Jean-Claude F.
Très bon câble HP
Jean-Claude F.
Yvain C.
J’ai hâte de la...
Goran K.
Mogami 3104
Excellent communication wt service support, fast delivery, cable received as described Very satisfied!
Domenico C.
AUDIOPHONICS OBSIDIAN Interconnect Cable RCA-RCA Pure Silver 0.75m (Pair) Optimal audio signal transmission without any defects is what we offer you with the Audiophonics Obsidian premium RCA interconnect cable. Its pure silver conductors and...
Highly performing
Truly high-performance signal cables: I've tried several others over time, even more expensive ones. But these are the most natural across all frequencies, respecting the true tone of the instruments, which also appear better defined and very well contoured in space. The sounds are characterized by new harmonics and new subtle ambient echoes, previously muffled or not very evident. The sound has a mix of 'silvery' and 'liquid' in the mid-highs, so it's never at all harsh. There's also more speed and much more rhythm, especially on the percussion. In very crowded orchestral instruments, everything is more easily distinguishable and well-ordered. Another thing I've noticed is the homogeneity of the sound across the entire sound spectrum and an improvement in the height and width of the soundstage. After a few hours of initial listening, you get used to it and you may mistakenly think that the sound has changed compared to before, but perhaps not that much. Then, when you go back to try the old cables, you have the clearest demonstration that there has been a real upgrade and you feel the desire to put the Obsidians back in their place immediately. For me, they are truly definitive cables!
freddy w.
bluffé et dubitatif
Bj, j'ai suivi un avis au final d'un ami qui m'a assuré que j'allais tomber parterre en écoutant ce cable dans cette gamme de prix par rapport à un câble de 20€ premier prix. Très septique par nature je me suis laisser tenter par l'expérience, et bien une belle et énorme claque aux oreilles. Mais comment un câble qui ne transporte que des ZERO et UN peut-il avoir un tel impacte d'espace et de détail ??? c'est incompréhensible pour moi et pourtant une évidence. Je recommande en bonne conscience. Merci à toute l'équipe d'audiophonics
Françoise B.
LHY AUDIO EFI Optical Galvanic Network Isolator Black LHY Audio's EFI implements complete galvanic isolation through optical conversion, transforming the RJ45 Ethernet signal into fibre optic transmission before reconverting it to...
Dans un système de qualité, ceux qui sont encore septique sur le traitement du signal numérique ethernet il faut essayer cet isolateur optique . Avec de bons cables rj45 ( un rj 45 Audiophile en sortie en remplacement d’un cable fourni) et après on ne peut plus s’en passer.
C’est plus qualitatif et musical que d’acheter un streamer 3 fois plus cher que celui que l’on possède.
Très bien fabriqué ,plug and play, et un grand merci à audiophonics .
Patrick P.
Musique !
Trois LP12 et maintenant trois Fosi phono x5.
Ravi, tellement ce petit boîtier fait entendre la musique et les musiciens en vrai avec cellule MC.
Service Audiophonics impeccable en termes de prix et livraison.
Charles B.
Connexion simple et robuste
Avec ces fiches pas d'élément à visser pour avoir une connexion de qualité, il suffit d'enfoncer le corps à fond ce qui plaque les bornes de masse contre la fiche femelle. Qualité et simplicité.
Charles B.
DYNAVOX Phono Cartridge Cleaning Liquid This cleaning liquid from Dynavox maintains the stylus of your cartridge efficiently. It comes with a small brush for precise application without damaging the diamond.
Très efficace
Parfait pour nettoyer sa cellule en douceur.
Très belle musicalité
Je suis très surpris par les capacités de ca câble à laisser passer la musique en favorisant le côté naturel et poétique.
Sue le plan purement sonore, il est certes limité. Il a caractère un peu rond, un peu descendant et moyennement transparent, mais sur le plan artistique, vu qu'il privilégie le medium et le bas-medium mais sans boursoufflure, et vu qu'il a une bande passante très homogène et stable, le rendu est vraiment dans le sens de la musique.
Un très léger manque de swing, avec des rubatos manquant un peu de vélocité, mais la fluidité et le soyeux des textures est superbement bien rendu, aussi bien sur de la musique classique que sur du rock. Les rifs de guitares électriques sont riches, nuancées et texturées. Elles manquent juste un peu de mordant et de grain mais c'est en faveur de la mélodie et de l'harmonie.
En tous cas, pour le prix, il rivalise vraiment les productions audiophiles. Par exemple, la câble Esprit Beta HP (8x plus cher) est plus transparent, plus rapide et plus dense, mais il n'est pas aussi homogène et pas aussi chantant.
