Pavel V.
Very good streamer
Customers reviews - There are 20152 reviews.
Hervé N.
IFI AUDIO ZEN V3 DAC Burr Brown USB-C XMOS 16 Core MQA 768kHz DSD512 With the ZEN V3, Ifi Audio presents a new version of its successful ZEN series. The brand's ambition is still to offer a digital/analog converter offering exceptional...
EXCELLENT DAC entre autres.
Pour un mode Bureau avec des enceintes Highland, j'ai connecté le V3 en entrée sur le petit ampli Loxjie A.30 et en USB.C sur mon vieux MacBookPro de 2012.
Le son est excellent, bien meilleur qu'avec la fonction DAC du Loxjie.
Je suis enchanté !
Martin S.
Lacking Some Detail and Control.
The aim was to replace my Musical Fidelity KW500 with something physically smaller.
I paired the MPA-S125NC power amp with a Lehmann Black Cube headphone/preamp, which I know very well with various headphones and have for a short time used it as a pre-amp combined with a class A/B power amp.
I initially just listened to music to give it a fair test, after a couple of evenings listening, these were my thoughts. Pros: wide soundstage; pretty good instrument positioning; fairly musical / Negs: lack of detail in bass and generally getting a bit muddled in complex layered tracks.
I switched to some test tracks:
1) Elbow, Asleep in the Back. This trips up many systems, the sibilance on this track can make it almost unlistenable if it is not well controlled. Not a total failure here, but was struggling a bit.
2) Clearlake, Lido. A layered album. Struggling to keep it from becoming messy.
3) Animal Collective, Feels. Again struggling to keep control of everything, sounded too harsh.
4) Pepe Deluxé Queen of the Wave. Could quite get the power and majestic and theatrical quality out.
There were other test tracks, but the above were the ones to highlight what I believe are the issues.
Conclusion. Just not good enough to replace the KW500. Perhaps this is a bit of an unfair comparison as the KW500 was a lot more expensive. However, I do not feel I can live with the MPA-S125NC as a main system component.
Jacques B.
NEOTECH NEP-3001G Power Cable Copper G-UPOCC Graphene 3x5.2mm² Ø16mm Neotech's NEP-3001G is a power cable incorporating 3 G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor marks a significant advance, both...
Remarquable câble !!
Une superbe fabrication, un montage délicat car câble assez rigide à prendre en compte si l'espace est limité derrière les appareils. Mais quel son naturel, précis, dynamique, une très belle ampleur et une douceur des timbres tout en ayant une grosse résolution et une neutralité certaine, contrairement à une autre marque très réputée en DIY !!! Je terminerai par sa polyvalence où, malgré le diamètre de ses conducteurs, il va aussi bien sur l'ampli que sur des appareils numériques, preuve de la qualité de son cuivre !! A recommander sans réserve, les limites étant données par la connectique et pas par le câble. Bravo Neotech.
Andre K.
EXICON ECX10N20 Transistor MOSFET (2SK1058) Exicon MOSFETS have been specifically designed for high power linear use. They offer high voltage capability, high slew rate and low distortion, making them the ideal choice for...
replacement
I used the Exicon transistor as a replacement for the discontinued SK1058 transistor. No need for any circuit modifications.
Geoffrey M.
Mise en place facile , borniers de qualité
Geoffrey M.
Câble utilisé pour le câblage interne de mes Klipsch
( Tweeter ) c’est mieux qu’a l'origine
Geoffrey M.
JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 3.9μF Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every...
Composant qualitatif utilisé pour upgrader mon crossover
Geoffrey M.
J’ai isoler mes colonnes Klipsch avec , prévoir de la Neoprene
Geoffrey M.
Parfait pour des soudures et le réglage température est un plus
Theodore A.
AMANERO COMBO768 Digital Interface USB 1536kHz to I2S / DSD The Combo768 is an USB audio device adapter designed for OEM applications. USB PCM audio data (2 channels) accepted as input are converted into an I2S stream or a native DSD...
Perfect module
I use it in my DIY DAC. Amazing performance and better than previous 384. I have it one year now with no issues. Buy with confidence
L'AMPLIFICATION ULTIME (?)
