MUSICIAN MONOCEROS III Balanced Class A Preamplifier Black
The Musician Monoceros III is an analog preamplifier designed entirely around discrete components, combining THD+N distortion of 0.0003% with an R2R ladder resistor network for volume control. This architecture promotes accurate reproduction and consistent channel balance across a 60 dB control range.
By buying this product you get 139 loyalty points
Reference : 22475
1 399,00 €tax incl.
1 165,83 € tax excl.
MUSICIAN MONOCEROS III: Front view
Designed for Hi-Fi systems with several analog sources, it offers two XLR stereo inputs, one RCA stereo input as well as XLR and RCA outputs. Its CNC-machined aluminum chassis enhances the overall rigidity while limiting the influence of electromagnetic and radiofrequency interference.
Musician Monoceros III: A fully discrete architecture
The Musician Monoceros III is a preamplifier built around a fully discrete architecture. This design allows each stage of the signal path to be optimized, while the use of matched precision resistors ensures good symmetry between channels and helps limit harmonic distortion to 0.0003% THD+N.
MUSICIAN MONOCEROS III: Circuit
MUSICIAN MONOCEROS III: Volume control
Musician Monoceros III: R2R volume control
Volume level adjustment uses an R2R ladder resistor network, consistent with the discrete approach adopted for the entire circuit. This structure allows precise volume control across a 60 dB range, while maintaining good consistency between channels at every listening level.
Musician Monoceros III: Suitable connectivity
The Monoceros III features two XLR stereo inputs and one RCA stereo input, allowing several balanced or unbalanced analog sources to be connected. Its XLR stereo and RCA stereo outputs then make it easy to pair with various power amplifiers or Hi-Fi systems.
MUSICIAN MONOCEROS III: Analog outputs
Musician Monoceros III: A machined and shielded chassis
Its CNC-machined aluminum enclosure provides a rigid structure, while helping protect the circuits against electromagnetic and radiofrequency interference (EMI/RFI). This construction provides a stable mechanical and electrical environment, suited to lasting integration within a Hi-Fi system.
Technical specifications
Product typePreamplifier
Inputs2x XLR stereo
1x RCA stereo
Outputs1x XLR stereo
1x RCA stereo
Frequency response10Hz-100kHz (-1dB)
THD+N0.0003%
SNR120dB
Dynamic range120dB
Input impedance20kΩ
Output impedance200Ω
Supply voltage110/240V AC, 50Hz/60Hz
Dimensions320 x 330 x 60mm
Weight6.25kg
Package1x Musician Monoceros III (Power cable not included)
1x Remote control
InputXLR
ClassClass A / AB
Remote ControlYes
The Musician Monoceros III is an analog preamplifier designed entirely around discrete components, combining THD+N distortion of 0.0003% with an...
