Yves j.
magnifique
bonjour
finesse ,détails ;richesse des informations tout est somptueux pour le prix remplace largement mon marantz sacd 7001...
benjamin b.
Validé
Je pratique l'aop rolling comme le tube rolling. C'est amusant de changer ces amplis Op et de constater leur...
benjamin b.
non cocluant chez moi
l'AOP rolling, amusant comme le tube rolling.
Graves tronqués et cartonneux sur un preamp diy. Il ne resteront pas en...
Customers reviews - There are 20908 reviews.
Peter S.
ATAUDIO L-4E6S Male USB-A to Male USB-B Cable Gold Plated OFC Copper 0.75m This ATAUDIO USB cable offers both high quality and luxurious design. It consists of a four conductor structure made of braided OFC 6N copper with excellent conductivity,...
A USB cable, what else ?
So hard to describe what this may or may not bring to the sound of a hifi system. I couldn't say, let's say it doesn't do any harm, and that's a good thing.
Very reasonable price, for a beautifully presented product.
Thomas H.
THINKYA DVR108 CD Player DAC ES9038Q2M 32bit 768kHz DSD512 Bluetooth 5.1 Thinkya's DRV108 is a full-featured CD player and DAC that uses a TMC688 processor and ES9038Q2M DAC chip to upsample CDs up to PCM 384kHz and convert digital signals up to PCM...
It is a great product for a small price.
Frank j.
reclocker
reclocker toslink optical
gives 10% better sound
its ok product
Pascal J.
AUDIOPHONICS PSU S4-HP Linear Power supply Module DC Micrel29752 Adjustable 5–24 V The Audiophonics PSU S4-HP power supply module has been designed to provide a clean DC voltage supply to an amplifier or other audio circuit. Its particularly rigorous design,...
Très très bonne alimentation
Associée à un trafo toroïdal en cuve Talema 80va elle alimente Mon Keces Ebravo.
C'est parfait et procure une
amélioration évidente comparée à celle d'origine ou même une brique Meanwell qualité médical.
Pascal J.
KECES EBRAVO Streamer WiFi UPnP DLNA Bluetooth 24bit 192kHz The Keces Ebravo is a versatile audio streamer designed to deliver a high-quality music listening experience. Compatible with many popular streaming services such as Spotify,...
Aucun avis ????
Une brique noire avec un œil bleu qui n'a l'air de rien,
sans prétention, un peu chère comparée à la surenchère de bien d'autres. Mais quelle brique !! 1) installation très facile, appli 4stream parfaite, aucun problème. Pas de bidouille, un nas Sinology pour la musitèque.
2) raccordé à mon Sonifex adda2 le son qui me convient de vrais et bonnes
basses, les médiums et aigues en bonne équilibre
avec les précédentes, très bien timbré, un son analogique. Le peu de tests
accessibles sur le net ne vous mentent pas c'est de la balle.
3) à l'intérieur pas grand chose : pas fpga de la mort,
pas d'horloge venue de l'espace. Juste la bonne pièce au bon endroit et beaucoup d'intelligence.
Bravo aux concepteurs
m
Mattias B.
ASCILAB F6B Bookshelf Speakers 125W 4 Ohm 84dB Black (Pair) The AsciLab F6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ aluminum dome tweeter...
Absolutely amazing
Mattias B.
3E AUDIO A5 Class D Stereo Amplifier PBTL 2xTPA3251 2x150W 4 ohm 3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A5 amplifier is based on two TI TPA3251...
Outstanding value
Henri c.
JANTZEN AUDIO AIR CORE WIRE COIL 000-0121 Coil 4N Copper 13AWG 1.3mH 0.23 Ohm Jantzen Audio Air Core Wire Coil are made from high-purity copper wire, perfectly wound to create a distortion-free inductor for all audio applications. Their low inductance...
bonne tenue du grave
j'ai utilisé cette self pour filtrer un large bande fostex ,( utilisé en quart d'onde ) le résultat est très bon ,avec du 6dB:octave ,ça permet des
bon transitoires, un medium bien présent et un grave bien tenu .
( il faut ajouter un tweeter pour avoir le haut du spectre )
Christian H.
Cable numérique 75 ohms
Pour rerlier les équipement SPDIF coax entre eux dans le respect des normes tels que prévus par les ingénieurs, à un prix raisonnable.
Christian H.