Enfin un amplificateur qui n'est pas ceci ou cela mais qui s'efface devant la musique. Pas de plus beau compliment pour un maillon Hifi. L'amplification classe D est elle entrée dans sa maturité? Avec ce module Hypex Ncore on peut l'affirmer. Tout ce que le mélomane attend d'un amplificateur me semble être ici présent: dynamique capable d'explosivité et de contrôle, sans traînage du grave, nuances fines restituées avec délicatesse, respect des timbres évident, sans aucune acidité dans le registre aigu, image stéréo superbe accompagnée d'une grande transparence. Que dire de la puissance sinon qu'elle est conforme à ce que le constructeur annonce, contrairement à ces multiples amplis chinois à base de TPA 3255, qui sont de bonnes machines, mais dont les puissances annoncées sont fantaisistes. Ce module Ncore va nettement plus loin en puissance comme en musicalité. Sur un plan purement matériel, la qualité de fabrication me semble au dessus de tout soupçon: chassis alu solide, connectique RCA, XLR, ENCEINTES de belle facture, câble d'alimentation de forte section, bref que du sérieux. Un ampli de puissance à associer impérativement à un très bon DAC (pas obligatoirement coûteux) et à des câbles d'une grande transparence. Bravo Audiophonics.
Christian L.
Rotary Digital Encoder 24 Steps Push Button D Shaft 15mm This 24-position rotary encoder has a D shaft for attaching a button and a push button. In particular, it can be used as volume and source control.
demande d'envoi des 2 en stock
Si le délai est trop long pour le réapprovisionnement merci de m'envoyer les 2 que vous avez en stock.
En fait j'en ai besoins que de 2. J’ai mis une quantité de 5 pour le minimum de commande.
Je vous offre donc les 3 autres.
Merci,
Christian Lemmer
dominique w.
Pour un tarif contenu ce câble bénéficie d'une trés belle fabrication qui va à l'essentiel. créer une ligne dédiée totalement indépendante avec ce câble m'a permis de constater une réelle et importante hausse du résultat global d'écoute qui s'est fait jour après un bon mois de rodage. Par rapport aux cordons d'alimentation, au conditionneurs et autres filtres hors de prix que j'ai essayé, il n'y a pas photo.
TOPPING L70 Balanced NFCA Headphone Amplifier / Preamplifier Silver With the L70, Topping offers a highly engineered balanced NFCA headphone amplifier and preamplifier combo that delivers excellent sonic performance and is suitable for a wide...
Topping L70 - Sennheiser HD-650
l'aspect extérieur donne une impression de bonne qualité. Acheté pour alimenter un Sennheiser HD-650 , après une dizaine d'heures de rodage les aigus se sont adoucis , les graves sont apparues : pour moi le son est parfait.
Livraison rapide , bien emballé : merci Audiophonics.
Robert C.
RQP très bon
J'avais un CHORD 2 QUTE depuis 11 ans, et j'ai voulu essayer un modèle R2R de chez HOLO Audio et mon choix s'est fixé sur le CYAN 2 car les frères ainés sont beaucoup plus cher.
Après une semaine d'écoute, les différences sont vraiment infimes ; le 2Qute n'étant pas Delta/Sigma mais un FPGA Spartan 6 avec un niveau de sortie de 3 V RMS était un bon Dac dynamique et très précis également ; le Cyan 2 aurait des basses très légèrement plus profondes et articulées, et semble aussi modérément plus homogène sur l'ensemble du spectre.
Le 2Qute aurait les hauts médiums et aigus un peu plus en avant. Il est vrai que ce sont des Dac de prix approximativement équivalent.
Connecté uniquement en USB pour l'écoute QOBUZ avec AUDIRVANA, je n'ai pas de souci à chaque mise sous tension.
J'aurai aimé connaitre un GUSTARD R30 ou HOLO MAY mais ils sont dans un budget bien au dessus.
Service et livraison rapide, merci AUDIOPHONICS et HOLO Audio.
Jörn K.
THINKYA R01 CD and USB Audio File Player Bluetooth 5.2 Bidirectional 16bit 48kHz The Thinkya R01 is a CD and audio file player with a retro look. It features a SILAN SC6137D processor and a precise laser head. In addition to allowing you to play your CD...
