Bruno R.
C'est la deuxième
Lefebvre F.
Produit au top
J'adore. Très bon son.
Seul...
Lefebvre F.
Très correct pour ce prix
Customers reviews - There are 19707 reviews.
Todor S.
Great device!
I have a USB powered DAC and I could hear the noise from my desktop PC. To solve this problem I use iFi iDefender+ in combination with Allo Nirvana and everything works perfectly. The noise is completely gone and the sound quality has improved significantly. Highly recommended device!
Joan M.
Very solid product
This is a very solid product you can trust when building your next DIY project.
Front panel is aluminum, very elegant finish
Rear panel is steel so you will need cobalt or titanium drill bit.
Fortunately for us IEC rectangle and fuse holder are already drilled
Jean-Francois B.
Parfait!
J'utilise cet adaptateur sur mon Hugo2 et franchement c'est du solide. J'en ai pas mal d'autres de ce type mais d'autres marques et c'était faux contact sur faux contact! Avec celui là, c'est parfait.
Alain S.
E1DA POWERDAC V2.1 Headphone Amplifier FDA TAS5558 320mW 32 Ohm E1DA's FDA PowerDAC V2.1 headphone amplifier builds on the excellent foundation of its predecessor, the PowerDAC V2, while now allowing operation with both balanced and...
Le seul FDA pour casque du marché
Produit exceptionnel à de nombreux égards ...
Il a l'audace d’être à la fois moins cher et meilleur que tous ces concurrents dans le domaine (sans parler des possibilités de réglages inédites).
Si vous aimez l'écoute aux casque et intras foncez !!!
WONDOM AA-AB31471 Class D Mono Amplifier Module TPA3110 30W 4 Ohm The Wondom AA-AB31471 is a small, simple and efficient Class D mono amplifier module. It includes a TPA3110 TI chip to enable it to provide a power of 30W for an efficiency of...
Wondom AA-AB31471 review
I bought this little amplifier for my portable system with JBL Control 1 Pro speaker. It is incredible what this little amp can do, it makes declared 30W with the 19Vdc power supply. I posted a review at ASR:
https://www.audiosciencereview.com/forum/index.php?threads/wondom-aa-ab31471-1-x-30-watt-class-d-amplifier-board-review-and-measurements.46972/
laurent A.
Discret et efficace
Merci a Audiophonics pour l'efficacité.
Dac discret, bon son naturel, son mat et flatteur avec les enregistrements de moyennes qualités.
Parfait pour le prix
Ruben B.
a well build super clean amp
It's a great clean amp, a class D amp that does not sound like one like all NCore amps, it's just gain on a wire. Build quality is good, design is basic, but so is the price compared to other builds. The only complain is that the led on the power buttom is way to bright (but modable).
Pascal B.
En remplacement de 4 patins Linn Skeet en fonte d’alu , ces contrepointes font merveille sous les pointes de mes plateaux supportant mes deux lecteurs Luxman ( D05 pour les cds et PD171 pour les vinyles)
Amélioration de la spacialisation et du réalisme de la scène sonore . Je suis ravi .
Décidément, Audio Bastion est une marque qui sait lutter contre les perturbations dues aux vibrations !
excellent raport qualité prix
Cette alimentation est vraiment silencieuse et enlève le stress sur le hautes fréquences. Précision : elle est connectée sur un boitier de filtrage du courant du secteur. Pour le prix, elle est parfaite.
ATAUDIO POLARIS Power Cable Schuko IEC C15 Shielded Silver Plated OFC Copper 1.5m The ATAudio Polaris power cable is of exceptional quality and uses extremely pure conductors. Of the six insulated conductors in the Polaris, three are made of OFC 7N copper and...
qualité
Câble bien construit avec des fiches de qualité. Utilisé entre la prise secteur et mon transformateur de filtrage de courant, il conserve la dynamique de mon système. Il est parfait pour un prix très raisonnable.
Hector S.
Banana Plugs Silver Plated Ø5mm (Pair) These low-cost banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers. The contacts are silver plated to ensure excellent signal...
