Dominique R.
Hautement recommandé
Paulo D.
Paulo D.
Pas fiables
Bonne représentation musicale, un peu grasse quand même mais agréable. Le gros problème est la durée de vie des tubes ! Un an ,...
Edmond S.
beau produit
très facile a installer, connections massives. beau produit
Dimitri D.
Excellent value!
Have always prefered solid core cables (starting many years ago with low cost power cables that even out performed many a "costly audiophile" cables ) and these Jantzen cables have to be one of the best hi-fi bargains around, providing neutral and naturally dynamic sound transmission! Should also add the web site and service is also excellent. Highly recommended!
Guus G.
Good banana tube terminators
They are well made and have some springiness to them, so they return to their original form quite well (after unplugging). Altough I soldered them initially with silver solder I noticed a performance drop so quickly unsoldered them and now use them pinched to the cable, which in my opinion deliveres a better sound quality.
Great service as always from Audiophonics.
Guus G.
Great value for money!
I orderd the AC-14se mk2 since I previously ordered the AC-14 and was amazed how a powercable can make that much difference.
The AC-14 gave me the confidence to invest yet a bit more and the AC-14se mk2 delivers. Not as much gain the AC-14 made over the stock cable but enough to be content. Great service from Audiophonics as always.
Guus G.
Disappointed
I bought the viablue sc-2 speaker cable as un upgrade to my 30 years old Monitor Cobra Cable 4mm. After a few days I switched back to my old cables as I was not convinced the ViaBlue sound better. On switching back I found my old cables are are better in revealing details across the spectrum. I tested some more playing audio test tones from Qobuz. The ViaBlue were not able to reproduce the 30 Hz tone but my old cables were rock solid. Some critical music listning also revealed less spatial information with the ViaBlue.
The cable is sturdy yet flexible. No complaints in that region. Sound wise however they are a disappointment.
David S.
top
Premières écoutes : Entre mon ampli Lector audio ZXT70 et mes enceintes Récital Define HEFA enterre le Mogami W3103 loin derrière.
Câbles très transparent, beaucoup plus de détails et de profondeur sur tout le spectre, les petites sibilances sur certains enregistrements difficiles ont disparues. Le couple cuivre/argent semble être adapté à mon système.
"C’est comme si on avait enlevé un bouchon. "
À recommander!
(du moins chez moi)
Eric V.
Sans réserve
Après plusieurs jours d'utilisation, ce dac remplit parfaitement son rôle, de plus sa construction et les composants utilisés sont de qualité.
A l'écoute, après quelques heures, il procure une écoute détaillée et précise ne mettant pas en avant un registre particulier (grave-aigu). La scène sonore est plutôt large et profonde. Sans être démonstratif, ce dac est assez dynamique.
Bref, ce Topping E30 II est à mon sens une réussite, compte tenu de son budget ! Audiophonics, comme souvent, a sélectionné un excellent produit. Bravo.
Jean B.
Cher, pour ce que c'est, mais bien construit.
Il faut mettre beaucoup plus cher pour avoir un vrai produit d'isolation.
Parfait sous de grosses platines vinyles ou des enceintes.
Jean
Jean B.
Très bien, plus de bruit lors des connexions à chaud
Dire que c'est mieux qu'une autre connectique moins cher, je ne sais pas, mais au moins on peut connecter à chaud sans risque.
Belle construction, à voir comment ça résiste sur le long terme.
Mais, de manière générale, je suis revenu des connectiques très haut de gamme genre Rhodium qui ne résiste pas aux conditions atmosphériques (humidité) du climat Marseillais par exemple. Ca flatte l'égo à l'achat et puis quelques années plus tard, l'état de la connectique (sans l'avoir branchée/débranchée outre mesure) laisse un gout amer, on a un peu l'impression qu'on a été le parfait gogo du marketing idiophile.
Je n'utilise donc plus que du câblage/connectiques pro, c'est moins cher, surtout si ça ne dure pas dans le temps et franchement, à l'écoute, ça fonctionne très bien.
Jean
Jean B.
DIN Pseudo Star QUAD
Parfait pour remplacer vos câbles DIN d'origine y compris les petits Naim.
Belle ouverture, pas d'agressivité.
Un très bon câble à prix démocratique.
Jean
Jean B.
Câblage platine vinyle
Parfait pour remplacer le câblage d'origine, souvent médiocre de votre platine vinyle.
Jean
Jean B.
