JJ ELECTRONIC ECC99 Tubes Double Triode (Matched Pair)
The ECC99 tube from JJ Electronics is a 9-pin double triode tube designed to be used as a driver for direct-heated power triodes. However, the ECC99 can also be used directly as a power tube.
Reference : 21720
89,91 €tax incl.
74,92 € tax excl.
Shipping date: 25-11-2026.
Photo of a pair of JJ ECC99 tubes
Chart of the JJ ECC99's specifications and dimensions
Product typePower tube
Tube typeDouble Triode
Number of pins9
Maximum dimensions68.4 x 22mm
Electrical Specifications
Filament heating voltage (Uf)6.3 ou 12.6V
Filament heating current (If)800 ou 400mA
Anode operating voltage (Ua)150V
Grid control voltage (Ug)-4V
Plate current (Ia)18mA
Mutual conductance (S)9.5mA/V
(Ri)2,3kΩ
Amplification gain (μ)22
Limit values
Anode voltage (Ua)400V
Cathode current (Ik)60mA
(Uk/f)200V
Anode power dissipation (W)5W
Contacts number9
Tube typeDual Triode
The ECC99 tube from JJ Electronics is a 9-pin double triode tube designed to be used as a driver for direct-heated power triodes. However, the...
