iouri C.
Au final déçu.
Antoine S.
CD Player Upgrader
Michel R.
Parfait pour mon usage
Stephane N.
Spikes M4 Aluminum Rubber Ø31x21mm Silver (Unit) This decoupling tip is made of Aluminium. It is surrounded by a removable rubber ring. The combination of these two materials allows the absorption of different frequencies. The...
Très bon produit. Utilises sous un DAC ATOLL, il font le boulot !
jouri k.
this is it :)
Packaging and shipping were superb. I was really curious how these expensive clocks would hold up. They don't let down. Much better than the accusillicon. Treble/mid/bass took a giant leap.
Imaging way better :)
It is so good, so happy to have high-end sound in my living room.
jouri k.
IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 5V The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply...
unexpected!
This power supply is a great upgrade. Also if you have the previous version. Which i have. Thus I was very sceptical about any noticeable upgrade. But this is a big one!
SERGE B.
Excellente qualité
Excellente fiche IEC qui vaut bien son prix. Permet de confectionner des câbles d'excellente qualité audio. Combinée à une prise Schuko ELECAUDIO PS-24RA et à un câble 3 X 1,5 blindé Elecaudio j'ai obtenu une différence de qualité nettement audible par rapport au câble d'origine. Surprenant mais la dépense valait la peine !
SERGE B.
Bonne prise IEC avec contacts en cuivre
SERGE B.
Excellente prise schuko coudée
Excellente conception et construction.
Parfaite pour fabriquer des câbles d'alimentation de qualité. Nettement supérieure aux prises BALS qui coûtent près de 5 fois moins. Mais la différence à l'écoute est stupéfiante...
Miutescu E.
AIYIMA T8 Tube Preamplifier 6N3 Headphone Amplifier MAX9722 DAC ES9018K2M Bluetooth 5.0 24bit 96kHz With the T8, Aiyima offers a versatile device that is a tube preamplifier, headphone amplifier and DAC at a very affordable price. Its preamplifier stage uses a 6N3 tube, which...
Perfect , but ...
It's really awesome preamp / dac . I use it in my P sistem - Dac Aiyima T8 and straight to my power amp Emotiva BasX A300 . Everything is beautiful, sound is excellent , but be aware that the output RCA is weak , like 1.9 V. So if you want more volume you really have to crank it up to allmost max volume from Dac . Except this thing, the preamp is really really good sounding and works like a charm
Patricio C.
Excelente!
Antes de probar este cable, estaba usando uno de Gustard (cable azul) y conectores Neutrik... fué poner el obsidian y el cambio fue brutal e instantáneo... ya no recuerdo si previamente lo dejé sonar por 20 horas a modo calentamiento..... pero fué como quitar un velo en la música, mucha mas transparencia, detalle y un sonido mas abierto sin ser brillante ni perder musicalidad o cuerpo en la zona grave... sin duda un excelente cable.
Alain M.
Protection modules for stereo speakers 12V 16A (Pair) This double mono protection module consisting of two cards will allow you to properly protect your speakers.
Problème de fonctionnement avec carte ampli SSD 3E Audio
J'étais assez content de découvrir ce module de protection qui permettait entre autre de simplifier la conception du boitier qui allait accueillir une carte ampli SSD 3E Audio et une alimentation SMPS Connex de 300W/36V.
une fois les connections réalisées je me suis aperçu qu'à la mise sous tension une petite diode rouge intitulée "Fault" s'allumait sur la carte 3E. Après investigation je me suis rendu compte qu’il ne faut pas alimenter ces 2 modules avec la même alimentation car de ce fait, les masses sont alors reliées. Ce problème n’existe probablement pas avec un amplificateur stéréo dont les masses des 2 canaux sont reliées notamment ceux faisant appel à des alimentations symétriques.
MUNDORF F71 Varnished Wire Ferrite Core Self 0.71mm 2.2mH The F-Series combines small size and low price, making it an excellent value for money for filtering woofers, or any other application requiring high inductance and/or low...
