Eric E.
E70 Velvet : c'est tout bon
Hubert K.
Une révélation
Andrii B.
Linear Power Supply circuit board 4 35mm Snap in gold plated This dedicated linear power supply circuit is ideal for designing stereo DIY amplifiers. It allows you to integrate 4 35 mm Snap-In capacitors of your choice (10 mm...
Good quality.
Used in DAC power supply unit.
Andrii B.
LHY AUDIO DIR9001Interface Module SPDIF to I2S 24bit 96kHz This SPDIF to I2S interface module allows to get a signal from a coaxial or optical Toslink input for output to I2S. It uses a Burr Brown DIR9001 receiver chip and supports PCM...
The product is as described.
Fast delivery from France to Germany.
Mark D.
Good input switch box
I was pleasantly surprised by the quality of this switch box. When introducing a switch and extra connections into your system, there is a natural concern that this could introduce some sonic degradation. This switch box seems not to have introduced any detectable sonic degradation at all. The switch itself is very smooth and easy to turn (almost too easy) which gives an impression of good quality. I was concerned that it might be too stiff.
Mark D.
Very good Interconnects
I was not expecting these to be as good as they are. They have made a very positive contribution to my system especially to the sound of my DAC which sounds a lot more coherent and well-balanced than before. It had been connected with more expensive cables previously..
MICHEL B.
Les meilleurs connecteurs 75 ohm
Pas la peine de chercher ailleurs, ces connecteurs sont les meilleurs, le contact est parfait et surtout la norme 75 ohm est rigoureusement respectée !
MICHEL B.
AUDIOPHONICS CANARE Digital coaxial cable 75 Ohm BNC-BNC 2m Here is a real digital coaxial cord BNC, version 75 Ohm, brand CANARE carefully assembled by AUDIO-GD. Its particularity is to include connectors CANARE C5F, also certified 75...
Superbe résultat
Ce câble qui respecte parfaitement la norme 75 ohms avec un conducteur et des connections de haute qualité donne un parfait résultat, la musique s'exprime en totale liberté.
Ce câble est bien meilleur que beaucoup de câble vendu très cher dans le commerce d'arnaque de la Hi-Fi !
Un grand merci à Audiophonics !
Windows 10
J'ai cet appareil depuis 3 ans, j'en étais totalement satisfait, jusqu'à ce que Windows 10 me soit imposé pour mon PC. Après avoir téléchargé le programme pour le réinstaller (DATS_V3_setup.exe), ça fonctionne, mais pas parfaitement. Rien qu'en faisant le test des câbles en court-circuit, au dessus de 10Khz, la courbe est totalement irrégulière, faite de creux et de bosses, pas trop normal je pense. Vivement que Dayton Audio propose une amélioration à son produit.
Bruno R.
LPSU100 Linear stabilized power supply 5V 11A DAC / Docking The Audiophonics team is proud to be able to offer you a regulated linear power supply to properly power digital players, storage devices, small audio systems, etc. This one has...
Très satisfait par cette alimentation et le processus d'achat.
A la recherche d’une alimentation linéaire délivrant 5V et au moins 2A pour alimenter mon lecteur réseau Bluesound Node N130 « tweaké » avec la fameuse carte d’alimentation de la société polonaise PD Creative, mes longues recherches m’ont amené sur le site d’Audiophonics.
Bien m’en a pris puisque je suis à présent l’heureux possesseur de cette LPSU100 en 5V et 11A, que j’ai pu acheter à un tarif hyper intéressant grâce à la promotion en cours (-40%).
Le coli est arrivé très rapidement en Colissimo classique (commande passée le mercredi à 23H, livraison le samedi matin) et parfaitement emballé.
Le boitier d’alimentation respire la solidité et la qualité, aussi bien des matériaux (alu brossé) que des composants. Il ne chauffe quasiment pas même après plusieurs heures d’écoute.
Et le résultat sur la qualité du son est bel et bien là. Tout ce que j’ai pu lire depuis des mois sur le sujet a été confirmé dès la 1ère écoute : les basses sont devenus plus précises et profondes, les aigus moins agressifs. Les instruments se détachent les uns des autres et la scène sonore gagne en espace. Les voix se montrent plus présentes.
