YANN P.
Excellente barette secteur
Jeroen v.
Jeroen
Kah Yeow K.
Great cable for REL
Rik R.
TOPPING DX3 PRO DAC 2x AK4493EQ XMOS XU208 32bit/768kHz Headphone amplifier Bluetooth aptX HD Silver Topping's DX3 Pro fulfills both functions of DAC and headphone amplifier. It offers excellent performance when connected to a digital source by wire or Bluetooth. Multiple...
World of difference
Befor plugging this little beauty into my iMac, i was listening with my m50x cans directly plugged with jack or using my old Soundblaster USB dac. Thought i had the best sound ever. No. I did not. This DX3pro opened my ears.
There is so much detail, and at the same time the listening experience is smoother. I can turn the volume very low and still hear all details. Which my former soundblaster usb-dac did not provide.
The volume button is lovely with little metal clicks you feel when turning. Just look after yourself because the sound is so clean, you will forget your loud volume easily. But the same is true for the opposite: you can turn it very low and still enjoy detailed full music.
Just hooked the usb cable to my iMac and MacOS automatically added the external audio device. Plug and play, no problems. Just enjoy.
Adam t.
KHOZMO ACOUSTIC Passive Preamplifier / 10k Source Selector this passive attenuator uses a precision resistor that is connected in parallel with a 1% SMD mechanical resistance switch. this resistor is connected to the potentiometer,...
Top produit (aucune coloration ni perte, finition exemplaire)
Je cherchais un preampli passif de qualité pour relier deux sources à mon ampli de puissance. Celui-ci répondait à mes besoins. La finition est à la hauteur du prix. Aucune coloration ni perte audible. L'atténuateur est un plus (mais je ne l'utilise pas). Son seul défaut: le long, tres long délais d'appro (5-6 semaines dans mon cas, très loin des 2-3 semaines annoncées)
Frédéric H.
DAC Module 2x AKM AK4497EQ I2S SPDIF XLR RCA 32bit 384kHz AOP NJR 5534DD This module will allow you to design a DAC that is extremely efficient in terms of musical and precise reproduction. Based on two AKM AK4497EQ Digital to Analog conversion...
Un DAC à découvrir
Il faut reconnaitre que la construction de cette électronique est faite dans les règles. Le montage comme la mise en œuvre ne pose pas de problèmes particuliers. La première impression est bonne !
A la première écoute, je dois avoué avoir été un peu déçu. Il manquait des détails, la scène sonore était brouillonne.
Mes doutes se sont portés très vite sur le relais (situé à coté des embases RCA) . Composant plutôt cheap commutant le signal de sortie pour éviter clic et pop...
Je décide de retirer purement et simplement ce relais et de remplacer le contact travail du signal par un simple strap.
La preuve est faite à la fois de l'inutilité totale de ce relais, et surtout de son effet dévastateur sur le signal de sortie.
Tout s'arrange...et même beaucoup plus. Cette électronique est transfigurée. Précision, justesse des timbres, profondeur du grave, image sonore...c'est magique. Ce convertisseur fonctionne à merveille, apportant tout ce que l'on peut attendre d'un DAC en se faisant oublier.
L'écoute est réellement musicale et de très haut niveau.
Fabrice L.
Effet immédiat et positif
Après 2 semaines d’utilisation, je peux confirmer que ce filtre marche diablement bien. Je précise que j’ai du courant porteur à la maison. Je n’ai donc certainement pas le secteur le plus propre du monde. Je l’ai mis sur ma barrette secteur. En début de barrette j’ai l’ampli, le caisson de basse, puis j’ai mis le filtre. Ensuite j’ai le préampli et le streamer. L’effet est immédiat et très clairement notable. Tout devient plus précis, les aigus sont plus rapides. Les basses plus tendues. On gagne également en profondeur de scène, je n’ai pas noté de gain en largeur. Pas d’effet négatif sur la dynamique non plus. Lorsqu’on le supprime, tout devient plus fouillis, plus brouillon. Attention aux systèmes ayant une tendance à la brillance. Cela risque d’être accentué du fait de l’augmentation de précision. On perd un peu en douceur, en rondeur, forcément… Si le système est équilibré, il le restera.
Stefano T.
TOPPING DX3 Pro...really good product.