Très bien.
Belle qualité de self, livraison éclair.
Super.
J'utilise ces condensateurs en parallèle pour mes filtrages HP.
Bravo Audiophonics pour la livraison toujours express.
MUNDORF E-CAP ECAP100 (BR100) RAW Capacitor 100VDC 32VAC 22μF Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not suitable for space or cost...
Super.
J'utilise ces condensateurs en parallèle pour mes filtres HP.
Excellent.
Excellente self de filtrage, y compris pour montage en série.
Que ferait-on sans Audiophonics et sa livraison express ?
Excellent.
Excellent.
JANTZEN AUDIO 000-0837 4N Copper Air Core Wire Coil 20AWG 0.92mH The Jantzen Audio Air Core Wire Coil is made of a very pure copper wire, offering distortion-free inductance. It will therefore be suitable for all audio applications. The coil...
Excellent.
Jean-Pierre D.
Très bonne amélioration comparé à l’HPA-S400 ET
Utilisé avec un pré-ampli Gustard H26, doux et neutre avec deux lecteurs DAC, un Neo Alpha avec un ESS 9038 pro et un Lumin D2 avec un DAC Wolfson WM 8741, couplé à des enceintes colonnes Triangle Signature Delta. Je trouve, au fil des premières écoutes sur ces deux lecteurs, la restitution juste et naturelle, c’est à la fois neutre et musical. Les timbres des voix sont réalistes et pas accentués. En comparaison avec l’HPA-S400 ET, il y a une peu plus de puissance perceptible, les basses sont supérieures, pour le reste il y a davantage d’ouverture, de micro-détails (à ce niveau évident), cela reste la même signature sonore propre aux Purifi d’Audiophonic, neutre, musicale avec absence de toute agressivité dans le haut médium et l’aigu avec un profil plutôt doux.
J’avais hésité avec le modèle récent 750, le prix de celui-ci m’a décidé ainsi que le retour du conseil technique d’Audiophonic, ce modèle largement suffisant pour mon usage, notamment au regard de mon préampli actuel (pas mal, mais pas exceptionnel) et de mon espace d’écoute. Pour conclure, le 500 me semble plus intéressant que le 400 malgré un prix un peu plus élevé.
Rudy C.
Rapport qualité/prix imbattable !
Très correct pour le tarif pratiqué
Marc J.
Speaker Terminals 24k Gold Plated Ø19mm x 50mm (Pair) These speaker terminal blocks offer excellent design quality at an affordable price. Their contacts are made of 24k gold-plated copper alloy, ensuring...
Qualité correct...mais pas en cuivre !
Contrairement à ce qui est annoncé ces borniers sont en laiton, absolument pas en cuivre.
Qualité correct pour le prix néanmoins.
Claude P.
SMSL M300 SE DAC Headphone Amplifier 2x CS43131 XMOS Dual Clock NDK Bluetooth 5.0 32bit 768kHz DSD256 MQA The SMSL M300 is a powerful and compact DAC in an atypical format. Integrating high quality components, it is the perfect ally to offer your HiFi audio system a...
Facteur de forme pratique et mignon, fonctionne très bien et délivre un beau son riche et dynamique.
J'apprécie aussi le fait qu'il démarre tout seul dès que la tension d'alimentation (+5v) lui est appliquée et qu'il ne génère aucun cloc à cette occasion, ni à l'extinction d'ailleurs (très bien pour mes enceintes actives Adam Pro).
Par contre, l'extinction (programmable) et l'intensité (variable) de l'écran incorporé sont incohérentes, des fois ça marche, des fois non, et c'est d'autant plus énervant que j'ai deux exemplaires accolés qui ne réagissent absolument pas de la même manière,
Claude P.
