DOUK AUDIO T4 PLUS Tube Phono Preamplifier
The Douk Audio T4 PLUS is a JAN5725W tube MM/MC phono preamplifier that also features headphone amplification with NE5532 OPAmps. Versatile, it incorporates an input impedance switch (1KΩ/470Ω/220Ω/100Ω/47Ω/22Ω/10Ω) making it compatible with most turntables and cartridges. The JAN 5725W tubes, coupled with a TL071+JRC2068 phono preamplifier stage, deliver a warm and smooth sound when listening to vinyl via the RCA line output.
Reference : 21110
114,00 €tax incl.
95,00 € tax excl.
Shipping date: 24-11-2026.
Douk Audio T4 PLUS Tube Phono Preamplifier JAN 5725W  Headphone Amplifier NE5532
Photo du DOUK Audio T4
The Douk Audio T4 PLUS is a JAN5725W tube MM/MC phono preamplifier that also features headphone amplification with NE5532 OPAmps. Versatile, it incorporates an input impedance switch (1KΩ/470Ω/220Ω/100Ω/47Ω/22Ω/10Ω) making it compatible with most turntables and cartridges. The JAN 5725W tubes, coupled with a TL071+JRC2068 phono preamplifier stage, deliver a warm and smooth sound when listening to vinyl via the RCA line output. The NE5532 OPAs provide considerable power for the 3.5mm headphone output, which is therefore capable of driving headphones and IEMs with an impedance of 32 to 300 ohms. In terms of design, DOUK has opted for singularity with its T4 PLUS, which has a vertical layout. There is also a VU meter for a very pleasing vintage effect.
Douk Audio T4 PLUS: MM/MC compatibility
The Douk Audio T4 PLUS is a phono preamplifier that offers a high level of compatibility thanks to its input impedance switch. It is compatible with MM/MC cartridges and can adjust its input impedance to a range of values (1KΩ/470Ω/220Ω/100Ω/47Ω/22Ω/10Ω) to ensure a line level output in all circumstances.
Compatibilité MM/MC
Douk Audio T4 PLUS: High-quality components
Préamplification phono TL071+JRC2068
TL071+JRC2068 phono preamplification
The phono preamplification stage of the T4 PLUS uses TL071 JFET and JRC2068 op-amps for low noise and low distortion performance.
Tubes JAN 5725W
JAN 5725W tubes
JAN 5725W tubes deliver a warm, smooth sound, revealing the details of your music with transparency and dynamics.
Amplification casque NE5532
NE5532 headphone amplification
The T4 PLUS uses NE5532 op-amps for its headphone amplification, allowing it to drive a wide range of headphones and IEMs. It delivers up to 150mW into a 32-ohm load.
Douk Audio T4 PLUS: A unique aesthetic
With its vertical format and vintage VU meter, the T4 PLUS stands out with its unique and elegant aesthetic. Its gold-plated connectors and sturdy casing are also noteworthy.
DOUK AUDIO T4 PLUS : une esthétique singulière
Douk Audio T4 PLUS overview
Aperçu du DOUK AUDIO T4 PLUS
1Vumeter
2Volume control
33.5mm headphone jack output
4MM/MC setting and input impedance
5JAN5725W Tubes
6Phono input
73.5mm AUX jack input
8RCA line output
912V DC power supply via DC jack
Product typeTube phono preamplifier / Headphone amplifier
TubesJAN5725W
Phono preamplifierTL071+JRC2068
Headphone amplificationAOP NE5532
Inputs1x MM/MC phono input
1x 3.5mm AUX jack input
Outputs1x RCA line output
1x 3.5mm headphone jack output
Headphone output power150mW @ 32 ohms
Recommended headphone impedance32-300Ω
Settings with Phono input
Phono input level0.005V
Max. RCA output level300mV (MM) / 3V (MC)
Frequency responseConforme RIIA (±3dB)
SNR71dB
THD0.8%
AUX input settings
AUX input level0.775V
Max. RCA output level1.5V
Frequency response20Hz-20KHz (±0.3dB)
SNR≥ 110dB
THD0.2%
Power supply12V DC
Dimensions (WDH)50 x 137 x 146mm
Net weight640g
Package1x Phono preamplifier
2x JAN5725W tubes
1x 3.5mm jack to RCA cable
1x 12V 1.5A DC jack power adapter
InputJack 3.5mm
InputPhono
OutputJack 3.5mm
ColorGray
ClassTube amp
DOUK AUDIO T4 PLUS Tube Phono Preamplifier JAN 5725W
The Douk Audio T4 PLUS is a JAN5725W tube MM/MC phono preamplifier that also features headphone amplification with NE5532 OPAmps. Versatile, it...
