The Dayton Audio WP60XTW is a two-way coaxial speaker designed to deliver sound both indoors and outdoors. Its 16.51cm (6-1/2") driver, its 2.54cm (1") tweeter and passive radiator extend reproduction down to the low frequencies, while its IP66-certified ABS cabinet withstands the elements.
Compatible with 70V and 100V networks thanks to its built-in transformer, it can also operate at 8Ω with a standard amplifier. Its suspended, wall-mounted or landscape mounting options allow it to be integrated into a variety of residential and commercial installations.
The Dayton Audio WP60XTW is a two-way coaxial speaker designed for residential and commercial installations, both indoors and outdoors. It combines a 16.51cm (6-1/2") woofer with a 2.54cm (1") tweeter, while its passive radiator extends the low-frequency response down to 47Hz. Its weatherproof, IP66-certified ABS cabinet allows use in exposed environments.
The built-in transformer supports 70V and 100V networks through several power settings, while an 8Ω bypass allows it to be connected to a standard amplifier. This versatility makes it easy to integrate into distributed audio installations as well as residential systems. The passive radiator enhances low-frequency reproduction compared to sealed suspended speakers of similar size, whose response typically extends down to around 80Hz.
The WP60XTW can be suspended, wall-mounted or installed in a landscape setting using the dedicated bracket. For suspension, a built-in eyelet allows the use of a safety cable, while a cover protects the transformer settings and the Phoenix connector. The ball-joint wall bracket allows the orientation to be adjusted on the vertical and horizontal axes, in order to adapt sound dispersion to the layout of the location.
Technical specifications
| Specifications | |
| Product type | Suspended / wall-mounted speaker |
| Number of ways | 2 |
| Sensitivity | 85dB |
| Frequency response | 47Hz-20kHz |
| Impedance | 8Ω |
| Power handling | RMS: 40W Max: 60W |
| Passive radiator | |
| Woofer | 15.2cm graphite cone with rubber surrounds |
| Tweeter | 2.54cm silk dome |
| Maximum SPL | 103dB |
| Protection class | IP66 |
| General | |
| Dimensions | 282 x 214mm |
| Weight | 3.68kg |
| Color | White |
| Package | 1x Dayton Audio WP60XTW 1x Suspension cable 1x Ball-joint wall bracket |
| Color | White |
| Impedance (Ω) | 8 |
| Efficiency / Sensitivity (dB) | 85.0 |
| Lowest frequency (Hz) | 47 |
| Highest frequency (Hz) | 20000 |
| Power (W) | 40.0 |
| Number of loudspeakers | 2 |
| Speaker type | Passive |
| Speaker form factor | Other |
