Claude T.
Bonne config
L'ensemble
- Monitor Pro contrôleur.
Apporte un plus...
Claude T.
Bonne config
L'ensemble
Apporte un plus...
JIOVANNI A.
DAYTON AUDIO UM8-22 ULTIMAX Speaker Driver Subwoofer DVC Glass Fiber 300W 2 ohm 84dB 30Hz-800Hz Ø20.3cm Dayton Audio's Ultimax series of dual-coil subwoofers use the latest in subwoofer technology. As a result, the UM8-22 Ultimax is capable of delivering extremely deep and punchy...
avis du produit
article bien reçu, bien emballé et qualité est exceptionnelle, j'ai testé le haut parleur est incroyable le son est parfait surtout les basses.
JIOVANNI A.
DAYTON AUDIO EPIQUE E180HE-PR Passive Radiator Carbone Fiber 16.3-22Hz Ø17.8cm Combining excellent performance with a reasonable price, the Dayton Audio Epique E180HE-PR passive radiator is the perfect companion to the Epique series of MMAG subwoofers....
avis du produit
les articles bien reçu, bien emballés et la qualité est exceptionnelle. cependant je n'ai pas encore installé pour essayer. j'ajouterai un commentaire une fois testé.
Yuriy N.
More air compared to N-Core 502. To obtain a good sound, it requires at least 10 hours of heating. Excellent build quality.
RENAUD C.
Pieds Dynavox
Belle finition, stable, nombreux diamètres. Intéressant pour remplacer les pieds usés ou inesthétiques
Simeon K.
Small DAC with excellent performance
I am really glad with the sound quality of the SU-1. The sound is detailed, very well balanced, no frequency sticks out or is lacking. Rhythm and timbre are present and the music sounds very refined and believable.
It is well suited for acoustic instruments, voices, brass, symphonic music. Probably not the best choice for metal/hard rock - that require more etched out had thumping sound. Otherwise SU-1 is unexpectedly great performer for my taste.
It pays off to feed the DAC with quality 5V power. In my opinion optical sounds slightly better than USB. A review on the Internet mentioned that coax is even better, but I have not had the chance to test it yet.
The SU-1 definitely deserves your attention. Test it and chances are that you will like it.
claude B.
Au top
Très bon rapport qualité prix sonne très bien avec mes enceintes Magnat monitor 220 de même que les vinyles a 1/4 de la puissance cela sonne déjà fort il y a de la réserve merci Audiophonic
Robert C.
Prong T Nut M8x20mm Ø22mm Black These steel/carbon prong T nut are M8x20mm format with a head of 22mm diameter. Ideal for fixing in wood.
Very good product
Product application is as expected.
Robert C.
Excellent I2S cable.
I'm using this cable as I2S cable and it is highly recommended for this purpose. High quality build and robustness with excellent audio performance capabilities.
Robert C.
Nice quality speaker terminals
I'm very pleased with quality and robustness of this speaker terminals. Highly recommended.
Robert C.
Hexagon Socket Countersunk Head Wood Screws M4x20mm Steel Black (x10) These M4 steel wood screws have a countersunk hexagon socket head. The type of steel chosen gives these screws great resistance.
Not good for plywood projects
Not good for plywood projects due to very soft screw head.
fabrice L.
adoptés
je viens de les monter , c'est ma première expérience dans ce domaine des aop , je détecte une plus grande profondeur du son et des voix mieux détaillées , un son plus chaud , maintenant il faut les roder !!
Yannis G.
Petit mais costaud !
J'ai pu avoir ce préampli dac d'occasion proche du neuf , et je l'adore pour son écran très informatif , concernant sa sonorité il as un son très penchant vers le médium aigu en mode préampli mais en mode dac il est parfait !
Christian T.
MUNDORF ACW120BK Wiring Cable Copper / Silver / Or PTFE 3.1mm² The Mundorf ACW120BK is a high quality wire with a high conductivity. Thus, its conductors are made of high purity mix copper / silver / gold and insulated by a PTFE sheath in...
Son homogène
Au début je trouvais le son de se fil moins bon que un fil argent pure occ.
Mais après quelques heures d'écoute le son de se fil, est devenue plus naturel avec plus de détails, c'est un des meilleur fil de câble que j'ai entendue, je l'utilise comme jumper pour mes haut parleur.
Juan Manuel G.
BURSON AUDIO V7 VIVID PRO Dual OPA (Unit) As an evolution of the V6 VIVID, the V7 VIVID Pro stands out for its clarity, precision and high dynamic range. It is particularly recommended for...
