonics.
Michel E.
Fais le job
Câble digital entre une interface Hecate un Naim Dac, en bnc, pourquoi chercher plus cher alors que tout est devant vous, comparable a mon Vovox
Jean-Baptiste G.
DAC SMSL SU-9 Pro
Ce dak pour son prix ne m'a pas impressionné.
Tout Juste musical sans plus.
Je pense qu'il doit y avoir mieux où équivalent pour moins cher.
Un peu septique je ne recommande pas forcément ce dak dans cette gamme de prix.
Krzysztof K.
Good HDMI Cable, indeed!
Hey, folks!
Actually, sometimes differences in the sound of digital cables are bigger than in analog ones.
I can recommend this cable. Sounds really good. Connecting Singxer SU-6 to Audio-gd R-1NOS. Comparing to Audioquest Cinammon - Cinnamon is worse. Sound from Cinnamon is muddy, gray and flat. No saturation and no detail. Pangea sounds open and airy with good amount of detail and perfect saturation.
Minus one star for stiffness! This is not elastic cable.
Sound sample - all system elements is description.
HEADPHONES ON!!!
Urtsua R.
MUNDORF MR10 non-inductive metal film Resistor 10W 2.7 Ohm Unlike conventional resistors, & film metal winding resistors have no residual inductance. Thus, in cases where impulse response is essential, in midrange frequencies for...
Fine
R. R.
Audiophile grade +
I use the connectors to complete satisfaction, they sound better than anything I've used before. I have them in combination with KLEI Perfect Harmony RCA sockets.
// They solder great, but be careful, if you don't know how to solder, you can ruin them just like any other connectors. //
Thierry C.
SHANLING ONIX ZENITH XST20 CD / SACD / MQA CD Transport Sanyo HD870 With the Shanling ONIX Zenith XST20, Shanling has unveiled a new top-of-the-range CD transport with a luxurious design and high-performance components. In addition to a...
Shanling reconnait enfin que ce lecteur n'est pas Gapless, sinon c'est un très bon lecteur CD/SACD
https://www.head-fi.org/threads/introducing-onix-zenith-xst20-high-end-sacd-transport-with-true-dsd-output.976312/post-18762663
And yes, we will be deleting the mention of Gapless SACD from our marketing materials. It was already adjusted in the texts, graphics should be done shortly after.
The marketing materials are created based on information from the engineers and the product manager. XST20 was indicated to support gapless for both CD and SACD.
Frédéric A.
NEOTECH NEP-3001G Power Cable Copper G-UPOCC Graphene 3x5.2mm² Ø16mm Neotech's NEP-3001G is a power cable incorporating 3 G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor marks a significant advance, both...
Excellent mais...
Ce câble offre une balance tonale équilibrée. Mais associé à l'amplificateur Audio-gd Master-3, il manque de présence dans le haut du registre, un peu d'éclat, bref. Ce n'est pas que le rendu n'est pas impressionnant. Le médium est fouillé, l'image stéréo large, la basse profonde et généreuse. Peut-être est-ce un manque de rodage, le câble à environ 230h au compteur. Je n'ai pas renoncé à l'intégrer à ma chaîne puisque je le considère tout de même excellent. A suivre.
Hans V.
Perfect passend voor infinity Kappa
Gezien de Infinity Kappa op de achterzijde in originele bezetting maar hele korte terminal pluggen kan gebruiken ben ik op deze uitgekomen.
Goed soldeerbaar.
Zelf ben ik gek op het geluid van zilver, in hoeverre dit hoorbaar is bij deze plug weet ik niet.
Ze klinken in elk geval zeker niet schel.
Krzysztof K.
AUDIO-GD R-1 NOS R2R Discrete DAC DSP FPGA USB Amanero HDMI I2S32bit 384kHz DSD512 Black The NOS version of the Audio-GD R-1 benefits from new features and a number of improvements, with the aim of providing ever more precise and rich sound reproduction.
Incredible DAC!
OK, cons first:
1/ clicking sound on digital coax cable connection when you switch from one sample rate material to another also from PCM to DSD.
This issue is not present on HDMI/I2S cable connection. Strange.
2/ Ridiculous burn-in time. DAC straight from the box sounds like broken one. Muddy, unclear, unpleasant. And all of this despite 100 hrs factory burn-in. I would send it back to seller, but before the purchase I made deep online research and all R1NOS users advised long burn-in time: minimum 600 hours. So I gritted my teeth and gave this DAC a chance and time to spread the wings.
