Michel V.
Musical et costaud !
Facile
Comme à son habitude, Viborg nous propose des prises RCA haut de gamme et facile à connecter avec vos cables préférés. Mais...
Customers reviews - There are 19151 reviews.
Wolfgang S.
WOW.
This cable is incredible. I started with the RAMM as a speaker cable. With Viborg Copper/Silver Bananas. To be honest...I never tried the RAMM Beryllium bananas or spades. That was already an amazing experience. And I could compare it here with cables which were much, much more expensive. Then I build my first power cable with the RAMM Amadeus. The same impact. Meanwhile my complete set up is connected with this cable. Even my Power supplies.. I tried different plugs...Furutech, with and without NCF, ieGo, Charlin, Viborg .....the cable grows with good plugs. But even with mid price connectors it's a revelation. For me and after all it's the best cable I know. Definetly. Try it. You will love it. The transparency, the timbres, the soundstage...that's really true fidelity. A deep emotional experience. For an affordable price. Thanx to Audiophonics for the strong support. Merci beaucoup.
De la Musique !
De la Musique, rien que de la Musique ! Ecoute vivante et fascinante, qui défie toute analyse.
Mes Supravox Héritage chantent comme jamais!
Klaus S.
SMSL D-6 DAC 2x AK4493S XMOS Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 The D-6 joins SMSL's wide range of DACs, offering excellent performance for a contained price. It is equipped with two AKM AK4493S conversion chips and a second generation USB...
A great improvment
After installing the SMSL D-6 sound from PC via USB and from Bluray via Coaxial was immediately improved. I was impressed how much the atmosphere and ambience of my blurays gained. Shit, now I have to watch all my blurays a-new.
Tibor P.
Simple, clear and powerful presentation of any music
I’ve got what I wanted. This classical AB Class amplifier design is capable of driving any loudspeaker system in a room with great sound and enough dynamics. This is what makes it different from a T-Class switching amp nowadays. There is no limitation on whatever classical, jazz, rock, or electric music is played. I really enjoy the performance and the sound quality. I don’t see any noise issue or vibration due to the big toroid transformer. The build quality is also excellent!
Nicolas B.
Etonnant !
Tout d' abord merci à la réactivité de l' équipe d' audiophonics !
J' ouvre le colis et je m' aperçois que l' ampli est tout petit, miniature! Je le branche en bonne et du forme , avec mes Eltax monitor 3 , puis mes colonnes maison, sur l' entrée optique , et la je suis tout simplement bluffé !!! Ayant eu des amplis home-cinéma et Hi-fi , je peux vous assurer qu' il est nerveux , dynamique et que le médium ressort correctement. Le son est droit, neutre, aucune coloration c' est du class D. De ce fait un changement de source , câbles, ou enceintes est très perceptible! tout est ok . l' entrée analogique est excellente aussi. Le bluetooth fonctionne directement même si ca ne vaut pas les autres en terme de qualité son. La puissance est plus que respectable et dépasse allégrement des amplis hi-fi des grandes marques à moins de 500 euros.
Je recommande.
Peter M.
Bon MAIS pas de cable d’alimentation!!
Bonne qualité de construction. Malheureusement, il était livré sans câble d'alimentation ! Je ne sais pas si c'est une erreur ou si c'est normal. Le préampli sonne bien. Il y a un peu de sifflement du préampli mais rien de plus. Il y a un clic d'interrupteur à l'allumage et beaucoup de bruit après l'extinction. Les contrôles de tonalité sont plus subtils que ce à quoi je m'attendais et j'aime ça. Dans l'ensemble, c'est un bon rapport qualité-prix et bien plus que ce que l'on peut espérer pour ce prix.
Philippe F.
Techniquement bien
Parfait pour un calibrage de pièce en mode amateur (mon cas). Le rapport qualité-prix est excellent. Le fichier de calibration est directement accepté par REW.
Seul bémol: un câble de 2 mètres insuffisant pour des mesure de pièce! Il faut prévoir une rallonge USB d'au-moins 3 mètres. (ou USB-C de 5m)
Rene C.
VIABLUE FILTER 18 Filtering Ferrite Reducer Ø18.5mm to Ø17.5mm Viablue Ferrite Reducers eliminate high-frequency electromagnetic interference (EMI) and the noise it induces within your audio cables. This is essential for designing high...
