Thierry C.
Qualité prix
Construction vraiment sérieuse et qualitative. Rien a redire pour le moment concernant l'écoute, j'ai pris ce câble...
Baptiste D.
Indispensables avec écouteurs HIFIMAN RE400 et sûrement d'autres
Ces écouteurs sans ces embouts, avec ceux en silicone d'origine, isolaient mal et sonnaient sans graves ni bas médium, ce...
Jan S.
One step further!
The IPURIFIER PRO works well. Better separation, details and image. Not a huge step, but enough to recognize it and like it....
Customers reviews - There are 21084 reviews.
SERGE B.
24k Gold-Plated Copper Spade Ø4mm (Unit) This robust spade is made from copper and is 24k gold-plated, giving it high conductivity and resistance to corrosion and oxidation. It features...
Excellente qualité
Excellentes fourches assez épaisses en cuivre OFC 4N comme il ses doit et plaquées or. La longueur du corps est suffisa systèmede
Michael L.
O-NOORUS PA-316 Amplifier Class D 2x TPA3116D2 Bluetooth 5.0 2x60W 4 Ohm This small, compact, versatile and high-performance O-Noorus PA-316 Class D amplifier incorporates two TI TPA3116D2 amplifier chips, each dedicated to one channel. It is thus...
Not perfect but good for the low price
My pa-316 just arrived
long press volume to turn it on,off short input selection (no aut bt) no pop sound turning it on,off
loose volume knob, like a steering wheel that only make the car turn after half an inch (hate it)
tone controls off neutral sound, clean sound even at max volume, above 12 o'clcok if you want it loud (volume better on a Fosi audio bt 20a), the difference on the volume from 12 o'clock to max is to big or not big enough how you interprest it (medium to loud from 12 to 2 o'clock) + a good bass
Gets varm playing loud (not alarming), a Fosi Audi bt20a don't get warm, 24v 6.75 psu instead of 24volt 4.5 a as some amps has
Usb works but no driver to change samplerate and to se what samplerate is used
Pierre-Marin L.
Je vais continuer la litanie des gens satisfaits : ce cable remplace un cable I2S couteux, et sur mon Holo Red vers mon Holo Spring le résultat est bien meilleur ! Pour un prix avantageux
Merci Audiophonics !
Deividas S.
Stéphane M.
2ème commande de ce produit magique
Tellement efficace et pas cher pour un nouvel usage et encore un exploit un terme d'efficacité tout comme Audiophonics ! commandé et réceptionné en 5 jours malgré un jour férié vers l'île de la Réunion. Un site vendeur exceptionnel.
voir ici le changement que produit ces isolants sur ma barre ambeo plus et Q Acoustics 3060s (remarquez la finesse de 1khz à 20khz) gain en clarté et spatialisation : https://i.postimg.cc/hP9rNS8M/Effet-sorbothane.jpg
bon rqp
Solide pas de perte audible prix correct.
Male Jack 6.35mm to Male Jack 6.35mm Stereo Cable Shielded Gold Plated 2m This double jack 6.35mm stereo cable features a pure copper core for maximum conductivity. The core is shielded by an aluminum foil combined with a copper alloy weave to ensure...
bon rqp
Aucune perte audible prix correct
Parfait, mis dans une sphère imprimée en 3D, excellent résultat audio.
Neutre
Très bon RQP.
Sebastien S.
TOPPING DX9 DAC AK4499EQ Headphone Amplifier NFCA Bluetooth 5.1 AptX LDAC 32bit 768kHz DSD512 Black To celebrate its 15th anniversary, Topping unveils a high-performance DAC / Headphone Amplifier: the DX9. In addition to its very high performance, Topping has given it a...
La musique prend de la vie avec ce DAC
J'ai remplacer mon intégré Cyrus 8 qui ne donne plus de dynamisme , ce préamp Dac redonne la vie à la musique, sur un ampli vintage DENON PMA 501 double transfo. J'ai connecté un lecteur CD mais cela ne fonctionne pas, faut-il un lecteur transport uniquement ? Merci pour votre réponse.