Michel R.
XDUOO TA-20 PLUS XLR Balanced Class A Headphone Amplifier with Tubes 1x5Z4P 2x12AU7 An upgrade of the TA-20, the TA20 PLUS from xDuoo features a number of improvements. This fully symmetrical Class A tube headphone amplifier now boasts...
Très bon ampli casque
Après quelques semaines de "rodage", le TA20 Plus donne sa mesure : puissant, musical, dynamique, parfaitement équilibré sur l'ensemble du spectre, à l'aise avec divers casques.
J'aurai prochainement recours aux conseils d'Audiophonics pour acheter un autre jeu de tubes qui pourraient éventuellement améliorer encore le résultat sonore.
SOMMERCABLE EPILOGUE RCA Modulation Cable Gold Plated OFC Copper Shielded 2m (Pair) Sommercable's Epilogue RCA modulation cable has been designed to contribute to a neutral and faithful sound reproduction, favouring a wide sound image thanks to excellent signal...
Vraie référence parmi les câbles de haute qualité . Modèle d'équilibre .
Il est tellement équilibré que je l'ai mis en liaison pré / bloc , lecteur cd/pré , tuner/pré et sources / intégré tubes . Et , sous peu , en liaison pré phono / pré ligne . Mes électroniques : Esoteric K-01, Audio Research , Coda , Magnum Dynalab , Triode 845 , Linn Uphorik . Enceintes Tannoy Westminster . Supérieur à tous mes précédents câbles y compris un Siltech du milieu de leur hdg ...Si un câble peut être neutre , alors le Sommer Epilogue entre dans la catégorie . Rapport prestations / prix remarquable .
Mihai Radu T.
Good solid upgrade to try before going up to expensive PSUs
I will start by saying that the use case for my RPi4B is as a DLNA server.
meaning i have a usb ssd where i store my music, and use assetUPNP to index and serve music on network in the form of a DLNA server.
i have experimented with 3 power supplies, i even modded an ifi ipower elite in order to get better performance out of the Pi.
I invested a lot of time in optimising the the RPI os to be as minimal as possible (turn off hardware i do not need, leds, stop unused processes, etc...)
even so, with many tweaks and fixes, this board provides a lower noise floor.
The soundstage becomes deeper, and more details are apparent, as well as greater dynamics, without any added harshness in the high registers.
So i would advise anybody that wants to play with a Rpi for audio to go for this board before spending much much more on better power sources.
i'm not saying don't do it, i am saying having this board as a buffer / interface (it feeds the RPI power through GPIO pins) has been beneficial even with higher quality switching power supply.
if i had to nit pick, i don't much like the spike feet - but nobody is making you buy them - and if there is something i feel the UCPI is not doing right, it is the choice of input power, the USP C.
i would have been happier with screw contacts like on the output side, or maybe a DC jack 5*2.1 for example.
and the solder points for input power could be thrgough holes, so you can actually solder bigger gauge wire.
so my only problems are with the connectors used by the board. functionally, i consider it an immens value, and a good adition to my setup.
High Purity Silver Plated OFC Copper Wiring Cable PTFE Sleeve 0.5mm² Ø 3mm Transparent This cable wire incorporates a high-purity OFC Copper conductor with a cross-section of 0.5mm² with Silver plating, ensuring excellent conductivity while being resistant to...
Très bon câble.........
Gaine très solide ...... Qui fait effectivement 3 mm de diamètre.
Par contre, le fil ne fait pas 0,5 carré ( diamètre de 0.8 ) mais 0.71 carré ( diamètre de 0,95 )......... Très bonne nouvelle
Franck Z.
CYP DCT-37 HDMI DAC / Preamplifier / Headphone Amplifier HDMI SPDIF USB RCA 32bit / 384khz The CYP DCT-37 is a true Swiss Army Knife dedicated to audio and video. It can control many digital and analog sources and then output to a wide variety of digital and analog...
Versatile et qualitatif
Je n'écoute mes sources vidéos (Blue-ray, Box, Console) qu'en stéréo, car je n'ai pas la place pour un home cinema qualitatif. Cet appareil très qualitatif que j'ai depuis 2 ans me permet de le faire sans dégradé la qualité du signal sonore. L'idéal dans le futur sera d'avoir les même genre d'appareil avec des possiblités d'upscalling sans perte.
Efthymios X.
As per title really.
Efthymios X.
ALPS RK27 4 Ways Potentiometer Smooth Cylindrical Shaft 100 kOhm The ALPS RK27 potentiometer offers excellent design quality and performance. It ensures low noise and very good channel balance. This model features 4 channels for a 100kΩ...