The best of the best
Rolls-Royce edition of the Ferrite core filter, look, fits and work great
Miroslava L.
Very happy with delivery and quality. Very serious business, great communication and fast delivery
Miroslava L.
william l.
J'ai acheté cet appareil en connaissance de cause, mais attention ce Topping M50 n'est pas vraiment un lecteur réseau.
S'il se connecte au wifi, c'est essentiellement pour pouvoir utiliser l'application HiByMusic qui permet de contrôler l'appareil.
Pour ma part, j'ai connecté un disque dur de 1000 GO sur un port USB (4 TO maxi) sur lequel j'y ai mis tous mes FLAC, je peux ainsi avec l'application lire la musique qui se trouve sur le disque dur.
J'ai connecté le M50 en fibre optique sur un DAC, la fonction Bluetooth et Airplay fonctionne très bien... Il y a aussi une entrée USB qui permet de le connecter à un PC, mais je ne l'ai pas encore testé.
Pour les points négatifs :
Je vous souhaite bien du courage pour rentrer le mot de passe wifi, l'écran étant minuscule, c'est vraiment compliqué...
La navigation dans les menus n'est pas très intuitive, mais avec un peu de patience, on arrive quand même a sans sortir.
La qualité de son et vraiment très bonne.
philippe C.
Transparence
C'est un upgrade par rapport à la précédente gamme de mini Dac. Topping arrive le tour de force à faire compact, d'une finition parfaite. D'une connectique absolument complète. Et surtout d'une qualité sonore formidable. C'est transparent; ultra détaillé avec une bande passante droite d'un point à l'autre de l'horizon. J'aime le son des puces ESS.
Je l'écoute sur des casques planars magnétiquesexigeants et sans pitié de très très haut de gamme et c'est un sans faute.
Comme toute la gamme Topping il doit impérativement être alimenté par une source de qualité en AES/EBU, sortie en XLR et avec une alimentation secteur très propre (câbles,EMI, etc...). C'est le prix à payer de la transparence et elle est exigeante.
Seul défaut le prix monte, mais très vite oublié à la première écoute quand il est associé au derniers ampli casque de la même marque en version Discrète qui est un bijou aussi et ils sont fait pour s'aimer.
Bien sûr il y a d'autres marques qui postulent dans la même gamme mais si vous voulez LE CHAMPION qui a un plus un peu spécial c'est cette gamme Topping.
Méfiez vous simplement car ils progressent très très vite et on se demande jusqu'où ils ralentiront dans l'excellence du MIDFI.
Bien à vous.
Edern C.
Passage obligatoire !
Bonjour à tous, je confirme les avis laissés par les autres utilisateurs de cette prise Furutech NCF.
Voici mes impressions après quelques écoutes :
•Dureté du son⬇️
•Profondeur du Sound Stage ⬆️ ⬆️
•Réalisme et textures ⬆️⬆️
•Timbres des voix et instruments acoustiques ⬆️
•3D ⬆️
C'est plus fluide, "libéré".
La scène sonore se matérialise de façon naturelle.
Il y a un voile qui disparaît et une crispation en moins.
Ça peut paraître fou.
Mais chez moi c’est le cas.
Je précise que je suis équipé d’une multiprise non filtrée et qualitative, de câbles secteur de très bonne qualité, ainsi que d’une alimentation linéaire pour mon Dac, avec un SR Orange. ????
C’est ce qui a rendu l’amélioration aussi probante, cela ouvre une porte à un niveau encore supérieur.
Pour finir, je dirais qu’il s’agit d’une "Upgrade" incontournable de tout bon système audio/ vidéo.
Merci Audiophonics ????????????
john p.
strange fruit
This is my first discrete test in an op amp topology. The pair replaced the 5534s in an evo sabre dac. (plug n play easy solution- no need for extension). After a few hours burn-in (they do need that) you get a holographic sound with mids and highs having the tonality and presence of a set amplifier. After a quick change to the previous 5534s the difference is quite audible. I am intrigued to get the vivids too but for now the supremes are doing the trick just fine. Needless to say that my beloved evo sabre dac shines in my main system.
Albert L.
