Max sampling rate
DAC / ADC Chip
Amplifier chip
Class
Power (W)
100 - 110
Channel
Input
Output
Remote Control
Networking
Streaming services
Color
Moyen
Elle se retourne en...
Giacomo P.
No for me
Absolutely no!
Gérard M.
Simple... efficace mais sommaire.
Très bon résultat sonore. Facilité de connexion. Ce qui aurait un plus c'est une alimentation fournie avec...
CD Player & Accessories
Discover our range of HiFi CD players and related accessories to enjoy your record collection in high quality!
  • CD Players
    CD Players
    Find in this category all our HIFi CD players, to enjoy your CD library in high quality!
  • CD Accessories
    CD Accessories
    Find in this category all the accessories for the maintenance of your CD player and your discs.
  • Ref : 21557
    The Shanling SCD3.3 is an SACD and CD-MQA compatible CD player featuring a third-generation discrete R2R conversion architecture developed in-house. It uses a 2R2 network totalling 212 resistors matched to 0.01%, spread across four channels to provide 24-bit conversion.
    3 890,00 € 3 241,67 €Ex.
    In Stock
  • Ref : 20391
    In Stock
    The SMSL PL100 CD player is the perfect way to enjoy your CD collection. It's essentially based on a CS43131 DAC chip and a PLL (Phase-locked Loop) circuit for sound reproduction as close as possible to the original source.
    119,90 € 99,92 €Ex.
    In Stock
  • Ref : 21584
    The SMSL PL100 Pro, an evolution of the PL100, is a CD player now based on two CS43131 DAC chips combined with a PLL (Phase-Locked Loop) circuit to provide sound reproduction as close as possible to the original source. The unit supports several CD formats: CD / CD-R / CD-RW / MP3 CD.
    159,00 € 132,50 €Ex.
    In Stock
  • Ref : 21587
    In Stock
  • Ref : 20923
    In Stock
    The SMSL PL150 is a CD player based on a CS43198 DAC chip, a Philips mechanism and a PLL (Phase Locked Loop) circuit for high-quality playback and conversion of your favorite CDs.
    In Stock
  • Ref : 20924
    In Stock
    In Stock
  • Ref : 21347
    In Stock
    The SMSL PL20 is positioned as a versatile CD player combining a dual CS43131 DAC architecture with a built-in ripper function, while ensuring DSD compatibility for high-resolution formats. This technical foundation is accompanied by extensive connectivity, from bidirectional Bluetooth to USB playback of DSD64 files, complemented by two dedicated...
    199,00 € 165,83 €Ex.
    In Stock
  • Ref : 21354
    In Stock
    In Stock
  • Ref : 18416
    In Stock
    The SMSL PL200 is a high-quality CD turntable/player featuring an AKM AK4499EX DAC coupled with an AK4191EQ digital filter. This CD player is both high-performance and versatile. It is equipped with quality components such as the P.A.S.S (Precision Acces Servo System) servo playback system developed by...
    739,00 € 615,83 €Ex.
    In Stock
  • Ref : 20546
    In Stock
    The SMSL PL200T is a high-performance, versatile CD transport. It's based primarily on a P.A.S.S. (Precision Access Servo System) playback system developed by SMSL, plus an XMOS USB interface on a USB-C connector. The playback system natively supports MQA CD and USB interface up to PCM 32bit 768kHz, DSD512 and MQA.
    549,00 € 457,50 €Ex.
    In Stock
  • Ref : 19478
    The SMSL VMV T2 is part of the brand's high-end product range. It's an MQA CD player that also acts as a digital interface, and features an optimized clock system. It is equipped with a P.A.S.S (Precison Access Servo System) playback system that natively supports MQA-CD. The SMSL VMV T2 also supports high-resolution PCM 32bit 768kHz and DSD512 streams, as...
    949,00 € 790,83 €Ex.
    In Stock
  • Ref : 17514
    In Stock
    The Syitren R300 is a small CD player with a nice retro design. Equipped with a Toslink optical output and a Jack 3.5mm headphone output, it will allow you to enjoy your CD collection at home as well as on the road. It also features Bluetooth 5.3 transmission capability, allowing it to automatically pair with Bluetooth headphones or speakers.
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 17034
    In Stock
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 21048
    In Stock
    The Syitren R400 is a small battery-powered CD player that combines retro design with modern features. It is equipped with an M93BG6 playback head and an SC6137D decoding chip. In terms of functions, the R400 offers a choice of playback modes: loop, single loop, or random. In addition, in terms of connectivity, it features a classic 3.5mm jack output for...
    89,00 € 74,17 €Ex.
    In Stock
  • Ref : 20932
    Thinkya's DRV108 is a full-featured CD player and DAC that uses a TMC688 processor and ES9038Q2M DAC chip to upsample CDs up to PCM 384kHz and convert digital signals up to PCM 768kHz and DSD512. The DRV108 also benefits from Bluetooth 5.1 bi-directional connectivity, allowing you to enjoy the convenience of a wireless connection, whatever your system...
    229,00 € 190,83 €Ex.
    In Stock
  • Ref : 18020
    In Stock
    The Thinkya JA-310 is a compact, attractive CD player that also acts as a USB file player. With its blend of vintage and modern aesthetics, it is both an excellent audio device and a beautiful decorative object, which will blend effortlessly into any living room.
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 20031
    The Thinkya R01 is a CD and audio file player with a retro look. It features a SILAN SC6137D processor and a precise laser head. In addition to allowing you to play your CD library via a 3.5mm jack line output and Toslink optical output, a 3.5mm jack headphone output is also available. This headphone output is driven by a G Class amplifier stage capable...
    64,90 € 54,08 €Ex.
    In Stock
  • Ref : 19941
    In Stock
    The Tonewinner TY-1CD CD player benefits from attractive aesthetics and quality components for superior CD playback performance. It features an ES9028 DAC chip as well as OPA1632 AOPs and an enhanced playback system, all incorporated in an anti-vibration chassis for optimum sound reproduction of your favorite CDs. It supports a wide range of formats...
    1 490,00 € 1 241,67 €Ex.
    In Stock
  • Ref : 17351
    The Tonewinner TY-30 is a beautifully integrated CD player, based on the use of quality components for efficient CD playback. The chassis is perfectly damped in order to limit considerably the vibrations that could affect the playback and its stability.
    699,00 € 582,50 €Ex.
    In Stock