As good as it always was
Plus reliable. That's it :)
Patrick R.
Cette Shucko V 512S silver associée avec une IEC Oyaide C004, constitue une association de haut niveau. Surement la force du contraste existant entre les 2 connecteurs, mais la synergie est parfaite montés pour ma part sur un cable secteur TTS-cable .
Service Audiophonics toujours au top.
Joseph N.
Très bon cable, mais attention aux connecteurs utilisés
Ce câble est excellent et surtout a ce prix, dynamique, très détaillé, avec une belle scène large et bien aérée
pas du tout "excessivement brillant dans les médiums et les aigus" comme dit un des intervenants, sauf peut être sur un système qui ne supporte pas l'argent et avec des fiches pas adaptées.
J'en ai monté 2, un avec des fiches plaquée Rhodium qui ne convient pas a mon système, rendu trop clair, l'autre avec des fiches cuivre pur est impeccable
J. E. K.
ASCILAB F6B Bookshelf Speakers 125W 4 Ohm 84dB White / Black Grill (Pair) The AsciLab F6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ aluminum dome tweeter...
My Ascilab F6B experience
The Ascilab F6B loudspeakers sound refined, neutral and very detailed with a flat frequency response. It is so good that from Mid to High no frequency corrections are needed. Only the Bass, below 200 Herz, needs correction (depending on the accoustic qualities of the room).
The transition from mid-loudspeaker to Tweeter is very evenly. A piano playing from low to high sounds natural with a coherent timbre. No crossover detectable.
Stereo (Soundstage) is pleasant wide. I can move my head to left/right without a change in frequencies and localization in the soundstage.
Vertical directivity is also good. I am not in the habbit of listening to music while standing but when I walk around in the room or enter the room, the music is pleasant, the instruments sound natural.
Should I write more about the music? All music benefits from the above. Human voice, speech: all enhanced.
The Ascilab's can fill my listening room (about 17 m2) easily with loud music. I am not interested in 'party' level sound because that always destroys quality (and my ears). I am 70 and proud to have good ears (up to 10,5 KHerz).
At this moment I use a subwoofer, for 2 reasons:
1. Mainly: to solve the room resonances. The subwoofer (SVS SB100 Pro) has 3 parametric EQ-options: this is enough to correct 3 room resonances. Crossover is set at 100 Hz.
Another way to correct room-resonances is to use Room-correction software like Dirac or Audeyssy.
2. To extend/equalize the Bass-response.
Just for reference: I have Kef R300 (2016) loudspeakers, combined with the SVS SB100 Pro subwoofer. It's good. But Ascilab F6B is different. More refined.
I am very happy with the Ascilab F6B.
I use Near Field Listening. Loudspeakers are 55 cm from back-wall to back of F6B, 80 cm from side-wall, loudspeakers are 150 cm apart (front-centers) and toed-in about 15 degrees, my ears are about 160 cm from the loudspeakers. It's perfect for detailed listening, the best I experienced in my life!
Pascal J.
CLOUDYX CL-BOX PRO Audio Streamer WiFi DLNA AirPlay Bluetooth 5.2 Multiroom DAC ES9018K2M Transform your audio setup into a true high-fidelity wireless system with the CloudyX CL-BOX Pro. This compact audio streamer enables multiroom broadcasting via WiFi and...
Ne vous cassez plus la tête !
Venant d'un Keces ebravo,
celui ci coûtant 7 fois moins
est 10 fois plus performant. En 1er lieu les mises à jour
Keces : Aucune
Cloudix: 2 mises à jour de l'os au démarrage et hop la sortie digitale passe à 192kHz.
L'appli I Audio de même 1 mise à jour et beaucoup plus stable.
De+ converto ess inclus avec en sortie des aop chinois de très bonne écoute cs4420c. Franchement pourquoi dépenser plus c'est ce que l' on nomme un bona fide. Je n'en dirais pas plus cela serai indécent plus les autres !
Davor F.
Quality connector
Easy to assemble and it's of great quality
Davor F.
Great piece of connector
Jürgen S.
Tune your Sound - change PSU
For all, who won't believe in it:
This PSU tunes your sound! Needed new PSU for RaspberryPi 3 B+ and Hifiberry Digi-HAT, because of "undervoltage". Old PSU was made by iFi, 2.5A...
Spounds good, "undervoltage" made Pi geeting hot! The Allo supplies enough power. No "undervoltage" anymore. Sound gots smoother and more space. Very important: check mains phase or loose soundquality. Just turn mainsplug and listen... Have fun
Manuel Campos A.