I was looking to improve the sound of my system based on an integrated amplifier Yamaha CA-800 plus a couple of Epicure 10 (2 ways speaker) both coming from the '70s connected via DAC (USB Sound Blaster external card) to a Lenovo T420 Win7 with a JRiver player. The sound improve really a lot, deeper bass and more defined mid range tones. Even as a headphone amplifier there's no compare with my previous DAC. The quality of service from Audiophonics has been very good (fast shipment, clear & good communication). Happy with my new DX3 Pro!
Ben R.
Great little DAC
I got the pi/DAC bug a few years ago and have owned/own a iqaudio, Boss v2.0, terradac and pi-fi V2.0. All sound superb and offered fantastic bang for your buck on the music front.
But I wanted to experience DSD and have been looking at options but nothing had caught my eye.
Then I found this little beauty.
Easy to build and set up - well nothing beyond the usual pi stuff. Once up and running, wow. Plays anything I throw at it, gets a bit warm when playing DSD files but to be expected with the extra processing power needed. Sounds amazing, much warmer than the other pi/dacs ive heard. I wouldn't even like to think how much you'd have to spend on a turnkey solution to get such an engaging sound.
Only issue was the crap sd card supplied, corrupted within a few weeks. This isn't a major problem, I've always got a few spare lying around. But make sure you have too, otherwise you'll be without music for a day or 2.
philippe t.
pour découpler un lecteur blu-ray
Très bonne qualité et finition . Le réglage des pieds permet de parfaire le réglage de l' horizontalité de la mécanique de lecture et donc d' améliorer un peu le suivi de piste et d' éviter des contraintes mécaniques mal réparties sur l' axe de rotation sachant qu' avec les blu-ray la vitesse de rotation est plus élevée qu' avec un CD . De plus pour améliorer l' atténuation des vibrations lors de la lecture je n'utilise que trois disques découpleurs de pointe et la quatrième pointe est en contact direct avec le support : cela permet un fonctionnement différent des quatre pieds car les symétrie renforcent les phénomènes de résonance .
Merveilleux
Je croyais être arrivé au bout du bout en qualité et ce petit truc a encore repoussé les limites..... encore plus de détails, une spatialisation à couper le souffle, et une clarté entre les instruments incroyable.
En remplacement de l'AOP d'origine, déjà trés trés bon du modéle " AUDIOPHONICS DAC AK4495SEQ 32bit 384kHz Asynchrone USB XMOS "
Merci à Mr Aubert et l'équipe d'Audiphonics qui me font progresser dans le monde de la musique dématérialisée, grâce aux conseils techniques et très pédagogiques.
Petit préampli mais grand son.
Que peut on demander à un bon préampli? En premier qu'il soit neutre, deuxièmement qu'il soit fonctionnel. Ce PGA2310 offre ces deux qualités, avec en plus une reproduction sonore de premier ordre. J'ai été surpris par la qualité des timbres qui offrent une belle palette sonore. Quel régal sur les voix qui restituent toute l'émotion d'une œuvre. Les écarts de dynamique sont bien dosés et offrent une belle qualité rythmique à la musique. J'ai fait part à un ami de l'acquisition de ce préampli qui au niveau écoute m'a séduit. Ce dernier sans même l'avoir écouté, m'a demandé de lui commander un exemplaire, intrigué par mes impressions d'écoute. Je suis surpris de sa demande, sachant que ses écoutes tournent autour de marques telles que Mark Levinson, Vincent, Bel Canto. Affaire à suivre donc.
Joel C.
Du bon
j'ai couplé ce DX120 avec un intra Ibassi IT04, il contient deux microSD de 200G chacune tous style musical.
Venant d'un DX80, je trouve que le 120 est plus sec au niveau du son, plus clair et moins ''tassé'' dans la restitution globale. une fois mon réglage trouvé Filtre numérique ''Filtre à pente très douce'' Mode sonore ''Référence'' (à vous de tester chacun son oreille) il est parfait et d'une qualité rare pour un produit dans cette gamme de prix.
Je conseille sans hésitation.
gilles F.
excellent produit et facile à mettre en oeuvre.
bon rapport qualité prix.
CHARPENTIER P.
Il faut l'entendre pour le croire !
J'utilise ce câble pour relier un préampli / dac SMSL M10 à mon ampli en symétrique sur XLR.
Déjà satisfait par l'ELECAUDIO 2210, je ne m'attendais pas à une telle transfiguration de l'écoute par un câble d'apparence somme toute banale, utilisé sur un appareil coûtant à peine plus de 500 € !
Qualité des timbres supérieure, image stéréo plus précise, aération et dynamique ample sans crispation sur les forte, l'écoute fait un bon qualitatif qui donne l'impression d'avoir changé le M10 pour un appareil beaucoup plus cher !