SMSL B2 DAC Bluetooth 5.1 Receiver CS43131 QCC5125 aptX HD LDAC The SMSL B2 is a small, practical, affordable and efficient DAC and Bluetooth receiver. It's based on a CS43131 digital-to-analog conversion chip and a Qualcomm QCC5125...
Testé ce jour
Fonctionne bien après un appairage rapide et sans histoire mais mériterait d'avoir un réglage d'intensité sur l'écran et surtout est arrivé avec le port optique HS (Led rouge éteinte).
Ayant le choix entre optique et coax, j'ai heureusement pu prendre cette solution.
Petit défaut de contrôle en fin de chaine ??
Contactez mes collaborateurs du SAV via les formulaires du site, il est anormal que toutes les sorties ne soient pas fonctionnelles en sortie de boite.
Ils feront rapidement le nécessaire.
Igor M.
Cables
I'm really impressed with the price to performance ratio of this cable. If you are looking for open and airy sounding cable with really good bass definition this is the must try cable.
Dmitrijs R.
Simple, good sounding amp
The MOS-120 is a very nice amp, I like it a lot. Sounds quite warm, without substantial coloration - all as per my taste. The build quality is also great. I would recommend it to anyone, who searches for a very simple, compact, single input amplifier.
Louis M.
manque de definition et d'equilibre
de la puissance, du volume, mais quid de la definition et de la musique ?
pas de la hifi...
Louis M.
NEUTRIK NC3MX-BAG 3 Way Male XLR Connector Silver Plated Ø8mm (Unit) This 3-pin XLR male Neutrik NC3MX-BAG connector allows quick and easy assembly, consisting of only 4 pieces and no screws. It benefits from a compact design, a sturdy Zinc shell...
bonne prise
parfait contact, pas de defaut
Louis M.
neutre mmais...
l'appareil est solide et presente bien, il n'apporte pas de coloration
mais...le bouton est lisse et il ne se manoeuvre pas facilement tant il manque de grip...
Louis M.
tres bonne prise jack, fontionnement totalement neutre
Louis M.
cable qui possede la caracteristique la plus interressante : il se fait oublier...
neutre et bien construit
Gautier C.
SOMMERCABLE EPILOGUE Modulation Cable Male XLR to Female XLR 2m (Pair) This high quality XLR cable pair consists of a Sommercable Epilogue modulation cable and Neutrik connectors, specially designed for optimal signal transmission. The cable...
Top, livraison rapide, bon produit
Un standard le Sommer XLR en quad. Très bon câble
Angelo B.
CANARE STAR QUAD L-4E6S RCA cable (Pair) 1m
Excellent quality RCA cables and made with great precision. Thanks to David and Madeleine.
EXCELLENT RAPPORT MUSICALITE / PRIX
Mon avis sur ce petit MOS 120 se réfère à une expérience personnelle de quarante ans où j’ai possédé pas moins d’une dizaine d’amplificateurs de classes A, AB et plus récemment de classe D. Le MOS 120 a une sonorité typique des bons amplis de classe AB à base de Mosfet, les timbres sont pleins, avec un grain enviable, la définition est bonne sur tout le spectre, l’image stéréo est exceptionnelle pour un produit proposé à ce prix, panoramique, vaste dans les trois dimensions de l’espace. Toutefois par rapport aux amplis de classe D, ce MOS 120 ne possède pas la même franchise, sa dynamique est plus sage et cela est assez regrettable pour l’expressivité. Le MOS 120 ne possède pas non plus une transparence aussi poussée que la plupart des classes D, en particulier si on la compare à l’étonnant Aiyima A07 max, il subsiste en effet un très léger voile, ‘scorie’ typique des classes AB quels qu’en soient leurs prix. La restitution est assez satinée voire mate ce qui ne plaira pas à tout le monde mais confère une douceur souvent appréciée. Bref, un très bon ampli de classe AB avec des limitations typiques de cette classe. Pour ma part je trouve que les bons amplis de classe D surpassent les classes AB en matière de transparence et de dynamique et font jeu égal en image stéréo.