DAYTON AUDIO DAEX32EP-4 Speaker Driver Exciter Bodyshaker Full Range 40W 4 Ohm Ø3.2cm Among the most advanced and precise vibrating speakers from DAYTON Audio with a generous 32mm diameter motor. An original speaker model that is reminiscent of an audio...
DML
Parfait pour de petits panneaux DML.
Conseil perso, faites des panneaux légers, de faible épaisseurs et très rigides, n'hésitez pas mélanger les matériaux. Et de les utiliser avec des amplis avec contre-réaction en courant, y compris de petits LM1875.
Résultats étonnant pour le prix et l'encombrement.
Jean
Jean B.
FONCTIONNE
Commande expédiée très rapidement, bien emballé, produit fonctionne mais chauffe trop par rapport à la tension d'alimentation.
J'ai acheté ce kit en dépannage, car il me fallait un ampli très rapidement. J'ai construit plusieurs petits ampli à base de LM1875, avec la même tension d'alimentation et le schéma standard de la datasheet, les LM1875 ne chauffent pas.
Pour être précis, à +/- 12V DC (après le pont de diodes, mesuré sur les capas d'alim) les LM1875 délivrent environ 10W/4 Ohms et ne devraient pas chauffer. Avec ce kit, ce n'est pas le cas, les LM1875 sont tout de suite chaud, prévoir un bon radiateur, mais ce que ça indique, c'est qu'il est probable que l'ampli oscille...
Jean
Bruno M.
Bon produit mais en-dessous d'un DAC même plus ancien avec puce AKM
Le DAC Topping E50 n'est pas mauvais, mais il reste en-deçà du DAC que je possédais déjà (Aune S6 équipé d'une puce AKM), L'élément manquant est la gestion des trémolos et des vibratos en particulier sur la voix ou la flûte traversière, insuffisamment fidèle avec ce DAC. J'envisage prochainement de commander un DAC Topping E70 Velvet qui lui est équipé d'une puce AKM me permettant de retrouver la musicalité manquante. Pour le reste, le dac Topping E50 est un bon DAC, avec une reproduction correcte des extrêmes basses aux quasi-ultrasons, sans distorsion repérable, même à haut niveau (proche du 0db, contrairement à ce que j'avais pu constater à haut niveau avec mon DAC précédent Aune S6 qui distorsionnait ponctuellement sur certaines hautes fréquences telles 13.7Khz bien avant d'avoir atteint le niveau maximum de 0db), Je suis donc en attente d'un changement de DAC et ne sait pas si je serais amené à utiliser mon Topping E50.
Charles R.
Marche plutôt bien.
Au cas ou vous galérez pour faire correctement reconnaître la carte par Windows même après 15000 installations des drivers :
AVANT d'y connecter le DSP
Branchez la carte à l'ordinateur, ouvrez sigmaStudio et établissez la connexion .
Après, ça fonctionne nikel.
Je ne met que 4 étoiles car sauf erreur de ma part, ce détail n'est mentionné dans aucune doc officielle de la marque.
Didier G.
AUDIO BASTION REDLINE DAMPER Anti Vibration Damping Pads Aluminum / Silicone 41 x 17mm (Set x4) These stands for HiFi equipment and speakers effectively absorb the vibrations of your equipment. They are composed of a silicone pad, encased in a composite resin part, all...
Absorbeurs efficaces
Placés sous des enceintes bibliothèques, ces absorbeurs améliorent la restitution.
Produit bien fini et esthétique.
Didier G.
Remarquable streamer
Ce streamer surpasse mon ensemble Melco N100+Audio GD DI20 (Dac HOLO spring entrée I2S) en termes de transparence, de relief, et d'image.
L’OS fourni est performant mais Gentooplayer apporte un plus à l’écoute
L’utilisation en mode UPnP avec l’application Mconnect ne pose pas de difficultés.
Une notice est disponible sur le net (en anglais).
Edmond S.
Hi-fi
Tout simplement excellent en hi-fi. Bande passante, détails, précision. Le monobrin cuivre serti sur des fiches cuivre y est pour quelque chose
Pedro V.
Update on previous review
Just like to update my previous review were I incorrectly blamed QC issues on this cable. The problem I had was related to other things on my system that I have since fixed. The ELECAUDIO cable is great value for money.
Sebastien w.
Bon ampli
Bien construit et performant. Satisfait de mon achat. Reçu rapidement et bien emballé. Merci à audiophonics.
Alexander D.