Un upgrade spectaculaire et un RQP finalement excellent malgré le prix élevé.
JEAN-BAPTISTE C.
Facile à installer, il fait ce qu'on lui demande, mais ...
J'écoute Spotify depuis ma tablette Samsung sur une enceinte JBL Xtreme 2. Avantage : je peux me balader partout dans la maison avec la tablette et le JBL.
J'ai acquis ce récepteur Bluetooth pour profiter de l'installation du salon : paire de colonnes Triangle Antal 150 W branchées sur un ampli Pioneer VSX 522 K, quand je suis confortablement installé dans mon fauteuil, le SMSL B1 étant relié en coaxial. Pour l'instant, mes écoutes me laissent sur ma faim, je trouve le résultat moins défini que lorsque j'écoute Spotify sur la même installation mais à partir d'un PC portable branché relié à l'ampli via un DAC Audioponics USB ES9023 TCXO. Inconvénient du PC portable : pas de télécommande pour le contrôler à distance, alors qu'avec la tablette dans les mains, tout est sous contrôle direct.
Détail bizarre : la petite loupiote verte ne s'éteint pas toujours même quand on a tourné le bouton à fond à gauche sur OFF. Il faut parfois actionner le bouton plusieurs fois avant extinction totale. Pas plus dérangeant que ça, sauf que si la loupiote reste allumée, c'est que la batterie interne risque de se décharger pour rien ?
JEAN-BAPTISTE C.
Epoustouflant ! Incroyable !
Ce minuscule ampli a remplacé avantageusement mon Kenwood "Vintage" KA-6100 2x40 W sous 8 Ohms et qui pèse plus de 10 kg : délivre la même qualité de son - pour mes oreilles tout du moins - tout en consommant considérablement moins d'énergie. En effet, le Kenwood "brûle" 480 W, même quand il n'y a pas de signal, alors que l'Alientek s'éteint de lui-même le cas échéant.
Seul bémol : pour une raison inconnue, parfois le D8 refuse de s'allumer, l'écran reste tout noir. Après moult tâtonnements, j'ai fini par comprendre que l'USB n'était plus sélectionné comme entrée par défaut. Il faut donc allumer le D8 manuellement, et on a alors la surprise de tomber sur un menu ... en chinois ! Heureusement que j'ai trouvé sur internet la solution : https://www.youtube.com/watch?v=AXCX6kUGkGI
Au début, j'ai cru comprendre l'origine de cet "auto reset" intempestif : le port USB de mon PC est défectueux et il suffisait de bouger légèrement le câble pour provoquer ce reset. J'ai alors rangé les câbles afin d'éviter que cela se reproduise. Eurêka ! ça a marché quelques jours, puis ce matin, rebelote : j'allume le PC comme d'habitude et j'appuie sur le bouton rouge de la multiprise sur laquelle sont branchés mes périphériques, dont l'Alientek. Ecran noir, allumage manuel, menu en chinois, etc...
J'ai alors branché l'Alientek sur une autre prise, permanente celle-là, et je vous tiendrai au courant des suites d'ici quelques semaines, sauf si le reset survient encore à nouveau entretemps...
Question aux techniciens : en laissant le transformateur branché en permanence, quelles sont les conséquences sur sa consommation et sa longévité ?
Volkher H.
Excellent player (and excellent service)!
I needed a small CD-player for a pair of active speakers and chose this one after reading around the Internet for a couple of days.
I decided to order from Audiophonics because they had the most sensible price (in Europe) and, apparently, excelllent service. And the player arrived here excellently packaged and quickly. I'm very happy with Audiophonics' service! Thank you!
The player also turned out to be excelllent. I have 4 other CD players (three Marantz, two of which are top of the line) and one (older) Teac. This Shanling performs equally well (!) and is just fun to "play with".
If anyone is reading this, the build-quality is excellent (the remote not so much, which you have to unscrew to replace the battery), the sound is excellent and it is a small hefty enough machine to exude a feeling of trust.
It would have been nice to have an English language instruction manual (the one provided is in Chinese), but I don't even know if one exists.
Iwould have only needed it to figure out the USB specifications, because, apparently, that part of he player's functions adheres to age-old standards (in regard to number of tracks, folder management, etc.). I still haven't figured that out in detail, but putting an album or two onto a USB stick (flat) results in quality sound! But, in regard to implementation, it seems to be more of a gimmick because display notifications are minimal (at least for my tagged files).