Jerome g.
FOSI AUDIO V3-48V Stereo Class D Amplifier TPA3255 2x225W 4 Ohm The V3 from Fosi Audio is a compact and powerful amplifier at a very affordable price. Despite its simplicity, the V3 amplifier uses high-quality audiophile components such as a...
belle surprise
je cherchais un ampli pour alimenter une paire de vénérables ditton 66 , sachant que la classe D a cette singularité d'y parvenir sans se ruiner .
l'essai est transformé ; les 30 cm des graves sont tenus , le MD 500 des ditton permet aux médiums de s'exprimer avec amplitude mais sans excès et pas de brillance dans les aigus ;
ça fonctionne déjà fort bien avec les aop 5532 d'origine
testé avec les oracles 2.2 l'équilibre des registres en maintenu avec une touche de douceur
les muses 02 respectent toujours l'équilibre graves méduims aigus et amènent un élargissement de la scène
superbe stéréo , excellente dynamique
je reste avec les muses 02
je n'ai pas fait l'essai avec mes klipsch rf82 , j'ai peur que ça brille un peu dans le haut , mais avec les ditton et toutes autres enceintes de ce type le fosi doit fonctionner à merveille
mes sources : airdac nuforce + fichiers flac du pc / platine cd technics sl pg 420
bref un excellent rapport qualité prix pour ceux qui peuvent se contenter d'une seule entrée analogique
j'envisage l'ajout d'un dac XDUOO XQ 50 pro 2 ou une aiyima T8 pour étendre la connectique
Romuald K.
Digital Interface USB Amanero / Bluetooth 5.0 to AES / SPDIF / I2S 32bit 192kHz DoP128 This small, high-performance digital interface takes a Bluetooth 5.0 or USB signal as input and then outputs it in I2S (via HDMI), AES, Toslink Optics or Coaxial. The Bluetooth...
Working well
Using it for 1 week only, tried I2S and TOSLINK output on headphone DAC/Amp with Foobar and Tidal on Win11. Driver installation without problems, output to the interface showing on the list. Sound is very good, clean and spacious. On few occassions short noise when PC loads a big piece of software, most likely nothing to do with the interface itself. Overall - too short experience to be decisive, but so far so good. With driver installed the interface works out of the box, provides multiple output options, everything as described on Audiophonics site.
Laurent D.
Bien mais vis fragiles
Boîtier abordable, facile à usiner, dans lequel il est très pratique d’installer des circuits et des connecteurs.
Inconvénient : les vis latérales, plantées dans la tôle d’aluminium des façades, tiennent très mal. Si on les serre un peu fort, ou qu’on les prend un peu de travers, on flingue tout de suite le pas de vis. La solution consiste à remplacer les vis d’origine par de courts boulons M2,5 ou M3 en collant l’écrou derrière à la super glue.
Dommage également que ce format de boîtier ne soit plus commercialisé en hauteur 40 mm, ce qui était bien utile pour des montages compacts.
Pierre S.
Insulated Female Blade Terminal Gold Plated Ø2.8mm (x10) These female terminals allow fast and efficient connections. Its contacts are gold plated to ensure good conductivity and resistance to oxidation. The conductor is simply...
J'ai cherché longtemps des cosses efficacement clippables sur les picots d'alimentation des transducteurs SEAS (tweeters, woofers) et celles-ci font parfaitement le job.
Harry H.
VIBORG XM203AG Male XLR Connector Pure Silver PTFE Ø11mm Black (Unit) Viborg's XM203AG is a premium XLR male connector, using pure silver contacts to provide maximum conductivity. It also features PTFE insulation and a rugged aluminum body with...
super connectors
see my review from the female connector.
Suberp!!
Harry H.