DIGIRESCUE Reclocker Isolation Galvanique de haute volée
1èrement : fait super bien ce pourquoi il est fait.
je ne rentrerai pas dans des chiffres (je n'ai pas en l'état les outils pour) mais parlerai du contexte et du ressentit (à l'écoute).
Sources reliées :
Un tuner DAB synpathique (Sangean WFT-4) cependant avec une sortie SPDIF pas au top.
Une TV avec sortie optique classique.
DAC en reception : TOPPING DX7 PRO upgradé Sparkos labs.
Alimentation du Digirescue : Ifi Ipower X
Résultats Immédiatement perceptibles : précision, profondeur, respect timing, impact, image tridimentionnelle, silence entre les notes, présence indéniable.
Bref hautrement reccommandé pour mettre à niveau des sources SPDIF moyennes avec en plus le bonus isolation galvanique entre appareils respecté (un vrai plus quand on pousse l'optimisation).
Merci Audiophonics pour ce beau et bon produit crée en partenariat avec IAN Canada
Walter M.
WONDOM KAB9 Amplifier Board PBTL USB 8x50W 4 Ohm This Wondom AA-KA32473 module is a very versatile amplifier, which can be used in a wide range of applications. It has four amplifier chips and is capable of delivering a power...
perfect for building a multiroom system using LMS/Squeezelite or Homeassistant
Philippe w.
FOSI AUDIO TB10D Class D Amplifier TPA3255 2x230W 4 Ohm The Fosi Audio TB10D is a compact and powerful Class D amplifier, offered at a contained price. Its amplification stage uses a TI TPA3255 high performance chip, capable of...
étonnant pour le prix . Si votre budget est serré , n'hésitez pas .Il réussit à bouger mes dynaudio émit M20 . Au cas ou , possibilité d'en augmenter la puissance en achetant l'alim 48v .Petit , se pose partout , si une seule entrée ne pose pas de problème (les autres sont sur mon Dac ) . Vraiment difficile de lui reprocher quelque chose . Cool ,bon achat .
André G.
NEUTRIK NL2FXX-W-S Female Speakon Connector Ø12mm The Neutrik NL2FXX-W-S is a robust 2-pin Speakon connector, ideal for designing professional-quality cables. It incorporates a proven locking system to ensure reliable...
Belle prise Neutrik
Ce produit Neutrik de qualité certes est un peu compliqué à monter si nous ne possédons pas une clé spécifique Torx ce qui est mon cas, donc impossible à installer. C’est dommage qu un fabricant sérieux comme Neutrik n ait pas prévu d en joindre une dans son package
Par ailleurs le diamètre du câble ne peut excéder 3/4 mm
En conclusion produit de qualité
Stéphane B.
VIBORG VS702 Pure Copper Spades Ø4.5mm (Set x4) Viborg VS702 are high-quality spades that ensure optimum connection and conductivity. These models are made from pure copper, guaranteeing excellent electrical conductivity....
Je n'ai noté aucune détérioration du son après l'ajout des fourches Viborg. C'est exactement ce que j'en attendais, ce qui en fait donc un très bon connecteur.
Fabrice B.
EVERSOLO AMP-F2 Amplifier Class D 2x250W 4 Ohm / 1x450W 2 Ohm The AMP-F2, developed by EverSolo in collaboration with the Starke Sound team, is a Class D amplifier based on the integration of the latter's innovative NS600 module. As a...
Amplificateur de très bonne qualité
Ma première expérience avec un amplificateur de classe D qui ravit mes oreilles. En remplacement d'un amplificateur Marantz NR1200. Toutes la connectique est présente pour se substituer à ce dernier en 2.1.
Stephane A.
LHY AUDIO LPS50VA Linear Regulated Low Noise Power Supply 230V to 15V 1.5A 50VA Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply...
Belle decouverte
Je ne soupçonnais pas les améliorations de ce type de device, une vrai decouverte.
Sert a alimenter mon microdac de Laiv.
Que du bonheur, je conseille
Stephane A.
LAIV HARMONY UDAC Discrete Balanced R2R DAC 24bit 768kHz DSD256 Black The LAIV Harmony µDAC, little brother of the LAIV Harmony DAC, is also a discreet, balanced R2R DAC. However, it features an ultra-compact form factor, similar to the...
Une merveille!