All in all, at a price of around (or below) $200, an excellent little machine whose longevity I cannot comment on yet. At the moment I'm quite sure that it will last for a long time.
Malcolm R.
M Ross
An excellent product, the sound quality is much higher than the usb to spdif converter I was using before. Highly recommended.
Francis B.
précision
Il faudrait indiquer qu'il s'agit du modèle court car du coup je me retrouve avec des fiches qui ne me servent à rien car pas adaptés
alain M.
à priori c est positif ... en début de ligne AC
il faut malgré tout ... simplement filtrer les éléments les uns par rapport aux autres car ils s auto polluent ... et finaliser en incluant 1 filtre ifi audio en debut de ligne ou en sortie de prise murale ...
michel F.
Electronicien utilisateur ...
Ce petit module permet d'être utilisé avec peu de place et offre des performances plus qu'honorables pour terminer un montage dans des conditions d'écoute déjà puissantes et de qualité . Son absence de gros radiateurs est un gain de place appréciable . Une notice plus détaillée serait la bienvenue ainsi que l'utilisation du " mute " ? Mention bien !
Frederic S.
RAS
Bonne qualité de matériaux et d'ajustements.
carole b.
IBASSO DX120 DAP HiFi Music Player DAC AK4495 32bit 384kHz DSD128 Blue The iBasso DX120 is a high-end digital music player (DAP) that delivers high-flying audio performance thanks to its clever design. DAC AK4495, USB XMOS XU208, Quad Core CPU,...
Très belle finition
Un son de belle facture..un Dac utilisé à son max ce qui est rare ..ici pas de course à 2 ..3..Dac..mais un Dac AKA de nouvelle génération..
Scène aérée..son délicat et précis.. digne de baladeur valant le double du prix..une belle surprise
Merci à Audiophonics pour votre sérieux et vos produits..
Francois M.
J'ai une alimentation 12V secouru avec Batterie, j'avais besoin de 5V pour alimenter un RASPBERRY et cela marche.
Stefano S.
Great site, great selection, very good service!
stephane g.
Pré ampli éfficace
Bon petit pré-ampli , bonne qualité de fabrication , les potentiomètre avec des petits cran son bien . Il est branché entre mon dac et mon ampli de puissance Il lui donne du punch . Il a un son de bonne qualité . Les corrections son bonne et bien utile sur certains morceaux . tout ça pour un prix Riquiqui
Jean-Luc L.
Génial
Je cherchais un streamer juste pour écouter Spotify sans y mettre plusieurs centaines d’euro.
Et franchement ce petit appareil fonctionne très bien. Très bon rendu on oublie que la musique est en mp3 320k.
Je vais en prendre un autre pour ma chambre.
Un Dac au son chaud et détaillé
Je possède un Dac AUDIO-GD R2R 11 dont je suis vraiment ravi et tout ce qui est dit sur ce Dac est amplement justifié.
Pour ne pas mourir idiot et parce que j'ai lu çà et là que les convertisseurs AKM étaient réputés pour leur son son chaud, voire tubesque...je me suis laissé aller.
Autant dire de suite, à la première écoute, le compte n'y était pas. Le son était certes précis, fourmillait de détail mais le son était bien moins chaleureux que le R-2R.
Mais pour avoir vécu l'expérience, souvent contestée du rodage des composants, j'ai laissé tourner, en comparant de temps en temps avec le AUDIO-GD R2R 11.
Et bien, au d'une centaine d'heures, autant dire que ce dac est une merveille. Il rivalise largement avec le AUDIO-GD R2R 11....aussi chaleureux, voire meilleur dans la définition, mais AUDIO-GD R2R est en plus, un excellent ampli casque, pré ampli et va plus haut dans les conversions.
Le son est aussi chaud, détaillé et spatial que le AUDIO-GD R2R 11.
Oui, les qualificatifs des convertisseurs AKM sont justifiés et me voilà réconcilié avec la conversion Delta sigma.
Maintenant je voudrais monter en gamme et aie...terrible dilemme...R-2R ou AKM ?
Bref , bravo Audiophonics pour votre création maison et surtout à 199 €.
Finition magnifique et son superbe.
Merci à David Aubert pour ses bons conseils.
Abdelnasser H.
Connecteurs très beaux mais de piètre qualité.
Ces fourches ont été utilisées entre un ampli à tube line magentic lm216ia et des enceintes Klipsch Cornwall III.
Les câbles haut parleur sont des câbles ptfe cuivre plaqués argent 1.23mm*4 torsadés donc 2x5mm2.
