NOBSOUND M5.1 5.1 Amplifier
The Sobsound M5.1 is a multichannel home cinema amplifier equipped with three TPA3116 circuits, delivering up to 50 W per channel to drive the front, surround, center speakers and the subwoofer. Its integrated audio processing supports 2.0, 2.1, 2.2, 5.1 and 5.2 configurations, while allowing a stereo source to be distributed across a 5.1 output.
Reference : 22508
179,00 €tax incl.
149,17 € tax excl.
NOBSOUND M5.1 5.1 Amplifier TPA3116 6x50W 4 Ohm
NOBSOUND M5.1: Front view
Designed for compact and versatile installations, it combines Bluetooth 5.0, optical, coaxial, USB, RCA 2.0 and RCA 5.1 inputs with independent adjustments for each group of channels. This architecture makes it easy to integrate various sources and allows the front stage, surround channels, center channel and bass to be adjusted separately according to the configuration used.
Sobsound M5.1: Amplification by TPA3116 chips
The Sobsound M5.1 is a home cinema amplifier equipped with three TPA3116 circuits, each assigned to a part of the sound stage. This architecture delivers up to 50 W + 50 W for the front channels, 50 W + 50 W for the surround channels, as well as 50 W for the center channel and 50 W for the bass channel, allowing a complete 5.1 configuration to be driven.
NOBSOUND M5.1: TPA3116 chip
NOBSOUND M5.1: 5.1 outputs
Sobsound M5.1: 2.0 to 5.2 configurations
Thanks to its integrated multichannel processing, the M5.1 supports 2.0, 2.1, 2.2, 5.1 and 5.2 configurations. Its processing mode also allows a stereo input signal to be distributed across a 5.1 output, in order to create a wider sound stage from a 2.0 source.
Sobsound M5.1: Extended audio connectivity
The Sobsound M5.1 combines Bluetooth 5.0 reception with coaxial, optical, USB (for U-disk) inputs, RCA 2.0 channel and RCA 5.1 channel inputs. This connectivity allows the connection of televisions, media players, computers, smartphones or consoles, while the USB input supports the playback of audio files such as MP3, WAV, APE and FLAC.
NOBSOUND M5.1: Connectivity
Sobsound M5.1: Independent adjustments
The main audio parameters have separate controls to precisely adapt the output to the installation. The overall volume, bass and treble are adjustable independently, while the levels of the front, surround, center and bass channels can be adjusted separately to balance the sound stage.
Sobsound M5.1: Outputs and system integration
The rear panel gathers the outputs dedicated to the front, surround and center speakers, as well as an output for an active subwoofer. The M5.1 can thus form the center of a compact multichannel system, with a power supply between 15 and 24 V DC and two power inputs provided for its operation.
Technical specifications
Product typeHome cinema amplifier
Channels5.1
Inputs1x RCA stereo
6x RCA
1x Coaxial
1x Toslink optical
1x USB-A
Bluetooth
OutputsSpeaker terminals
1x SUB output
SNR≥100dB
Frequency response20Hz-20KHz (+1.5dB)
Power6x50W @4Ohm
Amplification chip3xTPA3116
Amplification typeClass D
Input sensitivity0.775V
Total harmonic distortion (THD)0.05% @1kHz
Supported sample ratesUSB: PCM 16bit 48kHz
Bluetooth: PCM 16bit 48kHz
Coaxial: PCM 24bit 192kHz
Optical: PCM 24bit 192kHz
Supported file formatsMP3/WAV/APE/FLAC
Supply voltage15-24V DC
Dimensions230 x 130 x 49mm
Weight1.19kg
Package1x Sobsound M5.1
1x 24V/6A power adapter
1x optical cable
1x Bluetooth antenna
OutputSubwoofer
OutputSpeaker terminal
Channel5.1
Amplifier chipTPA3116
Power (W)50.0
The Sobsound M5.1 is a multichannel home cinema amplifier equipped with three TPA3116 circuits, delivering up to 50 W per channel to drive the...