Eric D.
Enfin satisfait
J’ai acheté ce dac ampli casque pour pouvoir exploiter min recent achat d’un casque moondrop para sur ce même site. Ce dernier sous 08ohms manquait cruellement de volume connecté à mon littledot mk2.
Aujourd’hui, totale satisfaction la puissance 3watts sous 16 ohms est parfaite pour mon casque.
Je découvre le dac et envisage un abonnement pour exploiter ses capacités au delà du mp3 et aac.
Merci à audiophonics pour l’expédition rapide et l’emballage serieux.
Benoit d.
Bien mais petit défaut
Conforme et bien construit. Les barettes de connexions pour bicablage sont simple a démonter. Mais pour mon usage il y a un défaut : les borniers dépassent du cadre même vissés complètement alors que je voulais qu'ils soint protégés pour le transport de l'enceinte.
Benoit d.
Nettoie parfaitement le bruit parasite qui venait de la connections de 2 amplis sur une même source
bernard g.
pince très fine passe partout parfait
bernard g.
CWS1 3-in-1 Cutting / Stripping / Cramping Pliers The CWS1 3-in-1 pliers have 3 functions. It will enable you to cut, strip and crimp cables.
trés bonne pince
bernard g.
collier parfait pour travaux délicat
bernard g.
ATAUDIO SNOW SLEEK Balanced Signal Cable Silver Plated OCC Copper Ø8mm This balanced modulation cable sold by the meter consists of 12 silver plated OCC copper wires individually insulated with a PTFE sleeve. It ensures an excellent conductivity...
cable secteur
une fois assemblé les 3 cables et les connecteurs krell de très bonne qualité après un essai le résultat est surprenant avec une section de 6mm2 les cables sont croisés ensemble
le cable secteur est entre la prise murale plaqué rodium et les barrettes shuko la musique a gagné en dynamique et est très bonne surtout avec une riche de détaille des basses très naturelle et des aigus limpide et des médium incroyable
attention tous a été optimisé les cables secteur sont tous de hautes qualités ampli casque a tube casque éléctrostatique haut de gamme et lecteur cd haute qualité fiches xlr haute qualité musicalement ce cable est le meilleur que j ai bernard
Charles B.
TOPPING DX3 PRO+ DAC ES9038Q2M NFCA Headphone Amplifier Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512 Silver Topping unveils its DX3Pro+, a direct evolution of the excellent DX3Pro, an excellent compact DAC also offering headphone amplification and preamplification functions. Embarking...
Produit livré rapidement et parfaitement emballé . Ce site est très sérieux et hautement recommandable . Le Topping DX3 pro + , offre pour moins de 200€ d’excellentes prestations . Sous un format compacte on trouve un préamplificateur un Dac et un très bon amplificateur casque , il drive actuellement mon Focal Elear sans problème. La construction respire le sérieux et la solidité , et son écran est utile et visible de loin , le gros plus dans cette gamme tarifaire est la …. Télécommande , vraiment appréciable ( toutes les fonctions de l’appareil s’y retrouvent ) . Je pense que l’ajout d’une bonne alimentation linéaire améliorerait d’avantage cet appareil . Même en rodage il a une excellente musicalité . Je recommande vivement ce produit qui pour cette somme , a un RQP exceptionnel.
TINYSINE TSA9840B Class D Mono Amplifier Module MAX98400A Bluetooth aptX TWS 20W 8 Ohm The TinySine TSA9840B is a small Class D amplifier module, based on a MAX98400A amplifier chip, allowing to deliver, in this mono version, a power of 20W. This module can then...
Parfait. Résultat excellent avec un petit Hp Dayton 95-8.
DC 5V Jack Filter with Supercapacitor to Jack DC This DC 5V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 4 supercapacitors 20F - 3.0V and an...
Superbe amélioration du résultat Audio
Je connaissais les SC mais j'hésitais de les utiliser a cause de la très forte demande en courant au démarrage, ce "petit" par la taille améliore fortement le résultat audio lorsqu'une alim linéaire ou découpage est utilisée.