Spectacular
Used on su9 ultra. Great neutrality and details. The best you can buy. It's worth the change. I have observed more gain than with OPA1612. Highly recommended in any mid-high range DAC.
Utilisé pour faire un drain de tresse de blindage.
AMPHENOL AXX3F Female 3 Poles XLR Connector Ø8mm The Amphenol AXX3F 3-pin XLR female connector lets you design robust, professional-quality cables. Nickel plating and body ensure durability and corrosion resistance. This XLR...
Rqp incroyable. Je les trouve vraiment étonnant de qualité pour ce tarif. Je recommande vivement.
AMPHENOL AX3M Male 3 Poles XLR Connector Ø8mm The Amphenol AX3M 3-pin male XLR connector lets you make robust, professional-quality cables. Thanks to its nickel plating and body, the connector is extremely durable and...
Qualité prix exceptionnel. C' est beau, ça se soudé facilement, mécanique impeccable . Restitution neutre. Meilleur que Neutrik ou équivalent?
Samuel M.
Excellentes
Sur mes monoblocs Jadis DA30 (ancêtres des JA30), elles ont remplacé les NOS telefunken.
Associées aux 12AU7 S l’equilibre global est excellent sur tous les critères de bande passante etendue, de microdetail, neutralité et dynamique.
Samuel M.
Excellentes
Je viens d’installer une paire de Psvane 12AU7 S en entrée sur mes 2 monoblocs Jadis DA30, une pré version des JA30, année 1987.
Sorties de l’emballage, le son est d’emblée excellent. Proches des JJ gold, elles me semblent aller un peu loin avec des basses et hautes fréquences plus étendues, un haut niveau de micro-détails qui procure une aération -ex applaudissements-, absence de coloration, tout ressort avec une meilleure homogénéité. Le principal gain est dans la dynamique.
Nb: j’avais également testé des NOS Mullard CV491 qui se sont révélées, sur ma configuration, en deça des JJ gold.
Dominique B.
Incroyable rapport Q/P
Très belle surprise à la réception de ces fiches, excellente qualité de fabrication et finition. Le serrage à vis du point central est très efficace et offre un contact parfait, la masse se fait très bien en enroulant le fil dénudé autour de la gaine du câble au niveau du serre câble arrière ainsi le contact se fait avec le corps de la fiche. Le serrage sur les embases est très efficace. Bref, un produit au rapport qualité/prix incroyable.
Manuel S.
Excellent amplifier and top service with very fast delivery
I ordered 2 of these amps to drive my Triangle floor standing speakers and I am impressed by the good sound quality and the low noisefloor of the amps. Due to horn loaded titanium tweeters, a noise floor will be present on 2m distance. This is not the case with these Purifi based amplifiers. Thanks to audiophonics I had them very fast and had also a very good impression to the service. I highly recommend the products of the Audiophonics workshop!
Joel T.
AUDIOPHONICS WIRE Interconnect Cable Stereo XLR OFC Copper Gold Plated 1.5m The Audiophonics Wire range offers a selection of affordable yet high-performance cables, hand-assembled in our workshops in France. The Audiophonics Wire XLR cable features a...
They do the job
They work perfectly, quality seems good.
Joel T.
TOPPING DX5 LITE DAC 2x ES9068AS NFCA Headphone Amplifier XMOS Bluetooth 32bit 768kHz DSD512 Black Topping offers with its DX5 Lite a DAC and headphone amplifier combo benefiting from both an exceptional conception and a resolutely modern design. At its heart is a...
Pretty Good DAC/AMP
I was looking for a not super expensive DAC+AMP combination, and I am very happy with the DX5 lite. It works well with windows 10, and I dont have software bugs. Audio quality is good, as expected.
Per H.
Great Sound!
I purchased this power amp to get better stereo sound from my AVR. It is great! Really good bass control and a lot better dynamics. My Dynaudio Emit 30 speakers have never sounded better.
Kai-M. L.
TinySine TSA1701
I ordered 2 TinySine DSP boards TSA1701 on May 27, 2024.
Only after the order I noticed that no units were in stock.
The parcel was finally delivered on June 18, 2024, i.e. after 22 days.
The price seems ok.
Unit price was 22,71 € at the day of order,
Including shipping to Germany this resulted in 25,75 € per board.
List price at TinySine is 21,20 USD (=19,93 € on June 21, 2024).
For 2 boards shipping cost are estimated as 8 $, resulting in a unit price of 25,20 $.
For an order of 2 the German distributor charges 37 € per unit.
Matthieu G.
HUMMINGURU HG01 Ultrasonic Vinyl Cleaning Machine The HumminGuru vinyl cleaning machine is an ultrasonic cleaning machine. This machine provides a professional level of cleaning for your vinyl. It's intuitive, compact,...
