Kevin S.
Paulius S.
Very Useful
Nothing to complain.
Paulius S.
Very Good
I like this cable and price very much.
Customers reviews - There are 19318 reviews.
Ferenc M.
KHOZMO ACOUSTIC Relay Volume Attenuator 10k 64 Steps MBB Switching Vishay Stereo With this product, Khozmo offers a very high-end relay ladder volume attenuator with incredible audio performance. This is based on Omron HQ relays rather than mobile contacts...
Very good quality
This attenuator is very good! The clicking sound of the relay is smooth and more quiet than the other I have tried. The display is tricky to be applied to the front panel of a chassis but functional, clearly visible, adjustable brightness.
Pavol B.
perfect isolation pads
Easy to use, good work, very soft and eat many small vibrations and etc. Recoomend it for any hifi device or speakers.
Pavol B.
Perfect full body cable, with 3D soundstage
I use this cable no for bi wiring, but i made him as single wiring in cross connection of wires. What i have to say - is magical, full body cable, with microdetails and 3D soundstage, no harsh or etc, deep bass, timre close to warm, for this price ...same as Mogami i guess, but cheaper. VERY recommend him. PS: is little bit stronger, but still OK
Pavol B.
good just little bit fat
Good strong fabric, just little bit fat, full. This fabric has deep layering, can keep dust to much, hard to clean, and i think also will dump high notes/microdetails... But for covering is OK.
Pavol B.
perfect splitters
Perfect splitters, even little bit expensive. I bout them for ELECAUDIO HP-25OCC cable. Fit perfect. Very nice....thanks...
EXCELLENT
Possédant un ampli numérique audiophonics les borniers d'enceintes sont petits et pas pratiques . Ces fiches bananes sont de bonne longueurs et assurent un contact parfait . Associées à un cable viablue cuivre argent le mariage est idéal. Son propre et net avec du relief ; aucune coloration . A éradiqué la coquetterie dans le médium certainement dû à un problème de contact . Gaine thermo pour la finition du meilleur effet .
Marc J.
très bon rapport qualité prix
Oui l'écoute est bonne au vu de l'appareil et de son prix....mais il ne faut pas s'attendre à une qualité d'écoute bluffante non-plus. Les voix sont sombres, il subsiste un voile sur l'ensemble du spectre et les timbres sont très simplifiés. Il est difficile d'être objectif pour juger cet appareil de toute façon totalement hors catégories. Comment se plaindre d'un appareil combinant ampli et dac pour moins de 150 euros ? L'exploit est là, cet appareil fait fonctionner sans problème des enceintes à 88db de rendement avec une dynamique pas ridicule. Et c'est déjà très bien. Mais on est quand même très loin du rendu musical...
Juan C.
Fantastique!
Après plusieurs mois d’utilisation, je suis encore plus impressionné et heureux de posséder ce dac Gustard. Comme déjà mentionné dans d’autres commentaires, il nécessite plusieurs heures de rodage et gagne vraiment en profondeur et précision avec le temps. Les basses fréquences descendent alors vraiment bien. Après ce rodage, le son devient extrêmement précis, profond avec une scène large. Bref, je ne lui trouve aucun manque par rapport à un dac delta sigma, mais un gros avantage par rapport à ceux-ci: le son est NATUREL et sans dureté. Ce dac fait de la musique avant tout. Un véritable plaisir.
Topissime
Ce câble Mogami est une révélation.
Associé à des prises Rca plaquées or basiques il offre une scène musicale exceptionnelle avec une bonne gestion des basses.
Par contre j’ai supprimé la tresse des deux côtés et c’est mieux je trouve.
Je vais le monter avec des prises plus performante pour voire ?
Bref, essayez le, vous serez étonné
La magie des câbles..
Je suis débutant dans le domaine de la hifi, mais j' ai des oreilles qui sont aussi vieilles que moi...
Je viens de changer mon câble furutech fp 314 AG ( bon câble au demeurant) pour celui ci....
Je comptais changer mon ampli Yamaha pour un ampli a tube (je le ferais surement), mais ce t excellent câble m' a apporté ce qui me manquait, a savoir, de l' aération. Une plus grande scène sonore. Des détails insoupçonnés, et une douceur mais aussi de la force !