It was real rollercoaster. One day DAC was sounding OK, another day excellent, next day - really poor.
But after approx 400 hours of burn-in sound started to be more stable and after 610 hours - just incredible!
Anyway: I've purchased this DAC 12/4/2025 and I'm able to use it normally just since yesterday: 21/7/2025. 600 hrs of burn-in is a MUST!
Now - pros:
1/ plenty of connection possibilities, including HDMI/I2S (best one!). Strongly advise to use this one! You will avoid clicks and the sound is definitely best.
2/ SOUND!!! Just unbelievable! Sweet, refined, rich, saturated, airy, delicate, nuanced, crystal clear. My system sounds like minimum 50 000€ stack and I paid in general approx 7000€ for all (some elements new, some second hand). Detail? Well... this is not delta/sigma. If you want detail, buy ESS. There will be detail, but there will be no music at all. This DAC is typical R2R - detailed enough. Anyway - for example articulation of guitar strings is fully satisfactionable.
I have just 2 things more to say:
1/ in its price this DAC is a STEAL!!! Totally non fatiguing yet absolutely crystal sound.
2/ this is cheapest Audio-gd DAC. If the price floor in this factory has so incredible quality, I would like to see the ceiling...
HIGHLY RECOMMENDED!!! (if you're happy to wait 600 hours)
Sound samples (all system elements in clip description):
HEADPHONES ON!!!
https://rumble.com/v6wi06o-dac-burn-in-is-over-.html
https://rumble.com/v6wi0rc-chinese-godfather-.html
https://rumble.com/v6wi1d4-leftist-waltz-live-.html
https://rumble.com/v6wj5au-big-in-japan-.html
Good job, Audio-gd! :)
Alain C.
NEUTRIK NL2FXX-W-S Female Speakon Connector Ø12mm The Neutrik NL2FXX-W-S is a robust 2-pin Speakon connector, ideal for designing professional-quality cables. It incorporates a proven locking system to ensure reliable...
Semblent bien faites, pas encore utilisées
Belle qualité de fabrication, pas plus d'infos à partager pour le moment
Alain C.
FIIO BR13 Bluetooth 5.1 Receiver QCC5125 DAC ES9018K2M aptX-HD LDAC 24bit / 96kHz The FiiO BR13 is a Bluetooth receiver equipped with a high-performance DAC. KEY FEATURES: Bluetooth 5.1 QCC5125 receiver chip SBC, AAC, aptX, aptX adaptative, aptX...
Excellent au delà de mes attentes
J'ai choisi ce produit pour améliorer mon Bluetooth actuel, avec les codecs LDAC et AAC pour Androïd et Apple, et aussi parce qu'il comporte un volume donc je peux directement attaquer mes deux amplis en mono.
Tout est vraiment mieux, la clarté du son, les basses, et la spacialisation a fait un bond en avant.
J'avais un correct Real Câble et j'ai clairement changé de catégorie.
Je vous le conseille, avec en plus ses entrées digitales ...
Frédéric R.
Absolument top!
Absolument top! Enceintes installées sans les pointes et sur support standard en plastique car une contrepointe perdu durant un déménagement.
Le son n’était pas bon, fade et sans profondeur. Même obligé de pousser sur les basses. Je me suis même demandé si mes enceintes n’avaient pas été endommagées durant les déménageurs.
Après installation de ces contrepointes, le son a vraiment tellement changé que cela en est incroyable.
Le son a du relief et de la profondeur à nouveau!
A recommander sans hésitation. Rapport qualité/prix totalement correct.
Audio Transformer E-9912 600:10K (Unit) This E-9912 600:10k permalloy transformer can be used for a wide range of applications. It can be used, for example, to convert a balanced signal into an unbalanced one and vice...
great for balancing
bought one for test, ordered 16 for the 16ch audio interface.
I use a modular system which puts out 21 Vpp maximum; so the audio interface has to be leveled down, too.
my mixer has RECORD OUT mono jacks, 10K there - and balanced 600 ohms to the audio interface; level down is 4 or -12 dB.
Frequency respone is great, goes down to 10 Hz and above 40 kHz;
distorsion I can't measure, not noticed.
Renaud D.
SHANLING M8T Digital Audio Player DAP Tube Amplification 2xAK4499EX 2xAK4191 32bit 768kHz DSD1024 Bluetooth 5.0 WiFi Shanling's M8T is a classy digital audio player with the distinctive feature of tube amplification, so you'll always have at hand the ability to enjoy the characteristic sound...
