Terrific cable
Tomasz C.
arnaud m.
Exelent
GUSTARD R26
GUSTARD DAC-R26 is an excellent R2R DAC, I used to have SMSL D1s, they are quite decent, however, GUSTARD is far away in sound, has stronger dynamics, clear highs, solid bass, full mids, settings are simple, then I did not try RJ45, nothing USB works great, I probably wouldn't use Roon, it's a parody of Audirvan, everything can be set much better there and with good tuning it gives excellent performance. Of course, it plays even better with the HQ player, which I would recommend. The conversion to DSD 512/1bit is fantastic. MQA also has very good results in presenting the sound space. You will then receive an excellent signal into your amplifier. This DAC is an excellent choice for more advanced connoisseurs. I recommend listening to the album Jean Guillou – Orgue et Percussions. You will get excellent space, wonderful acoustics, perfect dynamics, of course it depends on the type of your amplifier and speakers. This DAC is so good that I am considering buying another one. I can definitely recommend
Stéphane L.
Très bon DSP
Excellent rapport qualité prix. Utilisé dans une config 2.1. Le jour et la nuit avec mon ancien filtre passif sur le caisson. Sorties analogiques de bonne qualité (genre DAC à 300/500€). Manque juste un trigger 12v pour en faire un produit parfait.
David L.
FOSI AUDIO LC30 Audio Selector Switch for Amplifiers / Speakers vu-meter Yellow With its LC30, Fosi Audio unveils an amplifier and speaker selector. In other words, it allows you to switch easily and quickly between two power amplifiers and two pairs of...
Trés sympa mais calibrage limité
Petit appareil tres bien fini, solide, design simple et propre.
L’idée etait de juste en tester un pour éventuellement en prendre 4 pour mon 4.1 haut rendement.
C’est surtout un watt metre et selon le systeme ça va swinguer plus ou moins.
Dans mon cas, oú en plus je ne cesse de réduire la puissance suite aux mesures de tensions en utilisations diverses, ben ça bougeait presque pas.
J’ai bien tenté de l’ouvrir pour voir si on pouvait le modifier pour étendre la plage de calibrage, mais c’est au dessus de mon niveau.
Du coup en fouillant un peu les interwebs, “Z review” proposait une bonne idée pour palier au calibrage trop limité : carrément lui dédier un ampli.
Cad ne brancher qu’un ampli supplémentaire en source, sans hps, une sorte de circuit parallele et plus facile á calibrer du coup, pour swinguer les aiguilles sans se péter les feuilles.
J’avais un canal libre sur mon master dsp donc facile, un ptit v3 qui trainait et hop on branche.
Ensuite réglages niveau dsp / volume ampli / calibrage lc30 pour atteindre un comportement plus vivant.
Au final c’est tres sympa, d’ou le long retour ici.
Ça bougeotte a peine pour les ecoutes tranquilles, ça swingue bien pour le pêchu, mais bien sûr ça sort du cadran pour le vraiment fort, pas grave c’est rare de toutes façons.
Selon Fosi l’ampli voit quand meme 390ohms, en tous cas il ne chauffe absolument pas, et consomme rien.
Le top serait le meme genre d’appareil mais branché en digital sur la source, sur le -0dbfs.
Un step de plus en 25% sur les leds serait pas mal aussi, voir choisir la couleur elle meme, ça je vais ptet le bricoler.
Aiguilles tres reactives, a chacun de juger moi ça me va.
Ha, et il est assez gros et vide pour y mettre une TPA, j’dis ça comme ça Audiophonics hein ;)
Robert C.
Must try cable for speaker cables
For my DIY amplifiers with output power up to 40W per channel this cable is absolute favorite. Easy to assemble, flexible and more important absolutely transparent.
Robert C.
Incredible discrete OPAs
Everything is written and said in the online reviews on the web.
Natural, transparent, never harsh and with very good sound stage width and depth. Outstanding for the OPAs. Bravo Sparkos!
super génial
très bon produit le seule bémol les taxe de douane pour la Réunion dom 5 étoile merci
Philippe s.