Qualité incontestable pour l’alimentation des circuits audio
Voltage et puissance adéquates pour une réalisation personnelle composée d’un sélecteur de source et d’un module préamplificateur, déjà équipés de leur circuit de régulation. Pas d’effet électromagnétique perceptible malgré la taille réduite du boîtier et la proximité proche du transformateur, concernant notamment le préamplificateur. Notons au passage que ces circuits destinés à ce montage personnalisé sont sur le site Audiophonics. Transformateur d’un bon rapport qualité- prix, dans ce cas présent, en tenant compte de son double rôle.
Gilles G.
Presque parfait
Connecteur à l'esthétique vintage intéressante. Bonne qualité "tout en métal" Raccordement des fiches banane en axial ou en radial très pratique. Il manque toutefois une bague d'isolation pour un montage sur panneau métallique et un index anti-rotation.
Gilles G.
Câble semi rigide argenté de qualité. La gaine se dénude facilement et ne brûle pas durant le soudage. Capillarité parfaite pour la soudure. A découvrir pour le câblage d'un appareil audio de haut niveau.
Gilles G.
Gilles G.
top
connecteur solide en métal, il offre en plus une bonne protection de la prise RCA
Gilles G.
top
Thierry V.
Réparation volet piscine
Ce transfo m'a permis de réparer l'alimentation d'une carte électronique d'un volet de piscine.
L'envoi était rapide. ????????
Gilles G.
pratique
bien pratique comme cosse relais, solide et fixation facile
Xavier C.
Câble de très belle qualité
Le câble est très bien réalisé avec des prises très précises qui s'insèrent sans jeu et avec souplesse.
Xavier C.
Câble d'excellente qualité
Les prises sont très bien réalisées et s'insèrent sans jeu et avec souplesse. Une belle réalisation a un prix très bien ajusté.
Jean Luc S.
Pour une connexion satellite sans perte de signal
J'avais déjà acheté cet article l'année passée et la qualité de ce connecteur est toujours au rendez-vous. Même si l'on est pas obligé de souder le point chaud ,perso je préfère le souder pour un meilleur signal.
Pierre Yves P.
Bonne qualité, commutation bipolaire bien
Pierre C.
Surpris du rapport entre la compacité de l'appareil et sa pêche, multiples connexions, tout ça pour un prix serré. Très satisfait
Gerjan D.
Great cable!
I have a Saba receiver and was looking for a quality 5-pin to RCA cable. This is a great one, sounds really good. Shipping to The Netherlands is also good :) very happy.
Dominique m.
RCA Viablue
Bon produit,bien ajusté.
Dominique m.
DYNAVOX Gold Plated 90° Angled RCA Adapter (Pair) This set of 2 high-quality angled RCA adapters can be particularly useful, for example, for making connections in a limited space. The connectors are gold plated to ensure good...
RCA Dynavox
Très mauvais produit,la qualité du laiton est déplorable et casse
à la moindre contrainte.
en l'occurance mon tuner que je repositionnait.
Albert L.
Knob Aluminium Notched Shaft 30x10mm Ø6mm Black This 30mm diameter and 10mm deep black Aluminium knob has a 6mm diameter notched pin. A perfect button for mounting on a DIY project or as a replacement for a damaged button, at...
Bouton fragile
Inutilisable question d’esthétique. La face du bouton a reçu un choc durant son expédition dans un petit colis reçu en mauvais état Pas de quoi faire un drame ni une réclamation après cette découverte compte tenu du prix de l'objet, n'étant d'ailleurs pas le seul article de la commande.
Jerome P.
MMCX Female to A2DC Male Gold Plated Adapters (Pair) These headphone and earphone adapters have a female MMCX connector on one side and a male A2DC connector on the other. Their contacts are gold plated, ensuring both good...
Pas du tout adapté au casque ATH-MSR7b
Je pensais à une qualité extrême (vu le prix payé, comparé à ali) mais au final c’est moins bien et 3 fois plus cher. Les connecteurs gauche/droite ne sont pas strictement identiques, de plus l’or plaqué n’est pas parfaitement plaqué sur les fiches, et pour couronner le tout j’ai eu un mal de dingue à enficher les connecteurs dans mon casque ATH-MSR7b (au risque de casser les connecteurs internes) tellement c’est mal adapté. Ne parlons même pas de retirer (ou plutôt arracher) les adaptateurs une fois insérés (impossible sans grosse pince), un vrai calvaire, il n’y a pas d’autres mots.
Henrikas E.
Insane quality, life changing device.
Peter Z.
amélioration significative du son
je veux juste écouter, écouter et écouter encore
Peter Z.
