iouri C.
Au final déçu.
Antoine S.
CD Player Upgrader
Michel R.
Parfait pour mon usage
Aleksejs B.
MATRIX MINI-I 3 PRO MQA Balanced DAC ES9038Q2M Headphone Amplifier Streamer 768kHz DSD512 This fourth version of the Matrix Audio Mini-i series features network player capabilities as well as a balanced, powerful audio circuit while maintaining the superb compact...
MATRIX MINI-I 3 PRO
The DAC has a very good pre-amplifier, which makes it possible to effectively control the volume of active monitors. The sound quality after two days of listening, we only managed to understand that it is not worse than Chord Mojo, and provides better control over high frequencies. The mids are about the same. It is very pleasant to listen to the device, it is not sharp. The bass is still being worked out softly, the accuracy of the strike is not enough, it is possible to improve with warming up. However, we are very pleased with the technical equipment of the device with all kinds of inputs. BT works stably without interruptions. HDMI could not be connected to the Cayin N6 mk2, all four configurations in the menu did not help. On the remote control, the volume is adjusted step by step, one division of 0.5 db very slowly. The attenuar knob on the device is also very slow to adjust the volume. But this is good for night listening, since you can set the volume of active Genelec 8040 monitors extremely quiet, and the chip allows you to hear all sounds without loss.
Denis M.
Très bon DAC simple à monter
Agréablement surpris par la sonorité sur ma chaine Rotel via des câbles profigold 70cm. Le son est clair, suffisamment détaillé, mais pas trop haché pour une écoute très agréable.
Le montage est très simple et suffisamment documenté. Installé avec Volumio, rien n’a dire c'est plus que parfait, je redécouvre mes FLAC. La connexion Airplay est fonctionnelle de facto pour le plus grand plaisir de la famille. Je l'ai couplé à une alimentation ALLO NIRVANA connecté à la masse de mon ampli.
Je vais essayer d'autres solutions logicielles pour le fun car J'ai eu quelques freeze sans en connaitre la cause. La base HW avec le sabre est très bonne, le soft c'est pour la connectique et l'interface.
Quelques améliorations comme un switch logiciel pour étreindre l'écran ou un moyen HW de faire un shut down auraient été bienvenus.
Je vais regarder si je ne peux pas ajouter ceci sur le PI et gratter côté forum.
Le contact avec l'équipe pour le conseil avant vente et le support est très bon et efficace.
Philippe R.
Prise de qualité
À acheter les yeux fermés si vous voulez être sûr que la prise ne fonde pas avec un excès de chaleur lors du soudage des connecteurs.
Philippe R.
Utilisé en xlr entre ampli et préampli, ce câble est une grande surprise. Il s’avère très équilibré et dynamique sur tout le spectre, sans manque dans les graves où les aigus.
pierre a.
tres bonne fiches
tres bonnes fiches banane , ont l'air solides
acceptent du cable jusqu'a 6mm2
je recommande
pierre a.
tres bon cable
cable d'un tres bon rapport qualité/prix , tres souple facile a
scinder et a denuder
c'est sur que le plaquage argent améne un plus
service audiophonics au top comme d'habitude
Charles M.
ARYLIC UP2STREAM MINI V3 Bluetooth 5.0 WiFi Receiver Board DLNA UPnP AirPlay The Arylic Up2Stream Mini V3 is a WiFi and Bluetooth 5.0 receiver that will allow you to easily stream your music from any connected device. Practical, it allows you to limit...
Parfait pour sonoriser ma terrasse
J'avais un système DIY avec ampli Tripath2x100W, une paire de Kef tropicalisées avec une carte airplay (Airtry) qui fonctionnait un peu qd elle voulait. J'ai donc juste eu à connecter l'alimentation 5V sur la carte connecter les sorties analogique à l'ampli. En 45 min , configuration wifi comprise ça fonctionnait à merveille. Spotify en DLNA ou Airplay depuis le mac ça marche nickel, je recommande
Charles M.
ARYLIC UP2STREAM AMP V3 Amplifier Module Class D WiFi DLNA Bluetooth 5.0 2x50W 4 Ohm 24bit 192kHz Particularly practical, the Arylic Up2Stream Amp V3 combines the functions of both Class D amplifier and WiFi and Bluetooth receiver. It will allow you to broadcast your music...
Fonctionne parfaitement
Je l'ai utilisé pour sonoriser une salle de bain. Une alimentation de PC 120W en 19.5V DC ça déménage largement assez pour 12m2. Pour une pièce plus grande il faut idéalement 24-25V pour obtenir la puissance max. Sachant que comme tout classe D, la distorsion devient perceptible passé 50% du volume. Pour mes projets si j'ai besoin de 50W , je prends un classe D de 100W.
La connectique minimum pour ça marche est basique, Alimentation DC et sorties Enceintes , mais la polarité alimentation DC n'est pas indiquée sur la carte. La photo de la carte sur la notice , montre la polarité en regardant bien.
