MUSICIAN PISCES III Digital Interface Black
The Musician Pisces III is a digital interface designed to transmit audio streams to an external DAC, particularly an R‑2R DAC. It reorganizes and calibrates the digital signals to reduce clock jitter, thereby contributing to a more stable transmission and a more transparent reproduction. Its architecture combines an ARM STM32F446 controller, FPGA processing and custom active oscillators.
By buying this product you get 64 loyalty points
Reference : 22529
649,00 €tax incl.
540,83 € tax excl.
MUSICIAN PISCES III Digital Interface 32bit 1536kHz DSD1024 Black
MUSICIAN PISCES III: Front view
Musician Pisces III: Signal processing and clocks
The custom oscillators provide a time base suited to high-resolution audio streams, while an external clock input accepts frequencies of 45.1584 MHz and 49.152 MHz. The Pisces III also incorporates an O-type transformer with monocrystalline copper, designed to help power the interface's circuits.
MUSICIAN PISCES III: FPGA
Musician Pisces III: High-resolution inputs and outputs
The USB input supports PCM up to 1536 kHz as well as DSD up to DSD1024. On the output side, the AES, optical and coaxial connections transmit PCM up to 24bit / 192kHz and DSD64 in DoP format, while the I²S output supports PCM up to 1536 kHz and DSD up to DSD1024. This versatility makes it possible to adapt the Pisces III to the digital inputs available on the associated DAC.
MUSICIAN PISCES III: Supported sample rates
Musician Pisces III: I²S output
The I²S output offers eight adjustable pinout modes to ensure compatibility with different devices. The mode is set according to the connected equipment, without manual intervention on the interface's pins; in case of no sound or noise, the next mode must be selected until a correct transmission is obtained. Once the compatible mode is found, it can be retained for later use with the same device.
MUSICIAN PISCES III: I2S output mode
Technical specifications
Product typeDigital interface
Inputs1x USB-B
Outputs1x Coaxial
1x Optical Toslink
1x AES/EBU
1x RJ45 I2S
1x HDMI I2S
Supported sample ratesI2S: PCM 32bit 1536kHz, DSD1024
Coaxial / AES / Optical: PCM 24bit 192kHz, DSD64 (DoP)
External clock frequency45.1548MHz
49.152MHz
Supply voltage115V AC / 230V AC (switchable)
Consumption20W
Dimensions245 x 240 x 70mm
Weight3.6kg
Package1x Musician Pisces III
1x Power cable
OutputOptical Toslink
OutputCoaxial SPDIF
OutputI2S via RJ45
OutputI2S LVDS via HDMI
OutputAES/EBU
Max sampling rate1536kHz
Max sampling rateDSD1024
Interface chipFPGA
The Musician Pisces III is a digital interface designed to transmit audio streams to an external DAC, particularly an R‑2R DAC. It reorganizes and...