DD TC28CPRO Male USB-C to 2x Female USB-C OTG Adapter This DD TC28 Pro adapter consists of a male USB-C connector as well as two female USB-C ports, one OTG compatible and the other dedicated to charging. The shell of the adapter...
Finally I can charge my device
Finally I can charge my device while my smartphone is connected on my dac
RCA Plug gold plated Ø8mm (Pair) Black These rca connectors are 24K gold plated for maximum conductivity and corrosion resistance. They accept cables with a maximum diameter of 8mm.
En force
Connecteurs de bonne facture avec un niveau de finition très sympa.
Soudure facile et musicalité d’un très bon niveau.
Mais attention, l’insertion sur les embases femelles est très dure avec un risque mécanique évident.
Dommage, car la réalisation de ces prises RCA est sérieuse, et avec un diamètre plus important de quelques dixièmes, elles seraient parfaites, surtout au prix qu’elles sont proposées.
A bon entendeur
Après rodage sonne vraiment bien
Par contre sur un système très transparent elles donnent la limite (ETI tellurium par exemple donne son musical transparent et précis )
Frédéric R.
Dual NO Light Switch 250VAC 15A Green This NO type switch has two luminous green switches, each with two positions. The mounting is snap-in type and is done simply with blade connectors or via a few welds. This...
Très bonne qualité, pas de jeu ou faux contact comme sur certains Interrupteurs bas de gamme.
lucien S.
aucun interet dans mon cas.
ne fonctionent pas pour moi avec en sortie un sony xm800 en hdmi sacd natif sur entre gustard x16 en i2s avec cette interface !!! a savoir......
Jerome A.
Très belle surprise, son fabuleux, excellent rapport qualité/prix
Etonnant de voir le grand nombre de messages élogieux sur cet ampli sur les forums, et le peu d'avis ici.
Après écoute, je partage l'ensemble des avis ici, et d'ailleurs, il n'est pas très design, mais le son... excellent.
Sans fioriture, ni télécommande, aucun gadgets inutiles, pas de marketing de revendeur audio souvent risible, non, mais entrée/sortie symétrique, composant de choix, il va droit au but, le plaisir.
Si vous vous moquez du look, que seul la qualité et le son vous importe, alors vous pouvez acheter les yeux fermés.
Il fonctionne à merveille avec mes casques, denon ah5200, hifiman edition xs, audeze lcd2, il va probablement devenir mon ampli principal.
Comme à l'accoutumé, envoi rapide & soigné de la part du vendeur.
Philippe S.
Monté avec iec 48 ag sur un câble furutech n55s et après une vingtaine d'heures de rodage, la musique sort comme je ne l'avais jamais entendu, cela fait un câble secteur à 700€ mais je trouve que l'investissement en vaut vraiment la peine.
ETI LINK BANANA Banana Plugs Gold Plated Tellurium Copper Ø9mm (Set x4) The ETI Link Banana plugs offer a very nice design quality, ensuring an excellent signal transmission. The contacts are made of gold-plated tellurium copper with a very good...
Musical
Rien a voir avec pangeo et autres qui rajoute des basses et autres la on écoute ce qu'il y a très musical avec de beaux timbres (si votre système en a )
Daniel n.
Excellent service!
I received items within a few days (to the US) but they had lots of dings but were still functional. I contacted Audiophonics and the situation was quickly resolved. I will definitely buy from Audiophonics again - thanks for the great service!
Rodolphe L.
SMPS800RE Power supply Module 800W +/-40V The switching power supply SMPS800RE is a very high efficiency model capable of developing a nominal power of 800 Watts in an extremely small footprint. This power supply is...
Fait le job !
Alimentation SMPS utilisé pour donner vie à un amplificateur classe B. La mise en œuvre est facile, comprend déjà le fusible, le connecteur secteur, reste à ajouter l'interrupteur. Les tensions auxiliaires indépendantes ont une vraie plus value. Les tensions sont respectés en charge.
Mais une étoile de moins car cette alimentation est légèrement bruyante.
Ludo B.
Aucun probléme avec ce transfo. Sous tension et avec il est vrai une charge pas énorme, aucun échauffement et chose étrange, le compteur Linky indique 0va ! Surprenant !! Ce torique doit étre d'une trés bonne qualité !
Ludo B.
Power Supply Board LT1764A +/-15V 2x15V 5V This versatile power supply module provides two 15V outputs or one +/-15V output depending on the wiring, as well as a 5V output. The voltage of each output is adjustable, from...