J'avais prévu d'ajouter un bouton volume (encodeur rotatif) mais comme le volume se règle bien depuis l'application , ce n'est pas franchement utile.
J'ai l'impression que le bluetooth ne fonctionne qui si la carte n'est pas connectée à un réseau wifi. Sinon l'Airplay et le DLNA fonctionne parfaitement. J'utilise Spotify aussi, les récepteurs Arylic sont visibles directement depuis l'application Spotify. Les liaisons sont relativement stables (j'ai noté quelques décrochages). Boot en 20-30s. Bon produit, permettant de nombreux projet DIY. On peut sélectionner la voix gauche, droite ou stéréo depuis l'application. La fonction est intéressante si vos enceintes sont très distantes, mais en L solo ou Solo on ne récupère que 50W max, du coup c'est un peu gâche. J'attends la sortie de la version mono pour faire des enceintes actives connectées à partir d'enceintes colonnes passives.
Très très bon préamp !
Droit, dynamique, silencieux. Si vous recherchez un modèle pour réchauffer un peu votre son, celui-ci n'est pas fait pour vous.
Si, en revanche, vous voulez de la dynamique, de la transparence, du silence et du gain, alors oui, considérez le P26 comme un excellent choix.
En entrée Pré In de mon PSE 300ß, le mariage est superbe !
De plus, il est beau, bien fini, de taille intermédiaire, la réception IR très réactive, l'écran OLED jamais éblouissant.
Bref, superbe pour un prix très abordable.
Super mais avec une faiblesse tout de même
Je ne vais répéter tout ce qui a déjà été écrit; c'est un super petit DAC, équilibré et performant.
Un (gros) défaut toutefois selon moi, l'utilisation incontournable de la télécommande ! J'ai donc copié les codes de l'allumage/extinction, le volume sur une universelle pour ne pas à avoir l'utiliser tout le temps.
Excellent rapport Q/P
Alimentant un DAC SMSL, en comparaison d'une alimentation ifi iPower, la différence est "palpable". Plus dynamique et plus silencieuse surtout !
Disposer d'un second port en usb, même s'il est privé d'isolation galvanique, est très appréciable.
A ce prix, inutile de se creuser la tête en la comparant à des plus onéreuses, le bon choix est… ALLO
JEAN LOUIS B.
Il a tout d'un grand
Je l'utilise pour contrôler la partie grave d'une enceinte, un HP de 38cm Fres : 27HZ ..... Adieu les énormes bobine à air et les condos coûteux, les filtres pour booster une caisse un peu trop petite etc..... Ca se pilote très bien et ça marche, que demander de plus à ce prix! Faites l'essai c'est top!
Fabrice L.
De haute volée
Installé depuis plus d'un an sur DAC ou remplaçant des AOP de lecteur CD.
Excellente image sonore, les plans sont très stables.
Même si le message musical est complexe (masse orchestrale, multiples voix, divers effets électroniques), cet AOP n'est jamais brouillon.
Il est d'une grande finesse sur tout le spectre grave -médium-aigu.
Peut sembler un peu mat par rapport à d'autres AOP, mais c'est son côté rigoureux.
Pas d'esbrouffe, il révèle ses qualités au fil des écoutes.
Je le trouve dans l'ensemble supérieur, de peu, certes, au AOP Texas 1611 ou 1612 qui sont d'ailleurs excellents.
Un choix raisonnable pour éviter une brillance fatiguante et gagner sur la qualité de l'image stéréo.
JEAN LOUIS B.
AOP au top
Un véritable gain de définition du signal audio, détail et précision : un super produit. Facile à mettre en oeuvre car assez compact, en remplacement d'un CI existant. Ca m'ouvre de belles promesses de réalisations futures. N'hésitez pas ça vaut son prix.
Thomas J.
Revelation
This DAC replaces a Geek Pulse. Listening to it after letting it run for a few days was disturbing. DSD and hi-resolution PCM files sounded distorted! Nothing like my Geek, nor the Calyx M DAP I have. I wondered if I had blown my Audeze LCD2 headphones. And then I realized that what I was hearing was not distortion from the DAC or headphones, but sounds I had never before noticed. Audience sounds In classical recordings, maracas way to the left on Bob Marley LIVE (24-192), actual distortion from electric guitars. This DAC, especially mated via HDMI/I2Sto the RaspTouch I bought to go with it, delivers so much more from recordings than I am used to hearing. The jump in sound quality is similar to what I experienced moving from cassette tapes (metal on a 3-head Nakamichi, so pretty good) to CDs in the 80s. But from a much higher bar. There is NO noise that I can discern - similar to my Calyx M DAP. But the resolution is in another league. The Gustard is extremely well built, offers the “blackest” of backgrounds, delivers dynamics (micro and macro) with ease, and transports you to the musical performance beyond anything I have experienced in decades of being an audiophile. Just make sure the rest of your playback chain is up to the task! Highly recommended.
