Impedance (Ω)
Speaker Type
Diaphragm type
Loudspeaker diameter (mm)
0 - 530
Efficiency / Sensitivity (dB)
75 - 110
Xmax (mm)
0 - 34
Lowest frequency (Hz)
10 - 17010
Highest frequency (Hz)
0 - 57000
Amplifier chip
Class
Power (W)
30 - 220
Speaker Power (W RMS)
0 W - 2005 W
Speaker type
Contacts number
4 - 4
Channel
Input
Output
Accepts Banana Plugs
Color
Loudspeakers & speakers DIY
Pascal Richard F.
Highly recommended
The Oyaide Vondita was recommended to me as a real game-changer. So I ordered 9 metres of it straight away from Audiophonics to...
Kristian K.
Excellent power amplifier
After a long time searching for the perfect alternative to my long time favorite NAD M22, i decided to buy this power amp.
It...
Michael M.
Connect it with ifi zen streamer
It improved the sound of ifi zen streamer
Want to design your own speakers? Find here all our HiFi speakers references, but also pre-designed kits to assemble yourself.
  • Speakers
    Speakers
    Find in this category all our loudspeakers / Boomers, from the midrange speaker to the bass speaker, including of course tweeters. The whole range to create your own HiFi speakers, or to replace damaged or out of order speakers. Major French brands such as ATOHM or DAVIS ACOUSTICS are available, so you can be sure of the quality and performance of their speakers.
  • DIY Speakers Kits
    DIY Speakers Kits
    Qui n'a jamais pensé à confectionner soi-même ses enceintes HiFi ? Nous vous proposons une large gamme de Kits DIY pour enceintes, vous trouverez tout le nécessaire afin de monter et créer votre propre enceinte.
    ATOHM, MONACOR, SUPRAVOX... de nombreuses marques toutes spécialistes de l'audio et de la haute fidélité.
  • Measurement Microphones
  • Speaker Filters
    Speaker Filters
    Find here all our filter modules for loudspeakers, in order to adapt the restitution of your audio diffusion system, according to your design and its constraints.
  • Ref : 16611
    In Stock
    The Visaton K 50 WP is a small full range loudspeaker with a diameter of 5cm, with a plastic frame and diaphragm. It offers a wide frequency response and a beautiful sound reproduction. It is particularly suitable for use outdoors or in humid areas.
    7,50 € 6,25 €Ex.
    In Stock
  • Ref : 16610
    In Stock
    The Visaton K 64 WP is a small full range loudspeaker with a diameter of 6.4cm, with a plastic frame and diaphragm. It offers a wide frequency response and a beautiful sound reproduction. It is particularly suitable for use outdoors or in humid areas.
    7,50 € 6,25 €Ex.
    In Stock
  • Ref : 14144
    The Visaton SL 87 FE is a wide-range loudspeaker with a diameter of Ø8.5cm. It has a plastic membrane, a rubber suspension and benefits from high efficiency thanks to its large ferrite magnet. Its frequency response is very balanced and its reproduction accurate. Compact and very affordable, it will be perfect for designing small DIY speakers.
    20,90 € 17,42 €Ex.
    In Stock
  • Ref : 21240
    The Wondom SUPB6510 is a neodymium-powered plastic speaker specially designed for voice applications and DIY projects. In addition, its ultra-compact design makes it suitable for compact music systems.
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 21876
    The XCITE XBS100-4 is a vibrating speaker designed to convert an audio signal into mechanical vibrations that are transmitted directly to a surface. It delivers 100 W under 4 ohms, utilising an FEA-optimised, low-mass neodymium magnetic circuit and a dual 11.4 cm voice coil to ensure rapid and controlled movement of the inertial mass.
    119,90 € 99,92 €Ex.
    In Stock
  • Ref : 21878
    The XCITE XBS200-4 is a vibrating speaker designed to convert an audio signal into mechanical vibrations that are transmitted directly to a surface. It delivers 200W under 4 ohms, utilising an FEA-optimised, low-mass neodymium magnetic circuit and a 17.8cm dual voice coil to ensure rapid and controlled movement of the inertial mass.
    499,00 € 415,83 €Ex.
    In Stock
  • Ref : 21863
    The XCITE XBS25-4 is an vibrating speaker designed to convert an audio signal into mechanical vibrations that are transmitted directly to a surface. It delivers 25 W under 4 ohms, utilising an FEA-optimised, low-mass neodymium driver and a 5.3 cm dual voice coil to ensure rapid and controlled movement of the inertial mass.
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 21874
    The XCITE XBS50-4 is a vibrating speaker designed to convert an audio signal into mechanical vibrations that are transmitted directly to a surface. It delivers 50 W into 4 ohms, utilising an FEA-optimised, low-mass neodymium magnetic circuit and a 7.2 cm dual voice coil to ensure rapid and controlled movement of the inertial mass.
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 21880
    The XCITE XBS50MK is a mounting bracket designed specifically for the brand’s XBS50-4 exciter. It is designed to provide a mechanically stable mounting whilst optimising the transfer of vibrational energy to the host structure. It is built on a glass-fibre-reinforced ABS base incorporating copper inserts, which provide long-lasting protection for...
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 21887
    The XCITE XT19 is a compact vibrating driver designed for space-saving installations; its ultra-slim 14 mm profile makes it easy to fit into confined spaces whilst retaining significant excursion capability. It features a dual N42 neodymium magnetic circuit combined with a 4-layer voice coil, increasing sensitivity by more than 3 dB whilst maintaining a...
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 21890
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 21891
    The XCITE XT25 is a vibrating speaker designed to extend the frequency response into the high frequencies, optimised up to 19 kHz. It features a dual N42 neodymium magnetic circuit delivering high sensitivity, whilst its 3.0 mm Xmax, combined with a linear excursion of 1.4 mm, enables controlled movement, ensuring a balance between refined reproduction...
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 21894
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 18801
    In Stock
    The XCITE XT32-4 exciter features a unique combination of large travel and low inductance, guaranteeing vibrations with the lowest distortion across the entire frequency range. The XT32-4 is equipped with a double neodymium magnet motor, offering excellent power and precision. The XT32-4 is extremely reliable. It has been designed to avoid level drops,...
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 19461
    In Stock
    The XCITE XT32-8 is a exiter driver featuring a unique combination of long excursion and low inductance, guaranteeing vibrations with the lowest distortion across the entire frequency range. It is equipped with a dual neodymium magnet offering excellent power and precision. The XT32-8 is extremely reliable, designed to avoid level drops and equipped with...
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 21902
    The XCITE XTB40 is a vibrating speaker designed for low-frequency reproduction, with an architecture that optimises bass extension down to 25 Hz. It features an extended excursion of 5.0 mm Xmax for 2.5 mm of linear displacement, enabling it to generate significant mechanical energy whilst maintaining distortion control, whilst the combination of a dual...
    49,90 € 41,58 €Ex.
    In Stock