Branché sur une platine Rega Planar One, il assure complètement le job et cela pour un prix défiant toute concurrence. Comme d’habitude avec Audiophonics, expédition très rapide et soignée.
Jimmy S.
EVERSOLO AMP-F2 Amplifier Class D 2x250W 4 Ohm / 1x450W 2 Ohm The AMP-F2, developed by EverSolo in collaboration with the Starke Sound team, is a Class D amplifier based on the integration of the latter's innovative NS600 module. As a...
Puissance
Produit très bien, mais manque de puissance par rapport a ce qui est annoncé, voila pourquoi je retire une étoile,
Notre atelier a vérifié les données constructeur.
La puissance annoncée est bien au rendez vous.
Luis C.
todo el proceso impecable
todo el proceso impecable, buen embalaje y buen precio
Thierry V.
Bon cuivre mais...
Il n'y a rien à redire en ce qui concerne le cuivre. Le bât blesse par contre un peu dans l'isolant extrêmement difficile à travailler, à dénuder, glissant, et qui n'est que rouge. Ce qui oblige à le gainer si on cherche l'esthétique.
Kevin H.
SMPS800RE Power supply Module 800W +/-40V The switching power supply SMPS800RE is a very high efficiency model capable of developing a nominal power of 800 Watts in an extremely small footprint. This power supply is...
LD Systems Maui 11G2
Parfait pour remplacer les alims défectueuses des LD Systems Maui 11G2. Sur les trois systèmes que j'ai (qui ont environ 5 ans) deux ont vu leur alimentation d'origine casser de la même manière, sans aucune raison apparente...
Manuel G.
Avec ce câble, j’ai à la fois réalisé des cables d’enceintes et des cables secteur. Le résultat est à la hauteur de ce que j’attendais. J’ai essayé sur plusieurs types d’enceintes. Ce câble amène plus de douceur, de neutralité, de définition et à la fois plus de dynamisme.
Soyez bien équipé des bons outils. La pince à dénuder est obligatoire, Une petite pince qui serre, mais sans couper vous permettra de dénuder les petites gaines PE.
Si vous voulez relier votre câble à la carcasse de votre ampli, il faudra couper une première fois et recouper une seconde fois les cables de manière à ce que le fil de drain soit plus long.
Je note cinq étoiles ce câble, mais je note uniquement 2 étoiles le service commercial, qui n’a pas été à l’écoute de ma demande. Ils m’ont automatiquement orienté vers des cables d’une autre marque (Mogami, elecaudio) Qui soi-disant ont un meilleur rapport qualité prix. Je connais ces cables et il n’arrivent pas au niveau des ramm audio. À croire que les commerciaux de Audiophonics se basent uniquement sur les avis et le nombre de ventes… D’autre part, même pour une commande de 1000 € pour 14 m de câble, ils sont inflexibles sur les prix. Dommage que la démarche commerciale ne soit pas de la partie.
Alain D.
Excellent et compatible ROON
Très rapide sur les frappes de cordes et peaux, fin et détaillé. Spatial
pas de distorsion a fort niveau. géré par ROON est très pratique
Jean-Pierre D.
Un composant intéressant pour un ampli de puissance
Je recherchais pour exploiter mon ampli Purifi Audiophonics HP 400 ce type de préamplificateur, il s'avère idéal car j'ai à driver des enceintes Signature Delta de Triangle (vu sa caractéristique classe A). Les Triangle sont exigeantes en électronique car ce son des enceintes extraverties très chantantes.
Le résultat est très bon pour un prix d'achat pas dans ce que l'on trouve habituellement sur le marché. Pour l'instant, j'ai connecté en XLR avec l'ampli de puissance en XLR et en RCA avec le lecteur réseau (un Eversolo DMP A6), j'envisage plus tard un XLR pour cette dernière interconnexion. La restitution est pleine, détaillée et neutre avec un joli son jamais agressif, c'est une prouesse avec les Triangle. Je recommande pour ceux qui recherchent ce type de préamplificateur.
jean michel G.