Exceptionnel
Merci Audiophonics pour l'envoi rapide et soigné! en plus je ne m'y attendais pas , livré avec étui officiel :)
Sinon que dire j'ai eu pas mal de daps depuis 10 ans mais celui ci est clairement une merveille, précis chaleureux et si musical (le mode triode) je redécouvre mes morceaux favoris. jamais un DAP ne m'avait procuré autant d'émotions. J'ai l'impression que ma quête du DAP idéal est enfin accomplie.
Robert g.
FOSI AUDIO ZP3 Balanced Preamplifier NE5532 The Fosi Audio ZP3 is a balanced preamplifier based on NE5532 AOPs. It offers interference-free sound reproduction over a wide dynamic range, minimizing ground loop effects. The...
The sound quality is amazing for the money, the ZP3 sound is neutral without being too dry, transparent enough, with exemplary resolution for a the budget range. What I really like is the bass control and dynamics, especially on the hi-rez files that have a higher dynamic range. ZP3 presents the soundstage correctly, with correct positioning of the sound sources in space, without exaggerating or compressing the width of the stage, or the depth. This is almost on par with my E88CC unbalanced tube preamp - a mu-Follower configuration with capacitor output and mild NFB - except for the apparent 'naturalness' of the tones of natural instruments and human voices, otherwise the Zp3 has the edge on any other chapter!
On the audio tracks with a Dynamic Range more than 10, the modern recordings with avant-garde jazz, contemporary classical music or full scale orchestral works could sound 'scary' in a healthy impressive manner. Some music albums examples here, that I used to evaluate the SQ of my ZP3 unit:
- Mussorgsky: 'Pictures at an Exhibition'; Gürzenich Orchestra Cologne, Dmitrij Kitajenko; 2019 [Oehms]
- Mats Eilertsen Trio: 'Sails Set'; 2013 [Hubro]
- Jonathan Faralli: 'Percussion XX'; 1999 [Arts]
- Bach|Gubaidulina, Anne-Sophie Mutter: Violin Concertos | In Tempus Praesens; 2017 [Deutsche Grammophon]
- Aaron Copland: Orchestral Works CD1; 1996 [Decca]
My unit came with LME49720 opa factory installed, to my surprise, and I left it how it is, after briefly testing AD8599, which proved not to be on par with the LME chip.
This preamlifier is a keeper for those loving a neutral - studio like sound - transparent, decently detailed and dynamic sound, that faithfully reproduce the recordings as god as they are, and do not bother the lack of a volume control display. The remote set provided inside the package is quite handy, and works well from all angles, having enough power, like any decent remote.
Despite ordering my unit was was not on stock, the Audiophonics announcements, packaging and tracking service was exemplary: merci a vous !
My audio set consists in: custom balanced DAC with AKM4499; Fosi ZP3; Fosi V3 Mono x 2; 2way custom made passive 98dB sensitive speaker with Beyma 15LX60V2 low-mid driver and Beyma CD10 Nd compression driver in a Polish horn SEOS15 by Autotech, with 2-nd order crossover implemented with CD passive equalization.
Will give it 4 stars out of 5, because:
- lacking of a volume display
- it is advertised to allow the customer to easily swap the 2 output opamps, which in practice is almost impossible for a less skilled owner, as the black glossy acrylic decorative sheets from the L/R case sides are very hard to remove in order to reach the 4 screws of the aluminum side plates of the case (are attached with double-sided tape)
- on balanced mode, the volume control chip does enter in a kind of soft mute mode, especially when the unit is freshly started, a mute and un-mute sequence from the remote set being the cure. I do not find this normal, but it does not affect the SQ so far after the 'fix'.
Pascal H.
Demande technique avant vente , réponse reçue dans la journée
le service est très réactif et surtout de bon conseil.
Commande reçue très rapidement en point relais, le tout à un tarif très doux.
Merci à l'équipe Audiophonics,
SMSL A200 Class D Amplifier Infineon USB HDMI ARC Bluetooth 5.0 2x70W 4 ohm The SMSL A200 amplifier is a Class D amplifier incorporating two Infineon MA12070 amplifier chips for output power of up to 2x 70W @ 4 ohm. Versatile and compact, the A200...