Excellentes
L'efficacité du maintien est admirable, la fabrication est exemplaire. Elles s'insèrent avec douceur dans les prises des appareils.
C'est du zéro prise de tête; exactement le type de petits matériels qu'il est utile de toujours avoir en réserve.
Bastiaan v.
parfait, très content
Acheté en remplacement d'un IFI Zen V2 qui n'arrêtait pas de faire des micro coupures dans le flux. Un violon qui se coupe ce n'est pas possible.
Aussitôt branché, aussitôt trouvé par l'ordinateur. Le son est parfait, un peu plus chaud et un poil moins défini que le processeur Sabre de l'IFI Zen, mais ce sont des affaires de gout.
Pour 65 euro c'est un appareil fantastique, bien construit. Et surtout, depuis 4 heures d'écoute aucune coupure, même si j'ai traversé la pièce et donc les ondes Bluetooth des nombreuses fois. Envoi rapide, rien a dire.
Laurent B.
TRIANGLE SYMPHONIE SYS25A Speaker Cables OFHC Copper Silver Plating 2.5m (Pair) The Triangle Symphonie speaker cable has been designed to ensure excellent signal transmission quality, thanks to the use of high quality materials. It uses large conductors...
Agréablement étonnant !
Dubitatif quant à la nécessité de changer mes bon vieux et basics câbles d'enceintes.
J'en reconnait l'utilité maintenant avec ces "câbles triangle symphonie".
Je n'ai pas changé d'enceintes (des triangles) et pourtant !
Plus de détails dans tous les registres , moins d'agressivité et plus de finesse dans les aigus, des médiums enchanteurs et des basses plus profondes et tendues.
Je redécouvre des morceaux de musique avec des détails non perçus auparavant et pensait que mes enceintes donnaient déjà leur maximum, il n'en était rien.
Câble de qualité de fabrication reçu rapidement par Audiophonics.
Rien à redire.
Patrick G.
Etonnant!!
Par sa musicalité:donne corps aux notes musicales.Tout est à sa place concernant les timbres,la dimension spatiale....Au vu du prix,bluffant!!!!
placé entre mon drive cd shanling tempo et mon DAC reimyo 777mk2.Mon commentaire n'a de sens qu'à l'ecoute de mon système....A essayer avant tout achat définitif.
Laurent B.
Qualité de fabrication, esthétisme et efficacité.
Ces jumpers sont très bien fait, la qualité est au rendez-vous.
Certes ils sont grands et assez visibles mais ils sont beaux.
Je les ai mis en place et achetés en même temps que mes câbles "triangles symphonie " et ai gagné à l'écoute sur tous les registres.
Plus de clartés, de précisions sur les basses et hautes fréquences.
C'est grâce aux câbles d'enceintes ou à ces jumpers, c'est évidement les deux.
Reçus dans une jolie petite trousse à conserver et bien emballés.
Livrés rapidement ,rien à redire.
Léo Q.
Presque
La prise en elle même est très bien. J'adresse cet avis surtout pour le fabricant Elecaudio car il est dommage de proposer une prise coudée si grande alors qu'elle est sensée permettre de gagner un espace important. J'ai heureusement pu la bricoler à l'aide d'une ancienne référence Elecaudio PI-22G. En effet la partie iec de celle ci remplace parfaitement celle prévue permettant un gain de 8 mm environ. C'est donc dommage de ne pas directement proposer une référence plus petite constituée directement de bonnes pièces. A bon entendeur.
Niklas R.
Great Cable
Used this cable for DIY microphones. It's easy to solder, flexible, and very stable, while having a small diameter.
EXCELLENT UPGRADE
Pour un prix très modique ce LM4562 fonctionne à merveille sur l'amplificateur Aiyima A07. Belle dynamique, définition excellente et image stereo superbe en largeur comme en profondeur. Je le
préfère même à mon autre Aiyima A07 équipé de deux AOP Sparkos
Jean Louis G.
Ca fonctionne !