VIBORG XF203AG Female XLR Connector Pure Silver PTFE Ø11mm Red (Unit) Viborg's XM203AG is a premium XLR female connector, using pure silver contacts to provide maximum conductivity. It also features PTFE insulation and a rugged aluminum body with...
Very best XLR connector
I have tried a lot of XLR connectors but this is the very best.
Combined with the Neotech nemoi 1220 rectangular silver cable it is a marvellous combination. In our friend audio group we compared it with timber cable with Furutech connectors (1250,= euro) but the Neotech with Viborg pure silver contacts was the absolute winner
Francis B.
Il dépasse largement, ce qui est étonnant déjà, le HPA-S500ET version ampli stéréo que j'ai apprécié beaucoup pendant quelques mois. Maintenant passé sur les voix surround G et D.
Avec sa propre alimentation Hypex on a un sytème double mono incroyable.
Il est plus subtile. On entend clairement les niveaux de basses, les détails fourmillent. A faible volume les détails sont présents à fort volume pas de distortion. Un régale.
On a non seulement un sytème en HC formidable pour les dynamiques importantes dans les flms en RCA (vraiment un apport important en front, surround et back avec les audiphonics le son est clair et ne casse pas les oreilles même avec des transtoires complexes alors que j'ai le NAD T778 déjà réputé pour sa dynamique sur tous les canaux) et en stéréo XLR sur un bon lecteur réseau comme le UD-701 TEAC un son merveilleux pas du tout fatiguant. Pour un prix vraiment raisonnable et un très bon SAV et surtout de bons conseils pour optimiser l'installation.
Avec un HPA-S400ET également pour les surround back G et D on obtient des détails impressionants sur des films surround sans avoir les oreiles qui vrillent même à fort volume c'est génial. Grand merci à Audiophonics pour nous permettre d'accéder à ce niveau de son.
Yannis G.
Nice choice
After a SU6 dac that unfortunately broke irreparably at 15 months, I decided to proceed with the purchase of this dac since the various reviewers said good things.
Well it's excellent, more balanced, wide, airy and accurate, with excellent clarity for the money always, dynamic at full and very accurate. It looks and is superior in quality to the previous one, heavier with a better chip I think to the 9038.
It has been combined with a SMSL amplifier DA-9 which is powerful with good currents and 2 Polk R100 bookshelf speakers for desktop use (optical connect with pc).
I'm happy and haven't found a flaw yet.
Audiophonics 10/10 at all, order and shipping!!!
Dario G.
Dégraissé bien les basses fréquences, d'où une dynamique bien supérieure.
Un peu juste en terme de recommandation du poids pour mes enceintes mais le retour en arrière n' est pas envisageable !
Pour le prix, très bien.
NEOTECH NEVD-1001 Coaxial Cable 75 Ohm Pure Silver OCC Quad Shield Ø7.6mm The Neotech cable from the NEVD series has been carefully designed specifically for the transmission of digital audio signals. The main characteristic of digital audio signals...
Excellent câble 75 0hms
Grande amélioration par rapport à mon ancien câble Canare, qui demeure un excellent rapport qualité-prix. Le son est plus transparent, plus doux, plus vrai, avec une image large et profonde.
Francis B.
Et pour un prix raisonnable...dans la philosophie Audiphonics.
Albin A.
DENAFRIPS TERMINATOR II 12TH DAC R2R NOS Balanced 24bit 1536kHz DSD1024 Silver The Denafrips Terminator II 12Th is a high-performance, balanced R2R NOS DAC capable of delivering incredibly pure, rich sound. It benefits from an uncompromising design,...
Super DAC Ultime
Vraiment bluffant !
Rendu véritablement analogique
Signature sonore plus chaud mais dans le très bon sens du terme
S'écoute pendant des heures avec le plein de détails, timbres, ouverture sonore etc (à voir ce que cela donne associé avec le DCC mais franchement déjà comme ça c'est excellent)
Ne regrette pas un instant mon achat
Emmanuel p.
très bon connecteur
réglage de l'angle par vis intelligent, permet de très facilement passer un gros cable
philippe L.