Je le recommande , bien qu'il doit exister des câbles encore meilleurs.
Edgar P.
Audiophonics HPA-S400ET
I must say that Audiohonics did it right compared to similar Purifi based amplifiers. It was worth the wait and I bought 2 of these! 2 American companies also make these but Audiophonics clearly made a higher quality amplifier. And I checked inside of both and took lots of pix. These also run very, very cool. compared to my tube amps. I will not compare these to my NAD M23 at more than twice the price. The NAD is not a fair comparison, NAD makes their own modules, also. This Audiophonics amp is serious competition to any amplifier if you are wanting an extremely transparent, clean amplifier. Audio Science Review was extremely impressed. They are notoriously tough reviewers/testers. But let your eyes and ears be the judge of course. I have several preamps to pair with these for now. But I suspect a preamp with XLR connections like my ancient Mcintosh MX130 or better may be needed to get the best out of these great amplifiers. Way to go Audiophonics!! Made in France!!!!!!!
Edgar P.
Outstanding music streamer
WOW! The DMP-A6 is a very impressive, flexible and high quality music streamer. It is paired with a Audiophonics HPA-S400ET Purifi amp and Vincent SA-31 preamp. Speakers for testing this setup are Sonus Faber Lumina V for now.
Anh J.
TONEWINNER AD-1PA+ Power Amplifier Class A Stereo 2x300W 8 Ohm Silver Powerful Class A stereo power amplifier, the Tonewinner AD-1PA+ benefits from a high quality balanced architecture that allows it to develop significant power while ensuring a...
Really a very rare winner; excellent in Class A.
There is a review on Remusic in Italian. Use google translate and you will read the same as i did before i purchased this device. Now i have it and have listened to it for a couple of days i can only say this is a Best Kept Secret Device. Very rare winner. In Class A it is perfect. When used in combination with real hifi devices it does nothing wrong. You sit front row, projection of music is real live experience. All in Class A. Strong and deep Bass. No glare in the high frequencies. Voices are real life voices. Great resolution and wonderfull transparancy. And all this voor 3.400 euro. Remusic compared it with Viola Symphony amplifier. 25.000 euro device beginning this century. I compare it with Coda 16.0, Mcintosh MC 1.25 KW and also a Audreal PA Class A amplifier. This Tonewinner doesn't blush with these competitors. My pre-amplifier is a Accuphase C 3900, AVM PA 8.3 or a Mcintosh C 1100. Loudspeakers BW 801 D4, Chario Academy Serendipity and several others. On all speakers it is doing very well. Really a rare winner. Use a ventilator to cool it down; in Class A it gets very hot. When using in auto configuration it changes very quickly in AB. You miss the Class A experience. Buy it. You will not regret it.
Dr. David M.
Well-designed, easy-to-use + powerful
I purchased one of these to drive a pair of Elac DBR62s fed by a Wiim Pro source connected to the amp via optical cable. The amp is minimalist; produces a clean, transparent sound; and is powerful enough to drive a pair of DBR62s very loud in a small- or medium-sized room without issues and with power to spare. It is well-designed; easy-to-use; rugged; doesn't take up a lot of space; and integrates neatly into my application. This is a high-quality piece of equipment made available at a fair price. It is solid enough that I didn't think twice about purchasing a 2nd unit for use with another application. Recommended.
marco g.
PRE-TC10review
I have used this excellent pre for a diy project where TC-10 drives Nr.2 DSP Tinisyne managing two full 2.1 systems. Perfect for a lot of DIY projects where an high quality preamplifier is needed. Thanks Audiophonics, always a reference.
Nicolas l.
Équilibre et performance
Ce câble est très équilibré et ne zoom pas le haut du spectre « ouf » Aucunes fatigue!
Il à même gommé une très légère acidité sur certains aigus qui était de trop dans la musique de qualité moyenne.
La force de ce câble est le médium qui est chaleureux et bien présent sur les voix.
je ne trouve pas une grande différence sur les graves profond .
