Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Claude T.
Bonne config
L'ensemble
- Monitor Pro contrôleur.
Apporte un plus...
Claude T.
Bonne config
L'ensemble
Apporte un plus...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 1663
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. This makes it possible to achieve better inductances while maintaining low internal impedance and zero...
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 1664
    In Stock
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 4575
    In Stock
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 1665
    In Stock
    52,90 € 44,08 €Ex.
    In Stock
  • Ref : 1666
    In Stock
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 1667
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 1668
    In Stock
    48,90 € 40,75 €Ex.
    In Stock
  • Ref : 3356
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 3357
    In Stock
    14,70 € 12,25 €Ex.
    In Stock
  • Ref : 3354
    In Stock
    11,00 € 9,17 €Ex.
    In Stock
  • Ref : 3358
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 3359
    In Stock
    18,50 € 15,42 €Ex.
    In Stock
  • Ref : 3363
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 3364
    In Stock
    29,60 € 24,67 €Ex.
    In Stock
  • 61,90 € 51,58 €Ex.
    In Stock
  • 69,90 € 58,25 €Ex.
    In Stock
  • Ref : 3371
    In Stock
    129,00 € 107,50 €Ex.
    In Stock
  • Ref : 3372
    In Stock
    115,00 € 95,83 €Ex.
    In Stock
  • Ref : 3374
    In Stock
    175,00 € 145,83 €Ex.
    In Stock
  • Ref : 3375
    In Stock
    125,00 € 104,17 €Ex.
    In Stock
  • Ref : 3376
    In Stock
    159,00 € 132,50 €Ex.
    In Stock
  • Ref : 3377
    In Stock
    169,00 € 140,83 €Ex.
    In Stock
  • Ref : 3378
    In Stock
    97,50 € 81,25 €Ex.
    In Stock
  • Ref : 2391
    In Stock
    31,50 € 26,25 €Ex.
    In Stock
  • Ref : 2390
    In Stock
    29,60 € 24,67 €Ex.
    In Stock
  • Ref : 2392
    In Stock
    45,90 € 38,25 €Ex.
    In Stock
  • Ref : 2394
    In Stock
    38,90 € 32,42 €Ex.
    In Stock
  • Ref : 2396
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 2397
    In Stock
    51,00 € 42,50 €Ex.
    In Stock
  • Ref : 2402
    In Stock
    95,00 € 79,17 €Ex.
    In Stock
  • Ref : 2403
    In Stock
    105,00 € 87,50 €Ex.
    In Stock
  • Ref : 2413
    In Stock
    167,30 € 139,42 €Ex.
    In Stock
  • Ref : 2409
    In Stock
    179,00 € 149,17 €Ex.
    In Stock
  • Ref : 2411
    In Stock
    289,00 € 240,83 €Ex.
    In Stock
  • Ref : 5096
    In Stock
    55,90 € 46,58 €Ex.
    In Stock
  • Ref : 5094
    In Stock
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 5098
    In Stock
    65,90 € 54,92 €Ex.
    In Stock
  • Ref : 5099
    In Stock
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 5102
    In Stock
    85,00 € 70,83 €Ex.
    In Stock
  • Ref : 5103
    In Stock
    92,90 € 77,42 €Ex.
    In Stock
