Vraiment bon, surtout pour ce prix Vraiment une très bonne surprise : -très bon son ! très ample dans les graves sans aucune exagération et sans devoir ajuster...
Very good preamplifier for the money It is pretty transparent even with the stock OPAs (in my case LM49720). Highly recommended (for the money). It is difficult to...
This section presents all our midrange, midbass and full range speakers. Many brands are represented allowing everyone to find a model that will suit their project. The filters on the page allow you to make a more precise selection according to your needs.
The Dayton Audio PA130-8 is a good speaker at a low price, which can be used as a replacement for a defective model or for DIY speaker design. The wide covered frequency range and flat response in the mediums ensure accurate reproduction of voices and instruments.
This Dayton Audio PA165-8 has been designed to support a high output level for a speaker of this size. It is a perfect model for designing HiFi speakers as a woofer / midbass loudspeaker or for creating small stage speakers.
The Dayton Audio PA200-8 is a professional woofer / midbass speaker capable of supporting high power levels using an open system. The motor structure dissipates the heat from the coil and helps to reduce the compression power.
With the PC105-4, Dayton Audio unveils a full-range speaker driver with a compact form factor and 40Wrms power handling. This speaker delivers smooth, natural sound reproduction. It is ideal for DIY construction or repair of small audio systems, or as a building block for more complex assemblies requiring several drivers of the same type.
A full range speaker, compact and beautiful finishes. Ideal for building / repairing a small audio system or as a building block for more complex assemblies requiring multiple speakers of the same type.
The Dayton Audio PC68-8 is a full-range speaker driver featuring a damped poly composite (woven glass fiber) cone, rubber suspension and high-energy motor. Offering excellent full-spectrum performance, controlled off-axis response and high efficiency, this loudspeaker delivers impressive power for its size.
The Dayton Audio PC83-4 full-range driver features a woven fiberglass composite diaphragm, rubber surround and a powerful motor. The design allows for very good diaphragm control, low inductance and a significant reduction in distortion, improving the high frequency response. The performance of this model is very good over the entire frequency range, with...
The Dayton Audio PC83-8 is a wide-range loudspeaker using a braided glass fibre membrane, rubber suspension and a powerful motor. It provides low distortion and high dynamics for accurate and dense reproduction over a wide frequency range.
The Dayton Audio PM180-8 bass-midrange driver is based on the same design type as the Point Source broadband driver range. It will allow the design of multi-way loudspeakers with a wide frequency band reproduced in the midrange and lowrange midrange.
The Dayton Audio PM220-8 is a full range / midbass speaker based on the same design as the excellent Point Source range, but designed for exotic high-performance applications requiring a wide frequency response in the mid to low-midrange range.
Dayton Audio presents its Odeum range of high-end professional loudspeakers. The Pro 15 is a bass/midrange driver of incredible performance. It is based on a careful, intelligent design, enabling it to be installed in demanding systems requiring high power reproduction with fidelity.
The Dayton Audio Odeum Apollo 6 is a 16.5cm midbass driver supporting power ratings up to 200W RMS. It is equipped with a neodymium magnet motor, a 50.8mm voice coil with glass fiber support and a copper faraday ring to lower the distortion level.
Dayton Audio presents its Odeum range of high-end professional speakers. The Pro 12N is a bass/midrange driver with incredible performance. It is based on a careful, intelligent design, enabling it to be installed in demanding systems requiring high power reproduction with fidelity.
The Fountek PS220 full-range loudspeaker has the particularity of producing both bass and articulate, balanced midrange, as well as extended highs. The full-range concept eliminates the need for passive filtering (capacitors, chokes) for a highly musical sound. The loudspeakers in this range are thus capable of high sensitivity and smooth response.
The Dayton Audio PS95-8 is a full-range speaker from the brand's Point Source range. It features a curved cone made of lightweight paper, 100% natural fibers. The result is dynamic sound reproduction ranging from punchy bass to very high treble. In fact, this Dayton Audio PS95-8 loudspeaker covers the entire sound spectrum.
Range"Reference Series"DAYTON AUDIO redefined the concept of value for money in the highly competitive ultra-high performance speaker market. Combining a sophisticated engine with internal 2 distinct electrical shortcuts, andacone in ultra rigid aluminum, the transducers of this series dethrone from their pedestal many more expensive realizations.
DAYTON AUDIO's Reference Series is now available with a paper cone! These pieces feature a patented paper cone combining natural pulp, synthetic Kevlar ® and glass fibers to create the perfect combination. Combining a sophisticated motor with 2 separate internal electrical shortcuts, and an ultra-rigid aluminum cone, the transducers in this series...
Combining a sophisticated motor with 2 separate internal electrical shortcuts, and an ultra-rigid aluminum cone, the transducers in this series dethrone many more expensive designs. The aim here is to maintain extremely low distortion levels, despite comfortable power handling and a particularly wide frequency response. Judging by the listening quality...
Combining a sophisticated engine with internal 2 distinct electrical shortcuts, andacone in ultra rigid aluminum, the transducers of this series dethrone from their pedestal many more expensive realizations. The objective here is tomaintain extremely low distortion rates, and this in spite of a holding in comfortable powerand anparticularly wide...
Range"Reference Series"of DAYTON AUDIO is now available with a paper cone! These pieces feature a patented paper cone combining natural paper pulp, synthetic Kevlar® and fiberglass to create the perfect combination. Combining a sophisticated engine with internal 2 distinct electrical shortcuts, andacone in ultra rigid aluminum, the transducers of this...
DAYTON AUDIO's Reference Series single-handedly redefines the concept of value for money in the ultra-competitive ultra-high-performance loudspeaker market. By combining a sophisticated motor with 2 separate internal electrical shortcuts, and an ultra-rigid aluminum cone, the transducers in this series dethrone many more expensive designs. The aim here is...
The Reference Series brings a new generation of high-performance speakers. These speakers use a low distortion motor system and a rigid aluminum cone. Theseries reference can surpass woofers that cost several times the price!
DAYTON AUDIO's Reference Series is now available with a paper cone! These pieces feature a patented paper cone combining natural paper pulp, synthetic Kevlar ® and glass fibers to create the perfect combination. These speakers use a low-distortion motor system and a rigid aluminum cone.
A dome-type midrange speaker, ideal for your loudspeaker construction and repair projects. The RS52AN offers a nice linearity in the frequencies, without overwriting the sound balance. This speaker has a rich and detailed sound with a good dynamic restitution that avoids auditory fatigue.
The Dayton Audio RS52FN-8 is a soft-dome midrange driver offering excellent off-axis response and superb midrange performance. Its 2” (5.1cm) damped fabric cone offers a linear response from midrange to low frequencies, allowing a smooth transition to the tweeters.
Dayton Audio's Reference Series range offers a new standard of quality for their speakers. Featuring a low distortion motor with a copper ring, a copper cap and an aluminum phase connector, the RS75-8 exceeds the performance of many speakers at often much higher prices.
Dayton Audio's Design Series has been designed to give loudspeaker designers access to high-quality drivers. Featuring a cast aluminum frame, an anodized aluminum cone and polyimide coating, they can deliver a wide range with incredibly low distortion.
