iouri C.
Au final déçu.
Antoine S.
CD Player Upgrader
Michel R.
Parfait pour mon usage
Robert C.
FOSI AUDIO ZP3 Balanced Preamplifier NE5532 The Fosi Audio ZP3 is a balanced preamplifier based on NE5532 AOPs. It offers interference-free sound reproduction over a wide dynamic range, minimizing ground loop effects. The...
It is difficult to open and change the OPAs. Acrylic side plates are annoying.
Robert C.
Good quality product
This is for DIYers since soldering is mandatory!
If you have basic soldering skills and tools then it is easy and recommended.
Robert C.
SPARKOS LABS SS2590 PRO Dual Discrete OPA (Unit) After the undeniable success of the SS3601 and SS3602 discrete OPA, SparkoS Labs focused on discrete OPA that can be found in studio equipment or recording devices, such as the...
Best OPA. (so far)
So far, I have tested many different dual OPAs in different device (DACs, preamp and amps): 1612, 1656, LM49720, Muse 01, Muse 02, AD8599, SX52B, Akilam LC2, Akliam LC5 (A05), Sparkos SS3602 etc. and the Sparkos SS2590 Pro Duo is a clear winner. Everything what matters regarding sound quality is better: dipper and wider sound stage, better layering and instrument separation. If you have means and opportunity this is HIGHLY RECOMMENDED device and upgrade.
Cornelia Ekaterina L.
DENAFRIPS ENYO 15TH Balanced R2R DAC 24bit 1536kHz DSD1024 Black The Denafrips Enyo 15TH DAC is an R2R digital-to-analog converter supporting high-resolution audio streams up to PCM 24bit 1536kHz and DSD1024. R2R technology enables Enyo to...
Beautyful Sound
I used the internal DAC of my Wiim pro plus for about a year, but after a while came to the conclusion, that the Sound lacks a lot of the attributes I love about my Vinyl Setup. And as i digged into the rabbit hole of DAC Systems, I soon found out about Denafrips.
To put it short, this comes very clone to the vinyl sound, and absolutely makes a huge difference to the Wiim dac. So open, airy, wide soundstage. Listening fatigue is gone and it just makes me want to Listen to my digital chain more often.
Definetly recommended!
Yohann G.
FIIO DM13 BT CD Player Ripper on Battery 2xCS43198 Black FiiO's DM13 BT is a portable CD player with a sleek design and undeniable internal component quality. Its aluminum body houses two DAC chips from Cirrus Logic to offer a...
Finalement satisfait de mon achat.
Positif : le son excellent surtout sorties numérique et symétriques, la lecture sans aucun accroc, le format compact, connectique complète. Un plaisir de réécouter des cds.
Négatif : bluetooth inutilisable en usage mobile (coupures, pertes de connexions) pour ma part j'utilise un transmetteur bluetooth longue portée annexe connecté sur sortie optique ou symétrique pour cet usage. Il aurait été agréable d'avoir avec les bons adaptateurs ou câbles pour les sorties symétriques et optique minitoslink. Les écritures des boutons s'efface rapidement et sont peu lisibles.
Au final satisfait de l'achat.m malgres les problèmes de bluetooth et quelques difficultés pour trouver les bon câbles.
Patrick L.
6H6Pi Twin Triode Tube (Unit) The 6H6Pi is a durable and reliable dual-triode power tube that can be used as a replacement for a 6H6N or 6N6N tube.
Excellents
Je suis très satisfait, je recommande !
Joseph P.
Alimentation 36v 6ampères
Livraison très rapide et produit correspondant parfaitement à sa description ( avec câble secteur fourni ) Pas de " souffle ou de ronflement intempestif sur une puce 3255D2 d'un mini ampli classe D
Milan G.
XANGSANE XS-6002AU Banana plugs Gold-plated Ø7.5mm (Set x4) These Xangsane XS-6002AU banana plugs feature copper alloy contacts with gold plating for enhanced conductivity and resistance to corrosion and oxidation. Their...
Milan G
Very good quality banana plugs for this money. I’ve used them with Mogami 3104 speaker cable at speaker side in bi-wire constelatiin. Connection is quite tide and reliable. Just need to pay attention to the screws for wire fixing in banana body, ther are 2 type ands on these screws so dont change their position when mountig.
Milan G.