J'en possède maintenant 3 dont deux 5 volts sur streamer et Dac la troisième sera utilisée plus tard sur alim du Nas.
N'hésitez pas une seconde le rendu audio passe un gap énorme avec l'ajout de ces super condensateurs.
Christian S.
Best price-performance ratio!
Professional 75 ohm cables are all you need to transmit digital audio data. The Canare RCA plugs fit like a glove and are perfectly pressed onto the cable. For a RG6 cable with a diameter of 7,7 mm it is very flexible and easy to handle...
Laurent D.
Shanling confirme le défaut de la non prise en charge du gapless entre les pistes musicales.
Pas de corrections prévues pour le moment. Cette fonctionnalité n'est utilisable que pour les pistes sur microSD.
https://www.head-fi.org/threads/introducing-shanling-ec-mini-transportable-cd-player-dap.969879/post-17936483
Ammar j.
Excellent amplifier
Small, lightweight, clean power into any reasonable impedance, at a great price.
Martin A.
The name says it Hi End and the cable really is. Everything seems more mature more believable with this cable. And the impression is already straight out of the box. After some running things improve massively. Things like depth air positioning of different sources of sound on the stage are all there like the better and costly power cords do. Replaced an already good Qed ethernet that is like comparing midrange vs high end. Used between cisco 2960 and Gustard r26
Robert G.
BURSON AUDIO V7 CLASSIC PRO Dual OPA (Unit) As an evolution of the V6 Classic, the V7 Classic Pro now achieves ultra-low noise levels while retaining the sparkling highs that are the strength of its predecessor. Overall,...
Awesome upgrade from SS3602
Coming from the Sparkos the first thing i noticed was the huge stage.
The Classic is a bit more mid-focused which can be a bit much depending on your gear you listen on.
The Vivid on the other hand is the neutral sibling which shares the same spatial advantages over the Sparkos but keeps the same tonality, first thing i noticed with the Vivid was how clean everything sounded.
TLDR: Classic - mid emphasis (yum) Vivid - neutral
Philippe S.
Respire la qualité furutech
Voir mon avis pour la prise mâle.
Philippe S.
Oui, c'est un produit qui n'est pas bon marché mais j'ai gagné en clarté par rapport aux fiches 701 et 702, si vous le pouvez, n'hésitez pas à changer.
Paul D.
Petit mais quels résultats impressionnants
Cela fait quelques mois que je possède le SMSL PL 200, et il s’est progressivement affirmé!
La musique s’exprime d’une façon naturelle, en largeur et profondeur. Les sons, la définition,
la musicalité, sont d’un naturel surprenant, je me suis remis à écouter mes CD et ma musique
pendant plusieurs heures, alors que précédemment à mon achat j’étais resté moins attiré par mes écoutes! Formidable appareil!
adrien b.
Récepteur performant et pratique
Je suis très satisfait de cet appareil, que j'ai acheté pour rajouter le BlueTooth sur une ancienne chaîne haute fidélité :
Le son est impeccable ;
L'appareil est "plug and play", tout de suite reconnu ;
Pas de perte de connexion, même avec l'antenne courte ;
Boîtier robuste, connectiques de qualité et construction sérieuse ;
Le prix !
Alain M.
Excellence audio
J'étais à la recherche d'un petit module audio pour multi-amplifier mon enceinte, une Jalucine 24.
Puis, je suis tombé sur ce module dont Audio Science Review (et d'autres) disaient le plus grand bien.
Pour l'alimenter j'ai eu recours à une SMPS Connex de 36V/300W.
A la première mise sous tension, le son était très sale (râpeux, distordu), limité dans les aigus. Un peu déçu. Puis, je l'ai laissé sous tension toute la nuit, et je n'ai plus reconnu le son que j'avais la veille, beaucoup plus fin, mieux défini.
Au troisième jour, le son est parfait (comparé à un Super 30W Classe A Hiraga), du grave à l'aigu.
Je recommande donc sans réserve.
Patrick A.