Recht ordentlicher CD - und USB Player im Retrostil.
Der Thinkya R01 ist auf meinem Schreibtisch ein Blickfang. Auch wenn sein CD-Laufwerk von der einfacheren Sorte ist, kann mann damit gut CDs und CD-Rs abspielen, geauso gut auch MP3 Musik von einem USB Stick. Und die Fernbedienung ist sehr hilfreich. Ich habe den R01 aber optisch mittels Toslinkkabel an einen Dac angeschlossen, so dass ich über den Audio- und Kopfhörerausgang des Thinkya R01 nichts sagen kann.
Bin mal gspannt, wie lange das hier bei Audiophonics sehr, sehr günstig zu erwerbende Gerät tatsächlich seine Dienste verrichtet.
Mif freundlichen Grüßen genius1959jk.
Szilard S.
This is a class D beast!
I purchased the NC502MP stereo amplifier module for my dual subwoofer system, and the results have been nothing short of exceptional. The amplifier delivers immense power with absolute control – my 12” woofers are handled with surgical precision and zero distortion. Its dynamic range is astonishing, and the low end remains tight and authoritative across the 30–100 Hz range. What impressed me the most is how transparent the amp sounds – it adds no coloration or "flavor" to the signal; it simply amplifies what it receives. This is true high-fidelity performance. Integration with my MiniDSP Flex HT processor was seamless, and the system noise floor is dead silent. The build quality is excellent, the module runs cool, and power efficiency is top-notch. In my view, this amp has become the strongest link in my audio chain. If you're serious about low-end performance and high dynamic resolution, this module is a fantastic choice. Highly recommended – especially for those building custom active systems or subwoofer amplification. Thank you Audiophonics!
James N.
Excellentissime
Cohérence exceptionnelle de bas en haut du spectre. Beauté des timbres, musicalité. Médium et voix incarnées. Grave profond et modulé. Une réussite sur mon Audiomat Solfège ref qui drive des Triangle Cello. Seul bémol comme déjà mentionné, 40 heures mini pour le rodage mais c'est pour le meilleur !
James N.
Très Bons
Beaucoup de matière avec un médium plein, Subtilité pour les hautes fréquences. Grave puissant et tendu. Musicalité et évidence de la musique
Jean-Pierre T.
CRINEAR PROTOCOL MAX Balanced Portable DAC Headphone Amplifier 2x CS43198 PCM 32bit 384kHz DSD256 The CrinEar Protocol Max portable headphone amplifier and DAC is a device based on audiophile components to meet the needs of a demanding audience. It is based on two CS43198...
petit DAC ampli casque performant
Sur les conseils avisés d'audiophonics, j'ai fait l'acquisition de ce tout petit DAC ampli casque pour un sennheiser HD560s. Et j'ai bien fait de suivre leurs conseils. Ce petit DAC s'installe en moins de temps qu'il ne faut pour l'écrire avec un câble USB c très spécial...et joli. Il est tressé! Je l'ai acheté pour l'utiliser avec mon smartphone Samsung Galaxy a53 5G. L'adaptateur USB c jack 3,5 mm (assymétrique donc) que j'avais ne délivrait pas une puissance suffisante pour ce casque, ni même pour mon grado 80. Avec ce petit DAC ampli casque, et surtout avec le mode boost, la puissance est au rendez-vous et la qualité du son est très bonne. Je ne suis pas un expert mais tout me semble bien équilibré. Basses présentes mais pas de manière excessive, les voix ressortent très bien. Je n'ai pas encore tester les différents modes de qualité de son proposés par spotify mais en mode "automatique" le son est vraiment très bon que ce soit avec le sennheiser (impédance 120 ohms!) ou avec le grado (impédance 38 ohms). Bref un bon achat. Et encore merci à Audiophonics pour ses conseils car j'hésitais avec un modèle plus cher et ils m'ont conseillé celui-ci.
michel H.
Bon petit lecteur compact vintage
Très bien pour le prix avec un look de platine tourne disque
connecté via cable optique à un petit ampli foci MC331 à lampes et enceintes Elipson ce qui donne un petit ensempble sympa et esthétique. Son tout à fait correct pour mon utilisation
pascal P.
