iouri C.
Au final déçu.
Antoine S.
CD Player Upgrader
Michel R.
Parfait pour mon usage
Kostas K.
DIY Box
Very good. From packaging one allen screw was missing from the front.
Vincent b.
excellent lecteur
j'ai comparé ce lecteur à un ensemble lecteur + dac 20 fois plus onéreux mais plus ancien et force de constater que le gap
n'est pas énorme : le tempo a une qualité rare de rendre jusqu'a l'infra grave bien défini et de ne mettre aucune partie du spectre sonore en avant (du coup j'ai réalisé que le manque de grave ne venait pas des enceintes) et que certain dac externe priorise le medium sur le reste
Henrik K.
Excellent cable at bargain price
I made two 1m rca cables , using this one and Elecaudio RC-602 rca connectors . From cd to preamp and from preamp to power amp - Rotel RTC-940AX , Rotel-RB970BX . So 40€ for 2 pairs of excellent cables ! You just can't beat this ! Well , maybe Sommercable Carbocab ? That's what I'll try next...
Henrik K.
Cheap but effective
They might look like door stoppers , they might need some excessive rubber trimmed , but they do their job perfectly . I put the under my vintage Rotel RCD-945AX CD player . Instead of using screws , I glued them with silicone . Highly recommended !
Christian A.
Amazing performance - great match with tubes
I ordered this device based on the good reviews on linearity and the ability to provide power across the impedance range of a loudspeaker (also difficult loads). I always felt that this could be a limiting factor to my KEF LS50 loudspeakers.
Transparency and punch are just amazing. It outperformed a number of A/B Class amps with ease, even devices which cost 2-5 times more. What I particularly like is the (perceived) linearity and clarity. I sometimes felt that matching a preamp with an amp is a bit of a gamble, very much depending on the specific character of each device. With the MPA-S125NC I just stopped worrying about that as I think that it's so revealing and neutral.
I can now fully focus on tube rolling with my Schiit Freya preamp without the fear that what I hear will be a mix of factors. It´s amazing how the amp is able to reveal (yes again) even the slightest difference in a tube or source quality. Holography of tubes is directly transformed into the listening room now.
On the downside, the box seems sturdy, but the front panel paint easily gets wiped off (be careful when cleaning). The form factor is a bit strange - but works well for me. Clarity can be a big plus, but you might want to feel the urge to upgrade other parts of the chain soon though, this little box is able to unsurface weaknesses ;)
Strong recommendation! Especially the combination with KEF LS50 and the Schiit Freys Preamp in my case. Love it!
Dirck C.
Carte livrée en 48h, bien emballée. Ça change l’approche de la hi-fi que j’avais pour le moment ... là je retrouve vraiment une super qualité de son. Sur volumio impossible de trouver le bon driver, du coup j’ai testé avec moode et là tout fonctionne parfaitement le tout avec une tite appli iPhone et c’est parfait ou même par le navigateur de la TV ... très bon achat. Pour 80€ on peut se faire une solution au résultat très honorable !!!
Sous volumio vous pouvez utiliser tout driver générique (RPI DAC, ES9023, Hifiberry DAC etc...) Moode est un bon choix et est sensiblement plus stable.
philippe C.
L'incarnation du tube.
Ce module intelligent permet de changer la sonorité du DX220 selon le domaine musical à reproduire.
Il a la fluidité et l'incarnation du tube. Le son est encore plus analogique.
Un peu...( je dis bien : un peu) plus rond et analogique que le module d'origine du DX qui est très neutre et de référence.
Il est hélas aussi assez énergivore pour la batterie.
philippe C.
XDUOO X-SK1 Adhesive Pad for Mobile Devices The xDuoo X-SK1 is an extremely useful adhesive pad for combining two mobile devices such as a headphone amplifier and DAP for example, and therefore limiting the space required.
Pour associer deux appareils nomades sans les abîmer.
C'est intelligent comme un poulpe de poche...
philippe C.
XDUOO X20 DAP Digital Hifi Music Player DAC ES9018K2M 32bit 384kHz DSD256 Bluetooth aptX xDuoo comes back with a new DAP, the X20. It offers particularly comprehensive functionality and quality-based component design for excellent audio reproduction. On the program,...