Et surtout, surtout, l’écoute est devenue beaucoup plus confortable : il n’y a plus de fatigue même à un volume plutôt élevé. Je peux écouter à présent pendant des heures au même niveau du potard de mon ampli tout type de musique (même dans le répertoire metal dont les morceaux « occupent » très largement toute la bande passante) alors qu’avant cette alimentation, je finissais par baisser le volume voire même arrêter d’écouter par fatigue.
Bref, je recommande à 200% l’achat de cette alimentation auprès d’Audiophonics !
Stefano C.
Fantastic power cable
One of the few times that, as soon as the power cord is installed, an improvement is immediately felt. Really nice product! Highly suggested!
Teddy T.
[GRADE B] AUDIO-GD S-1 Amplifier Class AB 2x70W 8 Ohm Black Refurbished product - Grade B This Audio-GD S-1 amplifier benefits from Class AB architecture, enabling it to deliver a sound reproduction of fine musicality. Efficient, it...
Beaucoup de gens pensait que c'était un piège et pourtant ...
Pour son prix, c'est juste dementiel il est juste parfait.
Associé sur des petites Klipsch RB81MK2 ça fait vraiment des merveilles.
Michel L.
Moins de 10 heures d’utilisation et déjà une différence notable avec les électro harmonix installés précédemment sur mon préampli phono : meilleur rendu de la scène sonore justesse des différents registres et surtout des basses plus présentes et plus « grasses »
Pas de miracle non plus ces tubes ne transformeront pas une bourrique en cheval de course mais l’investissement vaut le coup si le matériel le justifie
Merci à Audiophonics pour la rapidité de la livraison
Claudio c.
Petit bijoux de puissance et de qualité sonore
Alors la je reste scotcher devant ce petit appareil audio. Puissant robuste, qualité sonore au rendez vous, rien à redire, excellent.
jouri k.
IAN CANADA MONITORPI OLED Screen and Signal Analyzer Board for Raspberry Pi The Ian Canada MonitorPi is an OLED display that works for all types of audio applications with Raspberry Pi. Installation is very simple using the module's GPIO port....
Works!
My MonitorPi was defective on arrival. Bad solder joints at GPIO. Couldn't get into settings
Got it resoldered. Works like it should. Has a huge impact on the sound. No more clicks between tracks. Also coverting to 32 bit is great for low res sources. Also DOP can be pass-through It souns better than expected!
Happy
Edmond S.
beau produit efficace.
les instructions de montage pourraient être complétées. enlever toutes les vis, séparer les deux parties en aluminium, ENLEVER LE CACHE PLASTIQUE du coté opposé à l'arrivée de courant, et ensuite les glissieres glisseront, **si elles ne sont pas encombrées de résidus de peintures époxy qui n'ont rien a faire à l'intérieur et empêchent justement de glisser.(en parler à votre fournisseur?) c'est le détail qui rend le montage du câble un peu pénible (pour la première multiprise).. resultat sonore excellent et très beau produit, mis à part le détail cité plus haut. Merci audiophonics
Edmond S.
beau produit
très facile a installer, connections massives. beau produit
Dimitri D.
Excellent value!
Have always prefered solid core cables (starting many years ago with low cost power cables that even out performed many a "costly audiophile" cables ) and these Jantzen cables have to be one of the best hi-fi bargains around, providing neutral and naturally dynamic sound transmission! Should also add the web site and service is also excellent. Highly recommended!
Guus G.
Good banana tube terminators
They are well made and have some springiness to them, so they return to their original form quite well (after unplugging). Altough I soldered them initially with silver solder I noticed a performance drop so quickly unsoldered them and now use them pinched to the cable, which in my opinion deliveres a better sound quality.
Great service as always from Audiophonics.
Guus G.
Great value for money!
I orderd the AC-14se mk2 since I previously ordered the AC-14 and was amazed how a powercable can make that much difference.
The AC-14 gave me the confidence to invest yet a bit more and the AC-14se mk2 delivers. Not as much gain the AC-14 made over the stock cable but enough to be content. Great service from Audiophonics as always.
Guus G.
Disappointed
I bought the viablue sc-2 speaker cable as un upgrade to my 30 years old Monitor Cobra Cable 4mm. After a few days I switched back to my old cables as I was not convinced the ViaBlue sound better. On switching back I found my old cables are are better in revealing details across the spectrum. I tested some more playing audio test tones from Qobuz. The ViaBlue were not able to reproduce the 30 Hz tone but my old cables were rock solid. Some critical music listning also revealed less spatial information with the ViaBlue.