MINIDSP POCKETADC ADC Converter ES9821Q RCA to Coaxial / Optical Toslink 24bit 192kHz The MINIDSP Pocket ADC is an analog-to-digital converter featuring a stereo RCA analog input and two digital outputs, a Toslink optical output and a coaxial SPDIF output. Thanks...
Petit appareil qui fait le job. Meilleur que le convertisseur intégré à ma platine DJ. Meilleur surtout que bien des numérisations bâclées des CD du commerce. N'hésitez pas à y brancher votre section phono, vous aurez un son plus "analogique" qu'avec les CD. Indispensable si, comme, moi vous avez une chaîne bi-amplifiée par filtrage numérique.
Benoit C.
SOMMERCABLE MERIDIAN SP215 Speaker Cable OFC Copper 2x1.5mm² Ø6.8mm This robust cable is specially designed for connecting speakers and technically meets all the requirements. Its copper cores with low oxygen content ensure excellent acoustic...
Rapport qualité bluffant !
Pour une installation modeste entre une paire de JBL et des amplis anciens réparés, ce câble fait très très bien le travail !
Si vous ne mettez de connecteurs aux extrémités, il faut étamer les brins pour qu'ils ne se cassent pas (le câble se travaille très bien cependant)
Sa souplesse lui permet de prendre le chemin désiré.
Artis S.
GENALEX GOLD LION KT77 Platinum Tubes (Matched Quad) These Genalex Gold Lion KT77 tubes provide faithful sound reproduction. Each tube features thick glass and sturdy plates for durability. Its grid wire is gold-plated and these...
Best lamps for price category
Sounds punchy, fast and rich bass cristal hights , recomend for rock and jazz, for blues litlebit agresif but for modern electronic music exelent
Artis S.
Lamps sounds kood with smooth soft juicy bass and neitral hights. recomend for classic music
Artis S.
Perfekt
Lamps work grate
Gregory C.
IBASSO DX180 Digital Audio Player DAP 4x CS43131 Bluetooth 5.0 Android 13 Black The DX180 from iBasso is an audiophile DAP of excellent quality. It benefits from a meticulous design incorporating four CS43131 DAC chips, delivering faithful, accurate and...
Ibasso dx180
Je suis vraiment très content du produit. J'avais un ibasso DC élite dont j'étais très satisfait mais je souhaitais ne plus avoir de câble entre mon téléphone et le DAC donc je préférais partir sur un lecteur et je ne regrette pas. Concernant le son il ne me semble pas moins bien ni mieux mais différent. Après les différents filtres fonctionne bien pour s'adapter à différents casque ou Iems. De plus j'ai été livré rapidement et je suis très content d'audiophonics que je recommande. C'est mon deuxième achat et j'en suis satisfait. Personnel très à l'écoute.
ANDREAS M.
A positive addition to my system
I am listening music by connecting a laptop to a USB Dac through a good but lengthy (5m) USB interconnect cable. The connection is asychronous, so in theory, adding a recloaker shouldn't make any difference.
The problem I was facing, was the appearance of a very noisy ground loop; I could only listen to music when the laptop was disconnected from its power supply and was relying only on its internal battery.
I solved that problem with the help of the SMSL gadget and a toshlink interconnect. As for the sound, I can discern a subtle but noticable improvement. Not a night and day difference, but the sound appears "fresher" and with a somehow larger soundstage. If the SMSL could be combined with an external power supply, the sound could be even better - but it only gets powered by the USB interconnect. In that price point, I believe that the company should provide the first option.
That said, the SMSL has been a positive addition to my system. Reclockers do work, even in a subtle way. Does it worth the cost? This is subjective. Not every system needs one, but when it's needed, I believe that the SMSL PO100 PRO won't dissapoint.
Patricio C.
GUSTARD S26 Streamer Airplay UpnP Roon 32bit 768kHz DSD512 Silver Gustard's S26 is a streamer designed to deliver exceptional audio performance thanks to the meticulous optimisation of each of its components. In fact, everything from the...
Excelente producto!