L'aspect de cet appareil est flatteur, vis à vis du prix. Certains adorent les Vu-Mètres ! Plus sérieusement, enfin un ampli avec une alimentation interne et un cordon secteur, ras le bol des amplis soi-disant puissants, mais alimentés par un bloc secteur externe et son petit câble coaxial. Le son est clair, plutôt doux, aucune stridence, aucune sifflante (voix de cantatrice sur les forte), impossible de déterminer que c'est de la Classe D, on pense plutôt à un ampli à tubes, mêmes qualités, mêmes défauts, extrémités de la bande passante très légèrement raccourcies, mais c'est insignifiant. Image très profonde, plus que large. La dynamique est raisonnable sans atteindre le niveau des stars de la Classe D, on privilégie le confort d'écoute. Aucune fatigue auditive. Je l'utilise sur des enceintes à haut rendement, les gros boomers sont plutôt bien tenus. Il est à noter des borniers plutôt sympas. Un appareil que l'on peut emmener partout, mais que l'on n'a pas envie de cacher, trop mignon. On apprécie également une vraie télécommande pour la partie préampli, volume, sources (et même tonalité).
N.B. : Attention ! La sortie subwoofer n'existe pas, erreur dans la présentation, point faible par rapport à des concurrents bien connus.
Marc C.
AUDIOPHONICS DIGIPI+I2S Digital Interface WM8804G for Raspberry Pi SPDIF I2S TCXO This Audiophonics DigiPi+I2S interface expands the output connectivity of a Raspberry Pi, giving it an additional panel of digital audio outputs. It includes a Toslink optical...
Utilisée en roon endpoint avec Riopeee, il faut choisir da
Marc C.
Vraiment bluffé !
Packaging sérieux. Utilisés en XLR et rien à redire...
Si le prix ! Un double mono à ce prix, c'est purement impossible de trouver ailleurs. Et la qualité est bien là.
Marc C.
Très étonné !!!
Je cherchais à connecter ma paire d'enceintes frontales à la fois pour mon système hifi et pour mon système A/V. Au début j'ai été dubitatif quand à l'achat de cette petite boite, n'aimant pas trop multiplier les connections entre les électroniques et les enceintes. Puis je me suis laisser porter par les autres avis.
Bien m'en fait puisque cette boite de répartition apparait bien transparente... enfin à mon oreille. Allez-y c'est du bon.
Merci à Audiophonics pour ce produit.
David S.
impeccable
Conforme à ma spécification un peu complexe: 0-11-22-40V et un second enroulement 0-4V: le tout très bien repéré et dimensions conformes au configurateur.
Délai un peu long, mais c'est du sur-mesure.
Mon vieux transport CD Audio Note dont le torique vibrait un peu trop ces derniers temps est de nouveau bon pour le service.
Merci Audiophonics!
Richard P.
Naturel
Je l'ai comparé à l'Albedo et bien pour moins cher il légale voir le dépasse si vous aimez un spectre moins montant qui apporte plus de détails mais moins de naturel. D'où mon titre naturel. Le bon équilibre pour mon système et mes oreilles !
Yannis G.
Petit mais costaud dans le haut grave et medium aigu
Mon 2 ième achat pour un ami qui l'utilise pour ses enceintes 3 voies diy monter par lui même en multi amplification il l'as utilser sur son medium 18 Sound 8NW650 et aigu beyma hd1030 parfait pour les fréquences haut graves et aigu , les borniers sont pitoyables pour les branchements mais on peut pas en demander plus pour le prix .
Pierre P.
HATTOR AUDIO THE BIG Balanced Passive / Active Preamplifier Takman REX OPA2134 Black This beautifully crafted Hattor Audio passive/active preamplifier features two high precision attenuators with Takman REX AMRT carbon film resistors, ensuring very low...
J'ai possédé son petit frère il y a quelques années.
Ce modèle actuel est toujours aussi bien fabriqué. Il procure une transparence exceptionnelle, surtout si l'on ne met pas en oeuvre la partie active.
Je le recommande totalement.
IBASSO AMP16 Raytheon JAN6418 Amplifier Module for DAP DX340 Silver iBasso's AMP16 is an amplifier module specially designed to be used with the brand's DAP DX340, providing tube amplification with an impressive 2000mW+2000mW at 32Ω.
Pour ibasso dx340
Ibasso amp16 change la DONNE LA QUALITÉ DE SONORITÉ EST SUPÉRIEUR SURTOUT SUR LE MODE TUBE HEUREUSEMENT QUE AUDIOPHONICS VEND CE PRODUIT VOUS POUVEZ ACHETÉ FACILE A INSTALLER VOUS AVEZ LE TOURNEVIS POUR LE MONTAGE
Arvydas V.
JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 1.5μF Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every...
A
Mohammed B.
Im Vergleich zu Mundorf CFC Spulen spielen die Mundorf nervöser härter heller und offener, aber die Jantzen spielen ohne Kantten weich und mit richtige Tempo und sind viel billiger als die Mundorfs
sehr zu empfehlen für Musik Genießer und Audiophieler.
Mohammed B.
Im Vergleich zu Classic WBT spielen die Jantzen Dnamischer offener
und mit mehr Druck im Bass aber die Standard WBT spielen sauberer und zurückhaltender und im Vergleich zu WBT CU Polklemmen spielen die WBT CU viel sauberer echter harmonischer mit super Bass widergabe.
Wer etwas mehr Dnamisch und offenheit braucht soll die Jantzen kaufen obwohl man bekommt die vollkupfer XANGSANE oder von Eizz hier bei Audiophonics billiger und klanglich viel besser.
Mohammed B.
die
audiophile und lässt keine Wünsche offen. Im Vergleich zu standard bzw Messingsteckern und andere CU Steckern von andere Herstellt spielen die Furutech viel realistischer und Neutraler.
Ich habe von Vibrog und Monus Audio ich finde Furutech viel besser
die Monos Audio spielen etwas gekünstelt und mehr Bass aber die Führutech spielen durchsichtiger und viel Realistischer ausgewogener und ausgeglichener.
Sehr zu empfehlen!
Für Musikanlagen die sehr zurückhaltend spielen nicht zu empfehlen.
Mohammed B.
Super Stecker und Top Preisleistung
die
Sehr zu empfehlen!
Mohammed B.
Super Stecker mit top Klang und preisleistung
die steckern spielen sehr realistisch warm flüssig detailreich angenehm
Sehr zu empfehlen!
magique
C'est ma 2e, associée aussi avec le vondita, sur le dac et c'est juste exceptionnel. C'est naturel, ouvert, détaillé et sans agressivité....
EXCELLENT CÄBLE
C'est le second que j'achète, la coupe a été un peu plus généreuse, 10 cm de plus (sur le premier, pas un cm de rabe), c'est appréciable sur un câble aussi onéreux. Et ça laisse plus de marge étant donné la section. Sur mon dac nuprime avec une FURUTECH FI-E46 NCF (G) et une FURUTECH FI-C15 (G), Il ne bougera plus comme sur mon intégré. C'est le câble le plus naturel que j'ai écouté. Cher, certes, mais juste parfait.
Tsvetan A.
Simply outstanding!
I have bought the Purifi to use for my Monitor Audio Silver C350 center, which before was powered by the receiver (Marantz SR6015), i wasnt expecting much, but to be honest the difference is big, much clearer voices/effects in movies, and for music... everything is better - voices, highs, even bass is tighter. Now a new problem - the rest of the speakers are lacking, heh. I Recommend it for center speaker with two hands!
Bernard B.
FIIO BTR17 Headphone Amplifier THX-AAA Portable DAC 2xES9069Q 32bit 768kHz DSD512 Blue With the BTR17, FiiO offers a portable headphone amplifier and DAC based on a pair of ES9069Q chips for digital/analog conversion, handling signals up to 32bit 768kHz PCM and...
fiio BTR 17
Pas d'ataptateur secteur pour la recharge de la batterie, dommage.
Envoi très rapide.
Laurent G.
Petit mais super efficace !!
Je viens d'un Sugden pure classe A, je peux affirmer que cet ampli n'est absolument pas froid, bien au contraire, les basses sont bien présentes, très définies et tout le spectre est bien mis en valeur. Le plus remarquable est sa transparence, Il alimente mes focal 948 avec aisance, fluidité et subtilité et s'efface pour transmettre le meilleur de mon pré ampli eversolo A8 (branchement XLR). Une véritable réussite à son prix.
Alain S.
SOFTEARS TWILIGHT Dynamic In-Ear Monitors IEM 16 Ohm 116dB 15Hz-40kHz With the Twilight, Softears presents top-of-the-range dynamic in-ear earphones whose lightweight, high comfort fit is only equalled by the quality...
Vous n'écoutez plus de la musique mais êtes au cœur de celle-ci et ça change tout .
A noter l'étonnant form factor qui permet de loger ces intra dans les oreilles de toutes dimensions.