Le changement globale de sonorité entre les câble secteur et très discuté mais oui il y a une équilibre différent à l’écoute mais Il faut une électronique derrière et des enceintes qui peuvent vous donner cette chance de le percevoir, est ce n’est pas à 20% de volume qu’il y aura une différence mais plutôt dans les écoutes assez soutenue ou les défauts et qualité sont mis en évidence d’un système.
Je conseil ce câble pour écoute neutre et agréable sans faire de fausse notes.
Philippe s.
Speaker Interconnection Banana Plugs Gold Plated Copper (Set x4) These interconnecting banana plugs are ideal for quick connection/disconnection of a pair of speakers or to extend a cable easily and quickly. They also provide good...
Bonne idée et bonne qualité mais il ne faudra pas les démonter trop souvent car les vis ne sont pas terribles.
Attention : je pensais que le plastique transparent pouvait être facilement coupé (comme les sucres d’électricien) mais il n’en est rien. Si vous voulez 2 paires séparées il faudra les découper avec une Dremel.
Philippe s.
EVERSOLO DAC-Z6 DAC 2x ES9068 XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA The EverSolo DAC-Z6 is a powerful DAC based on a neat technical structure. It embeds high-end components with notably two ESS ES9068AS digital/analog conversion chips and a XMOS...
Packaging exceptionnel tant au niveau esthétique que fonctionnel. Appareil de très bonne facture livré avec un bon câble secteur ainsi qu’un câble USB de qualité. La télécommande en plastique dénote un peu mais comme on bénéficie d’une application smartphone bien pratique, on ne l’utilise pas. Le panel de connections est particulièrement complet. La qualité sonore me paraît au rendez-vous avec une scène sonore assez étendue.
anatole g.
cool & facile
feeling général / usage exclusivement mobile :
- plutôt beau
- plug'n'play (en gros) : association automatique à l'allumage
- potentiomètre un peu vaseux dans l'incrémentation
- s'oublie très facilement
- agréable au toucher
- câble/prises/boutons/construction solide
- autonomie de triple marathonien (en bloutousse) (+/- 4 jours)
- inscriptions/marques (etc) gravées : c'est regrettable
- portée en LDAC (mode "priorité qualité", peu importe ce que ça veut dire) d'environ 5 mètres sans obstacle ..
- pas de contrôle(s?)/play-pause
"son" :
utilisé avec etymotic er3se sur deezer hifi / "source flac" (ou .wav je ne sais plus, enfin high-res) : sympa, j'ai découvert des sons supplémentaires sur des morceaux que je connaissais bien, c'est plaisant. globalement OK ; mais les intras me fatiguent un peu .. j'attends de tester sur le système elac elt-7/
Anh J.
This is a real rare winner. Secret tip. Excellent in Class A. Gets really hot, so i use a ventilator, very silent, to cool it down somewhat. Sound is very clear and clean. Sound picture is first row, but with big, huge and deep soundstage. Great resolution and magnificent transparancy. I play with very expensive devices, but this Tonewinner is worth the money and more. Review on Remusic is bull's eye review. The Tonewinner AD=1PA+ is really comparable with the viola symphony and worth the TAD loudspeakers. Sound is really very vivid and live like. Oncoloured. Deep Bass and no glare. Perfect voices. You can hear the effect of the 60 amperes and more than 200 damping factor. Total controle of speakers. I use BW 801 D4 and the Accuphase C-3900 and MCD 12000. Cumulus 3Tspeaker cables. The Tonewinner does not degrade these devices. Best kept secret.
Savvas P.
ATAUDIO POLARIS Power Cable Schuko IEC C15 Shielded Silver Plated OFC Copper 1.5m The ATAudio Polaris power cable is of exceptional quality and uses extremely pure conductors. Of the six insulated conductors in the Polaris, three are made of OFC 7N copper and...
Beau Cable
Bon rapport qualité / prix
Claude C.
fonctionne
fonctionne parfaitement . a voir dans le temps si les relais tiennent le coup .
Javier A.
Coolest CD player I’ve seen!!