Impressions après 1 mois d'utilisation
Après un mois d'utilisation quasi quotidienne (couplé à un Eversolo DMP-A6 d'abord en RCA puis en XLR): Les 2 connectiques sont excellentes, même si en XLR on gagne encore en ampleur et dynamique, la différence est clairement audible.
Comme les entrées RCA et XLR sont sélectionnables indépendamment, j'ai donc branché la sortie RCA de ma télé au SMSL, pour m'affranchir d'une barre de son plus que moyenne. (La consommation électrique doit être identique, par contre on gagne en qualité audio!)
Quant au réglage EQ initial (j'adorais le SDB au début) je suis finalement revenu en mode Direct ou Tone (Bass +1, Treble +2) selon ce que j'écoute, pour atténuer les basses du SDB, qui n'étaient pas si présentes au début. Un petit rôdage des composants a fini par assoir l'accoustique de cet ampli, en améliorant le mode direct.
L'entrée audio USB testée depuis le DMP-A6 (qui a une sortie usb audio out only) ne donne que du 16 bits/48KHz, (Test avec un fichier FLAC 32/384, j'ignore si c'est le Eversolo ou l'ampli SMSL qui est bridé...). Dommage, je reste donc en XLR. N'espérez pas non plus y brancher un lecteur CD usb ni votre smartphone. Rien n'est détecté, Ce n'est qu'une prise audio IN de plus, pour peu qu'on ait le lecteur disposant de la même prise usb audio out only, sinon elle est inutile, mais elle chargera quand même votre téléphone. (lentement....)
En fin de compte je l'aime toujours autant ce SMSL AO200 MKII, même s'il ne lui manque qu'une ou 2 entrées digitales pour être vraiment parfait. :)
Eric G.
Parfait , mais !!!
Produits qui annonce réellement ce qu'il doit faire , Full Spec , par contre je n'ai pas essayé avec 1500 volts pour tester l'isolation .
Je l'ai associé avec l'E1DA cosmos ADC et j'ai eu quelque soucis .
La charge (E1DA cosmos) n'est pas suffisante , il faut absolument
charger la sortie de l'HS02 si vous ne voulez pas avoir des ruptures de signal (min 10 ma), c'est pour cela que je ne mets que 4 étoiles .
[ il existe un PB avec l'alimentation interne , sans plus]
NICOLA G.
A game changer
I have upgraded my Audiophonics ncx 600 class d amp with these little guys and I must say I was in awe at the incredible improvement of the already excellent performance of the amp. It sounds smoother, more detailed, with more presence and stunning imaging. A real game changer, totally recommended. Many thanks to David at Audiophonics for his advice and patience. Top!
Robert C.
FOSI AUDIO ZA3-48V Stereo / Mono Class D Amplifier TPA3255 2x150W 4 Ohm / 1x240W 4 Ohm This small, compact and powerful Fosi Audio ZA3 integrated amplifier has the particularity of being able to operate in both stereo and mono mode. It...
Good for the money
For your information, I have thoroughly tested this device for a month with different OPAs and the result is that it is good for the money and for me personally only good for the near field listening with smaller speakers. It has a warm sound but with digital veil even with the Sparkos OPAs.
Hocine H.
Sublime.
En combo avec une paire Pro pour le volume, ceux ci ont été installés pour la sortie xlr et le mélange des 2 est juste incroyable. De la musique agréable à écouter, qui donne le sourire, une lolie fluidité sans sons prédominants, mais un subtil mélange de pur plaisir. Je conseille vivement.
Hocine H.
Je reviens sur l'avis que j'avais laissé en spécifiant que ce filtre n'e m'avait pas apporté de différence. Je l'ai finalement connecté directement en sortie de routeur et non directement sur le streamer et effectivement après plusieurs essais avec et sans, le avec l'emporte largement, j'ai l'impression d'un son plus analogique, ce qui est paradoxal pour un flux numérique, quoi qu'il en soit il fait le job et retire ce que j'ai écris préalablement.
fabrice v.
Oui du son
Alors 0 étoile pour le son, beaucoup de choses,mais si vous cherchez une âme, de l’émotion ,il faut passer son chemin.