Acheté suite aux avis et différentes reviews sur internet,
J'ai mis quelques heures a comprendre la qualité de ce dac car c'est un son tellement naturel avec une scene sonore en arrière plan qu'au premier abord il semble sonner petit et "froid". Mais après quelques heures d'écoute et un niveau sonore plus élevé permettant de noter concrètement la différence avec le dac de l'avance paris a10 ( que je préfère aux doubles dac de l'eversolo a6 au passage), j'ai enfin compris la qualité, le raffinement, la positionnement des instruments dans l'espace et le côté naturel du son.
Un pas dans la haute fidélité je dirai...
J'ai complété mon set up avec une alimentation linéaire de la marque LHY d'après les conseils d'audiophonics, qui au passage m'a très bien orienté car là encore, j'ai gagné en définition et aération dans l'image. (Je m'orientais vers le ddc de laiv mais il m'a plus conseillé une alimentation linéaire, bravo à lui, car il n'incite pas à dépenser plus)
Bref,on aura compris que je suis ravi des produits et des conseils pro et réactifs du conseiller d'audiophonics.
Prochain upgrade, alimentation linéaire pour l'eversolo a6.
Frank G.
Bestes USB Kabel zu diesem Preis
Habe mehrere USB Kabel von namhaften Herstellern ausprobiert.
Das einzige USB Kabel , was tatsächlich besser spielte , war das Audioquest Diamond ( Für mein Budget viel zu teuer)
Das neue Furutech GT 2 NCF spielte auch auf dem Niveau vom Neub 1020 , aber in meiner Kette hatte das 1020er etwas mehr Luft im Hochtonbereich und der Tiefton klang etwas kräftiger.
Jetzt muss aber auch noch dazu schreiben, dass das Neotech schon über mehrere Monate eingespielt war und das Furutech ungefähr 50 Stunden.
Aber auch das Furutech kostet das Doppelte vom Neotech
Jean-Pierre B.
NEOTECH NES-3001G Speaker Cable Graphene Copper G-UPOCC 8.3mm² Ø15mm Neotech's NES-3001G is a speaker cable incorporating 16 G-UPOCC composite conductors, a combination of OCC copper and graphene, with a total cross-section of 8.3mm² (8AWG)....
La construction d'un câble pour haut-parleur sur cette base m'a paru un peu compliquée aussi j'ai demandé à l'atelier Workshop d'Audiophonics de le faire pour moi. L'idée était de construire un câble dans l'esprit "Obsidian". Il est ainsi monté notamment avec des fiches bananes Viborg VB404AG et des gaines Viablue noires le tout du plus bel effet. Le résultat est en effet de toute beauté.
Au niveau de l'installation, la recommandation de l'atelier est la suivante "Le câble étant très rigide, n'hésitez pas à lui faire prendre une forme permettant de réduire l'effort sur les connecteurs". Le câble est bien gros et bien lourd et il faut travailler sa forme de façon à ce que la connexion sur les borniers de l'ampli et des enceintes se fasse avec une pression dans le bon sens, ce d'autant que les connecteurs en argent sont relativement fragiles.
Ceci posé, et même si le câble est superbe au plan esthétique, ce n'a pas été une surprise car conforme à mon attente.
Non la surprise vient de l'écoute. Comment dire, et ce avant tout rodage, j'ai obtenu plus de tout : extension dans le grave et dans l'aigu sensible, scène sonore plus profonde et plus large, instruments avec plus de matière etc. et pourtant mes câbles précédents n'étaient pas bas de gamme tant s'en faut (câble ELECAUDIO HP-25OFCS et fiches ETI KRYO). Le plus étonnant est que la qualité du fichier joué se ressent immédiatement en particulier avec une source en 24 bits au lieu de 16.
En conclusion, un câble exceptionnel avec un prix à l'avenant mais aucun regret, bien au contraire.
Au passage une sixième étoile pour l'atelier Audiophonics pour sa compréhension instantanée de la demande, ses bons conseils et sa rapidité d'exécution (environ 2 jours ouvrables entre la confirmation de commande et l'expédition) et aussi pour la qualité du montage qui est tout simplement parfaite.
Jurie J.
IAN CANADA TRANSPORTPI DIGI II Ultra Low Jitter Digital Audio Interface Module With the TransportPi Digi II, Ian Canada has taken their high-performance all-in-one digital audio interface for the Raspberry Pi to the next level. This module delivers a...
Super Saund.
Connecteur de grande qualité, facile a souder, mécanique irréprochable et transmission pour un câble d' horloge parfaite.
