Vraiment bon, surtout pour ce prix Vraiment une très bonne surprise : -très bon son ! très ample dans les graves sans aucune exagération et sans devoir ajuster...
Very good preamplifier for the money It is pretty transparent even with the stock OPAs (in my case LM49720). Highly recommended (for the money). It is difficult to...
Ascilab offers various colors for the waveguide of the F6Bs, F6B and C6B loudspeakers. To benefit from a color change, simply select your speaker model with the desired waveguide change. We will then assemble the new waveguide in our Audiophonics Workshop. The old waveguides will also be sent to you.
AsciLab offers various colors for the waveguide of the C6B speakers. To benefit from a color change, simply select your speaker model with the desired waveguide change. We will then assemble the new waveguide in our Audiophonics Workshop. The old waveguides will also be sent to you.
The AsciLab C6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ alumina-ceramic dome tweeter with custom waveguide and phase tapping, combined with a 6” woofer with alumina-ceramic cone, all housed in an enclosure with passive radiator.
The AsciLab A6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ alumina ceramic dome tweeter with custom waveguide and phase tapping, combined with a 6.5” PURIFI aluminum woofer, all housed in an enclosure with two Purifi passive radiators.
With the Mono Combo Pack, Fosi Audio offers a product pack tailor-made for a dual mono installation. It consists of two V3 Mono amplifiers, a power supply noise reducer, a 48V 10A mains adaptor and a dual DC jack to power your two amplifiers.
Hidizs ST2 Pro Nebula in-ear earphones are dynamic IEMs with a 10mm-diameter diaphragm for clear, detailed sound reproduction. An ES9218AC DAC chip integrated into the USB connector of their detachable cable supports up to PCM 32bit 384kHz and DSD128, enabling you to enjoy high-resolution files.
This active trigger sequencer is hand-assembled in our Audiophonics workshop. It avoids plocks and current peaks in order to switch on and off a chain of several Hi-Fi devices.
Jantzen Audio's C-Coil toroidal coils feature very low resistance and excellent heat resistance. This means they can withstand high power levels without overheating or causing distortion. The model in question tolerates up to 2000W (RMS) / 8Ω . In fact, they are particularly effective for bass induction when filtering your passive hi-fi speakers.
A true vintage treasure, this Jantzen Audio coil is fashioned from 99.9998% pure 12AWG copper ribbons hardened by a polymolecular paraffin wax. This technique has been developed by Jantzen Audio in such a way as to contain no air pockets in order to have a very advantageous tolerance. The result is a rock-solid, vibration-free coil. Each coil is...
Jantzen Audio Cross Coil have been developed in cooperation with Audio Technology (Denmark). They offer reduced distortion and greater dynamic range than conventional coils. This flat-film copper coil has a cross-section of 12AWG, an inductance of 0.15mH and a DC resistance of 0.07Ω.
The SMSL PL150 is a CD player based on a CS43198 DAC chip, a Philips mechanism and a PLL (Phase Locked Loop) circuit for high-quality playback and conversion of your favorite CDs.
The Fosi Audio SP601 passive two-way bookshelf speakers offer excellent sound performance combined with a modern, elegant design. These speakers deliver perfectly balanced sound, making them suitable for all kinds of music.
The Fosi Audio AH-01A is a RGB vumeter offering an original visual experience. Installation is very simple, as all you need to do is power the AH-01A via its USB-C connector. The AH-01A then picks up sound thanks to its built-in microphone.
The xDduoo Link10 is a compact yet powerful portable DAC. Designed around two Cirrus Logic CS43131 DAC chips, it is capable of converting signals up to 32bit 384kHz PCM and DSD256 while delivering 2x300mW of output power at 32Ω.
Thinkya's DRV108 is a full-featured CD player and DAC that uses a TMC688 processor and ES9038Q2M DAC chip to upsample CDs up to PCM 384kHz and convert digital signals up to PCM 768kHz and DSD512. The DRV108 also benefits from Bluetooth 5.1 bi-directional connectivity, allowing you to enjoy the convenience of a wireless connection, whatever your system...