Excellente solution pour le nettoyage des vinyles
Rien à dire. Machine compacte, silencieuse (pour une machine à ultrason), pratique. Les disques ressortent comme neuf et cela se ressent énormément au niveau de l’écoute. Prix un peu élevé, mais on reste en dessous de la plupart des autres systèmes existants.
Adam S.
Disapointing sound
Not worth the Money ,just a bad cable ,the sound was disapointing compared to the standard ptfe cable i have bought earlier from audiophonics
RENE R.
VIABLUE UFO Vibration Absorbers Ø35mm Black (Set x4) Viablue UFO absorbers can be used to dampen harmful vibrations by placing themselves under your speakers or HiFi devices. Due to their optimal pressure on the lower surfaces of...
Absorbeurs Viablue UFO
excellents sous une vieille platine Thorens td 160S.
J'en avais déjà acheté un jeu pour mettre sous TD 124 MK2.
RENE R.
1877PHONO EH
Bon produit cependant je n'ai mis que 3 étoiles car le diamètre est le meme que celui du disque ce qui fait que lorsque l'on change de 33 tours le couvre-plateau vient avec.
Donc il faut peut-etre mettre un scoth double-face?
Andrija K.
works great
everything works as described, using it to run BST-1 shaker and it works great
Georg O.
AUDIO-GD HE-1 MK3 Class-A Balanced Preamplifier ACSS XLR RCA Silver Audio-GD once again presents the quintessence of audio technology with its HE series products (here the HE-1 MK3), an evolution of the MASTER series. They have benefited from...
Mein bester Vorverstärker
Ein ganz herausragend gutes Gerät. Meine klassische Musik auf CDs hatte noch nie einen besseren Klang, obwohl ich bereits 12 andere sehr renommierte Geräte hatte ! Der Klang zeichnet sich durch eine besondere Präzision, Dynamik, Detailfreudigkeit und angenehmer Wärme aus! Ein ganz seltener Hochgenuss!
FURUTECH DAS-4.1 Balanced Interconnect Cable OCC DUCC Copper Ø10mm This Furutech DAS-4.1 balanced interconnect cable offers an absolutely outstanding design quality that will allow you to design your own high-end audio cables. It features two...
Attention Ovni i!!!
Ce câble, est venu en remplacement, du Furutech FA-aS22, chez moi il s'agit d'un câble Hybride RCA FURUTECH CF-102 NCF, et OYAIDE FOCUS 1 Connecteurs XLR Mâle. Ce câble, est a l'image de cette game HDG FURUTECH, au bout d'une semaine : beaucoup de transparence, de véracité des timbres, de finesse, de profondeur, de maitrise, est de lisibilité, d'une définition très poussée ,mais naturelle. Le seul bémol, est qu'il va être très long à roder (le câble secteur FURUTECH DPS 4.1 avait mis environ 500 Heures, pour arriver à Maturité) et son prix relativement élevé, mais je pense que cela en vaut la peine.( Il ya de très bonnes vidéos en ligne, pour le montage des câbles FURUTECH DPS 4.1, sous toutes leurs formes, faites par Furutech).
J-Paul R.
Excellent petit DAC auto-alimenté
Fonctionne parfaitement. Sert à relier un MacBook Air M1 à un ampli casque Micromega Myzic.
Werner H.
the best chinch sockets
***** these jacks show you how high quality cables Audience Au24 SX can sound *****
Harry H.
the best for the buck
The only affordable pure silver contacts XLR connectors.
Use them with the Neotech Nemoi rectangular UP-OCC silver IC and that is a very good combination
Harry H.
second buy for friend
This cable was so impressive in my friends set up (Macintosh pre/power amps, kef reference speakers and pink faun streamer/DAC, Yeti power conditioner and power cords, Timber XLR interlinks) when I took it to him to try the he said make one for me too. That,s why I ordered the cable again and the Viborg pure silver XLR plugs.
SUPER
Philippe L.
MOONDROP SPACE TRAVEL Dynamic True Wireless In-Ear Monitor IEM 20Hz - 20kHz Black Moondrop Space Travel wireless earphones feature a dynamic 13 mm titanium composite dome transducer in each earcup. These wireless earphones benefit from a Bluetooth 5.3 module...
Qualité/Prix imbattable
Des écouteurs avec du son! Un poil lent dans les commandes
Une étoile perdue en raison d’une app Moondrop Link “momentanément” absente du AppleStore et une fonction EQ à telecharger ailleurs… ceci dit, peu voire pas d’équivalent IEM TWS sur le marché
Michel P.