Milan G
This speaker cable I’ve used for my diy project. I’ve made a bi-wire speaker cable used this Mogami 3104 cable to connect my Sonus Faber Venere 2.5 speakers with tube integrated amplifier. My first listening test just made me satisfied with this choice. Amazing sound with all details of the stage and tones underlined with solid base tones. Highly recommend this hi-end cabe for afrodable price.
Milan G.
24k Gold-Plated Copper Spade Ø4mm (Unit) This robust spade is made from copper and is 24k gold-plated, giving it high conductivity and resistance to corrosion and oxidation. It features...
Milan G
Very solid build spade with glossy surface. Spade accepts a twisted pair of wires ((2x4 mm2). I’ve used it with Mogami 3104 speaker cable and works very well.
Good value for the many
robert m.
LAIV HARMONY UDAC Discrete Balanced R2R DAC 24bit 768kHz DSD256 Black The LAIV Harmony µDAC, little brother of the LAIV Harmony DAC, is also a discreet, balanced R2R DAC. However, it features an ultra-compact form factor, similar to the...
révélation
Acheté l’u-dac après avoir entendu un enregistrement de démonstration sur YouTube d’une source en qui j’ai confiance. Ce que j’ai vécu lors de l’enregistrement démo est exactement ce que je vis maintenant dans ma chaîne. Les saveurs diffèrent et ma préférence est un climat sonore spatial et ´laid-back'. C’est incroyable ce que l’u-dac ajoute en profondeur à l’image sonore. Ce n’est pas un son plat mais il est vivant et convient comme une expérience en direct pour le salon. Depuis que j’ai commencé mon passe-temps hi-fi en 1970, j’ai toujours utilisé des équipements à effets qui ajoutent plus d’espace à l’image sonore quelle que soit la gamme de prix de l’équipement hi-fi que j’utilise. Pour la première fois, j’envisage maintenant d’omettre cet équipement à effet et de simplement écouter l’u-dac.
robert m.
Unity Gain Buffer Symmetrizer / Desymmetrizer XLR RCA 2x AOP LME49720 2x LM317 This unity gain buffer offers dual connectivity, both unbalanced with stereo RCA input and output and balanced with 3-pole XLR input and output. In addition, it also takes on...
autre que prévu
Construit solidement et sans aucune influence sur le signal. Je m’attendais (dans ma naïveté) à ce que lors de la conversion de LXR en RCA, le niveau passe de 4 V maximum à 2 V afin que mon ancien préampli Sony avec RCA seul ne soit plus surchargé. Ce n’est pas le cas compte tenu de mon expérience d’écoute. Je peux utiliser ce produit ailleurs dans ma chaîne d’écoute donc je suis satisfait.
robert m.
Produit solide
Acheté la télécommande pour le LAIV Harmony u-dac. Est relativement cher; surtout si vous essayez d’économiser en n’achetant pas le LAIV Harmony dac. La télécommande est extrêmement solide et fonctionne bien avec le u-dac. Je peux maintenant changer la source à distance, passer entre OS et NOS et changer la phase positive vs négative pour le meilleur résultat d’écoute.
EVERSOLO PLAY CD Streamer DAC Amplifier CD Player 32bit 768kHz DSD512 2x110W 4 Ohm Whether you're a music enthusiast or a true audiophile, the Eversolo Play CD audio streamer and CD player takes your music experience to the next level. As versatile as it is...
ampli connecté multi fonction
Eversolo, c'est l'assurance d'une belle fabrication.
Beaucoup de fonctionalités pour le prix, premiers essais :
- insertion d'un cd : recupération automatique de la pochette : un régal, le lecteur est un lecteur de pc portable, peu importe s'il est sur le côté, il n'est pas bruyant. Mais y penser avant achat.
- ecoute vinyle sur entrée phono, j'ai une platine un peu cheap technics de 1990, mais ça marche. C'est un peu plus long, car il fait selectionner la source phono ou line dans un menu, depusi l'interface. Avec l'applcation android c'est un peu plus rapide.
- disque externe ssd de 1to contenant fichiers flac, mp3 etc, on peut naviguer par une arborescence de fichiers tout de suite ou indexer le lecteur usb (il faudra qq minutes pour scanner suivant le nombre de fichiers), ensuite on peut navigue par tag, album, artiste, c'est facile.
- creation de playlist, toujours un peu fastidieux même si l'ecran est bon, plus facile par l'application, mais j'ecoute en général album par album, old style.