En observant cette alimentation, on peut voir que chaques détails a été pensés. Qualité extréme ! Méme la couleur du circuit imprimé ( noir ) n'a pas été choisie au hasard. Excellent !!!
Utilisé avec Xlr EIZZ
Monté en Xlr sur Connecteurs EIZZ résultat excellent.
J'ai doublé les néotech sur point froid.
Le RQP est simplement exceptionnel sans dépenser des centaines voire des milliers d'€
EIZZ EZ-205F Female 3 Poles XLR Connector PTFE Platinum Plated Ø9mm Black (Unit) This Eizz EZ-205F 3-pin female XLR connector is carefully designed for good signal transmission. Its contacts are made of Copper alloy and Platinum plated. A PTFE insulation...
Excellents tout simplement
A l'écoute on ne se pose aucune question tout est la de haut en bas .
Jacques B.
Belle qualité !!
Belle qualité de produit. Serrage efficace du câble et excellent contact dans le bornier. A recommander
PS : Il a déjà été signalé que la clé nécessaire est une Torx et non pas une Allen six pans....!!! Le descriptif est toujours à corriger !!!
Utilisé pour un câble hx16 marche bien pour le prix
Permet de dérouler des bobines
Tiens bien
Emmanuel A.
Excellent sur les ampli gourmand
Pour vos appareils qui consomme beaucoup avec de grosse alimentation il est parfait
Très neutre meilleur que beaucoup d’autre plus Cher
Clarice C.
Giant Killer performance
This unit is a giant killer. At under 100€, you will have to spend 6 to 7 times more to top this. My first surprise, this DAC beats my SimAudio Moon CD-1 in clarity and is more lively. Wow.
By combining this unit with a Wiim Pro streamer, I have a streamer to play from my NAS. I use YouTube music for the moment and it does have some high resolution files: great.
I sang opera for over a decade and played an AIFF/MP3/and FLAC files and smiled so hard I nearly broke my ears.
The bass is firm and resolving: ECM recordings are sound fine on the unit. The timbre (native sound) of instruments is good.
At a higher price point, you pay foremost for a deeper and wider sound stage. That big tent feeling apparent on the Musician Draco R2R, Eversolo DAC Z-8 or the Pegasus DACs.
SU-1 is good but not 10x its price good. Draco is better. Draco is also R2R, but you are in the 650-800 € price range. Until recently I was thinking more in the Gustard A26 or R26 lines, but this little unit solves my problem for way less.
Dominique L.
Remarque Qobuz/Wiim Pro
Pour utiliser Qobuz en 24/192, il faut passer par Wiim Home, MConnect ou Bubbleup par exemple, sans utiliser Chromecast sinon on n'obtiendra que le 24/96.
L'appli Qobuz seule, ne trouve pas le Wiim Pro et doit passer par Chromecast soit maxi 24/96.
Pour ce qui me concerne, j'ai désactivé l'option Chromecast et je suis sur d'avoir ainsi le flux maxi.
Tomo Z.
Nice product from WBT ,well built could be a little bit cheaper but I still raccomand using this locking plugs
Jérémy b.
SHANLING UA1 PRO Adapter DAC USB-C ES9219C 32bit 384kHz DSD256 80mW 32 Ohm Silver Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones) or you simply want to improve the very average...
Petit prix, mais grosses prestations !
Après 3 jours d'utilisation, je peux laisser un commentaire avec un peu de recul.
Achat de ce DAC pour contourner un problème de carte son devenue capricieuse sur laptop gamer âgé de bientôt 12 ans.
Il est branché sur un port USB A 3.0 (je n'ai aucun port USB 2.0 sur la machine).
Petite chauffe du DAC, mais qui reste limitée, et non dérangeante.
Quel packaging, simple, mais élégant à la fois, on pense acheter un bijou, la finition du DAC couleur argent (en zinc apparemment) est splendide, on est loin du DAC en plastique ABS. Le cordeau en nylon tressé donne ce côté élégant et solide.
DAC utilisé uniquement sur Debian Sid (système Linux donc), avec Audacious pour la musique, et VLC pour les vidéos, aucun contrôleur de son installé (ni Pulseaudio, ni Jack, ni Pipewire), pas d'égaliseur, ni d'effets, lecteurs paramétrés pour du bitperfect absolu, le système a reconnu le DAC sans le moindre soucis.
Est utilisé des musiques en provenance de iTunes majoritairement (m4a 256 kbit/s, ALAC), et CD personnels.