No es necesario un app para IOS, con crear un acceso directo vinculado a la direccion s26.local... podrás acceder desde el movil o tableta IOS al reproductor Celplayer o a la configuracion del S26.
Tharbamar en su canal de Youtube acaba de subir un video y su análisis... el cual recomiendo que lo veáis. Le pone una nota de 10!! y el roon server de referencia.... en cuanto a calidad de sonido lo pone por delante del Eversolo T8. y califica al S26 como NEXT LEVEL!
Saludos
woo yong k.
아주 마음에 듭니다.
매우 만족합니다.
많이 파세요
Frank K.
The change in sound blew me away
The change in sound blew me away!
I connected the reclocker between my internet radio and the DAC via Toslink (optical cable). What happened next was incredible. I had a three-dimensional sound image. Only now did I realise that without the reclocker, I had only been hearing in two dimensions. I highly recommend the reclocker!
Andras S.
SMSL PL200T CD Transport USB XMOS 32bit 768kHz DSD512 MQA-CD The SMSL PL200T is a high-performance, versatile CD transport. It's based primarily on a P.A.S.S. (Precision Access Servo System) playback system developed by SMSL, plus an XMOS...
Small device - big sound
A very good sounding and funny transport. Compared to my Sony CDP-XA20ES (also used as transport) it has a bit more airy sound with bigger soundstage. Also sounds slightly better than my Holo Red streamer (with Volumio).
Positives: very good sound, superb finish, real plug & play (also with USB)
Negatives: extremely angle-sensitive remote with strange formed back panel, doesn’t read CD after switching from USB to CD input (needs restart), a bit shallow grip on the lid for bigger hands
M B.
AUDIOPHONICS HPA-S450ET Power Amplifier Class D Stereo Purifi 1ET6525SA 2x450W 4 Ohm The Audiophonics HPA-S450ET power amplifier is based on a Class D architecture, using a pair of Purifi 1ET6525SA amplification modules, a Hypex SMPS1200A400 power supply and an...
Happy
I'll cautiously give this five stars. Replacing an old Marantz SM-80, this amplifier is astonishing, albeit only with room correction. On the one hand the Purifi controls the speakers much better than my old amp. The in-room loudspeaker response is measurably flat to within +/- 2dB over most of the range. This was not the case before. On the other hand there is a massive, one octave wide, almost 12dB bass bump, peaking at 80Hz. This may well be down to my speakers and their positioning at only 10 inches from the wall. However this effect is more pronounced than it was with my old amp, itself no slouch in the bass department. I ironed this out with room correction EQ, which turned out essential for my living situation.
That said, the precision and instrumental separation this amp wrings from my 30-year old Polk (not KEF) LS50 speakers has redefined what I thought those speakers were capable of. This amp is in a different league. The ability to hear into a recording now rivals that of my planar magnetic headphones. At the same time I find it less fatiguing than my old amp. It also performs much more evenly across my record collection. Records that previously sounded good still do, but the Purifi tends to bring up muddy and/or complex recordings to a similar standard. That's a big win.
If there is a downside, it's that on some recordings I find snare drums, and raspy sounds in general, a little too prominent. However that may be due to an interaction with my speakers or with the ability to better single out instruments in the mix, including drum kits and tambourines. The emphasis is that this applies to _some_ recordings only.
Coming from a 30-year-old amp, I of course find the value and performance of the Purifi hard to judge against it's peers, but I will say that it runs cool, Audiophonics' build quality seems good, the connectors appear of high quality, and the amp was well packaged and arrived on time. That said, while the power switch is satisfying and includes a ~2s relay delay, I can confirm the slight power on pop, more like a static click in the speakers, noted by another customer. It happens about a second after the relay engages the amp. There is also a small amount of coil whine, emanating from the amp while turned on, though only audible from a distance of about 1m or less while the house is quiet, at night.
Julien V.
Petit mais costaud
Acheté pour relier le décodeur TV Orange en SPIF pour essayer d'avoir un meilleur son.... et il le fait très bien.
La connexion en BT est très bonne aussi pour juste streamer vite fait de la musique depuis le tel ou l'ordi quand le streamer est pas dispo.