If you’re into collecting CD’s then this is a must! I can’t stress how cool this CD player is, it’s aesthetically pleasing to look at, practical, and doesn’t feel cheap at all. At first I wasn’t too sure about ordering, but I decided to go for it and I’m so glad that I did. The packaging was great and shipping was insanely fast too, it arrived to the US in like 2 days after ordering. Honestly so worth it and one of my favorite purchases!
P v.
Amazing
This Q7 board is a worthwhile step-up compared to the already very capable Q3 + reclocker board. As previous described, more space, detail and musicality / timbre. Highly recommended
Jacek C.
Very good choise
Gustard R-26 - For now, after short tests, I can say that the sound quality improved in all aspects, after changing the vmv d1se, which is also a very good DAC in its class. Purchased with the latest firmware 1.42. The internal streamer works great, also on high resolution files and DSD up to DSD512. I haven't had a chance to test the DSD1024 yet. Earlier issues were fixed in the firmware. Also works great with HQ Player 5.0 after NAA update. I am very pleased with the purchase of the R-26. Audiophonic service and support excellent.
Elia M.
Regulated Linear Power Supply Module LT3045 LT3094 3x +/-15V This quality regulated linear power supply module has an input voltage of 220V AC on IEC C8 connector, and an output voltage of 3x ±15V on 3 pin XH2.54mm connectors. The...
Low ripple/noise psu
Very silent (ripple
Banana Plugs Gold Plated Lockable Ø9mm (The pair) These affordable banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers, while ensuring an optimized contact. The contacts are...
Magnifiques pour câble HP de forte section.
Achetées pour y brancher dedans mon câble HP Sommercable Elephant en 2x4mm2 soit 8mm2 de section.
C'est parfait, ça rentre facilement et il y a même de la marge jusqu'à 10mm2 de section de câble.
Le serrage par écartement de la fiche banane est simple et efficace, on ne risque pas de voir la prise se débrancher par accident.
Un tout petit reproche pour la route... j'aurais préféré des vis à clé Allen plutôt que des vis fendues pour un meilleur serrage.
Mais compte tenu du petit prix, c'est top.
Merci à Audiophonics pour la qualité des emballages et pour la rapidité de livraison !
Très bonne fiche à petit prix.
J'ai branché dessus le câble secteur Sommercable NYM-ST-J et cela convient parfaitement.
A l'autre extrémité, j'ai branché une prise mâle schuko Sommercable pour obtenir un très bon câble secteur.
Livraison super emballée et très rapide., top Audiophonics.
Vraiment rigide !!
J'avais lu que ce câble (marqué Général Cavi) est rigide.
Ayant coupé une longueur de 0,80 mètre puis placé une prise Schuko femelle Schurter et à l'autre extrémité une prise mâle Sommercable, le câble tient droit devant moi comme un bâton.
Vraiment rigide mais je peux quand même l'utiliser pour brancher mon ampli à lampes.
Constitué de 3 fils rigides monobrins de 2.5mm2 + un fil métallique supplémentaire plus fin et monobrin aussi (que j'ai branché avec le fil de terre) parcourent ce câble, il est effectivement blindé.
Le son est clair, plus transparent qu'avec un câble secteur ordinaire.
Bon achat, je suis toujours ravi de la qualité de l'emballage et de la rapidité de livraison par Audiophonics.
Janne K.
Hey, it works!
Perfect for a headless Plexamp pi feeding a Genelec SAM system! :-)
The missing star is for lack of documentation and a little for lack of a suitable case. Stole the idea to use a low profile passive heatsink case from Geekworm and cannibalize their acrylic plate "case" for a hood and bits, Works, but the hat still remains pretty exposed.
What's actually needed to get it working: 'dtoverlay=hifiberry-digi'.
Can't figure out (with enough certainty, not going to guess) where/how to wire a coax S/PDIF output; Really should be documented here.
Ne pas hésiter à bien asperger le disque . J'ai rempli un pulvérisateur de ce nettoyant . Après séchage avec un deuxième chiffon prévu à cet effet les craquements reculent de façon significative .
Elom G.