SMSL A200 Class D Amplifier Infineon USB HDMI ARC Bluetooth 5.0 2x70W 4 ohm The SMSL A200 amplifier is a Class D amplifier incorporating two Infineon MA12070 amplifier chips for output power of up to 2x 70W @ 4 ohm. Versatile and compact, the A200...
Attention à la description qui est erronée sur la sortie Sub.
Pas de sortie Sub sur ce modèle. Je me permet de le rajouter en commentaire pour les potentiels acheteurs, mon mail à audiophonics pour corriger l'erreur étant resté à ce jour sans effet.
Cette erreur provient de la fiche fabricant. nous prenons contact avec lui et corrigeons au plus vite.
Maxime R.
FX-AUDIO L07 Class D Amplifier Infineon MA5332MS 2x 200W 4 Ohm / 1x 400W BTL 8 Ohm The FX-Audio L07 amplifier completes the series, following in the footsteps of the R07 headphone amplifier and the DS07 DAC. Featuring the same form factor, it is particularly...
Très bon achat
Alors impression des premières secondes : c'est boomy !
Les basses sont clairement mises en avant.
Mais l'équilibre général du spectre sonore reste préservé, et c'est très important (je ne suis pas trop porté sur les basses). Et puis elles sont bien définies, assez sèches, ne bavent pas. On s'en rend compte sur les morceaux riches.
Les médiums sont excellents. Nullement étouffés par les basses, ils demeurent au premier plan. Chaleureux, vivants, pas fatiguants. Les hauts particulièrement. En opéra, les sopranos s'écoutent plein volume sans fatigue.
Les hautes fréquences passent bien également. Saxophones et violons sont soyeux, bien définis, pas de brillance.
L'ensemble de l'écoute ne manque pas de détails. Sur Whole outta love de Led Zepp il ne manque rien.
Il parvient également à sublimer les morceaux mal enregistrés, et ça c'est éloquent je pense.
Mais éventuellement le seul petit reproche c'est un léger manque de délié sur la restitution quand la scène est très chargée.
Mais bon, je sors d'un Topping PA5 qui excellait dans le domaine je trouve...
Bref : un ampli très musclé (on ressent bien la réserve de watts), généreux sur les basses sans déséquilibrer le spectre sonore, avec du détail et une scène stéréo large, mais un chouilla en retrait sur le délié lors d'informations sonores saturées.
Il vaut largement son prix cependant.
J'espère que mon charabia vous aura été intelligible
Grégoire Z.
Tarif très attractif et produit de qualité.
Florent L.
Regulateurs Parfait pour reglage volume du preamplie
Parfait pour réglage du volume de mon pre amplie phono, gros soucis c'est que ça bourdonne très fort si on touche les régulateur mais si on laisse comme c'est, c'est parfait.
Mats L.
Amazing cable!
I was very curious about this cable since it got such good reviews.
Bought it to test against my current Furutech FS Alpha cable.
I'm shocked how good it sounds, absolutely amazing!!
My furutech FS Alpha sounds a little warmer BUT not nearly as high resolution as LUDIC SILENOS!
LUDIC SILENOS is much tighter in the bass and more accurate than my Furutech FS Alpha,
I also think that the midrange is clearer and much more open !
It sounds very neutral and high resolution with a large 3D soundstage, yes it has everything you could wish for!
will probably replace the internal wiring in my speakers in the future as it will surely make the sound even better.
GUSTARD N18 PRO Network Switch 5x RJ45 1x Optical Fiber Black The Gustard N18 PRO network switch features 5 RJ45 Ethernet ports as well as an SFP fiber optic connector and a BNC connector for external 10Mhz clock. The RJ45 Ethernet ports...
La suite
A mon avis EtherREGEN plus bonne alimentation+ bonne horloge supérieur mais plus cher aussi vu le Gustard