J'étais dubitatif mais c'est efficace : meilleur discernement des différents instruments, image sonore agrandie et stable, impression d'ouverture plus grande, que du subjectif mais facile à mettre en oeuvre et la comparaison avec- sans est immédiate et parlante. A recommander pour le prix dans un système ayant pour point de départ un Mac et Roon (chez moi)
Fabian T.
MINIDSP FLEX DIGITAL Audio Processor DSP SHARC ADSP21489 XMOS Bluetooth The Flex Digital miniDSP is the brand's 3rd generation 2-in/4-out audio processor. It keeps the powerful floating point processor previously used with a redesigned input/output...
Nettes améliorations
Ce minidsp Flex D vient en remplacement d'un Minidsp 4x10HD.
Avec l'aide de deux DAC1 Benchmark, l'idée était d'améliorer la qualité sonore du 4x10, chose réussie mais un peu normale eu égard aux moyens mis en oeuvre.
Parmi les améliorations :
- meilleure connexion logicielle
- télécommande moins capricieuse
- affichage sympa qui heureusement s'estompe automatiquement
- entrée analogique plus silencieuse
Les gros regrets sont :
- pourquoi un deux fois deux voies ? Il eut été beaucoup plus intéressant d'en faire 4 x 2 voies stéréo. C'est vraiment le gros regret, il suffit de voir comment les Nonodigi s'arrachent sur le marché de l'occasion. Du coup, la troisième voie a été filtrée en passif. Les sorties optiques ne sont qu'un dédoublement des sorties coaxiales.
- suppression de la possibilité de configurer une entrée avec le contrôle de volume désactivé, cette fonction était intéressante pour y brancher un ampli
C'est vraiment dommage pour ces deux points car ce sont des fonctions qui ne coutent rien d'autre qu'une programmation logicielle, mais il n'y a pas d'autre alternative à un tel produit sur le marché, ce minidsp reste donc la seule possibilité confortable et abordable pour faire de la filtration active, mais en deux voies uniquement à la base.
Ghislain R.
SYITREN R300 CD Player on Battery Bluetooth 5.3 Black / Wood The Syitren R300 is a small CD player with a nice retro design. Equipped with a Toslink optical output and a Jack 3.5mm headphone output, it will allow you to enjoy your CD...
Fonctionne sur batterie rechargeable avec un chargeur de mobile.
D'où faible bruit. Bien insérer le disque. Relié (optique) à un DAC (2XESS 2038). Résultat très bon. Excellent pour le prix.
Francois g.
Très bon dac
Une très bonne surprise, derrière un lecteur cd/sacs/dvd Cambridge avec volume numérique et devant un Audio research D70, c’est somptueux. C’est fluide, c’est timbré et pas du tout fatiguant sur des écoutes longues. Bref, ce dac me rempli de joie depuis son acquisition.
Nikolay S.
1877PHONO TAD-2R DIN Angled Female 5 Pin gold plated Black
La qualité est excellente ! J'ai commandé 1 autre article, mais cette fois via une méthode d'expédition différente. Contrairement à la dernière fois où j'ai attendu 40 jours, maintenant l'envoi est arrivé en une semaine !
Trevor J.
FURUTECH LAN-8 NCF Ethernet RJ45 Cat8 Cable S/FTP 1.2m Furutech LAN-8 NCF is a beautifully designed Category 8 RJ45 Ethernet cable with S/FTP shielding for high-speed signal transfer.
Average performance
This is not high end.
It is not worth the price.
Two stars could be too much for it.
SUPERBE!
Beau matériel, bien pensé. Belle plénitude. Livraison hyper rapide.
Emballage top: Audiophonics oblige !
Pierre L.
PARFAIT POUR UN QUAD 405 !
Restauration de l'alimentation d'un Quad 405, remis à niveau il y a 10 ans, avec un kit DADA. Les deux cartes DADA sont désormais parfaitement alimentées : les basses sont profondes, le son excellent. Le résultat est époustouflant !!! Le transfo de 5 kg et les condos sont remplacés par cette alimentation SMPS500R de 230 gr !!! Cette opération est à la portée d'un bon bricoleur. l'ajout d'une carte de protection des HP est indispensable. J'ai ajouté deux ventilateurs Noctua totalement silencieux à l'extérieur et devant le radiateur du Quad 405.