Il s'agit d'une catastrophe, le son est très dégradée. Je les ai virées au bout de 30 minutes.
Luca M.
Nice sound
Just got mine, easy and fun to assemble.
Works fine with Volumio, GREAT SOUND
Jean S.
Jean
Ne pas préjuger au prix affiché.
J'en ai acquis 3 exemplaires dont 2 seront modifiés en fréquence de coupure.
Je le conseille sans réserve.
Jean
Michael R.
Nice fit but back to front
This is the perfect size for the Khadas Tone Board but the pre drilled holes are back to front. Therefore, the labels printed on the box end up being at the opposite side of the connections. Not a big issue for me since the box is not going to be moved around a lot and with only 4 connections it easy to connect correctly when following the diagram in the manual. Also, one of the 3 pre drilled holes does not align with the fixing holes in the circuit board but to fixing screws seems to be fine such a light board. Otherwise, it is a good quality and sturdy little box that protects the tone board well.
Mika H.
Well done
Very good cable for the price especially when connected to a DA converter.
Provides silent and black background for music.
Quite flexible with sturdy connectors. IEC connector could be a little bit tighter but it´s good as it is. Excellent for replacing bulk wires.
Stephane S.
Viborg VF502
De la même trempe que la Shuko , se produit entièrement cuivre et de très belle facture , comme la Shko ,Cette l'IEC Viborg contribue à une meilleure définition du signal et améliore l'écoute .
Stephane S.
Viborg VE502
Nouveauté chez Audiophonic j'avais entendu parlé de cette marque par un ami , qui m'en avait précisé que du bien. Après donc l'achat de ce produit , il s'avère que ce dernier et d'excellente facture , le fait déjà que la matière utilisé soit du cuivre , cela complète parfaitement mon câble qui est de la même matière , évitant les rupture entre matériaux. En tout cas produit ui me satisfait complètement et pour moi qui améliore l'écoute
cordialement
Stephane S.
pinta resobson
après l'achat de ce produit , et le positionnement sur une partie du mur arrière et des murs latéraux , ces panneaux sont d'un excellent facteur d'amortissement , évidemment il faut les placer au bon endroit , et bien étudier le placement avant. Une grande attention justement au positionnement , la partie auto collante une fois positionnée sur le mur et très difficile à enlever ! d'ailleurs une partie de la matière du produit reste sur le mur ! donc bien étudier la question avant .
cordialement
Achille m.
Cavo eccellente
Cavo USB eccellente, costruzione eccezionale, prestazioni al top dell'hi-end, connettori precisi e robusti, prezzo ridicolo a dir poco.
Bertrand D.
carte de qualité
Bon ampli casque et en classe A, le son est claire, manque juste un peu de grave mais bon, c’est normale vu de la puissance, largement suffisante pour un casque. Installé dans le boitier aluminium 220x191x52mm de très bonne facture. Pour le faire, il a fallut percer la face avant pour fixer la prise jack montée sur la carte, du coup le potar a été déplacé. L’alim avec un transfo torique 30VA ne provoque aucun bruit malgré sa proximité avec la carte dans ce petit boitier. Ca chauffe un peu, peut être prévoir une aération du boitier. Au départ du projet d’un ampli pour casque, j’étais parti sur la fabrication d’une carte ampli classe A, quand j’ai vu cette carte mon projet à changé et je ne le regrette pas à ce prix proposé.
Bertrand D.
Aluminium Case 220x191x52mm Silver Front Panel This 100% Aluminium housing will allow you to integrate a DIY design such as an amplifier or DAC. It is delivered with an Aluminium button, an ON/OFF switch and an IEC base. The...
beau boitier.
A ce prix, très bon boitier de bonne facture.
Sebastien B.
Simple à monter
Le montage est facile, par contre il manque 4 vis noir (V4). Il y a bien 8 vis sur le descriptif mais seulement 4 vis dans le paquet reçu.
Sinon le reste est parfait.
Jean-Luc B.
Armature Hecate ;
Bonjour ,
Cette petite interface fait très bien son travail !
La définition a montée d'un cran , le plan stéreo est plus précis .
Le silence de fonctionnement couronne le tout !
Bravo , je recommande !
B jl
après plusieurs mois d utilisations .
quelle déception ,
après plusieurs utilisations ses fiches n ont plus aucun couple de serrage.
si vous n êtes pas un maniaque du changement de câble c est ok pour vous .
Didier Z.