- il trouve aisèment mon deuxieme appareil eversolo, qui est un streamer avec ssd intégré, surtout si les 2 appareils sont sur ethernet.
- pas testé par bluetooth depuis un smartphone, je ne doute pas que cela marche sans souci.
sinon, reglages de themes, de l'eclairage du bouton, plusieurs couleurs, de l'extinction de l'affichage ou du bouton lumineux, ils ont pensé à tout !
Dès la réception, firmware mis à jour en ligne sans souci.
Il peut paraitre un peu cher mais il remplace le streamer et l'ampli, en plus d'ajouter la platine cd (non audiophile).
seul regret, pas de port usb audio in pour brancher un pc, mais est ce utile ? il lit très bien depuis un autre streamer, un nas ou par les 2 ports usb pour clés ou hdd externe.
felix q.
super
rien a dire
c'est une valeur sure, avec une amélioration du son de mes klipsch (j'ai entièrement recâblé mes enceintes klipsch avec les ZEF et le son est bien mieux
test fait à l'aveugle avec un amis qui ne savait pas ce que j'avais fait = mais il trouvait le son mieux)
felix q.
ATOHM WT-5524-G Speaker Terminal Block Gold Plated 54x24mm (Unit) The ATOHM WT-5524-G terminal block, like all the models offered by Atohm, is equipped with large-sized lead-free brass terminals with 24k gold plating. It accepts cables with...
tres satisfait
monter en remplacement des borniers pince des enceintes
La c est bien mieux, une légère amélioration du son
YONATAN R.
Fantásticas etapas de potencia, por el precio no conozco nada que suene igual de bien, hacen que el sonido florezca por todas partes... volvería a comprarlos mil veces, es de lejos la mejor amplificación que he tenido, gracias!
JEAN-MARC M.
TOPPING A90 DISCRETE Discrete Balanced Headphone Amplifier Preamplifier Black Topping returns with the A90 Discrete, an improvement of the previous A90, this time equipped with discrete components. Both a headphone amplifier and a preamplifier, it...
Sarisfait
Site très réactif. Beaucoup de choix à des prix raisonnables. Le suivi des envois est très pratique. Vraiment un bon site. Je recommande
Eliot C.
AUDIOPHONICS OPA1656 Dual OPA DIP8 (Unit) Audiophonics is proud to present its OPA line-up with the OPA1656 based on a authentic Texas Instrument chip. This OPA offers excellent performance for audio applications. In...
Clearly Audible Difference
Replaced NE5532s in Fosi ZA3s. 1656s are impressively clean, detailed and spacious. These have helped to open up compressed recordings a little bit more than the 5532s as they untangle dense material into more easily audible layers. I was hoping for a bit more warmth but realise now these aren't the op-amp for that. Still very impressive nonetheless!
Sandy Clémence B.
Très bon rapport Prix/Performances
J'aime beaucoup ces 6SN7EH GOLD.
Tout y est : équilibre spectral, espace, extinction des notes sur
du piano par exemple. En comparaison à d'autres, je trouve leurs
résultats d'écoute excellents. Pas de dureté, avec de la dynamique,
et beaucoup de raffinement. J'ai écouté pas mal de choses , dont
VT231, et autres NOS. Je confirme mon choix .
Sandy Clémence B.
Très belle sonorité
je viens ajouter ma petite pierre à l'édifice, en postant cet avis
très favorable. Sur mon CAYIN 845, le résultat est excellent.
L'écoute est définie, l'impression d'espace est présente, l'ensemble du spectre sonore est équilibré, l'effet clinquant ne transparait pas contrairement à d'autres réalisations actuelles.
Bref, SATISFAITE de mon achat.
Je laisse aux "petits ingénieurs" le soin de décortiquer davantage les paramètres de ces tubes. Perso, je laisse parler mes oreilles..!.
BRAVO.
Olivier C.
SHANLING MTW200 PLUS True Wireless Dynamic In-Ear Monitors IEM Ø10mm 32Ω 112dB 20Hz-20kHz With the MTW200 Plus, Shanling presents us with wireless in-ear earphones. The brand has opted for a dynamic 10mm driver with a titanium membrane, coupled with a special...
Ok pour un film, pas ok pour la musique
Autant pour les films ça passe, c'était mon objectif, le rendu en mode étendu est correct.