Sylvain S.
AUDIOPHONICS HPA-DM750ET Power Amplifier Dual Mono Class D Purifi 1ET9040BA 2x750W 4 Ohm The Audiophonics HPA-DM750ET is a Class D power amplifier featuring dual mono architecture. Integrating two Purifi 1ET9040BA amplifier modules and two independent Hypex...
Le début d'une nouvelle ère de haute fidélité
Du dynamisme, de la puissance et de la précision. Ce produit a révélé tout ce qui ne restituait pas correctement la musique sur l'installation.
L'ensemble des sources et DAC ont été changés pour lui permettre de s'exprimer à sa juste valeur.
Un produit incroyable à utiliser sur la connectique XLR.
Merci à Audiophonics de permettre à ces produits d'exception d'exister.
Sylvain S.
Un DAC pour (re)décrouvrir le son numérique
C'est en voulant changer de produit qu'on se rencontre de la valeur qualitative de ce produit.
Il est équipé de la fameuse puce de conversion AK4499EX qui apporte le son VELVET SOUND synonyme de précision et de douceur.
Il est aussi équipé d'un contrôle de volume numérique, parfaitement exempt de tous bruits parasites, permettant de le brancher directement sur un amplificateur de puissance. Le silence est remarquable.
Merci à Audiophonics de proposer des produits innovants et de cette qualité.
Sylvain S.
DENAFRIPS HERMES 12TH Digital Interface DDC USB I2S SPDIF Optical Toslink AES 32bit 384kHz DSD512 Black The Hermes 12Th USB digital-to-digital converter or digital interface (DDC) from Denafrips is the result of 3 years of research and development by the brand, which benefits from...
Le chef d'orchestre
Ce convertisseur numérique vers numérique apporte stabilité et lisibilité dans le message sonore. Tout devient précis et juste au bon moment. Un maillon indispensable dans toute installation utilisant un lecteur réseau audio.
Peter H.
USB 5V Supercapacitor Filter USB-C to USB-C / USB-A This 5V USB filter allows you to obtain a clean power supply for your Hi-Fi devices thanks to two 20F - 3.0V capacitors as well as an intelligent buffer...
Noticeably improved the sound in my system
I'm using this filter with an iFi SPDIF iPurifier2, which gets its power from a computer USB port. It's reclocking the Toslink signal coming from a Samsung TV. I'm also using an Audiophonics Digirescue after the iFi unit to reclock the signal one more time. The Digirescue is powered by an iFi Elite. Using both of these units in this specific order, with iFi first and Digirescure second, makes the sound by far the best in my system. I've tried every other combination of using no reclocker, only one reclocker powered by iFi Elite, and the two at the same time. Using both sounds best, and by adding this Supercapacitor filter for the iFi and its dirty PC power source made the sound leap to the next level.
I also have a USB source, and before I added this Supercapacitor filter the SPDIF source was a bit worse than my USB source. But with this filter in place the SPDIF signal is now better than USB by a comfortable margin. These supercapacitor filter products are probably the most cost effective method of removing power noise. In my system it exceeded expectations. Highly recommended!
Serge B.
SMSL DO100 PRO Balanced DAC 2xES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA The SMSL DO100 PRO balanced DAC is an evolution of the DO100 offered by the brand. The DO100 PRO benefits from numerous improvements. It features two ES9039Q2M DAC chips and a...
Bon rapport qualité/prix
Ne recherchant pas l'excellence à tout prix, mon oreille, d'ailleurs, ne me le permet pas puisqu'elle n'identifie pas les différences entre les formats MP3, FLAC et HiRes, ce petit DAC a une conversion et une restitution sonore qui me conviennent.
J'utilise les entrées optique (tv via le player de ma box) et coaxiale (lecteur réseau) et la sortie RCA (ampli intégré9.
La télécommande, qui fonctionne avec 2 piles R03 non fournies, s'apprivoise vite à condition de consacrer 2 minutes à lire la notice d'utilisation (en anglais)
luca f.
Articolo di scarsa qualità
Dopo 4 anni di utilizzo le prese si distaccano dall' interno,così è successo a me e ad altri amici, prodotto veramente di scarsa qualità
GEORGIOS C.
ELECAUDIO ADIACIUM GR Extensible PET braided sleeve Nylon 4-11mm Braided sleeve made in  PET (Polyethylene Terephthalate)  mono-strands which can be used in a wide variety of applications. Thanks to its expansibility, the unique PET...