Wiim Amp Pro
Nice dac amp (power dac) based on a TPA3255 chip + PFFB. The real added value of this amp is that it offers a parametric equalizer and we can therefore use the EQ optimized by Spinorama org for acoustic correction
Fiio BR13
En soi concernant le BT il fait son job. En revanche l equalizer paramétrique bug puisqu on ne peut pas le sauvegarder ( bug Fiio connu et non corrigé honteux !
Didier T.
Mitigé...
Serties (et non soudées) sur du Ludic Silenos (2,5 mm2 multibrins), elles m'amènent aux constats suivants :
- un excellent "grip" une fois insérées dans les borniers femelles qui assure un excellent contact sur la plus grande longueur insérée
- un sentiment de relative fragilité provenant de la finesse du matériaux : si elles n'ont pas vocation à être manipulées régulièrement, certains câbles qui rigides ou lourds peuvent mettre à l'épreuve leur solidité
- un impact sur l'équilibre sonore empreint d'une certaine forme de "maigreur aigrelette" de timbre : cela me donne le sentiment d'une transparence factice, confinant dans certains cas à un peu de dureté
En fin de compte, elles ne sont pas restées en place.
Thierry H.
upgradable
J’ai acheté la version précedente XQ-50 pro ( tout court ! )dont le pro 2 semble être le frère jumeau il y a 5 ans , très bon appareil , récement j’ai eu l’idée de l’ouvrir : comme sur le xDuoo xd05 basic v2 , l’AOP de sortie est sur un suport dip tulipe , donc facilement interchangeable !
Avec un opa 2134 le xq50 pro devient vraiement très très bon
Bruno R.
DD TC01BF USB-C Male to USB-B Female Adapter Gold-plated The TC01BF adapter from ddHiFi consists of a female USB-B connector and a male USB-C connector. Its gold-plated contacts ensure good conductivity and resistance to oxidation....
Semble OK
Contrairement au précédent acheté sur amaz.. celui-ci ne semble pas du tout affecté le transfert des données (donc le son) entre mon ordi Qobuz et mon DAC.
Belle finition, bon produit.
Radek P.
neotech nei 1220
Félix M.
6P1 Tube for Amplifier / Preamplifier (Unit) This durable and reliable 6P1 tube will allow you to replace a similar faulty model or design a tube amplifier/preamplifier. This tube corresponds in particular to those...
TUBO 6P1
LES TUBES ONT BIEN FONCTIONNÉ MAIS LE COLIS EST ARRIVÉ TOUT CABOSSÉ ET CASSÉ JE NE SAIS PAS COMMENT ILS ONT ÉTÉ SAUVÉS, MAUVAISE MANIPULATION DU COLIS MÊME S'IL ÉTAIT BIEN EMBALLÉ.
Axel P.
TOPPING HYNOTONE ARES Guitar Distortion Pedal Topping, following on from its Topping Professional range of USB audio interfaces, unveils a distortion pedal for guitar with its new Hynotone range.
Top à ce prix
Guitariste et audiophile, j'étais intrigué par cette pédale fabriquée par une marque issue du monde de la hi-fi et j'ai donc sauté le pas.
Niveau qualité de fabrication, rien à dire, c'est propre, les switchs et les potards inspirent confiance, le boitier est robuste. je trouve les potards très agréable et à titre personnel, je trouve le design générale simple mais très efficace.
Niveau son, on a bien affaire à une distorsion, un peu aigue à mon gout mais pas criard pour autant. Les potards agissent plutôt bien sur le son. Par contre il y a à redire sur les switch.
Le boost fonctionne très bien, on entend clairement la différence quand on l'active. Il a le même effet qu'un boost placé avant la pédale, il fait ressortir des harmoniques et donne un son plus tranchant, plus "metal". Une réussite pour moi.
Par contre, je n'entends pas du tout de changement de son avec les deux autres (le bite et le tight). Le tight est préconisé pour les guitares 7 cordes, ce que je n'ai pas, il est donc normal (je suppose) de ne pas entendre de différence. Le bite n'est pas préconisé pour une config en particulier et je n'entends aucune différence avec ou sans. A voir si on entend quelque chose sur une autre config.
La pédale a été testée sur un ampli à lampe blackstar avec une Ibanez équipée de Di Marzio air norton et tone zone.
Conclusion: Une excellente pédale pour ce prix même si certains switch ne semblent pas impacter le son. Comparé à une Chug Lite, elle n'a pas à rougir. Juste une question de goût.
Panikos K.
Nice
Very good & useful accessory and at extremely good price.