JANTZEN AUDIO Wave Guide Audax TW034X0 (The pair) This pair of Jantzen Audio wave guide is suitable for mounting Audax TW034X0 tweeters (made in Denmark). They allow an efficient diffusion of the frequencies reproduced by these...
É daqueles acessórios que não são apenas acessórios!
Uma grande melhoria na dissipação e ganho das frequências altas.
Leva-nos para a dinâmica e transparência do som ao vivo.
Recomenda-se !!!
thomas d.
THIEAUDIO OCEANIA 2PIN Headphone Cable CIEM 0.78mm to Interchangeable Jack Termination Palladium-Plated Silver 1.25m This ThieAudio Oceania headphone cable features CIEM 0.78mm connectors and interchangeable termination: 3.5mm jack, balanced 2.5mm jack and balanced 4.4mm jack.
Magique
Très bon câble intras
Léger, texture anti friction, se démêle facilement, multi usage via les differentes connectiques ... primordial pour du nomade
Au niveau son..aération, fluidité, neutralité, consistance dans les timbres
Testé avec les UM Multivers Mentor et AE mentawaii
On se régale
Merci Thie audio
Henri c.
excelent cable
j'ai utilisé ce câble pour câbler l’intérieur d'une enceinte artisanale ( bornier vers filtre, environ 90cm ) haut parleurs FE208 sigma et dôme magnésium Audax ,
ça a apporté plus de détails, de la dynamique, du naturel , l’excellent FE208 donne vraiment une grande écoute,
on oubli souvent le câblage interne des enceintes ( des ampli aussi )
dans le commerce c'est souvent catastrophique ,c'est dommage.
Jean-Pierre B.
Addictif
Premièrement ce câble est très beau et très bien fabriqué : un vrai bijoux.
Deuxièmement, si on le branche dans un système, on entend la différence : je partage l'avis de Philippe un peu plus bas, tout est mieux.
Troisièmement, cela devient addictif car le remplacement des autres câbles XLR est alors une nécessité.
Dans mon système, j'ai connecté en XLR un DAC Matrix X-Sabre Pro sur un répartiteur XLR Audiophonics 1 XLR verts 2 XLR qui me permet de choisir entre écoute des enceintes au travers d'un Cayin Soul 170 i ou écoute au casque au travers d'un Cayin HA-6A : Les 6 prises à l'arrière du répartiteur, 3 noires et 3 rouges font 'un effet boeuf, je dirais même splendide.
Enfin, pour rester dans la logique Obsidian, j'ai demandé à l'atelier Audiophonics de me monter un câble d'enceinte qui reprend la même présentation que ces XLR : Prises Viborg Argent pur, Gaine noire nylon Viablue sur un câble Neotech NES 3001G la on a quelque chose d'exceptionnel au niveau qualité du son.
Si l'on ajoute une connexion USB sur Oyaide Continental 5S, on aboutit a un budget d'interconnexion assez élevé (du prix d'un beau composant), mais ne dit-on pas que le prix s'oublie et que la qualité reste ?
Pour terminer, si Audiophonics n'existait pas, il faudrait l'inventer. Une seule remarque, vérifiez la disponibilité du stock. Si c'est disponible vous aurez une livraison ultra-rapide. Si ça ne l'est pas alors soyez patient car la livraison prendra du temps et sera en général dans le délai annoncé.
Viktor Z.
Excellent cable
The cable is beautifully made, the insulation is very nice , stretchy and flexible, with a beautiful gold colour. The conductors are also outstanding, the silver coating is nice and thick and the wire itself is nicely twisted , all in all this cable is excellent when it comes to materials and craftsmanship.
Stephane G.
Incroyable !!
Je possède depuis une vingtaine d’années du Naim Audio (NAC 282 / HICAP / NAP 250.2) couplé à des ATC SCM 50 Passives.
Très satisfait du résultat. Très musical comme je l’aime depuis des années.
Par contre je n’ai jamais pu complètement ignorer les dires comme quoi les ATC sont difficiles à driver… etc… etc…
Un peu plus de grave à bas volume n’est pas refus.
J’ai donc voulu essayer quelque chose de non conventionnel. Raccorder mon preampli Naim sur un ampli classe D. Dans la communauté Naim c’est un délit très grave :)
La condition était de conserver le PRAT Naim mais avec plus de patate pour voir l’impact sur les ATC.
Ce LPA-S450ET cochait toutes les cases. De la puissance, du facteur d’amortissement et de la neutralité.
Après quelques échanges sympathique avec David ici même j’ai sauté le pas.
Le câblage chez Naim n’étant pas conventionnel, Il a fallu trouver un câble DIN pour sortir de la HICAP vers du symétrique pour l’Audiophonics.