Avis
Sur un ampli BC ACCOUSTIQUE EX362D avec des Monitor Audio Silver 300 7g que je trouve un haut du spectre présent, ce câble ferait-il l'affaire ?
Marco H.
APERION AUDIO ENERGY 7 Power Amplifier Class AB 7 Channels 7x230W 4 Ohm The Aperion Energy 7, a 7-channel Class AB power amplifier, delivers considerable power and dynamics to your audio installation. Designed to excel even in extreme sound...
High quality Sound with amazing Bass!
Imported one Aperion Audio Energy E7 Amplifier to pair Marantz Cinema 40. It is a new demension in Bass with high quality of Sound! Thx to Aperion Audio and Audiophonics in France from Germany ❤
David C.
Superbe!!!
Ce drive CD est tout simplement magnifique & dans tout les sens du terme! La qualité de fabrication est très sérieuse, cela ce ressent au poids de l'appareil par rapport à sa taille....
Il est couplé en câble toslink au Bleusound Node 130 utilisé sur un ampli REGA BRIO (2017) équipé d'enceintes colonne HIGHLAND AUDIO ORAN 4305. Et très sincèrement bluffé par le rendu sonore de ce lecteur, rien à envier à mon ex ATOLL MD100!!!
La prise en n'est pas évidente surtout que le mode d'emploi est dans une langue que je pige pas (l'anglais)! Mais j'ai quand même réussi, après quelques heures de bataille à exploiter quelques fonctions: le Bluethooth franchement excellent rendu, appairage facile; AIRPLAY via Mac génial la pochette de l'album s'affiche sur l'écran!! J'adore! Bon parfois quand ont change d'album le changement de pochette peu prendre un peu de retard..... Il y la possibilité de se connecter à Tidal, pas encore essayé .... je verrais ça si je valide l'abonnement. Concernant l'application pas mal... mais certaines fonctions me paraisse pas assez aboutie, dont une réservée à la chine. Pour ce qui est du MQA pas encore l'utilité, ont verra ce que ça vaut le jour où....
Bref ce lecteur est une petite merveille!!! Il est beau, prend peu de place et procure un son splendide !!!!
Merci à AUDIOPHONICS pour l'expédition super rapide et son emballage sérieux, car le carton avait pris des coups & heureusement que SHANLING aussi n'hésite pas à mettre un double carton!!
p.s: Attention au disc cover il est en verre (épais quand même), pas besoin de vous expliquer plus..... Donc petite question à AUDIOPHONICS: Est-il possible d'en avoir de rechange???
Guillotin O.
HIFIBERRY DAC+ DAC Board for Rasberry Pi Burr Brown 24bit 192kHz The HiFiBerry DAC+ is a digital to analog converter module based on a Burr Brown DAC chip supporting PCM streams up to 24bit 192kHz. It has been designed to be associated with a...
Le produit est conforme à la description. C'est la 2e carte hifiberry que j'utilise et je ne suis pas déçu.
AIYIMA TUBE-T3 Phono MM Tube Preamplifier 2x 6A2 Black The Aiyima Tube-T3 is a simple and affordable phono preamplifier for MM turntables. It features two 6A2 tubes and a three level gain control, 39dB, 42dB and 45dB, allowing it to...
tres tres bon !
j'ai attendu un peu que les tubes se rodent avant de poster ! vraiment ce petit boitier est surprenant ! excellent son je dirais !
puis j'ai remplacé les tubes d'origine par des mazda 5654 v4 nos et c'est encore bien mieux ! ma vieille mais encore vaillante thorens 160 mk 2 s'est remise à chanter comme à l'époque ou je l'ai achetée en 1975! ! je redécouvre mes vinyles ! Son chaud et rond trés tube ,bien détaillé ,bel equilibre !
niveau livraison :comme d'hab rien à dire parfait !
merci audiophonics !
Sebastien D.
DYNAVOX Gold Plated Banana Plugs Ø5mm (Pair) These low-cost Dynavox banana plugs allow a simple and quick connection to the terminals of your speakers and amplifiers. The contacts are gold plated to ensure good signal...
bien
Fiches banane de qualité pour le prix, faire attention quand meme certaines vis peuvent etre déjà serrées d'origine faut y aller molo si c'est le cas sur les votres pour désserrer sans foirer le pas de vis, ce que j'ai fais et tout c'est bien passé ;)
Sebastien D.