C'est un fidèle Ami de musique
Ce petit DAP est très facile à vivre.
La musique qu'il délivre est puissante, linéaire, plutôt neutre, et soyeuse. Il a le registre grave magnifique et tendu qui semble être la signature de la marque et il place une scène sonore dense sous un éclairage aux teintes chaudes, lisses mais texturées. Très belle musique: incarnée. Il permet des écoutes longues et sans fatigue, dénuées d'artefacts numériques.
Chez XDUOO on semble proche des mondes de la musique pro: on reste neutre, concentré et on ne cherche pas à enjoliver les choses.
Le son est surpuissant quand il le faut ...et acoustique et neutre quand cela l'exige.
Il mérite un très bon casque.
Son utilisation est aisée, son association avec ses camarades de jeu est fluides. Il télécharge sur OS sans soucis et se manipule au doigt et à l'oeil par petites touches car il n'a pas d'écran tactile.
Il est magnifiquement sobre construit pour durer avec une batterie suffisamment puissante.
J'aime beaucoup cet appareil et il est devenu un fidèle ami de balades.
philippe C.
Un vrai "baroudeur"
La sonorité que délivre ce petit amplificateur est dense, faite de plénitude, de matière, avec des teintes chaudes et fauves jamais fatiguantes même en écoute prolongée.
Le médium est charnu, doux et varié. Les aigus n'en font jamais trop et restent bien intégrés à la façon d'un "Large bande". Avec lui la musique est retransmise avec neutralité sans accident. Il reste assez droit et énergique et ne cherche jamais à être surdéfini.
Le registre grave est absolument magnifique. On n'attend pas d'un si petit objet autant de grandeur dans le bas et le milieu de l'espace sonore. Quelle santé ! Quel coffre ! C'est grandiose, sombre à souhait quand il le faut et plein de saveurs. Il ne recule pas devant une cathédrale de sons énorme et sait donner des couleurs à un quatuor à cordes.
Avec lui, la musique a quelque chose de soyeux, de très séduisant et d'élégant parce qu'elle semble provenir d'un objet d'où l'électronique et le numérique sont absents.
Le mariage sans fil ou Bluetooth avec ses petits camarades se fait le plus simplement du monde et reste extrêmement stable.
Son format et son ergonomie sont proches de l'idéal pour la hifi nomade. Il est taillé pour l'aventure...
Formidable !!
Yannick M.
cuivre ET laiton
seuls les connecteurs IECet les rivets de sertissages sont en cuivre doré.
les connecteurs faston sont en laiton doré.
Je ne sais pas en quoi sont faits les contacts du fusible, par contre.
Ceci dit, c'est déjà très bien, et cette embase IEC est d'un excellent rapport qualité prix !
philippe C.
DX 220: Diva caractérielle...
Ce DAP est un somptueux Bijou musical...
Il a un grave abyssal, une scène spacieuse et crédible. Sa musicalité est à l'avenant...
On pourrai disserter des heures sur les beautés sonores que distille cette merveille... En bref; pour un mélomane: c'est un "Must have", une source de bonheur.
Dans cette gamme de prix, Il a peu de concurrents et encore une fois; c'est une question de saveurs et de goût personnel...
J'apprécie beaucoup la fenêtre musicale qu'il me fait découvrir et Il mérite d'être associé à un très bon casque qu'il pourra transcender.
... il est aussi très versatile et rétif.
Sa manipulation est délicate et je n'aime pas son système d'exploitation qui est beaucoup trop instable. Sa bibliothèque Mango est juste passable. On est encore très loin de MacOS, et sa batterie est vraiment sous dimensionnée.
Alors évidemment..., on ne peut pas reprocher à une fusée d'être inconfortable, improbable et énergivore. Par fonction, elle nous permet d'explorer des mondes musicaux encore inconnus...
C'est une Diva! On l'aime pour son talent de Maestro très rare... mais pas pour son caractère capricieux...
philippe C.
Minéral précieux...
La basse est liquide, dense, profonde et définie. La scène sonore est immense, transparente, familière, aérienne et légère. Le médium est incarné, analogique. Les aigus sont riches, variés, lisses, et jamais agressifs. Les détails d'ambiances; d'émotions, de délicatesse et de musicalité sont révélés.