Le DAC est très bon et la définition détaillé. Le niveau de sortie est assez haut.
Frederic L.
Excellent rapport qualite/prix
Belle finition, 2 vis pour un contact sur et stable, et livrees avec gaines retractables. Que demander de plusc?!
Frederic L.
Tres satisfait
Gros diametre mais relativement souple, facile a denuder. Tres satisfait du rendu sonore avec ampli Primare i35 et enceintes B&W704 (neutre, dynamique, precis. ....). Pas de comparaison avec d'autres cables a l'aveugle.
Frederic L.
AUDIOPHONICS Heat Shrink Tubing 3:1 Ø18mm Black (x2) This set of 2 black heat-shrinkable sleeves allows you to offer your cables an excellent finish with a clean result. The Audiophonics logo is affixed to the sheath.
Utilises avec cable HP Canare 2F11S. Mise en oeuvre facile, la gaine se retracte rapidement et reste stable dans le temps. Permert d'obtenir une finition de cable tres propre.
David S.
Headphone Balanced Cable Jack 3.5mm to 2x Jack 3.5mm OCC Copper Silver Plated 3m This headphone cable features one balanced 3.5mm stereo jack connector and two balanced 3.5mm jack connectors. The cable uses two OCC copper conductors and two...
TOP
Fait le taf pour remplacer le câble trop court du casque HIFIMAN EDITION XS. Un grand gain en qualité également par rapport au câble d'origine. (Il faut quand même qu'on m'explique la signification de symétrique pour un câble casque. Les normes étant bien faites, le + et le - se retrouvent quand même au bon endroit à droite et à gauche.)
David S.
rien à redire
OK pour le prix, c'est surement difficile de trouver mieux.
Casque pas tout à fait neutre à mon avis, mais tous les détails sont là et très bien pour une écoute au casque occasionnelle, car il est un peu lourd. Câble de qualité moyenne et ridiculement court pour mes besoins (95 cm jusqu'à la séparation des câbles) qui gagne à être remplacé par un plus long et plus qualitatif. Bizarrement il passe mieux sur un ampli casque à base de 6922 équipé avec des 6N23P-EV que sur mon HA-B6120.
THIBAUT M.
Top - Résultat très satisfaisant
Installé sur PI 4 B et alimentation IFI AUDIO IPOWER MK2 pour l'ensemble, je stream du Hight Res sur Qobuz avec Moode. Le résultat est très bon sur un ampli atoll et enceintes B&W, très large scène sonore, détails impressionnants pour le prix. A moins de 250€ l'ensemble, on concurrence des lecteurs réseaux 2 à 3 fois le prix sans problème. Bravo audiophonic pour ce matériel.
Martin B.
TOPPING A50 III Headphone Amplifier NFCA Silver With its A50 III headphone amplifier, Topping unveils a compact, high-performance device. It maintains the features of its predecessor, with improvements such as a 3-level gain...
Very nice and "powerful"
Driving a pair of Dan Clark Noire XO with these via the balanced output. These are 13-ish Ohm planar magnetic headphones, so they draw quite a bit of power.
Thought I'd have to buy some expensive headphone amps to drive these, but the A50 III has no issues driving them. The amplifier gets a bit warm at best over long periods of listening with these.
Product also feels nice, it's a sleek slab of aluminum. Quite pretty actually.
And the volume knob is spaced nicely far apart from the headphone jacks so your fingers don't "collide" with the jacks (something many other amps get wrong).
Martin B.
Male Jack 6.35mm to Male Jack 6.35mm Stereo Cable Shielded Gold Plated 0.5m This double jack 6.35mm stereo cable features a pure copper core for maximum conductivity. The core is shielded by an aluminum foil combined with a copper alloy weave to ensure...
Working as advertized
Got two of these (L+R to connect audio interface to headphone amplifiers via balanced connection). Stuffed it into a place with some power cables. As expected, no interference noticeable.
Jérôme K.
Amplificateur xlr bien construit, chauffe légèrement.
Qualité sonore :
Timbre réaliste
Courbe de fréquence droite
Très dynamique
Images stéréo holographique
Grave profond et tendu
Rapidie , très bon sur les transitions, c’est pas un bourrin il c’est être nuancé il a de la matière.
