Soulage au passage mon ampli HC en prenant en charge les colonnes.
By buying this product you get 74 loyalty points
This product has been replaced by the new version, the Audiophonics AP-300S500NC Power amplifier.
Class D Stereo Amplifier Ncore NC502MP 2x500W 4 Ohm
The Audiophonics LPA-S500NC is a stereo amplifier based on an amplification module Hypex Ncore NC502MP. This solution is ideal for anyone who wants to have a large power reserve (2x500W) without sacrificing sound reproduction quality. This amplifier block is suitable for demanding speakers, it can be used to sonorize large listening rooms as well as studio applications requiring large headroom without compromising the accuracy and richness of the audio message.
All components are integrated in a simple and robust 100% Aluminium housing with openings to facilitate heat dissipation. Its design also limits signal interferences for cleaner audio output.
The amplification circuit uses a Hypex Ncore NC502MP module. This is a versatile high-performance Class D amplifier which offers a tremendous power of 2x500W under a 4Ω load while taking advantage of Class D amplifiers high efficiency.
Its main characteristics are its flat frequency response regardless of load impedance, its almost frequency-independent distortion level and its ability to reject EMI interference. Its operation is based on a self-oscillating loop controlled by phase shift which does not take feedback into account except at the speaker output level.
The NC502MP module also integrates its own power stage. It consists of a regulated half-bridge switching power supply (SMPS) with synchronous rectification on its main output rails. Compact, powerful and efficient, this power supply is particularly suitable to provide clean power to a Class D amplifier.
Its power supply can work with different voltages delivered by the various electrical networks, the power supply is indeed equipped with an automatic input voltage doubler. The NC502MP module also has an overload protection system.
LPA-S500NC Amplifier has a 3-pole stereo XLR input on Neutrik NC3FAV2 sockets as well as a stereo RCA input on Elecaudio ER-106 sockets.
Bipolar selectors allow source selection and even allow independent control of the channels.
The amplifier output is made on Elecaudio BP-209 24k gold-plated speaker terminals. They can accept bare wires, banana plugs or even spades for quick and easy connections.
A 5-12V trigger connector in 3.5mm Jack format allows to control the automatic powering of the amplifier when integrated in a compatible system. Finally, a bistable button allows the device to be switched on and off.
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
| Specifications | |
| Product type | Amplifier |
| Class | D |
| Number of channel | Stereo (2) |
| Max. power (@ 1kHz, THD=1%) | 2x350W @ 8Ω 2x500W @ 4Ω 2x450W @ 2Ω |
| Input | 1x Balanced Stereo XLR 1x Single Ended Stereo RCA |
| Output | Speaker terminals |
| Trigger | 5-12V |
| THD+N | 0.0018% |
| SNR | 124dB |
| Output noise | 47µV |
| Output impedance | 1.5mΩ |
| Frequency response | 10Hz - 48kHz |
| Sensibility | Max Power at 2.35V RMS XLR : 2x1.17V RMS RCA : 2.35V RMS |
| Efficiency | 92% |
| Général | |
| Power Supply | 230V / 110V (switch auto) |
| Matériau boîtier | Brushed Aluminum |
| Dimensions (w/o connectors) | 190 x 359 x 78 mm |
| Net weight | 3010g |
| Color | Black |
| Package | 1x Audiophonics LPA-S500NC XLR 1x Power Cable |
| Input | RCA |
| Input | XLR |
| Output | Speaker terminal |
| Color | Black |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | Hypex Ncore |
| Power (W) | 500.0 |
Average votes 5.0 / 5 11 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Bruno C.
Ilari M.
Uwe K.
Noel C.
Thomas B.