Très bonne solution DAC + Ampli
Facile à monter et à configurer (client Roon avec DietPI). Fonctionne parfaitement, comme je l'espérais, pour alimenter mes vieilles - mais excellentes - enceintes Philips Legend 1. Merci Audiophonics pour la qualité de service (commandé un vendredi et reçu le mardi suivant en Suisse).
Jan G.
God Headphone Amplifier
Work very well whit my Philips x2,
Fast delivery to Sweden to...
Andrei M.
Recommend
Good product. Made of high quality. I hope they're really made of pure copper.
on trouve mieux dans la marque
je teste beaucoups de câbles à different prix pour denicher la pépite , mais encore une fois ce ne sera pas celui ci . quand on connait son grand frère le 3103 qui reste pour moi le meilleur de tout ce que j ai testé , et ca sans parler de son prix .
BONNE MUSICALITE ... MAIS PAS AUTANT QUE LE FX AUDIO D802...
Ce petit FX 1002A n'est pas un FDA mais un amplificateur classe D c'est à dire acceptant sur ses entrées des signaux exclusivement analogiques. Cet appareil sonne comme un bon ampli classe A/B avec ses qualités et ses petits défauts. Couplé directement à un lecteur CD de salon, la restitution révèle d'emblée une propension à favoriser le milieu du spectre ce qui donne de la densité aux voix. Cette chaleur, certes flatteuse, s'obtient au prix d'un certain artifice, il faut bien l'avouer! La définition est très correcte mais les attaques du piano ne sont pas d'une absolue précision, enfin la transparence, bien que satisfaisante n'est pas parfaite. Couplé à un DAC de compétition digne du très haut de gamme (un FOSTEX HPA8), le piqué est meilleur, l'image stéréo gagne en dimension mais n'est pas meilleure que celle du FX AUDIO D802. Le léger voile qui limite la transparence persiste et restera toujours là car inhérent à la double conversion A/N + N/A et à ses incontournables altérations du signal. Sur ce dernier point, un FDA tel que le D802 est nettement meilleur. En conclusion, pour ceux qui ont déjà goûté à l'amplification Full Digital (FDA), revenir à un classe D tel que le FX 1002 me semble difficile, pour ne pas dire impossible, en tout cas pour ce qui me concerne. Quant aux quelques critiques que certains font aux FDA, leur reprochant de ne pas suffisamment "enrober" la musique et d'être "trop" transparents, je leur répondrai que créer de l'expressivité musicale n'est pas le rôle d'un appareil quel qu'il soit, mais bien plutôt celui des musiciens eux-même.
marc v.
facile d'utilisation
testeur simple a utiliser mais diaboliquement efficace.
Marco S.
MiniDSP EARS Low noise omnidirectionnal stereo 180° Microphone The measurement microphone EARS is the equivalent of the popular Umik-1 for headphones and in-ear systems. It uses the same technological trunk and shares its excellent...
getting a better feeling for headphones
hi audiophonics. thanks for the best price of minidspEars in europe. the ears work great. if helps me to get a better feeling of what headphones are really producing at their outputs. together with REW they are a great tool. comparing my measurements to the russian website https://reference-audio-analyzer.pro/en/report/hp/denon-d2000.php also showed that the measurement is really quite reliable.
thx.
ps: as usual in measuring audio equipment - measure to get information but trust your ears :-)
Georges B.
coffret DIY
Excellent coffret très bien fini,robuste et beau,ce qui donne un aspect vraiment professionnel au montage.Même pour les anciennes technologies comme les tubes pour mon ampli à tubes PCL86.
http://gozgeorges.fr
Gábor F.
FX-AUDIO TUBE-03
Felül múlta a várakozásomat mint küllemben mint hangzásban elégedett vagyok a szállítás sebességével és a termék állapotával csak ajánlani tudom mindenkinek
Samuel P.
outsider audiophile
Câble acheté pour relier un transport CD Cambridge CXC au DAC Magic Plus de la même marque. Il me fallait un câble le plus court possible et de haute qualité pour cette liaison cruciale.
Marque quasiment pas connue et distribuée en France (merci Audiophonics !!!), je me suis laissé tenté après des avis élogieux sur des blogs audiophiles, comme je les comprends: neutralité, haute définition, dynamique, tout ce que je recherche est là, le prix contenu devenant même "ridicule" tant le niveau de performance et la qualité de fabrication sont élevés.
Cerise sur le gâteau si vos câbles sont apparents: une esthétique hors normes.