Subjectif ont dirait un mix entre un nad pour le grave et atoll médium aiguës.
Comparer à un classe ab intégré :
Je parle de mes amplificateurs
Nad c3050, yamaha as2100,musical fidility m3si.roksan attessa.
Se sont d’excellents amplificateurs pour alimenter des petites colonnes ou enceintes étagères, pour des belles colonnes 2voie ou 3 voies
Il bat mes autres amplifications en écoute normal plus de dynamique grave mieux tenue meilleure transition grâce a sa grande puissance, mais pour moins 500€ franchement je regrette d’avoir acheté autant de classe ab pour rien j’étais jamais satisfait il manquait toujours quelques chose.
Niveau enceinte :
sonus faber sonetto 8g2, dynaudio evok 50 , et large bande altec 420. Source teac nt 503 .
Peter S.
AUDIOPHONICS STEALTH XLR Interconnect Cable XLR-XLR OCC Copper 0.75m (Pair) The Audiophonics Stealth range offers a selection of particularly high-performance, affordable cables, hand-assembled in our workshops in France. The Audiophonics Stealth XLR...
Inspires confidence
I needed shorter XLR cables, and wanted something of excellent quality without breaking the bank. These cables replaced some cables that cost me some 500 € several years ago. To be honest, life is too short to worry about any minor difference, and this pair do the job perfectly well.
Peter S.
ATAUDIO L-4E6S Male USB-A to Male USB-B Cable Gold Plated OFC Copper 0.75m This ATAUDIO USB cable offers both high quality and luxurious design. It consists of a four conductor structure made of braided OFC 6N copper with excellent conductivity,...
A USB cable, what else ?
So hard to describe what this may or may not bring to the sound of a hifi system. I couldn't say, let's say it doesn't do any harm, and that's a good thing.
Very reasonable price, for a beautifully presented product.
Thomas H.
THINKYA DVR108 CD Player DAC ES9038Q2M 32bit 768kHz DSD512 Bluetooth 5.1 Thinkya's DRV108 is a full-featured CD player and DAC that uses a TMC688 processor and ES9038Q2M DAC chip to upsample CDs up to PCM 384kHz and convert digital signals up to PCM...
It is a great product for a small price.
Frank j.
reclocker
reclocker toslink optical
gives 10% better sound
its ok product
Pascal J.
AUDIOPHONICS PSU S4-HP Linear Power supply Module DC Micrel29752 The Audiophonics PSU S4-HP power supply module has been designed to provide a clean DC voltage supply to an amplifier or other audio circuit. Its particularly rigorous design,...
Très très bonne alimentation
Associée à un trafo toroïdal en cuve Talema 80va elle alimente Mon Keces Ebravo.
C'est parfait et procure une
amélioration évidente comparée à celle d'origine ou même une brique Meanwell qualité médical.
Pascal J.
KECES EBRAVO Streamer WiFi UPnP DLNA Bluetooth 24bit 192kHz The Keces Ebravo is a versatile audio streamer designed to deliver a high-quality music listening experience. Compatible with many popular streaming services such as Spotify,...
Aucun avis ????
Une brique noire avec un œil bleu qui n'a l'air de rien,
sans prétention, un peu chère comparée à la surenchère de bien d'autres. Mais quelle brique !! 1) installation très facile, appli 4stream parfaite, aucun problème. Pas de bidouille, un nas Sinology pour la musitèque.
2) raccordé à mon Sonifex adda2 le son qui me convient de vrais et bonnes
basses, les médiums et aigues en bonne équilibre
avec les précédentes, très bien timbré, un son analogique. Le peu de tests
accessibles sur le net ne vous mentent pas c'est de la balle.
3) à l'intérieur pas grand chose : pas fpga de la mort,
pas d'horloge venue de l'espace. Juste la bonne pièce au bon endroit et beaucoup d'intelligence.
Bravo aux concepteurs
m
Mattias B.
ASCILAB F6B Bookshelf Speakers 125W 4 Ohm 84dB Black (Pair) The AsciLab F6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ aluminum dome tweeter...
Absolutely amazing