C'est juste pratique pour un jeune geek qui débute,pour sa console, la TV ou un smartphone.
La puissance annoncée est faussée si cela fait 70 W ,il en perd la moitié en route.
Je ne comprend pas tout ces avis à 5 étoiles. Vaut 10 fois mieux mettre 100 euros supplémentaires pour un ampli bas gamme de marques sérieuses, désolé mais en ce monde on en toujours que pour son argent et souvent moins ,ici ç’est même beaucoup moins .
Par contre toujours 5 étoiles au service Audiophonics !!!!
Martin S.
Absolutely neutral, detailed sound. Real High-End.
I have this DAC in use for two months now, connected via XLR to Preamplifier Topping A90D and Neumann KH 420 G active speakers.
Source is a notebook running foobar, connected via USB, source material is PCM from 16/44.1 to 24/192.
The build quality of the device is very good. Remote control is the same type as every Gustard/Topping/SMSL remote.
Unfortunately, the manufacturer does not provide any user manual, so I found the menu control by accident (press "D-Filter" for 3 seconds).
Stand-by mode does not exactly switch off the device, but reduces the power consumption from 15 watts to 10 watts, so I prefer to use the rear power switch when the DAC is not in use.
I did intensive side-by-side listening tests with Gustard X16/X18/X26 pro, Topping D90MQA/E70V/D30 pro, SMSL SU-10 and Teac UD-501.
A comparison to the lower-priced DACs I mentioned above would not be fair, so I will describe my personal impressions of the sound differences between this device, SMSL SU-10 and Gustard X26 pro.
To my ears, in my system, the SDA-6pro2 performs great (I use the default digital filter, "short sharp"). Sound is precise absolutely neutral and well-balanced in every regard. Tonality, soundstage, dynamics. The amount of detail is stunning, in every frequency range. High frequency are a more on the brilliant side, textures in human voices are clearly audible, without any hint of harshness. Of all the DACs compared it with, this is the most neutral sounding.
For years, I used to prefer ESS-based DACS, to my taste AKM-based DACs sounded always a bit to soft- but the Singxer really changed my mind. It combines the dynamics I like on the ESS chips with the natural and detailed sound of the AKM chips.
In comparison, the SMSL SU-10 lacks a bit of detail retrieval in every frequency range, mid-bass is a bit pronounced and female voices tend slightly to "shout" when listening at high volume levels. The soundstage of the SU-10 is huge and also somewhat diffuse.
The difference in sound compared to Gustard X26 pro is a matter of taste. SDA-6pro2 detail retrieval is on par with X26 pro. Bass definition of Singxer is better, but X26 has more pressure and wall-shaking subbass. In short, X26 pro sounds more spectacular due to punch and dynamics, but acoustic instruments and human voices tend to sound a bit artificial in comparison to SDA-6pro 2, which sounds more natural and refined.
I highly recommend this DAC for customers who want simple, perfect sounding DAC and don't need comfort functions or a fancy user interface.
Eric J.
Appliqué sur les fines parois latérales de mon Rack hifi reconstitué à partir d'un meuble de récup, ce produit supprimé efficacement les vibrations sur celles-ci. Efficace également en couche sous des plaques antivibratoires en mdf.
vincent r.
TOPPING E30 II DAC 2x AK4493S XMOS XU208 32bit 768kHz DSD512 Silver Topping comes back with the compact DAC E30 II, a real evolution of the excellent E30, presenting many technical improvements allowing to reach even better sound performances....
Petit Dac Dual Mono très sympa ; beaucoup doux que certaines autres marques mais très détaillé à l’écoute.
La fabrication est de qualité.
Penser à faire la mise à jour du Firmware avec l’application sur PC
vincent r.
Le produit est très intéressant au niveau de ses possibilités, sa stabilité en Wifi.
Relié en sortie RCA coaxiale avec un DAC externe Topping E30 II ; on a quelques choses de très bien musicalement.
J’ai un ancien Wxc 50 (que j’ai gardé) ; mais je trouve l’association WIIM Pro Plus et Topping E30 II meilleure à l’écoute. Plus douce
Daniel P.