Depuis plusieurs heures ça joue. Et ça joue très très bien. Je suis bluffé. Le PRAT est conservé. Je ne suis pas dépaysé comparé au NAP 250.2 mais il y a un peu plus de tout. Le grave est un peu plus présent à bas volume. Donc sur ce point c’est validé. La scène sonore ne change pas. Le médium est le même et toujours magnifique à nos oreilles. La musicalité de la source et du preampli est conservée et c’est ce que je recherchais. À fort niveau ça n’a rien à voir ça envoie vraiment très fort sans tassement ni distorsion comparé au NAP 250 qui pouvait forcer un peu.
La neutralité de cet ampli est exceptionnelle. On dirait de la classe AB. Rien de montant ou de fatiguant.
Je me retrouve avec une source et un preampli Naim couplé à des ATC SCM 50 et au milieu un ampli classe D de 1300€. Beaucoup diraient que c’est du n’importe quoi. Mais non. Ça chante. Comme quoi…
Reste à voir la fiabilité. Le système est sous tension 24/24 et 7j/7.
Merci David pour les conseils.
Banana Plug Gold Plated Copper Alloy Ø5mm (Set x4) This banana plug offers an excellent quality / price ratio. Made of copper alloy with gold plating, it ensures a very good conductivity and durability. Its design also allows a...
Attention fragile
La conception est fragile et le conditionnement très sommaire : certaines des vis sont coincées dans la banane.
Egalement, la longueur des vis est relativement courte et ne permet pas de visser convenablement le câble sous peine que la vis quitte le filetage du fut.
L'ensemble ne respire pas la qualité, le corps est très fin et l'ensemble semble très fragile, même après montage.
Yves F.
Marvelous DAC
Ma configuration : Denon PMA 3000NE, streamer dmp a6 master edition gen 2 + dac holo cyan 2 (connection en USB : câble Black Rhodium) et enceintes AE 320 1ere génération (Câble Black Rhodium minuet collection) .
Mon avis : exceptionnel, beaucoup d'émotion, la musique vous prend aux tripes, Jazz, electro, voix, tout est propre, aéré, précis, tridimensionnel, sans fatigue... Seulement la musique.
Les artistes sont là devant vous, votre corps tremble d'émotion, emporté par les notes, vous avez envie de danser, la musique fait partie de vous....Merci Kitsune et audiophonics.
Raymond L.
Service Clientèle c'est une sans faute et en plus !
Sans parler de cet achat, le service clientèle est parfait avec une aide qui ne pousse pas à acheter plus et plus cher. Toujours aimable, je débute et sans Audiophonics, je serais perdu dans la jungle du digital. Merci et Merci encore pour votre assistance. Raymond en Ariège.
Luca R.
Excellent distributeur électrique
Avec ce prix, vous ne pouvez pas demander plus , ici nous avons :
· Un beau châssis entièrement en aluminium noir.
· 5 prises Schuko plaquées or de bonne qualité Berker.
- 1 x prise d'entrée IEC d'excellente facture en or de chez Viborg (au lieu de Furutech comme décrit mais la qualité ne change pas)
· Câblage interne avec câble rigide en cuivre OCC monocristallin Neotech de bonne section
Ils m’ont appris que les choses simples, sans complications diverses, sont les meilleures pour la qualité sonore. Je pense que lorsqu'on utilise ce type de répartiteur, sans divers filtres, interrupteurs, fusibles ou voyants de présence secteur, le son est certainement meilleur.
Quant au son, je ne l'ai pas encore essayé car j'attends plus de matériel pour le câble d'alimentation mais ce sera certainement une amélioration sur tous les paramètres. En fait, il sera assemblé avec le câble OCC Elecaudio CS-361B + fiche Schuko coudée Viborg LE505G + fiche IEC Viborg VF503G.
Recommandé à tous ceux qui recherchent un excellent distributeur Secteur 5 Ports , petit à mettre derrière le meuble HiFi avec des composants d'excellente qualité.
Bruno L.
Très bon câble !
J'ai utilisé ce câble pour confectionner un câble de deux mètres de long pour remplacer celui un peu trop court fourni avec mon casque.
Le résultat est excellent, mon casque planar magnetic (le moins cher de chez Audiophonics) est boosté dans tout ses registres.
Je ne pensais pas qu'un câble pouvait apporter autant d'améliorations.
Vu le rapport qualité/prix je le conseille hautement.
Pour réaliser les soudures sur des connecteurs jack 3,5 et jack 6,35 je n'ai pas rencontré de problème. J'ai suivi le conseil d'Audiophonics concernant l'emploi d'un flux pour soudure pour étamer préalablement les extrémités du câble.