Goran D.
TOPPING A30 PRO Headphone Amplifier NFCA Silver The Topping A30 Pro is a high quality NFCA headphone amplifier that will delight lovers of headphone listening. With two headphone outputs at different impedances and a...
A30
Champion
Goran D.
Pack Topping E50 Balanced DAC + L50 Balanced Headphone Amplifier + TCT1 Jack 6.35mm Cables Silver This Topping pack is composed of a balanced DAC E50, a balanced headphone amplifier L50 and cables Jack 6.35mm TCT1 allowing the connection of both devices. This set will allow...
E50/L50
I'm overjoyed
Goran D.
IBASSO DX170 Digital Audio Player DAP 2x CS43131 Bluetooth 5.0 aptX LDAC WiFi Android 11 Blue iBasso offers with its DX170 an excellent audiophile DAP. This one benefits from a careful design, using quality components, allowing to provide a faithful, precise and dynamic...
DX170
Fantastic
Goran D.
MOONDROP ARIA In-Ear Monitors IEM Dynamic 10mm 122dB 32 Ohm 5Hz-36kHz Moondrop's Aria in-ear headphones combine balance, transparency, richness and a wide sound stage. They integrate a dynamic 10mm transducer within a double magnetic cavity, with...
Aria
Nice, very nice
Ben L.
Essential to truly set up your Wondom JAB amps!
The amps work fine out of the box, but you get an almost infinite amount of options if you use the programmer, it is easy to get lost in SigmaStudio exploring all the different modules!
It is in my opinion an essential addition to any Wondom or Dayton Audio DSP/amp with DSP!
Note: with the JAB5 you won't have the Miumax Bluetooth phone app as an option, but the Miumax/Wondom PC UI desktop program works perfectly with most of them
SigmaStudio works with all of the DSP amps with an ADAU chip
Ben L.
WONDOM JAB5 AA-JA33286 Amplifier Module Class D Bluetooth 5.0 DSP ADAU1701 4x100W 6 Ohm The JAB5 is an integrated 4-channel audio amplifier board with Bluetooth 5.0 (aptX HD support) and DSP ADAU1701, offering a true all-in-one audio solution. It delivers 4x100W of...
Relatively small, yet powerful!
Awesome amplifier, for it's size you'd never expect it to get this loud (if you supply it with a high enough voltage, it needs power to create power, preferably 34V!)
Easy to set up a pair of channels in bridge mode, it literally has banana plugs for it.
That makes it very easy to make a 2.1 setup or a 3 way active speaker (sub/low, midrange, tweeter), or 2 2-way bi-amped speakers
it isn't super quiet so on high efficiency drivers you'll definitely hear some white noise
The default program in SigmaStudio the amp comes with has a low volume cutout, so under a specific volume it wont play
Thanks to the inbuilt DSP you can very easily tune it to your room or even improve the overall response
using REW (Room EQ Wizard) and a measurement mic you can measure the response and save it, which you can then import in Sigma Studio to have it as flat as possible, after that you can apply your own EQ and have it tuned to your preference dependant on what a kind of sound you want.
Aristotel Eduard G.
Good quality linear power supply
I had ordered this linear power supply 5V 2A for powering a WiiM pro streamer. I replaced the original charger with this power supply. Very good quality I can say that the streamer is sounding very good and detailed. After a month of using I recommend this product. Delivery was a big surprise, I got the package in RO in 48 hours after ordering !
Doris G.
A07 pro + NJR MUSES 8920 AOP
Excellent résultat. Un son pur comme je n'ais jamais entendu.
2ème avis ( astuce )
J'ai obtenu le meilleur résultat en le posant sur le plateau caoutchouc ; gain en détail et dynamique flagrant ; un kif à l' écoute ! la surépaisseur ne gêne apparemment pas la lecture mais je n'aurai peut être pas osé avec une platine de plus grande valeur ; à essayé pour les curieux …
sans compromis ...
