Elevate your audio experience with the Denafrips Hades preamplifier, a masterpiece born of uncompromising dedication to audio perfection. Designed for the discerning audiophile, the Hades is the pinnacle of technical precision and sonic sophistication.
With the Hestia 12TH, Denafrips presents a balanced preamplifier based on 100% discrete components operating in pure Class A to deliver unprecedented sound quality. Its microprocessor-controlled 60-step attenuator with precision-tuned resistors ensures perfect balance between channels and an incredibly low harmonic distortion level of just 0.000230%,...
With the TPR-1, Dynavox offers a tube preamplifier with 3 6N3 lamps. It has been developed to provide a detailed and precise sound reproduction, while revealing the softness and warmth characteristic of tube systems.
The Cosmos Scaler is a low-noise, variable-gain preamplifier designed specifically for the brand's Cosmos ADCs. It incorporates quality components such as two OPA1612 and two OPA1656 AOPs. It features 16 gain positions from 0 to 26dB, plus an automatic adjustment position.
Eversolo returns this time with its DMP-A8, a network player and DAC of the highest quality and incredible versatility. A true centerpiece of today's HiFi system, it offers a wide range of uses, from local file playback to accessing your music library from network devices or your favorite streaming applications. Its meticulous design also ensures the...
Ferrum's OOR is a high quality balanced headphone amplifier and preamplifier, capable of accompanying all types of headphones, including the most demanding, while preserving the essence of your music. With very low distortion, impressive dynamics and an incredible level of detail, the OOR is the ultimate companion for headphone listening.
FiiO offers us the evolution of their K9 model. The K9 AKM is a versatile DAC model integrating analog and digital inputs, and can be used in USB DAC mode. This model features a latest-generation AKM DAC coupled with its Delta-Sigma modulator, enabling music playback at resolutions of up to 32 bits / 768kHz and DSD512 file decoding. These two THX...
With its R9, FiiO unveils an extremely versatile high-performance desktop device. The R9 functions as a DAC, network player and headphone amplifier. Two ES9038Pro DAC chips enable it to decode high-resolution streams up to PCM 32bit 768kHz, DSD512 and MQA, while its RJ45 port and large display give you easy access to all streaming services: Tidal,...
With its S15, FiiO unveils a very high-quality audio streamer. In fact, it rivals many high-end streamers for a price that defies all competition. Ultra-complete, this device offers numerous streaming solutions thanks to its Android 12 operating system, while relying on a combo of AK4191EQ + AK4499EX DAC chips for top-level audio performance. It supports...
Fosi Audio's GR40 is a versatile, compact stereo DAC and tube preamplifier, featuring full connectivity and Bluetooth 5.1. The digital-to-analog conversion section is based on an ESS9028Q2M DAC chip, and enables signal conversion up to PCM 32bit 384kHz and DSD256. Coupled with the tube preamplifier stage, the GR40 delivers the rich, warm sound...
The Fosi Audio P3 is a compact, high-performance preamplifier. It features two JAN 5654W tubes and a QCC3031 Bluetooth receiver chip. A 3.5mm jack is also available on the front panel, with volume and tone controls for bass and treble.
The Fosi Audio P4 preamplifier is a compact and versatile solution. With its three stereo RCA inputs, volume control with motorised potentiometer, tone control, gain selection and neat design, it offers a high-quality sound experience.
With its SK02, Fosi Audio unveils a small, versatile, high-performance device that takes up the form factor of its SK01. The SK02 fulfills the functions of headphone amplifier, portable preamplifier and portable DAC. The SK02 features an ES9038Q2M DAC chip and a low-noise,...
The Fosi Audio ZP3 is a balanced preamplifier based on NE5532 AOPs. It offers interference-free sound reproduction over a wide dynamic range, minimizing ground loop effects. The ZP3 is ideally suited to audiophile and professional use, given its performance and connectivity, including TRS/XLR combo jack inputs and a balanced XLR output.
With the Tube-02 Pro, Fx-Audio offers a small tube preamplifier and headphone amplifier in a compact and affordable format. Its preamplifier stage uses a pair of 5725 tubes, giving it a soft and round sound. The buffer of the Class A headphone amplifier section uses transistors to provide a nice energy reserve to accompany many types of headphones.
The FX--Audio Tube-03 MKII is an update of the Tube-03E. It is an affordable two-tube 6k4 preamplifier. Complete and powerful, with its own volume control and adjustments for bass and treble levels. These tubes are associated with AOP NE5532 and JRC4556 for tone control and participate in a rich and musical sound reproduction.
The Tube-05 is a compact device from FX-AUDIO. This desktop headphone amplifier/preamplifier is based on the use of an ECC82 tube. It features an innovative appearance and form factor, as well as quality components such as WIMA and Nichicon capacitors and a JRC NJW1194 volume control chip with output selector and tone control.
With its H26, Gustard unveils a class-A balanced audiophile preamplifier/headphone amplifier featuring discrete components. It features 8 pairs of power transistors, two dual LME49720 AOPs, two toroidal transformers, a relay volume control matrix and a balanced architecture.
The Gustard R30 is a DAC, streamer and preamplifier based on an R2R ladder resistor network to offer high-precision digital-to-analogue conversion, supporting PCM up to 32-bit 1536kHz and DSD up to DSD1024 for faithful and detailed reproduction. Its extensive connectivity allows it to be integrated into a wide range of audio setups. Based on CelWare 3.x...
This beautifully crafted Hattor Audio passive/active preamplifier features two high precision attenuators with Takman REX AMRT carbon film resistors, ensuring very low distortion for pure and transparent sound reproduction. It offers the latest refinement in high-end preamplification.
This superbly crafted Hattor Audio The Big passive preamplifier features two precision 1% SMD resistor attenuators and offers the very latest in sound reproduction refinement. Both a passive preamplifier and a input selector with generous connectivity (2x RCA & 3x XLR IN / 2x RCA & 2x XLR OUT), this impeccably finished, hand-assembled device is an...
This passive remote-controllable preamplifier with dual attenuators with 1% accuracy SMD resistors offers the latest in sound reproduction refinement. Both passive preamplifier and selectors for 5 sources and 4 outputs, this device with its aluminium and black carbon finish will convince. It is equipped with very high quality components assembled by hand...
This passive remote-controllable preamplifier with dual attenuators with 1% accuracy SMD resistors offers the latest in sound reproduction refinement. Both passive preamplifier and selectors of 5 sources and 4 outputs, this device with its aluminium and wood finish will convince. It is equipped with very high quality components assembled by hand with the...
The Hattor Audio Tube Active Stage is a very high quality gain/buffer stage. It has been thought and designed mainly to be associated with the passive preamplifiers of the brand. However, it can also be used with other passive preamplifiers.
With the Prelude, HIFIMAN presents a balanced Class A headphone amplifier based on MOSFET transistors to deliver natural sound reproduction and 10W of power at 32Ω.
With its Serenade WiFi, HIFIMAN unveils a versatile R2R DAC that also acts as a preamplifier, headphone amplifier and streamer, thanks to an RJ45 LAN port and WiFi functionality. The device was developed by HIFIMAN in collaboration with GoldenWave. It features R2R Hymalaya Pro conversion technology, as well as an XMOS XU316 USB interface and Class A...