Trés bon amortisseur de vibration
Utilisé sur un pré-ampli donne d'excellents résultats : basses plus sèches, son plus dynamique image stéréo plus stable, détails révélés. Pose facile avec un peu de précision et d'attention. Cependant nécessite de faire un essai préalable pour juger du résultat selon les appareils et l'emplacement de pose, selon ces critères j'ai obtenu des effets différent : lecteur réseau aucun impact, pré-ampli : sur le dessus (capot) très bien, sur le dessus une plaque interne + une plaque externe très très bien sur le dessus et dessous encore mieux, sur les cotés : négatif (son dur et agressif). Pour les essais j'ai retiré qu'une partie (par bandes) du film protecteur de la partie collante afin de faciliter le retrait; attention néanmoins si cette procédure donne une bonne indication des effets, lors de la pose totale il peut y avoir de légères différences.
SUPERBE ECOUTE !
Informé d'une nécessité de rodage avant un résultat optimum, j'ai été toutefois surpris d'obtenir immédiatement un excellent rendu, déjà supérieur à mon précédent Dac pourtant aussi R2R de qualité.
- La fabrication du Gustard R26 et la structure même des circuits internes et des composants retenus (ex: horloges), sont visiblement de la plus haute qualité.
J'ai attendu une dizaine de jours avec le Dac sous tension secteur permanente (et modulation en silence les nuits) afin de pouvoir donner un avis un minimum cohérent et crédible !
- Le son de la section Dac du Gustard R26 est tout simplement remarquable; à la fois précis, dynamique, très articulé et avec en prime un fruité de l'aigu comparable à celui d'excellents systèmes de lecture vinyle ce qui est extrêmement râre.
L'image sonore assez "panoramique" offre une belle profondeur 3D avec une agréable impression de présence réaliste des interprètes musiciens ou chanteurs.
L'écoute est d'emblée très supérieure musicalement au rendu de mes 9 ou 10 précédents Dacs.
- Son lecteur réseau intégré plus classique, bien que très correct n'a certes pas le caractère exceptionnel de la section Dac mais on doit considérer que proposer un Dac d'une telle qualité + un lecteur réseau très correct + une télécommande, + Bluetooth etc. pour un prix de 1599 € s'affiche comme un excellent rapport qualité/prix.
En conclusion: c'est probablement l'un des 3 ou 4 meilleurs Dacs actuellement disponibles sur le marché, dans une tranche allant jusqu'à env 3500 € !
Rien de moins ! !
Gilles R.
Fausse bonne impression
Celui-ci a une tendance certaine à accentuer le poids des notes d'un piano par exemple,au détriment des voix qui passent logiquement en second plan.Pas du tout emballé.
Djènè S.
Du très beau matériel
Équipé d'un dac teac ud 503 branché en rca esprit alpha à roksan k3 sur monitor audio silver 500 6G. Source tidal depuis pc. Je remplace le teac + pc par ce a26.
Gain léger en utilisant le gustard avec source pc en usb. Puis je passe en l'an avec le streamer interne avec source tidal sur bubble upnp. Et là le gain est incontestable. J'avais déjà un très bon son, bien optimisé, peaufiné pendant des années. Mais là je gagne sur tout. Scène un peu plus large, et clairement plus profonde. Silence un niveau au dessus et surtout micro informations et attaques un gros cran au dessus. Le son a bas volume conserve sa qualité et son dynamisme, avant je sentais qu'il fallait pousser un peu pour profiter du potentiel de mes HP de 20cm.
De nouveaux micro détails se révèlent de manière évidente. Le plus flagrant s'entend sur les percussions/batteries. Un solo de batterie complexe est maîtrisé sans aucune bavure et avec une finesse qui permet d'apprécier l'intention de chaque frappe même quand le batteur est surexcité. J'ai l'impression que ce a26 est capable de gérer tout ce qu'on lui envoie. Au point où j'ai l'impression qu'à présent c'est peut-être le reste du matériel qui mériterait de monter en gamme.
Esthétiquement rien d'incroyable mais c'est minimaliste et très bien construit, donc RAS. En terme de signature sonore, c'est dans la continuité de ce que j'avais avant (double akm) mais tous les curseurs sont clairement poussés en termes de performances. Un son neutre, défini, naturel sans excès, pas de chaleur superflue qui nuirait à la définition, pas de froideur particulière mais une maîtrise virtuose qui prend aux tripes si le reste de l'installation est cohérente.
Ps : je suis habitué à des écoutes sur de nombreux systèmes HDG (atoll, Mac, hegel...).