The cable is sturdy yet flexible. No complaints in that region. Sound wise however they are a disappointment.
David S.
top
Premières écoutes : Entre mon ampli Lector audio ZXT70 et mes enceintes Récital Define HEFA enterre le Mogami W3103 loin derrière.
Câbles très transparent, beaucoup plus de détails et de profondeur sur tout le spectre, les petites sibilances sur certains enregistrements difficiles ont disparues. Le couple cuivre/argent semble être adapté à mon système.
"C’est comme si on avait enlevé un bouchon. "
À recommander!
(du moins chez moi)
Eric V.
Sans réserve
Après plusieurs jours d'utilisation, ce dac remplit parfaitement son rôle, de plus sa construction et les composants utilisés sont de qualité.
A l'écoute, après quelques heures, il procure une écoute détaillée et précise ne mettant pas en avant un registre particulier (grave-aigu). La scène sonore est plutôt large et profonde. Sans être démonstratif, ce dac est assez dynamique.
Bref, ce Topping E30 II est à mon sens une réussite, compte tenu de son budget ! Audiophonics, comme souvent, a sélectionné un excellent produit. Bravo.
Jean B.
Cher, pour ce que c'est, mais bien construit.
Il faut mettre beaucoup plus cher pour avoir un vrai produit d'isolation.
Parfait sous de grosses platines vinyles ou des enceintes.
Jean
Jean B.
Très bien, plus de bruit lors des connexions à chaud
Dire que c'est mieux qu'une autre connectique moins cher, je ne sais pas, mais au moins on peut connecter à chaud sans risque.
Belle construction, à voir comment ça résiste sur le long terme.
Mais, de manière générale, je suis revenu des connectiques très haut de gamme genre Rhodium qui ne résiste pas aux conditions atmosphériques (humidité) du climat Marseillais par exemple. Ca flatte l'égo à l'achat et puis quelques années plus tard, l'état de la connectique (sans l'avoir branchée/débranchée outre mesure) laisse un gout amer, on a un peu l'impression qu'on a été le parfait gogo du marketing idiophile.
Je n'utilise donc plus que du câblage/connectiques pro, c'est moins cher, surtout si ça ne dure pas dans le temps et franchement, à l'écoute, ça fonctionne très bien.
Jean
Jean B.
DIN Pseudo Star QUAD
Parfait pour remplacer vos câbles DIN d'origine y compris les petits Naim.
Belle ouverture, pas d'agressivité.
Un très bon câble à prix démocratique.
Jean
Jean B.
Câblage platine vinyle
Parfait pour remplacer le câblage d'origine, souvent médiocre de votre platine vinyle.
Jean
Jean B.
DAYTON AUDIO DAEX32EP-4 Speaker Driver Exciter Bodyshaker Full Range 40W 4 Ohm Ø3.2cm Among the most advanced and precise vibrating speakers from DAYTON Audio with a generous 32mm diameter motor. An original speaker model that is reminiscent of an audio...
DML
Parfait pour de petits panneaux DML.
Conseil perso, faites des panneaux légers, de faible épaisseurs et très rigides, n'hésitez pas mélanger les matériaux. Et de les utiliser avec des amplis avec contre-réaction en courant, y compris de petits LM1875.
Résultats étonnant pour le prix et l'encombrement.
Jean
Jean B.
FONCTIONNE
Commande expédiée très rapidement, bien emballé, produit fonctionne mais chauffe trop par rapport à la tension d'alimentation.
J'ai acheté ce kit en dépannage, car il me fallait un ampli très rapidement. J'ai construit plusieurs petits ampli à base de LM1875, avec la même tension d'alimentation et le schéma standard de la datasheet, les LM1875 ne chauffent pas.
Pour être précis, à +/- 12V DC (après le pont de diodes, mesuré sur les capas d'alim) les LM1875 délivrent environ 10W/4 Ohms et ne devraient pas chauffer. Avec ce kit, ce n'est pas le cas, les LM1875 sont tout de suite chaud, prévoir un bon radiateur, mais ce que ça indique, c'est qu'il est probable que l'ampli oscille...
Jean
Bruno M.