C'est une écoute magnifiquement musicale pour mélomanes. Ils se font oublier et vous plongent sur les lieux d'enregistrements.
J'en ai d'autres beaucoup plus chers, mais ceux là je les aime et j'y reviens souvent: ils sont simplement musicaux...
... des petits cailloux qui vous aideront à ne pas vous perdre dans la forêt des intras.
Angelo P.
confiant
je les ai pas encore essayer ,mais je mets 5 etoiles quand meme,j'ai confiance dans le materiel fourni par audiophonics
Angelo P.
essai
commander pour remplacer des tubes chinois sur un preampli phono, ca marche mieux avec les nouveaux tubes russes. rien a rajouter c'est parfait
Istvan D.
Difficult to find better
It knows all what a streamer must do;
- Flexible, since lot of free solutions to play music, like Volumio, etc.
- There is digital room correction in players like brutefir at Volumio. The RPI 3 board can run it in good quality (with long filter)
- USB Async output; it can sound better (jitter free) than SPDIF streamers since all DAC resync the incoming USB signal.
- Output noise just depends on the quality of the power supply, since USB output and processing board very well isolated from each other.
I don't know better streamer for 10 times more money.
Allo Shanti power supply (or something on the same level) is necessary for low USB output noise.
A minor disadvantage is, RPI4 CM board does not exists and RPI3 CM run on full power all time if long FIR (room correction) filters are on. RPI heatsinks are recommended on all chips in case of FIR computing.
Recordcard ..
Fiabilité et qualité de régulation et protection nulle
J'en ai acheté une deuxième pour alimenter un NAS, au bout de 7 H00 NAS cramé, l'alimentation débite 21V!!! Au final selon le SAV c'est supposé de ma faute, inversion de polarité alors que le NAS était cablé avec leur câble. Ok pourquoi le fusible a pas grillé? Pas de réponse.... Par curiosité, j'analyse la 1ère que j'ai depuis janvier, une vraie daube question régulation, dès que la charge avec un appareil qui pompe 0.50 A, on perds 0.25V, pour une alim censée tenir les 13 A il y a un sérieux problème.
D'autant plus que le réglage de sortie interne peine revenir au 12 V. Passez votre chemin.
Arnaud G.
Parfait pour l'utilisateur exigeant que je suis.
Utilisé avec un casque Sennheiser HD650, il gère plus que largement son impédance élevée, il y a même beaucoup de marge, on pourra utiliser le réglage de gain intermédiaire. Reconnu direct sous Linux (Xubuntu 18.04). Sous Windows (10), il suffit d'installer les pilotes proposés sur le site web du constructeur. Lorsque je l'allume ou l'éteins (commutateur que l'on entend en amenant le bouton de volume à zéro), le son bascule automatiquement entre ma carte son pci-express reliée à ma chaîne hifi et cet ampli/DAC relié à mon casque, que ce soit sous Windows ou Linux. Matériaux robustes, boutons rigides, volume souple et amortit, la qualité se fait sentir dans son utilisation quotidienne depuis maintenant 1 mois. Même si je ne suis pas expert en la matière (juste exigeant), la qualité sonore me semble excellente, un poil au dessus de ma carte-son déjà au dessus du commun.
dynamique et transparent
Je l'ai connecté sur un Préamplificateur Passif / Sélecteur de Source 10k KHOZMO ACOUSTIC. Transparent, relief des plans sonores, beaux timbres, aucune agressivité, cet ampli est musical. Il parait bien fabriqué et vu le poids/taille du transformateur, il explique une partie des qualités auditives de cet appareil. Bon, une fois n'est pas coutume chez Audiophonic, mais une ailette du dissipateur thermique coté entrée était fléchie (le transport sans doute), je l'ai redressé et tout est en ordre. Amplificateur à recommander !
Grzegorz B.
Good quaility but difficult to use
This isn't connector for 4,5mm cable, even 4,2mm are too thick for this connector, I tried to use SOMMERCABLE ISOPOD SO-F50 Cable Patch Bi-Conductor 2 x 0.5 mm2 Ø4.2mm and this was too thick to mount. In my opinion max cable is 3mm.