Un cable bien conçu qui respire la qualité.
Dario G.
AUDIOPHONICS DA-S125NC Class D Integrated Amplifier NCore NC122MP DAC ES9038Q2M Bluetooth 2x125W 4 Ohm 32bit 768kHz DSD256 Versatile and powerful, we offer you with DA-S125NC an integrated amplifier with digital inputs to which you can add speakers to enjoy your music in the best possible way....
Très étonnant !!!
Félicitations audiophonics, envoie rapide, emballage sérieux.
Ai eu plusieurs amplis intégrés, classe AB, CLASSE T, tube...
Dans le cas de cet intégré, conseillé par un ami c'est une excellente surprise !!
Il sort à peine du carton et déjà grave ( Hp de 38) profond et très articulé, scène sonore large et profonde, beaucoup de nuances, détails abondants, son reposant sans aucune acidité.
A ce prix... pourquoi dépenser plus, bravo audiophonics.
Thomas C.
AUDIOPHONICS HC Trigger Home-Theater to HiFi system switcher 12V The Audiophonics HC is a home-theater trigger whose primary benefit is to save you the trouble of changing cable connections between your hi-fi system and your home-theater...
Au top
Voici le genre d’accessoires très pratique au quotidien.
Deux installations un ampli de puissance. Plus besoin de débrancher/rebrancher son installation.
A l’usage pas de souffle perçu sans musique, la bascule se fait automatiquement.
A recommander.
A quand une version qui ajoutera la fonction de symetrisation du signal ?
tres tres bon !
j'ai attendu un peu de rodage des tubes fournis c'était déjà vraiment très bien ! puis je les ai remplacés par des Mazda 5654 v4 nos ! c'est encore bien meilleur !! ce petit pré est vraiment étonnant ! très bel équilibre et des mediums et aigus chauds et ronds très tubes très fins !!
bref très très bon achat !! je peux enfin écouter mes vieux vinyles sereinement avec délectation !!!
ne surtout pas oublier de connecter le fil de masse bien sur !!
le son est meilleur chez moi avec le maximum de gains !
ma vieille Thorens td 160mk ii retrouve ses airs de jeunesse !
ps: niveau livraison ras ,parfait comme d'hab !
merci audiophonics ......
André G.
Qualité et ecoute
Utilise entre un ampli de puissance et un equalizer paramétrique pro ce câble qui semble solide m a donné satisfaction au niveau sonore. À recommander
OPA1612 Dual OPA DIP8 (Unit) The TI OPA1612 dual operational amplifier benefits from excellent technical characteristics, allowing very good electrical and audio performance. It ensures a very low noise...
Upgrade indeniable
Par rapport au ne5532, cet aop offre de meilleures bass,, moins de bruit donc plus de définition et de musicalité.
ATAUDIO AT-FR008 RCA Male Connector Ø6mm (Pair) This ATAUDIO AT-FR008 male RCA connector has a carbon-fiber body and gold-plated pure copper contacts. Its carbon body provides insulation against interference, while the...
Rqp au top
Je conseil ces fiches RCA pour ceux qui débutent en diy. Elles sont jolies, de qualité et faciles a souder. De plus, offrent une très bonnes connexion avec les appareils hifi.
Marc A.
J'ai hésité avec les Viborg qui sont plus chers, mais tout cuivre au lieu d'alliage de cuivre pour les Eizz.
Je me suis dit que nos chers ampli, enceintes (amplifiée), ou Dac, n'ont pas de connecteur d'entrée tout cuivre. Donc pourquoi prendre un connecteur tout cuivre s'il doit être mis en contact avec un connecteur en alliage?...
De toute façon cela marche très bien, j'ai le très bon son de mon système et je n'ai pas de perte.
De plus il parait que le sans soudure est meilleur, alors...