BEATECHNIK x LHY AUDIO LPS-A6 220V MK1 Linear Power Supply Module for EverSolo DMP-A6 Gen 1 The LPS-A6 linear power supply module has been specially designed to enhance the power supply stage of EverSolo DMP-A6 and DMP-A6 Master Edition network players by replacing the...
Dégradation de la scène sonore
On parle d'ouverture de la scène sonore mais ça fait totalement faux, je suis très déçu, cette alimentation n'apporte pas un plus par rapport à celle d'origine, peut-être moins performante mais bien étudiée par Eversolo.
Je regrette cet achat. Je vais être obligé de la revendre à perte.
Jean-Pierre W.
Excellent module
Idéal pour remplacement d’ampli dans un caisson de basse , ici je l’ai adapté dans un caisson Klipsch avec boomer 38 , je dirais que la musicalité , voir les basses en HC est milles fois meilleurs que celui de la marque d’origine ( Klipsch).
Il faudrait juste faire un peu d’ébénisterie pour l’adaptation .
Je recommande fortement , bon tarif , livraison rapide et de plus vers la,Réunion .
Jean-Pierre D.
Préampli musical et propre intéressant dans sa gamme de prix
J'avais le P26, j'ai voulu avoir un préampli moins neutre, avec un son moins clair, ce H26 plus haut en gamme est vraiment intéressant, plus doux, cela reste neutre, mais la musicalité gagne, à recommander sur les musiques acoustiques et classiques ou les voix claires, l'image est holographique et très réussie. Cela évite financièrement de monter en prix, construction irréprochable, merci à Monsieur David Aubert pour les conseils. Je recommande ce préampli, j'ai utilisé avec un set de câble Neotech et ampli Audiophonics HP 400 Purifi, l'association est très bonne.
Joseph B.
Très bon produit, conforme aux avis. Niveau son bien mieux que le Bada 5600.
Jamais déçu par toutes les commandes passées.
Jeanphilippe c.
MUNDORF MCAP SUPREME SILVER OIL MKP Capacitor 1000V 0.33μF Mundorf MCap Supreme Silver Oil are capacitors with an oil-impregnated metallized polypropylene dielectric. As the name suggests, high purity Silver is used for the capacitor...
Mundorf
Condensateur utilisé dans un amplificateur à tube pour le couplage. (Tube de puissance. Finesse des timbres, détails des harmoniques, douceur de la scène sonore. Je recommande vivement.
Eric H.
MUNDORF MLYTIC AG Capacitor 25V 22000μF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
Exellent
2eme commande et toujours aussi bon
Eric H.
Très bons connecteurs
Je ne comprends pas les avis précédents disant que les pinces faisaient un mauvais contact
Au contraire, je trouve que le contact est très bon voire même un peu trop serré car il faut un peu forcer pour le rentrer à fond.
Un fois en place, aucun jeu possible...
A part ça très bons connecteurs, bien construits, robustes et qui inspirent confiances.
Les câbles se soudent facilement et en plus vous avez toute la place qu’il faut pour travailler
En résumé, très bons connecteurs en cuivre pur, à un prix très raisonnable et présentés dans une belle boîte avec la clé Allen fournie.
tout a fait d'accord
pas donné mais quel son !
utilisé sur un switch internet
Michael L.
FOSI AUDIO BT20A Class D Amplifier 2x TPA3116 Bluetooth 5.0 2x90W 4 Ohm The Fosi Audio BT20A is a compact and powerful Class D amplifier, offered at a contained price. Its amplifier stage uses not one but two TI TPA3116D2 chips, capable of...
High value for you're money
Very harmonic amp, tone controls adjusted since 12 o'clock might not be 100% neutral, i feel i don't miss anything except when playing loud, there are other amps that can play louder and are more suitable for low sensitive speakers,no pop sound turning it on,off which is super, fast connection via bluetooth and as soon as it's on theres sound, if the source is playing, low price considering you get a 24 volt psu and it looks good to. Driving triangle esprit titus ez