Complément idéal de la carte DAC AK4497
Voulant évoluer vers la lecture d’enregistrement Hi- Res, Audiophonics m’a conseillé cette interface digitale USB. Avec une loupe, la soudure des pins est aisée, ensuite il reste à l’insérer l’interface dans le support sur la carte DAC, les 4 visses permettent un bon maintien de l’ensemble. J’ai relié mon DAC à un IPad via un câble USB, et je découvre toute la qualité des enregistrements en haute résolution.
François M.
Pacotille
Fixation correcte sur un panneau problématique et les lames des contacts très fragiles, une m'est restée dans les doigts.
A éviter
philippe C.
IKKO OH1 Hybrid In-Ear Monitors IEM 18 Ohm With its OH1s, Ikko offers high-end in-ear monitors at a low price. Indeed, it is a model with a hybrid design with two loudspeakers, usually reserved for products at much...
Très liquide et analogique
Moelleux; souplesse; densité et matière pour un intra bien pensé et très confortable. A l'usage, on comprend pourquoi il est adulé dans le monde entier par les mélomanes nomades. Il préserve la musique dans toute son ampleur et sa texture et il distille de longues écoutes sans fatigue en se faisant oublier.
Jean Paul F.
Élément indispensable
L'ancien modèle amenait déjà une meilleure définition des timbres avec une plus grande ouverture, beaucoup de fluidité et d'aération.
Cette dernière mouture apporte en plus, de la précision, du détail, moins de duretés, et un grave mieux maîtrisé.
En résumé, un son plus naturel, plus analogique.
Un minuscule investissement pour un résultat saisissant.
Jean Paul F.
Andrei k.
MUNDORF MR10 Resistor 10W 0.47 Ohm High quality manufacturing resistance and excellent longevity. Ideal for audio applications
information erronée
La résistance MUNDORF MR 10 est annoncée en couche métal non inductive mais ne correspond pas à la réalité. C'est une résistance banale avec un fil en métal embobinée autour de la céramique.
Stefano A.
Not an MQA decoder! just a renderer
iFi should clearly declare in the ZEN dac specs that it is only an MQA renderer, not a decoder, thus it will not be able to perform MQA unfolding if you don’t use a software to perform the first unfolding (like Tidal app, Audirvana, …).
It is very disappointing this kind of misleading information by iFi.
Franck P.
IBASSO AMP8 Discrete Balanced Amplifier for DX150/ DX200/ DX220 / DX240 The Ibasso AMP8 is an amplifier board that can be combined with the Ibasso DX150, DX200, DX220 DAPs. This amplifier integrates a discrete symmetrical circuit with high voltage...
un module ampli homogène
Acheté pour équiper un DX200, il remplit à merveille la tâche : le son est plus naturel sur tout le spectre, les basses sont plus présentes, et les aigus aussi, conférant ainsi à la musique une meilleure ouverture sonore. L'ampli original amp1 avec sa sortie symétrique 2.5mm se débrouillait pas trop mal, mais il lui manquait cette homogénéité : son trop "propre", trop "contenu" typique des ampli opérationnels. La contre partie : une autonomie en baisse, mais au service de la musique.
Enfin, les défauts que je trouvais à mon casque pioneer ont disparu aussitôt l'amp 8 installé. J'ai hâte de le tester avec un Senn. HD650 et son câble adapté en symétrique 4.4mm
christ yannick b.
Légère différence
J'ai changé les borniers de mes Triangle Borea br02 juste pour voir si ça faisait une déférence. Après une comparaison A-B de 5 minutes. J'ai cru déceler moins de distrosion ou un effet placébo. Les borniers d'origine devait déjà être bon, ils ne réagissait pas aux aimants. Je dirai que j'ai gagné 1%.
Faut dire que j'avais déjà tout changé dans les enceintes (crossover de meilleur qualité et câblage interne occ) .
Je prendrai le modèle au dessus pour mon ampli.
Pour le prix ça doit être un super upgrade pour des enceintes vintage ou un vieux ampli.
Leonel T.