Bon produit mais en-dessous d'un DAC même plus ancien avec puce AKM
Le DAC Topping E50 n'est pas mauvais, mais il reste en-deçà du DAC que je possédais déjà (Aune S6 équipé d'une puce AKM), L'élément manquant est la gestion des trémolos et des vibratos en particulier sur la voix ou la flûte traversière, insuffisamment fidèle avec ce DAC. J'envisage prochainement de commander un DAC Topping E70 Velvet qui lui est équipé d'une puce AKM me permettant de retrouver la musicalité manquante. Pour le reste, le dac Topping E50 est un bon DAC, avec une reproduction correcte des extrêmes basses aux quasi-ultrasons, sans distorsion repérable, même à haut niveau (proche du 0db, contrairement à ce que j'avais pu constater à haut niveau avec mon DAC précédent Aune S6 qui distorsionnait ponctuellement sur certaines hautes fréquences telles 13.7Khz bien avant d'avoir atteint le niveau maximum de 0db), Je suis donc en attente d'un changement de DAC et ne sait pas si je serais amené à utiliser mon Topping E50.
Charles R.
Marche plutôt bien.
Au cas ou vous galérez pour faire correctement reconnaître la carte par Windows même après 15000 installations des drivers :
AVANT d'y connecter le DSP
Branchez la carte à l'ordinateur, ouvrez sigmaStudio et établissez la connexion .
Après, ça fonctionne nikel.
Je ne met que 4 étoiles car sauf erreur de ma part, ce détail n'est mentionné dans aucune doc officielle de la marque.
Didier G.
AUDIO BASTION REDLINE DAMPER Anti Vibration Damping Pads Aluminum / Silicone 41 x 17mm (Set x4) These stands for HiFi equipment and speakers effectively absorb the vibrations of your equipment. They are composed of a silicone pad, encased in a composite resin part, all...
Absorbeurs efficaces
Placés sous des enceintes bibliothèques, ces absorbeurs améliorent la restitution.
Produit bien fini et esthétique.
Didier G.
Remarquable streamer
Ce streamer surpasse mon ensemble Melco N100+Audio GD DI20 (Dac HOLO spring entrée I2S) en termes de transparence, de relief, et d'image.
L’OS fourni est performant mais Gentooplayer apporte un plus à l’écoute
L’utilisation en mode UPnP avec l’application Mconnect ne pose pas de difficultés.
Une notice est disponible sur le net (en anglais).
Edmond S.
Hi-fi
Tout simplement excellent en hi-fi. Bande passante, détails, précision. Le monobrin cuivre serti sur des fiches cuivre y est pour quelque chose
Pedro V.
Update on previous review
Just like to update my previous review were I incorrectly blamed QC issues on this cable. The problem I had was related to other things on my system that I have since fixed. The ELECAUDIO cable is great value for money.
Sebastien w.
Bon ampli
Bien construit et performant. Satisfait de mon achat. Reçu rapidement et bien emballé. Merci à audiophonics.
Alexander D.
DD TC28CPRO Male USB-C to 2x Female USB-C OTG Adapter This DD TC28 Pro adapter consists of a male USB-C connector as well as two female USB-C ports, one OTG compatible and the other dedicated to charging. The shell of the adapter...
Finally I can charge my device
Finally I can charge my device while my smartphone is connected on my dac
RCA Plug gold plated Ø8mm (Pair) Black These rca connectors are 24K gold plated for maximum conductivity and corrosion resistance. They accept cables with a maximum diameter of 8mm.
En force
Connecteurs de bonne facture avec un niveau de finition très sympa.
Soudure facile et musicalité d’un très bon niveau.
Mais attention, l’insertion sur les embases femelles est très dure avec un risque mécanique évident.
Dommage, car la réalisation de ces prises RCA est sérieuse, et avec un diamètre plus important de quelques dixièmes, elles seraient parfaites, surtout au prix qu’elles sont proposées.
A bon entendeur
Après rodage sonne vraiment bien
Par contre sur un système très transparent elles donnent la limite (ETI tellurium par exemple donne son musical transparent et précis )
Frédéric R.
Dual NO Light Switch 250VAC 15A Green This NO type switch has two luminous green switches, each with two positions. The mounting is snap-in type and is done simply with blade connectors or via a few welds. This...
