TRETTITRE Pack Platine Vinyle TTT-LP3 + Lecteur CD TTT-DP3 + Lecteur Cassette TTT-CP3 + Rack
New
This Trettitre pack brings together the TTT-DP3 CD player, the TTT-CP3 cassette player and the TTT-LP3 turntable in a single ensemble designed to form a true listening space. The wall rack supplied with the turntable accommodates the devices and composes a harmonious installation, where each format naturally finds its place.
By buying this product you get 52 loyalty points
Reference : 22596
529,00 €tax incl.
440,83 € tax excl.
Instead of 577,00 €
Shipping date: 25-11-2026.
Pack content
Trettitre TTT-LP3 + TTT-DP3 + TTT-CP3 Pack Turntable + CD Player + Cassette Player + Rack
Trettitre TTT-LP3 + TTT-DP3 + TTT-CP3 Pack: Front view
CD, cassette and vinyl thus coexist within a single wall-mounted display. An all-in-one proposal that combines listening and decoration, making this ensemble a fully integrated element of the interior.
Trettitre TTT-LP3: Bluetooth Turntable
The Trettitre TTT-LP3 is a wireless turntable designed to integrate vinyl playback into a contemporary audio installation. It supports 33⅓ and 45rpm records, while combining an Audio-Technica AT-3600L cartridge, a self-balancing tonearm and an integrated battery to simplify setup as well as the positioning of the device.
Intended both for domestic listening and for wall-mounted installation, it transmits the signal via Bluetooth 5.3 with support for the aptX HD and aptX Adaptive codecs, while retaining a 3.5mm jack audio output for a wired connection.
See more information on the Trettitre TTT-LP3
Trettitre TTT-LP3: Front view
Trettitre TTT-DP3: Front view
Trettitre TTT-DP3: Bluetooth Portable CD Player
The Trettitre TTT-DP3 is a portable CD player featuring Bluetooth 5.4 transmission, designed to combine physical media playback with wireless audio integration. Compatible with CD, CD-R and CD-RW discs, it relies on a compact design with a transparent magnetic lid, revealing the disc while simplifying everyday use.
Intended both for portable listening and for domestic installation, it combines a 3.5mm jack output, an OLED display and an integrated 2000mAh battery, allowing autonomous use or operation with headphones and a Bluetooth speaker. Designed to join the TTT-CP3 cassette player and the TTT-LP3 turntable, it can also take its place in a modular wall composition where the different audio formats contribute directly to the aesthetics of the installation.
See more information on the Trettitre TTT-DP3
Trettitre TTT-CP3: Bluetooth Cassette Player
The Trettitre TTT-CP3 is a Bluetooth cassette player designed to integrate analog tapes into current audio systems. It retains the mechanical elements characteristic of a cassette deck, notably the independent control keys, while relying on precise signal decoding to reduce background noise and preserve the recording's details.
Intended for enthusiasts of physical media as well as users wishing to revive their collection, it combines a 3.5mm jack audio output and Bluetooth 5.4 transmission, allowing tapes to be played through headphones or a wireless speaker.
See more information on the Trettitre TTT-CP3
Trettitre TTT-CP3: Front view
Technical Specifications
Trettitre TTT-LP3 Specifications
Product TypeTurntable
Output1x 3.5mm Jack
Bluetooth 5.3
Playback Speed33⅓ rpm
45 rpm
CartridgeAudio-Technica AT-3600LA
Headphone Output Power≥1mW+1mW @32Ω
Signal-to-Noise Ratio (SNR)≥38dB
Tracking Force2.5~4.5g
Speed Adjustment>5%
Battery3.7V 2000mAh
Charging Time2.5h
Battery Life6h
Bluetooth CodecsSBC, aptX, aptX HD, aptX Adaptive
Bluetooth Output Level≥300mV+300mV
Power Supply Voltage5V DC 2A
Dimensions342 x 233 x 87mm
Weight1395g
Packaging1x Trettitre TTT-LP3
1x Modular wall rack
1x USB-C cable
Trettitre TTT-DP3 Specifications
Product TypeCD Player
Outputs1x 3.5mm Jack
Bluetooth 5.4
SNR>70dB
DisplayOLED
Total Harmonic Distortion (THD)<3%
Battery2000mAh
Charging Time2.5h
Battery Life3.5mm Jack output: 10h
Bluetooth output: 8h
Compatible Disc FormatCD-DA
HDCD
Compatible CD TypesCD
CD-R
CD-RW
Dimensions170 x 170 x 27mm
Weight324g
ColorWhite
Packaging1x Trettitre TTT-DP3
Trettitre TTT-CP3 Specifications
Product TypeCassette Player
Output1x 3.5mm Jack
Bluetooth 5.4
Compatible Cassette TypesType I~IV
Output Power0.6W
Output Level3.5mm Jack: ≥250mV+250mV(32Ω)
Bluetooth: ≥300mV+300mV
Signal-to-Noise Ratio (SNR)≥53dB
Total Harmonic Distortion (THD)≤2%
Wow and Flutter (W&F)≤0.2%
Battery3.7V 1200mAh
Recharging Time2h
Battery Life8h
Dimensions120 x 120 x 33mm
Weight400g
Packaging1x Trettitre TTT-CP3
This Trettitre pack brings together the TTT-DP3 CD player, the TTT-CP3 cassette player and the TTT-LP3 turntable in a single ensemble designed to...