J'ai attendu plusieurs mois avant d'émettre un avis ; le temps d'un bon rodage . Ce câble est très sensible à l'environnement . Au début j'avais un son très détaillé mais un peu dur ; en remplaçant les pieds de mon cd par des pointes les détails était toujours là mais avec un grand naturel . Scène sonore large ; on entends tous sans agressivité ; présence sonore réaliste mais pas caricaturale . Cable pour mélomane ; attention câble sensible qui pourra valoriser les défauts de votre système ; à associer avec des éléments de bon niveau .
Pascal B.
Remplacent des match point 300 ssc sous mes Egglestonworks Fontaine signature . Il n’y a pas photo entre les deux ! Les contrepointes Audio Bastion X pad ont permis d’augmenter la richesse du message sonore de manière très significative . deux jours après la mise en place , une musique plus présente , des extinctions de notes qui s’allongent , en bref ce que j’attendais ! J’envisage d’équiper mon meuble des pieds titan de la même marque !
Pierre s.
Problème chauffe
Cette alimentation est excellente. Néanmoins, branchée à ma box et NAS (tous 2 donnés pour du 12V/5A), elle chauffe beaucoup avec un seul appareil branché (box) et le capot devient même brulant avec les 2 appareils connectés. Le SAV Audiophonics m'a aimablement répondu en me disant que c'était normal mais un an après son utilisation, je me demande si elle n'a pas simplement de mal à alimenter les 2 appareils en même temps. Du coup, je me contente de la seule box branchée...
Rodolphe L.
Modules avec du potentiel
Point négatifs:
- Pourquoi diable des modules en miroir ? Pratique quand on met les deux amplis dans un seul coffret. Mais pas pratique quand on fait deux coffrets. Quid de la stricte équivalence des modules ?
- L'aigu pas assez précis à mes oreilles, balance subjective tonale trop grave ? Peut être lié à la classe de fonctionnement ?
Points positifs:
- Le double mono a une image sonore très aéré et précise dans les basses et médiums.
- La tenue des hauts-parleurs est bonne dans le grave. Mes deux 12" par enceinte sont bien pilotés dans les graves.
Par curiosité pour écouter car il y avait le schéma qui montre une contre réaction en courant et pas de condensateur sur le circuit de contre réaction et en plus des circuits cascodes. Je m'attendais à de meilleurs aigus, trop métallique à mon goût, mais c'est peut être lié à la classe de fonctionnement des transistors de sortie, qu'on ne les fassent pas plus travailler en classe A ? Possible avec de plus gros radiateurs...
Du potentiel donc !
Andoni G.
Good plug
Look solid with good gold plate
Best plug for price
Andoni G.
Good plug
Easy yo handle and Solid ay barca un price
Sebastien D.
Remplace aisément daphile que j'utilisais avant, certe c'est un coup à l'achat comparé à daphile qui est un logiciel libre mais c'est tellement plus confortable, le son du dac interne est magnifique et niveau encombrement c'est qd même agréable d'avoir tout en un, j'ai un abonnement qobuz et un SSD 4to déjà rempli de 2,5 to de flac et DSD encodés en DTS 5,1 et SACD 2.0 et 5.1, tout y passe même les "ISO" c'est le top, que demander de plus à part peut-être pouvoir installer toutes les apk intéressantes du play store? En fouillant bien on arrive à en avoir mais il faut des appli qui ne demandes pas de compte Google... Allez j'y retourne
Fantastique amplificateur
je viens d'acheter d'occasion cet ampli "chinois".....
eh bien ils savent faire de très belles choses.....
cet ampli fait fonctionner à merveille mes onkyo D302D pour lesquelles je cherchais un ampli capable de bien les driver.....des possesseurs de ces enceintes disaient qu'elles ne pouvaient rien donner à bas volume....avec l'audio gd leur théorie se casse la figure....une main de fer dans un gant de velours....c'est d'un naturel confondant !!! une fluidité à faire pâlir nombre d'amplis à lampes....l'équilibre entre les registres est parfait et les timbres sont justes !!! je n'ose imaginer ce que peut rendre son grand frère le master 10 mkII....pour tout vous dire l'écoute est aussi agréable que celle que j'ai pu faire de blocs mastersound à base de 845 associés au pré-ampli phl5.....cet ensemble vaut 20 fois le prix du precision 2 !!!!