Pour ce qui est de qualité de ces connecteurs, c'est parfait, c'est beau, il y a un peu de poids. Bel objet.
Je recommande.
Coté service et rapidité d'envoi, Audiophics sont les meilleurs.
Marc A.
Ce cable est suffisamment souple avec un peu de fermeté, juste comme il faut. De fait, il se tient bien.
Son diamètre est également comme j'aime, pas trop mince, pas trop gros, juste ce qu'il faut pour offrir une bonne perception de qualité.
La couleur est un peu trop "framboise " à mon gout, mais ça va il est beau.
Pour ce qui est de l'écoute, je dois dire que mes enceintes et mon lecteur réseau sont respectés, il est donc neutre.
Un cable est soit neutre, soit un "bouchon", jamais il améliorera les défauts d'un système.
Donc, la neutralité est au rendez vous.
MUNDORF 6.3G Insulated Female Blade Terminal Gold Plated 6.3mm 4-6mm² Yellow (x10) These female blade connectors allow a simple and fast connection/disconnection while ensuring excellent contact. The contacts of these connectors are gold plated to provide very...
Solides.
Plus solides que les cosses identiques que j'ai déjà acheté ici à un prix bien inférieur.
Pas d'inscription Mundorf ni sur l'emballage ni sur les cosses.
Elles donnent cependant de bons résultats branchées sur mes HP Cabasse Dom 4 et Dom 12 ainsi que sur les 21NDB.
Cuivre pur ou laiton ?
Sinon il y a les Furutech FT-210 en haut de gamme cuivre pur garanti OFC.
Livraison ultra-rapide, bravo Audiophonics.
Solides.
Hans V.
Goeie kwaliteit
Nadat ik eerst een goedkope rca plug had die zich niet liet solderen ben ik voor deze duurdere plug gegaan.
Het totale gemak die ik er van had deed mij al vrolijk stemmen. In vergelijking tot de standaard goedkope plug die ik op mijn interlink had zitten klinkt deze mooi gebalanceerd en ben volledig tevreden hiermee
marc g.
bruit de fond trop élevé.
Marche très bien reconnaissance facile, connexion bien placées. Mais tout est gâché par cet insupportable chuintement en permanence, qui rejaillit sur l'ampli même quand on est en niveau ligne et pas par le bluetooth. OK pour une enceinte de SdBain, mais pas plus. Il faut dire que pour le prix, on en a pour son argent...
Werner H.
Best Speaker Indoor Cable
This is the best cable I know for wiring indoor speakers. The difference to standard cables is brutal!--------------- 6 stars
Werner H.-------------Germany
Werner H.
Best Cables--------- EVER
jean-jacques C.
Excellents
Cables installés entre mon pc et la box puis de la box à un switch Netgear (alimentations linéaires stabilisées sur le switch et la box ; alim Teddy Pardo doubles sorties) , carte son maudio . Sur mes petites lansing de bureau gains importants sur le niveau des détails ; du silence. Les musiciens et les voix gagnent énormément en réalisme et en présence. Je rachèterai ces cables sans hésiter. Aucun regret au contraire.
Gerard C.
Super rapport qualité prix
Très bonne multiprise remplace très avantageusement mon ancienne multiprise en plastique, un sont plus aéré et plus percutant. produit de très bonne qualité! merci beaucoup a David pour les conseil en plus expédition super rapide reçu en 2 jours ! bravo Audiphonic toujours au top ;)
Panagiotis B.
Good quality but nothing really special in the audio territory. Stiff and difficult to manage.
Quality is ok but it's thick and it doesn't bend easily.
That's not a good thing when you have a small DAC like SMSL SU-6s
I really didn't notice any percievable audio difference vs another (1/3 of the price) OFC cable, wihout the much advertised 75 Ohm certified RCA plugs,
Tobie H.
Ravi
Utilisé en remplacement d'un iFi Audio iDefender 3 que je trouvais trop "décapant" et sonnant trop "digital". Le Topping HS02 effectue le même travail en mieux, c'est-à-dire supprimer la composante 5V du signal USB, pour les DAC disposant de leur propre source d'alimentation. Il est également doté d'une fonction d'isolation galvanique.*
Cela fait environ 15 jours que je l'utilise et le son se bonifie progressivement depuis 3 ou 4 jours, apportant davantage d'enveloppe, de chair à la musique qui se retrouve davantage centrée sur le médium.