Pas de bruits parasites, ni de bruit de fond, pas de déconnexion, ni de bugs quelconques à déclarer.
Est branché sur le DAC, une petite paire d'enceintes amplifiées en USB, et branchées en jack (Edifier r12u), le son prend beaucoup + d'ampleur, + d'aération, les micro-détails difficilement audibles le deviennent nettement mieux, les aigus filent + haut sans être agressifs, et un petit mieux subtil au niveau des basses (limitées par les capacités évidentes de ces enceintes qui n'ont aucune prétention ni vocation à rivaliser avec de la pure hifi évidemment), mais l'amélioration globale sonore est vraiment là, rendant les écoutes agréables malgré tout, et chose surprenante, les enregistrements de piètre qualité ne sont pas pardonnés !
Est aussi utilisé sur le DAC, un casque Beyerdynamic DT-240 Pro, là aussi l'amélioration globale est + qu'évidente, la musique prend une claque monumentale, c'est vivant à souhait, il y a foule de détails à n'en plus finir, la dynamique s'envole, les musiques type rock, ou les lives sont d'un délire absolu, ça part dans tous les sens, une sacrée réussite pour qui aime les médiums riches en micro-informations, des aigus qui montent haut sans devenir criards, et des basses généreuses mais sans trop en faire, un bon équilibre tonal.
Là aussi attention aux mauvais enregistrements, ça saigne les oreilles.
Le changement d'avec la carte son d'origine complètement pourrie du PC est stratosphérique, et pourtant ce DAC est un entrée de gamme, idem pour le casque, et les enceintes USB n'ont aucune vocation musicale, bien sûr je préfère mon vrai système hifi, mais force est de constater que pour une somme modique, on peut avoir de belles surprises.
Comme mentionné de partout dans les commentaires, le service Audiophonics est parfait, emballage adapté, produit fonctionnel qui n'a aucun soucis, livraison rapide, prix attractif.
Je recommanderai à l'avenir lors de mon déménagement futur, très certainement des câbles.
Jérémy b.
DAC utilisé uniquement sur Debian Sid (système Linux donc), avec Audacious pour la musique, VLC pour les vidéos, et MPV pour un usage minimaliste, aucun contrôleur de son installé (ni Pulseaudio, ni Jack, ni Pipewire), pas d'égaliseur, ni d'effets, lecteurs paramétrés pour du bitperfect absolu, le système a reconnu le DAC sans le moindre soucis.
Est aussi utilisé sur le DAC, un casque Beyerdynamic DT-240 Pro, là aussi l'amélioration globale est + qu'évidente, la musique prend une claque monumentale, c'est vivant à souhait, il y a foule de détails à n'en plus finir, la dynamique s'envole, explose littéralement, les musiques type rock, ou les lives sont d'un délire absolu, ça part dans tous les sens, une sacrée réussite pour qui aime les médiums riches en micro-informations, des aigus qui montent haut sans devenir criards, et des basses généreuses mais sans trop en faire, un bon équilibre tonal.
la multiamplification démocratique
1l amp pour l aigu ruban amt pro 4 et un autre pour le suraigu fostex t 90..résultat fantastique.mieux que de bons vieux classe A.
Et en prime un look sympa et une très bonne finition.
Trop fort les chinois.
Un doute
Un peu comme un autre avis manque de précision et dynamique
A confirmer
Frédéric B.
Grande Qualité
Connecteur qualitatif, solide, facile à monter avec très bon maintien du câble.
NOTE importante de montage: la rondelle en plastique de l'embase peut s'enlever le temps du montage pour libérer la rondelle de caoutchouc de centrage du câble, pour qu'elle ne soit pas abimée quand on manipule le câble dans l'embase, lors de sa fixation.
Frédéric B.
Grande Qualité
bon rqp
Apporte de la propreté à l'écoute en positionnant les pointes vers le haut ou le bas vous pouvez jouer sur l'image sonore . bon produit.
marc g.
très bien pour un usage très particulier
franchement bluffant si collé à une plaque de plâtre. Assez décevant avec d' autres configuration, mais j'ai pas tout essayé. bonne bande passante, le son est très propre sans qu'on puisse parler de hifi. Rendement très très faible en revanche. Prévoir plusieurs exemplaires a répartir dans la pièce, avec un condo de 100uF en série pour couper les basses et monter en puissance. En complétant avec un petit caisson de basse genre pour ordi, c'est parfait. On sonorise le magasin avec, et tout le monde est content.