The ADIACIUM series are great products
All of the products in the ADIACIUM series from ELECAUDIO are excellent. They have a very dense weave, they stand the test of time and also - very importantly - when handled carefully, they do not melt from the temperature of the air gun (on the low setting), used for the heat shrink tubing that will seal the ends (or elsewhere on our project).
Vladimir V.
Best value for the money
This is one of the best cables in the market. It doesn't do anything to the sound, just let your equipment work at its best.
Despite the thickness, it is flexible enough.
Ioannis P.
OYAIDE TUNAMI TERZO RR RCA Interconnect Cable 0.7m (Pair) This high quality modulation cable is assembled with the most famous Focus 1 connectors and a 102SSC cable, a top of the line model from Oyaide. This cable is presented to us...
Absolute pleasure
Used between vintage control pre and power amp (Kenwood Basic C2 and Technics SE-A5). Tremendous imaging, super wide and balanced soundstage, revealed supreme performance, accuracy and tonal clarity with a neat warm scent. Oyaide at its best, a real performer.
Ioannis P.
Great VFM
Nice solution for digital sources. Really decent soundstage and imaging, will trim / roll-off harsh treble frequencies on such equipment.
Ioannis P.
Banana Plugs Rhodium Plated Ø7mm (Pair) These banana plugs, although inexpensive, benefit from a beautiful design quality. The lamellae of these plugs allow a very good contact between the connector and the terminal...
Top quality
Very nice fitting, excellent value for money. Combined with Supra Classic 4.0 on second system.
A C.
SPARKOS SS 3602
Tout d' abord envoi reçu en 48 h00 et bien emballé pour un prix compétitif. Installation sur un fosi bt20apro sans problèmes. Dés la première écoute amélioration très nette par rapport aux op d' origine. Son plus profond et chaleureux, certains détails ressortent mieux, le tout contribuant à une écoute moins fatigante sachant qu' une période de rodage ne pourra qu' améliorer ce premier constat
A H.
Very nice cable
The sound is neutral, clear and very open. With this level of transparency this definitely is a bargain. Thanks to Audiophonics and the reviewers to bring the attention to this cable.
It has arrows for the direction, but they are hard to see. I think it is just a handy feature to find back the side where you put the shield to the ground. I didn’t read anything about directionality. I build them the wrong way but these cables sound so good that I cannot believe I made a mistake to make them the other way around.
A H.
VIBORG VF518R IEC C7 Connector Silver / Rhodium Plated Pure Copper Ø20mm The Viborg VF518R IEC C7 power supply connector is of high quality construction, ensuring extremely reliable transmission of the electrical signal. It features pure copper...
Viborg quality control should be better
The VF518 should have a metal body, like in the picture shown. It looks like Viborg puts VF508 plugs in a box that says VF518. Hence the Audiophonics description that says it has a nylon body. But I believe that is due to Viborg putting the wrong plugs in the boxes.
The plastic body is nice though, so I will keep it.
Don’t expect Furutech-type bolts, the Viborgs bolts/ screws are smaller and weaker. But Viborg plugs are also cheaper.
Only 2 stars because of the bad quality control of Viborg, although I am still satisfied with the plug.
stephane e.
Qui peut mieux?
Aussitot commandé,presque aussitot livré!
Ce petit bijou est destiné a driver des jmr orféo grande accompagné de l'eversolo dmp-10. Etant habitué au classe D de mon appareil actuel je recherchais plus de controle des basses,plus séche plus percutante quoi!
C'est chose faite,la puissance aidant cette ampli délivre sur tous les registres un son limpide ,aéré avec de la profondeur,de la largeur tous est bien distillé entre les enceintes.
Meme a bas volume,la dynamique ne s'écroule pas et les détails sont la.
Bravo a toute l'équipe pour avoir osé créer une machine qui délivre une puissance colossal et qui laisse passer la musique émotionnellement tel qu'elle est!
DAVID P.