Très bon DAC
Très bon dac et ampli casque. J'avais un radson earstudio dont j'étais déjà très content, mais avec ce Fiio K3, j'ai une meilleure résolution: le son est clair et limpide.
Seul bémol, j'imaginais la puissance de sortie plus importante sur le mini-jack 3,5 mm.
Bilan globale : je recommande !
Ioannis K.
Excellent for small components
Very good for small stuf.I am using them in my VMV D1SE DAC replacing the annoying factory spikes.It does the job.
Ioannis K.
Very good quality product
Used in my Unico hybrid integraded amplifier.I am enjoying the excellent sonic characteristics.Replaced the previous Mullard ones with very short life (unfortunatelly!).Not as brilliant as Mullards but very musical and pleasant with a lot of body in mids.I hope the will last more...
Laurent B.
DAYTON AUDIO IMM-6S Measurement Microphone for Smartphones and Tablets The Dayton Audio iMM-6S is a professional quality measurement and recording microphone designed to work with iDevices (iPad, iPhone, iPod) as well as Android and Microsoft...
Microphone de Mesure pour Smartphones
Microphone de qualité robuste et livré dans une boite métallique.
Claudio R.
Toute la HiFi dont j'ai raisonnablement besoin - filtrage USB recommandé +++
Cet avis va de pair avec quelques "conditions bonne-pratique" propre à mon utilisation de n'importe quel DAC USB ou interface audio USB : un bon câble USB qui isole bien les conducteurs pour données des conducteurs pour l'alimentation, et un filtre USB (dans ce cas un Pure Clock de chez Oehlbach) qui va permettre de réduire davantage le jitter en isolant le signal des données de celui du transport d'alimentation au niveau du port USB.
Sans le Pure Clock, ce petit DAC donne un son de qualité, agréable, bien meilleur que celui de votre chipset audio. Mais avec le Pure Clock d'Oehlbach, on passe à un autre niveau et on se rend compte de quoi il est vraiment capable : un son extrêmement bien contouré et précis, d'une fidélité que je ne m'attendais vraiment pas à écouter. J'ai été le premier surpris car j'ai surtout mis le filtre pour éviter les parasites et autres saletés éventuelles. Et en fait il a tout simplement révélé les véritables qualités de ce DAC qui offre bien plus de haute-fidélité que ce dont je pensais en tirer. Comme pour nous autres, êtres organiques : une alimentation saine pour des performances optimales.
Vincent P.
Petit mais costaud
Le plus petit dongle dual DAC avec contrôle du volume du marché (j'ai épluché des tonnes de pages produits) ! Si le form factor et le design sont excellents, le son n'est pas en reste, il drive parfaitement mes Sennheiser IE800 et se débrouille très bien avec mon Denon D9200.
Laurent B.
AUDIOPHONICS RASPDAC Kit DIY Streamer for Raspberry Pi 2 / 3 & DAC This RaspDAC kit contains the Aluminum case, button, display, HDMI extension, Micro SD extension cable and the necessary hardware to mount your DIY network drive. DAC and...
5 ans après
RAS tout marche si vous ne modifiez rien au niveau software (sur Volumio 2.619
nicolas m.
rapide
rapide et bon produit
Vincent D.
IBASSO DC03Pro Portable DAC Headphone Amplifier 2x CS43131 USB-C 32bit 384kHz DSD256 Silver With the DC03Pro, iBasso offers a portable DAC and headphone amplifier combo as compact as it is powerful. Thanks to an optimized design based on the use of quality components,...
bon
utilisation sur pc portable et iphone14 pro max .flac 16 et 24 bits bonne restitution sur HD 599 et ROG cetra II en attente d'évolution ...
Bonne finition général , néanmoins un jeu au niveau de usb-c !
Nicolas S.
Très bien !
Ampli compact par sa taille mais belle restitution sonore sur mes triangle antal 902. Son précis et transparent sur tous types de music ( jazz, chant, pop). Ecoute en flac uniquement pour le moment. Belle puissance en réserve et surprise! Graves profonds!!
et fermes . Borniers enceintes un peu petits.
Jose M.