Autant pour la musique, ça ne me plait pas du tout : ça sature sur des notes de piano simples.
L'ergonomie ne permet pas de les garder dans mes oreilles quand je bouge un peu trop, malgré les embouts les plus petits, les contrôles sont approximatifs, et la réduction de bruit ne fait rien.
Très déçu à ce prix, il vaut mieux faire confiance à des marques plus grand public.
Snif ...
peter S.
velmi dobry kabel, spokojnost
peter S.
velka spokojnost
peter S.
peter S.
super *****
peter S.
Jean-Pierre D.
TONEWINNER TY-1CD CD Player DAC ES9028 The Tonewinner TY-1CD CD player benefits from attractive aesthetics and quality components for superior CD playback performance. It features an ES9028 DAC chip as well as...
Lecteur CD qui s'approche du très haut de gamme
Conseillé par une relation qui a le pack complet Tonewinner, ampli, préampli haut de gamme de la marque chinoise, permet de redonner à ses CD un son de haut niveau, puissance, musicalité et pas mal de micro détails sans que cela soit analytique ou chirurgical. Associé à un ampli intégré Soulnote, c'est très bon.
Ayant eu par le passé un Denon DCD 2500ne, remplacé aujourd'hui par le 3000, je trouve le Tonewinner largement au niveau, les Denon sont en moyenne trois fois plus chers. Celà m'a évité de mettre beaucoup d'argent dans un Atoll 400CD que j'ai écouté avec l'ampli 400 que je possède, je dirai on n'a pas de frustration de mettre cinq fois moins cher. Intérêt du Tonewinner permet de connecter deux amplis avec des paires d'enceintes distinctes.
A recommander
Jean-Pierre D.
Conseillé par une relation qui en acheté un, remarquable rendu sonore, beaucoup de détails et une grande musicalité, associé à un ampli Soulnote A1, j'ai eu un D
Ortiz C.
impresionante!
Tube que esperar 1 mes a que llegaran componentes que faltaban para poder fabricarlo y casi que desisto .... menos mal que esperé!! Impresionante el trabajo balanceado y equilibrado de los canales que percibo ahora como perfectos y mis columnas HECO son mejores que antes..... me estaba volviendo loco con mi sala moviendo muebles , cuadros y añadiendo paneles hasta que este AP310 con su muses72320 me ha demostrado que el problema no esta en mi sala, sino en utilizar componentes nada audiofilos . Además que han mejorado mis LPs en profundidad, claridad y separación de instrumentos siendo una experiencia ultra.. bravo por tan pocos euros !!!
Valentin G.
DYNAVOX 2-Way Speakers 40W 92dB 4-8Ω 50Hz-20kHz (Pair) This pair of low-cost 2-way trapezoidal speakers offer excellent value for money and are ideal for use in small rooms or bedrooms. Each speaker is equipped with a 130mm...
Parfait à ce prix !
A 50 euros la paire, que demander de plus ! Utilisées avec un Yamaha A-S201. Manque de profondeur et de pêche dans les basses, mais les middle et aigus + scène sonore sont très bien définis !
Valentin G.
Parfait à ce prix !
Pour 45 euros la paire que demander de plus ? en combinaison avec Yamaha A-S201. Pa
Jacek Z.
Połączyłem bezpośrednio z NODE ICONE przez XLR . Dodatkowo uziemiłem przewodem RCA gdyż słyszalne były niechciane dźwięki. ( zalecenie na stronie Bluesound) Działa idealnie. Triger połączyłem zwykłym kabelkiem stereo 3.5. Polecam . Wcześniej testowałem też z DMP A6 ME gen 2 . Na moje ucho było za ostro :).
NEOTECH NEET-1008 Ethernet RJ45 CAT6E Cable UP-OCC Silver 1m Neotech offers with its NEET-1008 an excellent RJ45 Ethernet cable, benefiting from an exceptional design. It incorporates four pairs of silver UP-OCC conductors with a...
A cable with an unbelievable price-performance ratio ... Neotech is one of two OCC copper and silver conductor manufacturers in the world ... most hi-fi cable manufacturers (Audioquest, Nordost, Kimber etc.) buy their cables for their high-price products there ... you wouldn't get this cable in this quality from these brands for less than 1,000 euros or more ... rather over 2,500 euros
Thierry W.