VRAIMENT BIEN
Les polémiques et discussions sur les cables vont bon train sur les forums et ne sont pas toujours rationnelles ou seulement objectives. pour ma part je pense que l'on devrait batir son systeme avec des cables neutres comme les Cordial ou les Canare, puis une fois celui ci stabilisé, on peut commencer a investir dans des cables plus haut de gamme (que ce soit de modulation ou d'enceinte). J'utilise depuis plusieurs mois les Oyaide Across 3000 qui sont chatoyant. J'avais besoin de 2x2.5 metres pour mon Mc275 et ne voulais pas dépenser 250 € j'ai donc opté pour ces Oyaide deux fois moins chers. La différence est immédiatement perceptible. Pour l'instant les aigus sont peut etre un peu moins moelleux qu'avec les Across mais les basses sont terrifiques. Si votre systeme est un peu juste dans ce domaine, vous pouvez essayer les Explorer, vous devriez obtenir une amélioration notable.
PASCAL P.
FOSI AUDIO GR70 Tube Headphone Amplifier 5654W / 6AC7 The Fosi Audio GR70 is a headphone amplifier based on a combination of 2 x 564AW and 2 x 6AC7 tubes. As a result, it delivers a smooth, warm and authentic sound. Thanks to its...
Excellent ! 100% Tube Vraie Classe A ! Prix ridicule par rapport à ses performances
Après une semaine de rodage et avoir testé pleins de configuration de casques différentes (planar: Oppo 1PM, ETHERC by Dan Clark, FT1 pro; hybrides : Mezze Liric ; dynamiques : FiiO FT1, DT700, FOCAL BATHYS, FOSTEX TH600,.. ) ainsi plusieurs IEM de différentes sensibilités et d’impédance voici mon avis sur cette petite merveille
Basses
La réponse dans le grave est ample, ronde mais bien contrôlée. Le GR70 donne du poids aux basses, notamment en mode impédance haut, mais ne noie jamais le reste du spectre. Les amateurs de basses profondes pourront affiner encore ce registre grâce aux réglages de tonalité physiques.
Médiums
le médium est riche, vivant, très légèrement en avant. Les voix, en particulier féminines, gagnent en chaleur sans exagération. Les instruments acoustiques bénéficient d’une restitution texturée et nuancée, rendant l’écoute très “humaine”.
Aigus
Les aigus sont doux, non agressifs, avec une extension convenable et beaucoup d’air, mais sans brillance excessive. On relève une absence totale de sibilance et aucun effet de projection artificielle : la restitution garde une belle fluidité et ne fatigue pas à l’écoute longue.
Scène sonore et image stéréo
Le GR70 propose une scène large et profonde “juste ce qu’il faut”, sans surjouer l’effet. L’imagerie stéréo est précise, avec une bonne localistation des instruments. Sur des enregistrements binauraux ou des musiques complexes, l’espace sonore paraît réaliste et immersif
Pour ceux qui veulent encore augmenter l’espace sonore et avoir encore plus de FUN , je conseille un changement de tube préamplificateur RCA d’origine par des une paire de Voskhod Rocket 6J1P-EV ! L’espace sonore est exceptionnel voire holographique ! Les aigus sont plus précis, aucune sibilance.
Ces tubes de l’ère soviétique sont plus musicaux que la monté d’origine , plus chaleureux tout en étant plus précis et plein de bonne harmoniques paires et confèrent au son cette texture douce, pleine et tridimensionnelle !
Richard Z.
FIIO SNOWSKY MELODY Portable DAC Headphone Amplifier 2x CS43131 32bit 384kHz DSD256 Maple The FiiO Melody is a small, portable USB DAC and headphone amplifier with a unique design and an attractive wooden housing. Its digital-to-analog conversion stage is equipped...
Exellent, mais...
J’ai eu l’occasion de tester ce dac. Il est exellent. Neanmoins , avec des audios losless sur spotify ET sur mon samsung s24 ultra, il génère du souffle. Dommage!
Un peu moins de souffle avec tablette xiaomi pad 7 pro
Sylvain S.
SINGXER SA-1 V2 Balanced Headphone Amplifier Preamplifier Class A The Singxer SA-1 V2 is a complete, high-performance headphone amplifier and preamplifier based on Class A architecture and fully symmetrical discrete circuits. Version 2 of the...
De l'analogique dans ce monde numérique
Ce préamplificateur apporte de la chaleur, de l'ampleur et de la profondeur tout en conservant les micro-détails des équipements sources en amont. Il est installé entre le DAC et un amplificateur de puissance PURIFI et est parfaitement exempt de tous bruits parasites. Le silence est remarquable surtout pour les amplificateurs et casques très sensibles.
István R.
