JJ ELECTRONIC ECC99 Tube Double Triode (Unit)
The ECC99 tube from JJ Electronics is a 9-pin double triode tube designed to be used as a driver for direct-heated power triodes. However, the ECC99 can also be used directly as a power tube.
Reference : 21725
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 25-11-2026.
Photo of a JJ ECC99 tubes
Chart of the JJ ECC99's specifications and dimensions
Product typePower tube
Tube typeDouble triode
Number of pins9
Maximum dimensions68.4x22mm
Electrical Specifications
Filament heating voltage (Uf)6.3 ou 12.6V
Filament heating current (If)800 ou 400mA
Anode operating voltage (Ua)150V
Grid control voltage (Ug)-4V
Plate current (Ia)18mA
Mutual conductance (S)9.5mA/V
(Ri)2.3kΩ
Amplification gain (μ)22
Limit values
Anode voltage (Ua)400V
Cathode current (Ik)60mA
(Uk/f)200V
Anode power dissipation (W)5W
Contacts number9
Tube typeDual Triode
The ECC99 tube from JJ Electronics is a 9-pin double triode tube designed to be used as a driver for direct-heated power triodes. However, the...