J'ai changé le câble secteur avec un furutech tcs31 avec viborg rhodium, gain évident sur les basses qui sont plus musclées et longueur de note sur les micro informations.
J'espère qu'il vous plaira.
Matthias E.
Happy it makes a great difference
I have a Chord mojo and a hifiberry dig+ pro. Before I was using a power bank, and there was a clear difference between coaxial and toslink, toslink sounded 3d but a little less decisive, and coaxial was more impactfull but 2d, now both inputs sound equally 3d, clearly there was some electrical noise coming through coaxial that affected the dac which by the way is not galvanically isolated and this psu solved the problem, I'm very happy with this result, in the future I plan on powering a Chord qutest and allo digione signature with this
Jean-Luc M.
Superbe DAC
Je possède également un DAC RME ACI2 (AKM 4493), le Cyan2 apporte une différence importante sur le rendu avec une écoute plus "analogique", un placement plus précis des instruments et des voix, et le registre des basses plus soutenu.
Il est associé à un préamp Lake People MC100 et des enceintes ATC 20 Pro Active.
Je l'utilise avec Roon et HQPlayer 5 en mode DSD direct upsampling DSD256 et il révèle alors tout son potentiel.
Il semble qu'il faille entre 4 à 500 h de rodage pour qu'il soit complétement au top.
Attention si vous avez plusieurs sources (USB, AES, coax, I2S), vous n'avez pas de sélecteur à votre disposition, il choisi la première activée, mais à tendance à privilégier l'USB (j'ai activé l'AES, mais il bascule quand même sur l'USB si j'active en second l'USB).
Service impeccable avec Audiophonics.
Achat très recommandé.
Si vous êtes intéressés, passez commande dès qu'il est de retour en stock, car cela part très vite....
Jacques T.
Pour un streamer Octavio
Je possède un streamer Octavio que j'utilise en simple transport réseau vers un DAC Heed Abacus (+ Ampli Heed Elixir et enceintes PEL Toscane). Le remplacement de l'alimentation d'origine par celle-ci est simplissime en utilisant la connexion USB A et le câble USB A - USB C fourni par Octavio. L'écoute via Qobuz montre une belle spatialisation précise et sans fatigue auditive ainsi qu'une meilleure musicalité, cette amélioration reste subtile mais suffisante pour accorder de l'intérêt à ce changement d'alimentation.
Il est à noter l'envoi soigné et extrêmement rapide du colis contenant cette alim mais il est vrai que j'habite à proximité du siège français de Audiophonics.
STEFANO M.
Good!
Good replacement for Behringer MS40 Tweeter, it is necessary to profile them one mm smaller in diameter (66mm these vs 65mm original MS40 Tweeter) they seem to sound very very good.
Jean O.
Jean O.
J’ai acheté cet ampli Purifi en remplacement d’un ampli Project Amp Box DS2. Ce dernier est équipé de modules Hypex UCD 180. Bien que fonctionnant tous deux en classe D et ayant la même origine, des différences audibles existent. Le Purifi a plus d’assise dans les basses et est moins montant dans les aigus que le project. Il est également plus transparent (microdétails) et plus naturel. Bref très bonne impression. Merci audiophonics.
Attention, le boitier est étroit mais profond. J’ai du utiliser un cable d’alimentation et des renvois RCA coudés pour qu’il rentre dans le meuble.
Patrick M.
GENALEX GOLD LION Tube 12AT7 / ECC81 / B739 Gold Pins (Unit) The high-end Genalex Gold Lion Gold Pins double triode tube unveils a wide sound stage, characterized by expressive midrange, deep and precise bass and generously developed treble.
Belle amélioration
Il remplace avantageusement une EH qui équipait mon ampli casque Canor tp10: aigu plus suave, médium plus souple et champ sonore mieux ressenti avec mon Grado PS500E.
Stephane N.
Spikes M4 Aluminum Rubber Ø31x21mm Silver (Unit) This decoupling tip is made of Aluminium. It is surrounded by a removable rubber ring. The combination of these two materials allows the absorption of different frequencies. The...
Très bon produit. Utilises sous un DAC ATOLL, il font le boulot !
jouri k.
this is it :)
Packaging and shipping were superb. I was really curious how these expensive clocks would hold up. They don't let down. Much better than the accusillicon. Treble/mid/bass took a giant leap.
Imaging way better :)
It is so good, so happy to have high-end sound in my living room.
jouri k.
IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 5V The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply...
unexpected!
This power supply is a great upgrade. Also if you have the previous version. Which i have. Thus I was very sceptical about any noticeable upgrade. But this is a big one!