Très bonne qualité, pas de jeu ou faux contact comme sur certains Interrupteurs bas de gamme.
lucien S.
aucun interet dans mon cas.
ne fonctionent pas pour moi avec en sortie un sony xm800 en hdmi sacd natif sur entre gustard x16 en i2s avec cette interface !!! a savoir......
Jerome A.
Très belle surprise, son fabuleux, excellent rapport qualité/prix
Etonnant de voir le grand nombre de messages élogieux sur cet ampli sur les forums, et le peu d'avis ici.
Après écoute, je partage l'ensemble des avis ici, et d'ailleurs, il n'est pas très design, mais le son... excellent.
Sans fioriture, ni télécommande, aucun gadgets inutiles, pas de marketing de revendeur audio souvent risible, non, mais entrée/sortie symétrique, composant de choix, il va droit au but, le plaisir.
Si vous vous moquez du look, que seul la qualité et le son vous importe, alors vous pouvez acheter les yeux fermés.
Il fonctionne à merveille avec mes casques, denon ah5200, hifiman edition xs, audeze lcd2, il va probablement devenir mon ampli principal.
Comme à l'accoutumé, envoi rapide & soigné de la part du vendeur.
Philippe S.
Monté avec iec 48 ag sur un câble furutech n55s et après une vingtaine d'heures de rodage, la musique sort comme je ne l'avais jamais entendu, cela fait un câble secteur à 700€ mais je trouve que l'investissement en vaut vraiment la peine.
ETI LINK BANANA Banana Plugs Gold Plated Tellurium Copper Ø9mm (Set x4) The ETI Link Banana plugs offer a very nice design quality, ensuring an excellent signal transmission. The contacts are made of gold-plated tellurium copper with a very good...
Musical
Rien a voir avec pangeo et autres qui rajoute des basses et autres la on écoute ce qu'il y a très musical avec de beaux timbres (si votre système en a )
Daniel n.
Excellent service!
I received items within a few days (to the US) but they had lots of dings but were still functional. I contacted Audiophonics and the situation was quickly resolved. I will definitely buy from Audiophonics again - thanks for the great service!
Rodolphe L.
SMPS800RE Power supply Module 800W +/-40V The switching power supply SMPS800RE is a very high efficiency model capable of developing a nominal power of 800 Watts in an extremely small footprint. This power supply is...
Fait le job !
Alimentation SMPS utilisé pour donner vie à un amplificateur classe B. La mise en œuvre est facile, comprend déjà le fusible, le connecteur secteur, reste à ajouter l'interrupteur. Les tensions auxiliaires indépendantes ont une vraie plus value. Les tensions sont respectés en charge.
Mais une étoile de moins car cette alimentation est légèrement bruyante.
Ludo B.
Aucun probléme avec ce transfo. Sous tension et avec il est vrai une charge pas énorme, aucun échauffement et chose étrange, le compteur Linky indique 0va ! Surprenant !! Ce torique doit étre d'une trés bonne qualité !
Ludo B.
Power Supply Board LT1764A +/-15V 2x15V 5V This versatile power supply module provides two 15V outputs or one +/-15V output depending on the wiring, as well as a 5V output. The voltage of each output is adjustable, from...
En observant cette alimentation, on peut voir que chaques détails a été pensés. Qualité extréme ! Méme la couleur du circuit imprimé ( noir ) n'a pas été choisie au hasard. Excellent !!!
Utilisé avec Xlr EIZZ
Monté en Xlr sur Connecteurs EIZZ résultat excellent.
J'ai doublé les néotech sur point froid.
Le RQP est simplement exceptionnel sans dépenser des centaines voire des milliers d'€
EIZZ EZ-205F Female 3 Poles XLR Connector PTFE Platinum Plated Ø9mm Black (Unit) This Eizz EZ-205F 3-pin female XLR connector is carefully designed for good signal transmission. Its contacts are made of Copper alloy and Platinum plated. A PTFE insulation...
Excellents tout simplement
A l'écoute on ne se pose aucune question tout est la de haut en bas .
Jacques B.
Belle qualité !!
Belle qualité de produit. Serrage efficace du câble et excellent contact dans le bornier. A recommander
PS : Il a déjà été signalé que la clé nécessaire est une Torx et non pas une Allen six pans....!!! Le descriptif est toujours à corriger !!!