Les aigus sonnent également "charnus" (on distingue le son intrinsèque des clochettes et triangles et pas seulement un tintement aigu). Et enfin les graves semblent plus présents, plus "ronds". Tout cela est très agréable car plus proche de la vérité, du "vrai son" des instruments et de l'ensemble.
* Attention : Si votre DAC ou streamer en aval intègre déjà une isolation galvanique, il se peut que le Topping HS02 ne fonctionne pas, bloquant purement et simplement la totalité du signal (pas de musique, silence complet). La chose est précisée dans le manuel d'utilisation.
Cedric C.
Audio bastion xpad3
Produit de haute qualité ! Je recommande
Alfred T.
Boitier DIY DAC
Boitier de trés bonne facture et de qualité Tous les éléments sont emballés séparément .
Johan R.
Favourite for the price
Think you can’t get better cable?! Bang for the buck especially with Elecaudios own ”bullet”
Plugs. Thanks Audiophonics
Johan R.
NEOTECH NEI-1002 Interconnect Cable UP-OCC Silver Triple Shielding Ø11.5mm The Neotech NEI-1002 is a modulation cable consisting of two single crystal UP-OCC silver conductors. These conductors are maintained at equidistance thanks to the use of PE...
Wow!
Upgraded from this from
A cheaper neotech and feels like i have got new life in my speakers. Very transparent and open. Never hard sounding. Used Wbt 0158 cu. Not easy to build but worth it.
Jeanphilippe c.
Lecteur cd
Parfait. Très bon upgrade pour mon lecteur cd lm215. Livraison et emballage soignée. Je recommande
Jeanphilippe c.
Tube preamplification
Parfait, pour mon Line magnetic 216ia. Je recommande ces tubes. Livraison parfaite
jean pierre g.
DYNAUDIO EMIT 20 Bookshelf Speakers 2-Way 86dB 42Hz-35kHz Walnut (Pair) The Dynaudio EMIT 20, the big sister of the EMIT 10, is a high-performance two-way bookshelf speaker. This model is ideal for medium-sized rooms. They are equipped with an 18cm...
dynaudio emit 20
Très précis sur les instruments en petites formations,son clair,belle image stéréophonique .
Sa réputation n'est pas exagerée,foncez.............
Q ACOUSTICS 3030i Bookshelf Speaker 2 Way 88dB 46Hz - 30kHz Walnut (Pair) The Q Acoustics 3030i loudspeakers incorporate a large woofer/midrange driver inspired by the 3050i floorstanding speaker and a 25mm decoupled tweeter.  This combination...
Tres belles enceintes
Vraiment pas déçu de ces enceintes for élégantes dans cette couleur.
Le rodage est encours et je donnerai mon avis pour le son dans quelques jours après qu'elles se seront libérées
Merci à Udiophonics pour cet envoi, car reçu en 24 h avec un emballage tank...
Helder S.
Helder
J'ai remplacé la soudure de mes enceintes Wilson par cette soudure Mundorf Supreme 10% Silver et le résultat est remarquable. Plus de détails, une meilleure extension des basses et un peu plus de transparence dans l'ensemble.
Cyril K.
broches a souder
Un connecteur de bonne qualité,mais les broches a souder sont trop petites ,il manquerait également une clé Allen pour viser le corps du connecteur.
Robert C.
AUNE AR5000 Open-back Dynamic Headphone Ø50mm 28Ω 108dB 5Hz-41Khz Aune's AR5000 are open-back headphones with a dynamic MLD ("Multi-Layer Distributed") driver of no less than Ø50mm. Thanks to its innovative driver, high-tilt acoustic...
True reference performer
Neutral, transparent, never harsh sound.
Very solid and robust aluminum design but yet comfortable.
I'm using these as reference headphones in my system.
Highly recommended.