NEOTECH NER-OCC RH RCA Connectors Rhodium Plated OCC Copper Ø10.5mm (Set x4) Neotech NER-OCC RH RCA connectors, sold in sets of 4, feature Rhodium-plated Copper OCC contacts for perfect conductivity and oxidation resistance. These connectors accept...
Ces connecteurs RCA offrent une excellente qualité de fabrication et un rendu sonore irréprochable grâce au cuivre OCC et au plaquage rhodium. Cependant, le plaquage rhodium rend la soudure très difficile, nécessitant un fer à souder puissant et une technique irréprochable. Plus gênant, les fiches sont tellement serrées qu’il est presque impossible de les insérer dans des prises RCA femelles standards, ce qui limite fortement leur compatibilité avec la plupart des appareils. Un défaut majeur qui compromet l’expérience utilisateur malgré la qualité intrinsèque du produit.
Marc S.
Petit bijoux
Je juge ce petit bijoux de DAC en association avec le HOLO Biss (voir mon commentaire). Aucune fonctionnalité, aucun réglage, une télécommande qui ne sert presque à rien (sans option préamp puisque qu'il est raccordé au Bliss) et c'est tant mieux finalement. je préciserais vis à vis des commentaires déjà nombreux que cette technologie R2R est vive et rapide sans aucune froideur. Pour dire, j'ai retiré ma platine vinyle avec une Ortofon 2M Black dépassée par ce DAC sur tous les critères. Comme source j'utilise un MacBook Pro avec Audirvana + le VST Dirac. Connection USB robuste et très bonne. La licence Dirac coute cher mais il le mérite, croyez moi.
Période de rodage nécessaire avec un peu de patience ...
Marc S.
HOLO AUDIO BLISS LEVEL 1 Class A Discrete Balanced Headphone Amplifier The Holo Audio Bliss Level 1 is a discrete, high-end pure Class A headphone amplifier, offering incredible sound quality thanks to a design based on an optimized and careful...
Ce Bliss est incroyable en tant que préamplificateur classA HDG. Je l'utilise avec le DAC Holo Sring3 L2 et pour la puissance un ampli Audiophonics HPA Q450ET sur la base des derniers modules Purifi. L'association A/D est magnifique au point que j'ai retiré ma platine vinyle pourtant équipée d'une 2M Black. Comme moi vous pouvez utiliser la deuxième entrée XRL en "by-pass" (gain du Bliss à 0dB) pour le Home cinéma, ça a apporté un plus sur les Fronts.
Maintenant je cherche un casque à sa hauteur.
Si je devais émettre une réserve ce serait l'absence de télécommande pourtant mentionnée dans la Doc. Du coup j'utilise le volume d'Audirvana avec un gain fixe sur le Bliss et en mode puriste j'annule le contrôle de volume d'Audirvana et je joue du volume sur le Bliss. Aucune différence audible entre les 2 méthodes et puis une fois réglé on écoute et on ne bouge plus tellement c'est beau.
Johan v.
Good after software update
Not bought here for practical reasons it would not read anything after track 31 and after a helpful email from Shanling and a bit of work on the computer it works as it should.
Soundwise not better than my Tempo EC1b CD player when used as transport.
Johan v.
My favorite hookup wire
Strips easely soldering well heat resistant great to work with
Johan v.
Not for printed circuit boards
It has a very small circle of contact pins and trying to fit it to a pcb it turned into a disaster with pins not wanting to sit properly.
As chassis mount I still find the pins too close together.
André A.
HP GP70N DVD / CD Audio Player HP GP70N is a compact, high-quality  DVD / audio CD player . This reliable, stable audio DVD / CD player works in Plug & Play via a mini USB-B 2.0 connector. You can...
Fais le job
Produit correspond à la description. Très simple d'utilisation, léger compact bref parfait pour lire ou ripper support.
Luca C.
LHY AUDIO OCK-2S Master Clock OCXO 10MHz Black The LHY Audio OCK-2S is a high-precision master clock with ultra-low phase noise, designed to minimize sampling errors on high-resolution streams. This clock features six...
The LHY OCK2-S synchronises the AGD DIS5HE and AGD R27HE in my system. I must say that, even though the quality of AGD devices is already very high, with the addition of this LHY clock, the leap forward has been very noticeable.
I am very satisfied with my purchase!
Obviously, as usual, Audiophonics is the best!!!
Panos M.