Remarque : j’ai choisi les connecteurs pour leur facilité de soudure et non pour leur qualité.
Il me reste donc un peu de marge pour un surplus de performance.
Merci à toute l'équipe d'Audiophonics.
Brice D.
IFI AUDIO SILENT POWER HDMI ISILENCER 2 HDMI Signal Conditioner The iFi Audio Silent Power HDMI iSilencer 2 is a state-of-the-art HDMI signal conditioner that eliminates distortion throughout your entire AV system. Using a combination of...
Petit gadget au top
J ai pris ce i silencer sans trop grande conviction..
J ai été bien surpris une fois ce conditionneur branché.
Sur mon système le gain est significatif d un affinement de la scène sonore et au niveau des basses , elles sont mieux tenues , plus tendues ...
Patrick G.
Comme d’habitude, un super cable pour toutes les applications. A acheter sans risque d’être déçu.
Damien M.
DSPEAKER ANTI-MODE X2 Room Correction and Equalizer DSP Compact yet extremely powerful, the DSPeaker Anti-Mode X2 presents itself as a DSP to perform acoustic room correction and equalization tasks with great efficiency. It features...
Un classique de L'anti-mode !
la notice n'est pas exhaustive, notamment par l'absence de schémas de câblage,à fortiori lorsque l'on ne dispose pas d'entrée Main in sur l'ampli et que l'on veut palier via le tape monitor. Mais bon, ça reste intuitif. Je l'utilise en config 0.1 (gestion uniquement du caisson de grave) pour un excellent résultat qui m'a permis d'atténuer un creux modal entre 40 et 60hz. Cela contribue à une écoute hifi superbe. En revanche en calibration 2.1 dans mon cas précis, si la courbe relevée avec Rew est la plus linéaire, le son a cependant moins d'attaque, est moins dynamique , plus pataud. Je me suis aperçu au niveau des basses, que le X2 efface quasiment celles de mes enceintes (qui ont d'origine une belle attaque et ne demandent qu'un léger soutient dans le registre) pour y substituer le caisson. La courbe est belle , mais l'écoute est beaucoup moins agréable qu'en 0.1. Avec un autre caisson(plus sec) peut être, le résultat aurait été certainement différent. Hormis la télécommande un peu cheap, l'appareil de bonne facture et simple d'utilisation, s'intègre facilement dans un meuble hifi de part son encombrement très réduit et outre la possibilité de mémoriser 3 profils de calibration différents, permet d'offrir de réelles possibilités d'optimisation du son audio dans des pièces à l'acoustique délicate. Je recommande.
Patrick G.
DAYTON AUDIO SPA1000 Subwoofer Amplifier Module 1000W 4 Ohm The Dayton Audio SPA1000 is one of the most technologically advanced subwoofer amplifiers on the market. It is based on a Class G circuit combining the high power and fidelity...
Bon produit, reçu rapidement. Je ne mettrai pas 5/5 car j’ai demandé à Audiophonics de me renseigner sur une procédure concernant cet article. J’ai dû entrer en contact avec le fabricant qui m’a renseigné avec courtoisie. Je n’ai à ce jour aucun retour de la par d’Audiophonics de ma demande. Dommage. Sinon l’ampli est très bon et procure beaucoup de sensations, les 4 graves Tannoy en 38 cm s’envolent et sont épaulés à merveille. Le caisson est un ancien sub Mc Intosh THX avec 2 graves de 30cm. Le rendu est très vivant et le rôdage se fait ressentir.
didier S.
Qualité au top
Après quelque heures, le lecteur s'est aéré et le rendu est magnifique. Détail des instruments, clarté des voix et silence total de fonctionnement. Je rajoute la qualité de la relation avec Audiophonics : Information sur les délais, promesse tenue, envoi "blindé". Bref au top.
Je rejoins d'autres utilisateurs sur l'impossibilité de sélectionner une plage du CD mais ça reste mineur.
André T.
SMSL PA400 Stereo / Mono Amplifier Infineon GaN 2x250W 4 Ohm / 1x500W 8 Ohm The SMSL PA400 is an innovative amplifier that uses Gallium Nitride (GaN) transistors to deliver 2x250W amplification at 4Ω. Its versatility also allows it to operate in...
Excellent ampli gallium PA 400 de Smsl...
Reçu très rapidement à domicile par La Poste...
Tout de suite essayé avec un Wiim Ultra en guise de pré-ampli accueillant aussi une clé usb de 32 Go à l'arrière pour lecture de fichiers musicaux grâce à l'appli Wiim Home ..