SMSL M200 Balanced DAC AKM4497EQ XMOS U208 Bluetooth 5.0 768kHz DSD512 Black Balanced desktop DAC with native DSD XMOS USB interface, SPDIF & Bluetooth 5.0 192kHz. Delivered with its infrared remote control.
endgame Amp
I'm not going to dwell too much into details and such. I'll just make it short and straight to the point. It's a magnificent desktop toaster (it gets hot. but I got a rebel amp that beats it to the punch and can cook an egg if needed to, so, not that of an issue), with probably the cleanest output I've had the pleasure to lay my ears onto. THX has come to revolutionize the market. I can't stop bragging and loaning my unit to friends, so that they can suck it up, and hear for themselves that it is CLEAN. And pairing it with a good dac (hybrid,tube,solid, you name it), believe me, what you'll be hearing is what the DAC outputs and nothing else. So, if you are really looking just for an amp, (no soundstage, coloration, separation and all that crap, messing around with the source audio) this is it. In all seriousness, just buy the damned thing and go on with your life. no need to look more, or you get this, or the Monolith THX... and then, close your wallet.
cheers
Well, my 2cents.
christophe S.
Silence sa tourne.
Le tunami v2 est un câble sans aucune coloration ,il n est pas aussi charmant que le tc31 furutech , mais il reproduit plus réellement la musique sans aucun artifices ,les instruments, les médiums, les timbres sont d une grande réalité ,et surtout de superbes pause musicale d' un silence hors du commun.
Si vous recherchez un câble secteur d une grande réalité prennait cette oyade si vous recherchez du charme opté tc31 furutech.
A consommer sans modération
Arrivé ce matin, ce câble s'ouvre de morceaux en morceaux. L'écoute est magnifique; les basses sont détaillées et claires, rien de boomy, le medium offre une clarté et une aération saisissantes quant au registre aigu il se montre très fin et doux. Ce câble dynamique nous offre une réelle présence qui sublime l'écoute et avec plaisir on redécouvre ses CD chéris. Le son est aéré, clair, fouillé, vivant. Par rapport à mon ancien câble Viablue NFA7 qui sonnait déjà très bien, celui ci nous offre une restitution ou il n'y a rien de plus mais tout y est mieux. Très bon matériel, réalisé avec soin et sérieux, le résultat est là.
Frederic p.
Oui Satisfait
Effectivement cette barrette Electra est d’une bonne fabrication après déballage
J’ai démonté la plaque inférieur pour y regardé la fabrication qui est de bonne facture.
Le câble fourni avec mériterai d’être changer pour un bon câble d alimentations.
Niveau gain de son bon là malheureusement il ne faudra pas s’attendre à un miracle !!!
Je note quand même qu’il a une amélioration des basse et des médiums, au niveaux de gains de puissance ou pèche rien de rien de plus .
Après sa ne peut que augmente la qualité de votre système hifi donc à ce prix n’existe pas.
Mon matériel ampli marantz pm 11sa avec le lecteur cd 11sa enceinte focal sopra n2 câblage esprit
qualité au rendez vous
Fourches robustes inspirant la confiance. Son neutre , transparent et détaillé au sein d'une scéne sonore homogéne . Un sans faute pour un prix raisonable.
Ignacio S.
Topping DD30 DAC
Se trata del primer DAC que he comprado por lo que no puedo ofrecer una opinión técnica. Creo que funciona muy bien. Respecto de la atención y el envío del producto a estado perfecta. Espero volver a comprar en Audiophonics. Muchas gracias.
Ceci est le premier DAC que j'ai acheté, je ne peux donc pas donner d'avis technique. Je pense que cela fonctionne très bien. Concernant l'entretien et l'expédition du produit en parfait état. J'espère acheter à nouveau chez Audiophonics. Merci beaucoup.
Avraam S.
IAN CANADA LIFEPO4 MKIII Batteries Power Supply 2x3.3V + 5V + 2x Adjustable Outputs 3.3V-13.2V With the LifePO4 MKIII, Ian Canada offers a consistent, high-performance battery power supply that is extremely complete in terms of functionality and modularity....
Superbly finished
Arrived well packed, and worked flawlessly.
Greatly improved the sound of my TPA Buffalo Pro 38 DAC, working bridged with a MKII LIFEPO4 supply.
Laurent G.