NEOTECH NEI-1001 II Interconnect Cable Balanced UP-OCC Silver 2x1.17mm² Triple Shielding The Neotech NEI-1001 II is a balanced modulation cable made of 2 Silver UP-OCC conductors with a cross section of 1.17mm². Each conductor is composed of 4 strands of...
better than Siltech G5, G7
I soldered NEI-1001II cable with VIBORG VR106AG RCA connectors. Unfortunately, I made the mistake of not choosing this cable right away, but experimenting with NEMOI-1220 first. NEMOI-1220 also showed the leading virtues of silver UP-OCC. NEMOI-1220 was a little below my expectations in the bass range, and slightly exaggerated in the high range.
However, the NEI-1001II and other Neotech silver UP-OCC cables are successively replacing my Siltech G5 and G7 cables I have been using so far.
Sylvain S.
DENAFRIPS ARES 15TH Balanced R2R DAC 24bit 1536kHz DSD1024 Black To celebrate its 15 years of expertise, Denafrips presents the Ares 15TH, a high-performance, balanced NOS R2R DAC. The digital/analog conversion stage is made up of no fewer...
Suppression du Live Dirac
Après avoir essayé différentes solutions pour corriger un problème de résonance dans les basses, nous avons choisi ce DAC qui immédiatement résolu le problème en apportant un son naturel avec beaucoup de détails et de maitrise. Un produit extraordinaire et un maillon essentiel dans notre configuration.
Sacit T.
Good for both digital and analog audio
I tried as coax s/pdif and analog rca interconnect cable. Both are very successful.
Jean-Pierre B.
ELECAUDIO DCT-2.1G Male Jack DC 5.5/2.1mm Connector Tellurium Copper Gold Plated 3µ This DC 5.5/2.1mm Elecaudio DCT-2.1G connector will allow you to design high quality power cables, ensuring a clean transmission of the electrical signal to your HiFi device....
Excellente Qualité et Finition
Qualité/ Fabrication sérieuse et excellents matériaux pour le prix !
La masse est d'un seul tenant, et l'orifice permet d'utiliser des câbles de bon diamètre (2 X 1,6m² pour ma part).
Vivement recommandé quoiqu'en disent les avis douteux non fondés...
Serkan A.
MINIDSP UMIK-2 Low Noise Omnidirectional Measuring Microphone USB XMOS ASIO 32bit 192kHz The UMIK-2 is the second generation MiniDSP omnidirectional low-noise measuring microphone. It takes advantage of everything that made the first version, the UMIK-1, so...
Très bien...utilisation professionnelle...
Jerome B.
FICHES BANANE EXCELLENTES
Je n'ai pas encore installées celles-ci mais j'ai déjà un jeu de 4 (achetées chez Audiophonics) que j'utilisent depuis plusieurs années.. rien à redire c'est du Furutech. le son n'est pas montant notamment ce que l'on pourrait croire sur les mediums ou les aigus. NB Je remercie une fois de plus la diligence d'Audiophonics. J'ai commandé mes fiches + cables le lundi soir reçus tout ce petit monde le mercredi en parfait état. Merci encore
Thomas R.
Super cable
Câble d’excellente qualité. J’avais des buzz avec un câble similaire bas de gamme pour relier ma platine vintage Grundig à mon ampli hi-fi. J’ai attendu et hésité car je trouvais le prix élevé mais je ne regrette pas du tout, super son et plus de bruits parasites. Je recommande vivement
Siegfried M.
Excellente qualité
Jyrki L.
GUSTARD R30 DAC R2R Preamplifier Streamer 32bit 1536kHz DSD1024 Black The Gustard R30 is a DAC, streamer and preamplifier based on an R2R ladder resistor network to offer high-precision digital-to-analogue conversion, supporting PCM up to 32-bit...
Great sound quality here!!
I am happy that I decided to order this product. Clear upgrade from Okto research dac8, which is also a great product. This Gustard is more musical and at the same time with more detail and nuances. Bass response is fabulous with the lowest end and definitely not boomy at all. Of course you need a top notch source to pair with this wonderful dac. Pricey but still very much of a bargain.
ciro p.
EXICON ECX10P20 Transistor MOSFET (2SJ162) Exicon MOSFETS have been specifically designed for high power linear use. They offer high voltage capability, high slew rate and low distortion, making them the ideal choice for...
ottimo prodotto
ottimo prodotto consiglio servizio super veloce e spedizione eccellente grazie mille alla prossima