Leur lecteur de cd's Smsl PL 200 branché à l'arrière du Wiim Ultra permet également de lire des cd's avec une grande précision....
La dynamique et la clarté du Smsl PA 400 sont superbes....un vraiment bon ampli à la hauteur des espérances de cette nouvelle technologie GaN...il y a un bouton de volume bien pratique sur la télécommande, mais pas de réglage des aigues ou basses sur le PA 400 , ni sur le Wiim Ultra....pas trop grave parce que l'équilibre tonal est excellent avec les enceintes JBL monitors que j'utilise.
En résumé enchanté de l'achat de ce modèle , qui peut rivaliser en qualité d'écoute avec d'autres amplificateurs de grandes marques bien plus chers...
Bruno V.
KECES P8 Ultra Low Noise Regulated Linear Power Supply 9 / 12V + 18 / 19V 4A The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply offers a careful...
Une merveille de douceur et de réglage
Je sais que ce n'est pas l'alimentation la plus plébicité sur ce site mais elle vaut vraiment qu'on s'y attarde.
Ces multiples possibilités de choix quand aux voltages de sorties en font un élément qui va s'adapter à vos besoins. C'était le critère de choix qui m'a fait choisir ce modèle plutôt qu'un autre.
Comme tout dans une chaine hifi, c'est une question de mariage, parfois, on cherche de la douceur, de la précision et parfois de l'impact. On est plus du côté douceur et précision.
Pour l'un de mes appareils, je l'ai associé avec un Filtre Jack DC 12V 5F à Supercondensateurs. Je voulais plus d'impact sur cet appareil là. Après quelques modifications supplémentaires, ce filtre a disparu lui aussi. Je reste donc avec l'alimentation seule.
Je lui trouve une qualité merveilleuse que je n'ai pas vu ailleurs. La possibilité de régler la tension de sortie. Le cadran en façade indique le voltage de sortie et ça, c'est vraiment un plus. On constate que la tension varie de temps en temps probablement avec la tension du réseau donc elle est issue. Il y a une possibilité de réglage des sorties de l'appareil via un potentiomètre (4 en réalité-un par voltage) . Il est juste dommage, que ce soit à l'intérieur de l'appareil.
Cette possibilité est vraiment un avantage incroyable.
Mes sorties réglées à 12V précis pour le switch internet et à 18,9v pour le streamer (aurender). il y a tout à coup une harmonie qui apparait. Une fluidité que je n'obtiens qu'avec ce réglage précis et possible avec cet appareil.
Marcus L.
Perfect for network switches
A nice SQ improvement on ordinary data switches even in comparison with expensive SMPS or less expensive LPS. A firm recommendation from me as well.
Un bon cable HP
Le Silenos remplace avantageusement mon ancien cable diy en pur fil d'argent isolé coton et tressé. Il descend plus dans le grave tout en le tenant bien. Belle dynamique équilibré sur tout le spectre sonore. Peut-être un peu cher. Vu comme cela il ressemble a un cable lambda le le traitement doit être pour beaucoup dans sa réussite. C'est quand même devenu mon cable de référence.
FIIO WARMER R2R DAC R2R Tube Buffer E88CC 32bit 384kHz DSD256 Silver The FiiO Warmer R2R is a DAC combining discrete R2R conversion, a JJ E88CC tube stage and a linear power supply, all housed in a retro-style chassis equipped with a mechanical...
Remarquable avec Roon
Ecoute facile, vivante, vraiment très agréable. Du punch, de belles voix, on prend vraiment plaisir à écouter.
Jérémie M.
Less Is More
Ce DAC est excellent au regard de son tarif, philosophie Less Is More : pas de bluetooth, pas d'écran, un design industriel carré mais qui inspire la solidité. Niveau connectique l'essentiel vital, par contre je note un peu de jeu dans le port fibre. Niveau son pour mon installation audiophile de premier niveau il fait mon bonheur. Pour relier un ordinateur et plus à son amplificateur sans se ruiner c'est un rapport qualité prix imbattable.
Ludovic M.
WIIM ULTRA Streamer DAC ES9038Q2M Headphone Amplifier Bluetooth 5.3 WiFi 6E 32bit 384kHz Silver The WiiM Ultra sets a new benchmark in the world of audio streamers, thanks to a design conceived to deliver an unrivalled audio experience. It lets you enjoy your music library...
Remplis très bien sa fonction
Je cherchais un lecteur reseau pour ecouter la radio( radio paradise,FIP,INTER ,MUSIQUE ).Le son est excellent sur les flux hd,en sortie analogique et sur caque en Bluetooth.