Cable pour douceur et raffinement
Initialement avec des cables audioquest, mon ampli Sugden A21 faisait sonner mes enceintes Sonus FABER VENERE trop clair, trop transparent, avec fatigue auditive. Le passage avec ce cable Mogami 3103 a nettement amélioré la restitution. Le son est plus 'posé', 'assis'. Les hautes fréquences sont plus douces, basses fréquence plus appuyées, mais surtout sans perte de transparence et de dynamique, l'image sonore gardée et plus agréable; c'est qui rend ce produit vraiment performant et à prix accessible, moins cher que la concurrence. Excellent rapport! De +, il est souple et se prépare facilement. Je recommande vivement.
Henrik K.
Simple , good quality
You could spend much , much more and won't get better RCA connectors. Unbeatable at this price. Made 2 pairs of
1 m cables with these and Canare L-4E6S star quad cable. One pair for CD to preamp , another for preamp to power amp. So total price for two pairs of excellent cables - 40 € . Had much more expensive cables from Van den Hull , Tara Labs , etc , and they weren't "sounding" any better than these ones. Excellent customer support from Audiophonics , and prices also .
Rémi B.
Best
Meilleur mini amplificateur
Rémi B.
Best
Meilleur mini amplificateur au monde
Jacek B.
I compared D70 and D90 and - for me - the D70 is definitely better. The best choice.
Rafaël R.
Il n'y a rien à dire, cette petite boite est parfaite.
Rafaël R.
Déçu
La qualité de fabrication a l'air correcte, pourtant il y'a un bruit de fond / sifflement qui ne passe pas inaperçu dès lors que l'on monte le volume et ce quelle que soit la source d'alimentation utilisée.
Michael J.
Utilisé sur des Sopra 2 et denon pma 2500 , restitution fine , aérée , le top, incomparable a mes anciens câbles ...
Dominique F.
IFI AUDIO HIP DAC Portable Balanced Headphone DAC Amplifier 32bit 384kHz DSD256 MQA iFi Audio presents the HIP DAC, a DAC combo and nomadic symmetrical headphone amplifier, both compact to accompany you in all your travels or on your desk, but also benefiting...
j'ai utilisé le HIP DAC raccordé à un MAC, un IPAD et un téléphone Android pour des fichiers au format ALAC ou MP3; cela a été vraiment plug and play dans tous les cas, bravo! Comme casque, j'ai utilisé un Sennheiser HH800S d'une impédance de 300 Ohms: pas de soucis de niveau sonore, même en asymétrique, et une qualité sonore étonnante dans le style bien droit et détaillé.
Rémi P.
Top!
J'avais 2 enceintes bibliothèques que je n'utilisais plus... Et hop une petite installation audio Bluetooth de qualité pour ma fille.
Guillaume B.
Ce qu'il faut!!
Pour remplacer ce que l'on trouve sur nos appareils, même les chers, c'est ce qu'il faut!
Du cuivre pure, un boitier solide une fixation de câble sûr, il n'en faut pas plus pour avoir de la qualité.
Je recommande.
Guillaume B.
belle pièce
Belle construction, on sent la solidité dans la main, les matériaux choisi sont logique pour l'application, donc transparent/neutre.
Belle finition, peut-être différentes finitions colorées ajouteraient-elles...
Gilles G.
J'apprécie ce câble dans mes montages audio à tubes. Je l'ai choisi pour ses qualités : sonores puisque conducteurs argentés, esthétique, physiques parce que souple mais pas trop.
Très facile à souder, très bonne tenue à la chauffe grâce au PTFE.
Seul le dénudage du blindage demande un peu de soin.
Solution parfaite pour propager les signaux électriques faibles entre les étages électroniques. Elimine les phénomènes "d'antenne" dans les pré-amplification.
Guillaume B.
Je l'utilise pour alimenter un boitier de filtration (modif maison) en amont des appareils audio et l’efficacité est bien là, on sent bien que l'électronique est mieux "nourri" j'ai pu écouter différents genre musicaux jusqu'au max à ~92db (mesure appli phone) sans avoir le déséquilibre grandissant avec le volume que j'entendais avant, je note une belle tenue des basses, plus de brouillon entre grosse caisse et basse, un medium un poil plus détouré et un aiguë moins agressif et plus fin, Associé au connecteur Viborg cuivre pur je suis pleinement satisfait de cette achat, je recommande, et puis il s'agit de YARBO quand même!!
