Impedance (Ω)
Speaker Type
Diaphragm type
Loudspeaker diameter (mm)
0 - 530
Efficiency / Sensitivity (dB)
75 - 110
Xmax (mm)
0 - 34
Lowest frequency (Hz)
10 - 5010
Highest frequency (Hz)
0 - 57000
Amplifier chip
Class
Power (W)
30 - 220
Speaker Power (W RMS)
0 W - 2005 W
Speaker type
Contacts number
4 - 4
Channel
Input
Output
Accepts Banana Plugs
Color
Loudspeakers & speakers DIY
rodrigue Y.
Connecteur RCA
Franck M.
Franck M.
excellentissime
Want to design your own speakers? Find here all our HiFi speakers references, but also pre-designed kits to assemble yourself.
  • Speakers
    Speakers
    Find in this category all our loudspeakers / Boomers, from the midrange speaker to the bass speaker, including of course tweeters. The whole range to create your own HiFi speakers, or to replace damaged or out of order speakers. Major French brands such as ATOHM or DAVIS ACOUSTICS are available, so you can be sure of the quality and performance of their speakers.
  • DIY Speakers Kits
    DIY Speakers Kits
    Qui n'a jamais pensé à confectionner soi-même ses enceintes HiFi ? Nous vous proposons une large gamme de Kits DIY pour enceintes, vous trouverez tout le nécessaire afin de monter et créer votre propre enceinte.
    ATOHM, MONACOR, SUPRAVOX... de nombreuses marques toutes spécialistes de l'audio et de la haute fidélité.
  • Measurement Microphones
  • Speaker Filters
    Speaker Filters
    Find here all our filter modules for loudspeakers, in order to adapt the restitution of your audio diffusion system, according to your design and its constraints.