Christophe M.
Super câble mais….
Je vous avouerais que en recevant mon colis avec le câble et des prises NCF je flippais grave car là ça commençait à chiffrer. J’ai eu l’expérience du tcs31 qui n’a pas été convaincant . Aussi, après avoir monté le tout minutieusement, je le branche sur mon Dac rien ne ne se produit…Je commençais à changer de couleur. J’essaie avec mon préamplificateur Yamaha c5000 : moins bien que le Thunder d’Audioquest. Ma dernière cartouche etait mon conditionneeur secteur qui avait un câble Gigawatt de base. Et alors là, c’était le grand spectacle. Hyper detaillé très beaux timbres un grave propre espace sonore très large (on repousse les murs) . En résumé génial mais avec un conditionneur secteur ou une barrette point final.
Pierre Yves P.
Bonne embase solide
Bon produit, dommage que la photo montre 5 poles à 180 ° soit inexacte, les poles du modèle fourni sont bien à 240°
Nasser A.
Magic Box
Je cherchais un convertisseur de qualité à un tarif accessible pour épauler mon lecteur réseau Wiim Pro. En parcourant les tests et avis sur Internet je suis tombé sur ce modèle qui fait l’unanimité chez les audiophiles avertis.
Le boîtier ne paye pas de mine avec ses dimensions réduites et son côté austère mais la construction a l’air solide.
La connectique est suffisante pour mon utilisation avec des entrées Usb, optique et coaxiale. Pour ma part, l’entrée Usb sert au branchement à une prise secteur. Si c’est le cas pour vous aussi pensez à commander un chargeur+câble usb-c/usb-c non fournis avec l’appareil. Seul le câble usb / usb-c est présent dans la boîte pour le branchement à un ordinateur.
En ce qui concerne le SON je ne m’attendais pas à une grande amélioration par rapport à la conversion du Wiim Pro et surtout à mon précédent convertisseur Audio GD valant 10 fois plus cher.
Dès les premiers morceaux la surprise est totale : une sensation de présence accrue, une scène plus précise et une belle transparence. L’écoute est donc très naturelle sans coloration particulière et avec du détail.
J’ai préféré la connexion coaxiale à l’optique, un peu plus organique à mon oreille.
La plus-value est réelle sur mon système. Je confirme donc la très bonne réputation du SMSL SU-1. Ce petit boîtier est tout simplement étonnant surtout au vu du prix. Je ne regrette pas mon achat et ne suis pas près de changer.
Cinq étoiles, sans réserves.
Frédéric S.
Un poil trop de jeu
Attention diamètre interne de 5.6 certaine prises mâle se déconnectent trop facilement.
Jean-Marc H.
Après 9 ans passé en compagnie d'un Audio-gd NFB 2.32, je ne voyais pas d'autre alternative que de le remplacé par un autre Audio-gd
Comme stipulé dans d'autre commentaires, en terme rapport performance prix, difficile faire mieux. Neutralité, nuance et restitution précise, mais plus analogique que chirurgicale...Donc plus naturel sont au rendez-vous. Il y avait déjà de ça dans mon ancien DAC et c'est pour cela que je suis resté chez ce fabricant.
Jean-Marc H.
Très bon tube
Utilisé depuis un peu plus d'un an sur des bloc mono (DIY) en push-pull, j'en suis très satisfait. Elles ont remplacé des Gold Lyons KT88 avec beaucoup de bonheur. Un son plus claire, plus aéré et un gain significatif en transparence. J'appelle "transparence" neutralité. Le matériel s'efface derrière la musique. La réserve en puissance permet de voir loin, en durée de vie, car elles encaissent mieux les montées de courant intempestive lors de la mise en route par exemple et accessoirement permettent un choix d'enceinte plus étendu ; plus de 60W par bloc dans mon cas, je peux leurs coller du HP à faible rendement sans arrière pensée.