Une fois l’appli wiim installée de nombreux paramétrages sont disponibles par le biais de la tablette ou directement sur l’ecran du wiim ultra.
Une remarques
,si on coupe le secteur j’ai été obligé de récupérer le wifi.
Merci aux techniciens du service technique pour leur conseil qui a guidé mon choix
Eelco K.
SMSL D1 DAC ROHM BD34352EKV XMOS XU316 32bit 768kHz DSD512 The SMSL D1 is a budget DAC based on high-quality components. Digital-to-analog conversion is performed by a USB XMOS XU-316 interface combined with a Rhom BD34352EKV chip,...
Sibilance and harsh treble. Not good for piano and female voices
Floorstanding Elipson 1303, Firstwatt F5m DIY poweramp with Zen Mod iron pre amp. I do not consider my system very revealing but there is some difference compared to my other DACs. First of all the DAC sounds detailed in the high tones and has quite some weight in the mid and low tones for this price. It also has a good soundstage (is this because of the extra treble?). There is good seperation of instruments and voices.
Besides the detail in the high it is also very harsh. Piano and female voices can sound sharp, sound like clipping and piano can sound different to false. This is not due to the extra treble but a mistake in the device. In general it doesnt sound so organic when listening to natural music. I switched back to my Google Chromecast audio. A DAC which sounds slightly smooth, a little less detailed but realistic and doesnt have this sibilance problem. The piano and voices are just right. The soundstage is just a little bit smaller. p.s. It can be that this is a faulty device so I will ask Audiophonics if its possible to return it.
Eric D.
Super, et je lui ai fait une boite en imprimante 3D
https://www.printables.com/model/1721910-box-for-audio-amplifier-tpa3116d2-2x50w.
Ravis de ce petit amplificateur. J'ai déssiner une boite pour lui avec quelques instruction pour les intéresser.
Krisztian B.
DD BC30XLR XLR Interconnect Cables Stereo Silver OCC Copper Gold Plated 75cm (Pair) DD HiFi's BC30XLR is a 3-pin XLR to 3-pin XLR cable that can be used for all your balanced output connections, such as, for example, a DAC to an amplifier or active drivers. The...
Easy choice if you don't want to try 20 cables, just one
There are audible differences between cables, and between RCA and XLR, finding the right cable for your system is sometimes not easy. I can recommend this to anyone who wants a cheap* but still good sounding cable for the price. In 90% of hi-fi systems this is a perfect choice because there is a level where you no longer choose this. Oh and the look and quality of the material are nice.
(*of course there are good options for cheaper ones, but you may have to try more of them)
Bruno R.
SINGXER UIP-1 PRO Isolator USB 2.0 480Mbps The Singxer UIP-1 Pro is a small, high speed (480Mbps), low noise (20µs) USB 2.0 isolator with a 2kvRMS isolation voltage. It also supports USB 1.0 and 1.1 and works...
Suite au changement de mon dac, qui était équipé d'une correction de jitter intégrée performante, par un Holo cyan2 qui n'a pas cette correction intégrée j'ai d'abord essayé un correcteur passif de chez audioquest d'une installation précédente. Mais si la correction était correcte le Holo avait un peu perdu de sa transparence et de sa profondeur. J'ai donc fait l'acquisition du Singxer. Après 48h de rodage H24 le Holo a retrouvé toute sa transparence et sa profondeur et en bien mieux encore. La source est un pc à refroidissement passif, player qobuz (pas de logiciel type audirvana qui rendent le son sec et artificiel sur mon système), et à la sortie du Singxer un câble USB One de chez hi-fi câbles et Compagnie.
Très satisfait de ce Singxer, transparent et efficace sans toucher au naturel du son pour un prix "assez raisonnable"
Pascal Richard F.
Highly recommended
The Oyaide Vondita was recommended to me as a real game-changer. So I ordered 9 metres of it straight away from Audiophonics to make new power cables for all the components in my stereo system. For the plugs, I used the Legato from ETI Research. The Legato plugs are also my top recommendation here. The build quality is perfect. I have now built a power cable using the Vondita for both my Audes ST3000 and my T+A PA 3000 HV integrated amplifier. As I don’t like the red colour of the cable, I’ve covered it with a basalt braided sleeve. I’ve also treated the ferrule ends crimped to the conductors with graphene. Well, what can I say? I had no expectations, as I previously had Shunyata Alpha V2 power cables... In any case, the Vondita with ETI Research Legato plugs is so much better that it leaves me speechless. I would have expected only subtle differences at most, but this is simply staggering. The soundstage is so much more natural and effortless in every respect. An absolutely natural flow with great timbres and significantly more detail. Highly recommended.