Simple et efficace
Utilisé sur un vieux Denon PMA 280 afin de lui ajouter des entrées numériques, le résultat est excellent sur des Focal Chorus 726. Audiophonics toujours aussi bien en qualité de service et conseil.
Christian M.
Contre-pointes de très bonne qualité, bien finies et de très belle apparence, ce qui ne gâche rien. Je les utilise sous des enceintes (colonnes, 12kg) posées sur du marbre. Le déplacement des enceintes est très facile, sans ajouter de feutre ou quoi que ce soit et - pour l'instant du moins- le marbre n'est pas marqué par le glissement du métal. Je conseillerais volontiers ce produit..
THIERRY P.
TOPPING NX7 Portable Headphone NFCA Amplifier Balanced Black The Topping NX7 is a compact and powerful portable amplifier, offering a beautiful precision and richness of sound. It is equipped with a new NFCA amplifier circuit specifically...
Etonnant Nx7 !
Couplée avec le Dx170, vous prenez un gap sonore bluffant, la profondeur de scène et énorme, ainsi qu`une basse présente et bien texturée, la largeur de scène prend aussi de l`ampleur, le tout et magique ! Un achat de haute qualité.
THIERRY P.
Etonnant Nx7 !
Sur mon DX170 couplee avec le N
Joel G.
Passive Preamplifier converter RCA to XLR / XLR to RCA Silver This passive stereo 10kΩ volume controller allows you to switch from balanced XLR to unbalanced RCA inputs and vice versa, from unbalanced RCA to balanced XLR. The two...
Very good for its price
This little box works great when used from balanced in to balanced out. When going from unbalanced in to balanced out, I experienced some quality loss, but only on certain loud numbers / passages. I guess it is not expected for a passive pre in this price range to be able to balance an unbalanced source. Unbalanced in to unbalanced out worked great too. The only case I didn’t try was balanced in to unbalanced out. As a curious person I opened my unit and saw that the potentiometer has printed C20K, I guess it is actually a 20K potentiometer? Anyway, it sounds great and the price is great
Rodolphe L.
Bon Ampli
Bon ampli avec des composants de qualité, qui marche bien, simple à mettre en œuvre. Cet ampli image très bien en stéréo, tout les instruments sont bien localisés. La bande passante est large, les basses sont rondes et bien tenues. Le médium-aigu ressemble à un son d'ampli à tube.
Ensuite affaire de gout, très subjectif j'aurais aimé un peu plus de texture, de matière sur les timbres pour que ce soit parfait, Je sais je suis exigeant. Cette remarque qui n'enlève rien à la qualité du produit qui est très bon.
Enrico R.
MAXWELL Supercapacitor 2.7V 325F This Maxwell supercapacitor provides significant energy storage for demanding applications. Supercapacitors are an ideal choice for applications requiring large amounts of...
Pay attention to soldering
Pay attention to the supercapacitor soldering because their mass need for a powerful soldering tool (at least 80 W, but i suggest also 100W) and a good practice skill. I also suggest a liquid flux for electronics.
Enrico R.
IAN CANADA UCCONDITIONER Ultra Capacitor Conditioner Board 5V The UcConditioner 5V is a ultra capacitor signal conditioner board operating with a 5V power supply. It will significantly improve the quality of your...
Pay close attention for supercapacitor soldering.
Very good product. It transforms the power supply at a higher quality level, with a better sound quality (if the audio circuit is equally audiograde). Pay attention to the supercapacitor soldeing because their mass joined to the large soldering area need for a powerful soldering tool (at least 80 W, but i suggest also 100W) and a good practice skill. I also suggest a liquid flux made for electronics.
Enrico R.
IAN CANADA SHIELDPI PRO Multifunction Board EMI Shielding / Power Supply Filter for Raspberry Pi Ian Canada's ShieldPi Pro is not only a universal EMI shielding module for Raspberry Pi, but also a high performance power supply filter, ON/OFF control button and GPIO...
Excellent product
At this price this is a really excellent product, the effect on the sound is clearly perceptible. I put it on my Raspberry 3B between it and a R2R DAC and the result leads to an undeniable clarity improvement.