Its more my personal taste
I am doing a lot of DIY, the last DAC was based on an ES9038Pro in stereo. This one is different. I coupled it with a tube buffer and an XMOS interface, it worked with no issues and in my taste more musical than the ES. For the cost its a no-brainer.
Ludovic P.
Excellent ampli avec une sonorité plutôt chaleureuse, un niveau de détail très correct (exceptionnel pour ce prix) et une capacité à driver des enceintes pas forcément faciles !
A associer à une alimentation permettant de fournir le courant nécessaire pour que l'ampli soit dynamique, comme la Huntkey HKA06012050-7C (que fournissait Audiophonics à une époque) ou la HKA06012050-7F.
Les alimentations linéaires, même assez puissantes, ne sont pas trop sa tasse de thé, la dynamique n'est plus là (peut-être serait-elle meilleure en ajoutant un supercap ?).
Testé avec succès sur des enceintes à haut et moyen rendement.
Attention également à l'étage d'entrée qui sature très vite avec des sources au niveau de sortie élevé ; il faut penser à baisser le niveau de la source dans ce cas...
Ludovic P.
Très bon tube avec un petit côté chaleureux
Très bon tube, monté en remplacement de tubes NOS Siemens.
Le Gold Lion est moins sec dans le medium tout en étant aussi détaillé avec un petit côté chaleureux dans le bas médium.
Superbe écoute, aucun regret
Eric V.
JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 0.47µF Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every...
Filtre enceinte
condensateur au rapport qualité prix excellent.
Son ouvert et davantage détaillé. La balance tonale est respectée du bas médium à l'extrême aigu, le tout avec de la matière et un respect des timbres. Bref une amélioration notable par rapport à des condensateurs polypro de base.
Ludovic P.
Excellent tube au médium magnifique
Excellent tube en remplacement de tubes NOS Sylvania et aucun regret !
Ce tube est très détaillé, avec un médium clairement en avant mais sans agressivité.
Après rodage (~50 heures), le tube se montre plus ouvert vers le grave et l'aigu, plus linéaire mais toujours aussi délicat et précis.
Une très bonne alternative aux tubes NOS bien plus onéreux !
Ludovic P.
USB 5V Supercapacitor Filter USB-C to USB-C / USB-A This 5V USB filter allows you to obtain a clean power supply for your Hi-Fi devices thanks to two 20F - 3.0V capacitors as well as an intelligent buffer...
Efficace mais manque un interrupteur on/off
Utilisé entre une alimentation linéaire 5v Audiophonics et un Ifi Audio LAN ipurifier pro, ce filtre améliore sensiblement la perception des détails.
J'enlève malgré tout une étoile pour l'absence d'interrupteur on / off, qui entraîne durant la phase d'allumage (charge du supercap - environ 30s à 1 min) et d'extinction une sous-tension en sortie.
De fait on voit l'ifi audio Ipurifier pro clignoter, lumières faiblardes, reboot en boucle... pas sûr que ca lui fasse du bien.
Pour éviter cela, je dois attendre à l'allumage que la charge du supercap soit terminée avant de brancher le câble d'alimentation usb en sortie.
Et a l'extinction, débrancher le câble l'alimentation usb avant de couper l'alimentation secteur.
Les autres filtres usb supercap proposés par Audiophonics (non usb) ont ce bouton on/off qui doit résoudre le problème
Eric E.
Remarquable !
La neutralité et la transparence sautent tout de suite aux oreilles. Le son est limpide et détaillé, les plans sonores sont parfaitement lisibles, tout le spectre est net, précis, exact. L’écoute prolongée n’entraîne aucune fatigue, au contraire le naturel et l’aisance sont vraiment reposants.
Mon LPA-S450ET pilote des Infinity Quantum 3, des mamies d’efficacité modérée réputées difficiles avec leurs boomers à double bobine travaillant à 2,5 ohms… mes mamies sont toutes ragaillardies et n’ont jamais si bien sonné. En fin de journée l’ampli est tiède, mesuré à 34° dans une pièce à 25°. J’ai poussé le volume au delà du raisonnable pour tester la tenue des basses, aucune défaillance audible.
Je retrouve avec cette classe D convaincante ce que j’ai connu avec une voiture électrique, quelques heures ont suffi pour enterrer définitivement le passé. L’expérience est si positive qu’à la fin de l’année je monterai en gamme.