Peter Z.
Olivier d.
Entrée usb NFB 11
Acheté se super dac il y a trois ans.
Performance indéniable en usb sur mon vieux mac book pro.
Mort de vieux mac et achat d'un mac book pro actuel et plus possible de lire en usb.....
Audiophonics n'a pour solution que l'achat d' un convertisseur usb spdif a 180 euros.....
Convertir deux fois n'a pas de sens.
Donc cet engin qui ne peut évolué est trés decevant.
Olivier
L’arrêt du support de l'interface USB de votre appareil est plutôt la faute du fabricant de votre ordinateur ...
Concernant l'usage d'une interface SPDIF, il n'y a pas ici de notion de double conversion le signal arrivant dans le DAC restant 100 % numérique.
Nous vous avions proposé une bonne référence mais il en existe à tous les prix :
https://www.audiophonics.fr/fr/interfaces-digitales/phiree-u2s-2019-interface-usb-vers-spdif-sa9023-otg-24bit-96khz-noir-p-10522.html
Marc T.
Sensationnel
Dès qu'on le branche, on est surpris de la qualité du son produit : scène sonore généreuse et précise, fréquences extrêmes (dans l'aigu et plus encore le grave) reproduites avec aisance, voix parfaitement timbrées.
Soutient la comparaison avec un câble british presque trois fois plus cher.
Belle réussite à ce prix !
Marc T.
Bon câble, mais...
Bien présenté ; sonorité plutôt ronde, chaleureuse, mais pas assez analytique. Pas gardé assez longtemps pour savoir si après rodage, les choses s'améliorent.
J'ai quand même des doutes sur son métal : la mention "cuivre OCC" n'est inscrite nulle part...
Simon V.
Compatible avec le Aiyima A07
Très bon adaptateur d'alimentation qui fonctionne bien avec l'amplificateur Aiyima A07.
Il inspire confiance comparé à l'adaptateur générique livré avec l'amplificateur Aiyima.
Merci Audiophonics!
Kenneth m.
Super good for the price...
Works really well with the 3 amp. output for my Chord Qutest, and the 1 amp. output for my TP-Link TL-SG105E 5-Port Switch...
Jacques O.
Parfait pour l'utilisation
Fonctionne très bien mais attention, le diamètre est un peu plus grand qu'annoncé: 70mm au lieu de 64mm.
Ivars K.
AUDIO-GD AS-1 2021 EDITION DAC 2x ES9038Pro 3x Accusilicon FPGA Amanero 32bit 384kHz DSD512 The Audio-GD AS-1 2021 Edition is a balanced DAC based on a duo of ESS ES9038Pro digital/analog converters. It ensures an extremely low level of distortion, very...
AUDIO-GD AS 1 EDITION DAC
I am really very pleasantly surprised! Thank you!
Philippe L.
Potentiometre 500k
Les 2 livrés sans rondelles et sans écrous
Philippe L.
Potentiometre alps
1 des 2 potentiometre 3 pattes tordus écrasées
ALAIN A.
CANARE coaxial 75 Ohm
Relie un Sonos Connect au Dac de mon TEAC CD 3000. Excellent résultat ; très satisfait du produit
Eric Z.
Drazen C.
Everything perfect!
Everything perfect!
Claudiu P.
Qualité exceptionnelle
Je les ai montés sur les enceintes Tekton M-Lore et l'amélioration du son est flagrante ! La qualité des matériaux et de la présentation est impressionnante, et le fait que les fils internes de l'enceinte soient fixés mécaniquement, par vissage et non par étamage, est un gros plus !
Nikos B.
DD BC44B Balanced Male Jack 4.4mm Cable Silver / OFC Copper Gold Plated 10cm This DD BC44B cable is equipped with a 4.4mm jack connector on both sides. With a length of 10cm, it is ideal for short interconnections, as for example for the connection of a...
An excellent interconnect cable...
This IC is of impecable materials and manifacture and it comes in a quality little box with guarantee card. It is long enough to connect two portable devices such as a dap with a portable amplifier and the connection is absolutely perfect. Acoustically it enhances noticably the sound adding more transparency with more air and space around the instruments. The bass is presented in a more autharative way with extra body and weight. Highs are airier and without any sign of sibilance or harshness. Delivery from Audiophonics was very fast. A very satisfactory deal overall!