Charles M.
Excellent rapport qualité prix à un détail près
Entièrement métallique , de bonne facture, très bon rapport Q/P. Petit détail esthétique, la bague en plastique rouge ou noir ballote une fois qu'on a serré le câble, car elle n'est plus plaquée par la vis serre câble. Cést pas très judicieux, mais ça reste un très bon produit
JF L.
Ce câble est excellent. C'est aéré, vif, ça laisse tout passer, le meilleur comme le pire, selon les enregistrements ! Nul besoin d'aller se ruiner !
Bruno M.
Simple, efficace (commutation sans parasites).
Niveau de sortie trop faible
Après analyse des caractéristiques avec un banc de mesure audio, ce petit préampli est vraiment excellent.
Son seul défaut, et il faut que je me penche sur le sujet, est son niveau de sortie un peu faible pour attaquer des enceintes amplifiées tel que des FOSTEX PMO.5n qui fonctionne très bien avec d'autre préampli. En effet le contrôle de volume n'est réellement opérationnel que de -50 à 0 db alors que la page de fonctionnement est de -90 à 0db.
Dommage qu'après plusieurs remarques sur le sujet le fabricant n'est pas rectifié le tir et changé la valeur de de la résistance de gain de son ampli OP interne.
Pour la télécommande beaucoup de boutons pour pas grand chose. je n'ai toujours pas compris à quoi servent certains boutons de celle-ci.
je recommande ce petit produit qui fera très bien l'affaire pour constituer une micro chaine audio de très bonne qualité car comparé avec des préamplis de 5 à 20 fois sa valeur, il en impose par sa simplicité et son excellent rendu.
Pierre
Andis O.
For lovers of pure sound
Great product at this price.
Clear, detailed sound.
The sound stage is not very wide.
Fast and dynamic.
The low frequencies are not highlighted, but are very detailed.
The double bass and bass guitar sounds fantastic.
The vocals sound great.
Also a symphony orchestra.
Not suitable for those who like big bass.
Not suitable for systems with low bass.
Good and clearly visible display.
Slight noises are heard when switching to MQA.
Only 3 feet.
Didier R.
Conforme à la description
Une face arrière en tôle aurait été suffisante (le produit livré avait une face avant et arrière en alu)
Jean-Luc B.
Câbles enceintes , straps ;
Très bon produit , de bonne qualité et surtout très facile à utiliser .
Recommandé !
Jean-Luc B.
Très bon produit , bien conçu ,et surtout très pratique à utiliser .
Recommandé !
insatisfaction totale
Bonjour je viens d'ouvrir ce matin le colis car absent ! Enorme déception ce n'est absolument pas le bon produit , autre aussi d'ailleurs !
Pour le rouge le diamètre est de 4 mm et pour le noir je dirai 8 cm !
Comment peut on se tromper à ce point ?
Je vous renvoie bien évidemment les 2 produits !
A votre écoute
Laurent Olivier M.
Une excellente surprise
Sur les - excellents - conseils du service client d'Audiophonics, j'ai sauté le pas et troqué mon Creek Evo2 contre cet ampli.
Et je ne le regrette certainement pas !
Je ne peux que confirmer ce qui a déjà été écrit ici, en particulier l'étonnante impression de 3D sonore qui se dégage de ce tout petit ampli.
L'extension dans l'aigu donne un relief saisissant aux meilleures prises de sons dont elle révèle les détails sans une trace d'agressivité.
L'image sonore est particulièrement stable et profonde et la dynamique surprenante, heureusement que je n'ai pas de voisins immédiats !
L'impression d'ensemble est celle d'une grande transparence, comme si les enregistrements sortaient directement des enceintes. Les colorations que je remarquais avant ont totalement disparu.
Revers de la médaille, les prises de son médiocres ne sont aucunement enjolivées...
Dans l'absolu, c'est excellent, et pour le prix, je conseille vraiment d'essayer !
Petar S.
TOPPING D10S DAC USB 32bit/384kHz DSD 256 XMOS U208 ES9038Q2M Silver Revisited version of the D10 from Topping, the D10s is an office DAC with impressive capabilities in its price range. This second version includes an ESS ES9038Q2M 32bit...
Topping d10s
Audiophonic is reliable partner with fast delivery and accurate description of products.
Françis S.
Françis S
Confirmation de la bonne tenue acoustique de ce câble . Prévue pour relier la sortie casque d'un téléviseur à un émetteur de casque sans fil , cela change complètement la donne . plus de clarté , plus de détails , meilleurs timbre et un peu plus de niveau .
guy s.
Après avoir galérer avec les pointes de découplage Elipson, je me suis tourné vers les Superpikes, j'ai hésité à cause du prix mais finalement je ne regrette pas mon achat. Ces pointes font parfaitement le job et de plus je peut déplacer mes colonnes sans problème.
Victor D.
Bon récepteur, signal transmis, même assez loin.
Très pratique pour éviter de changer de DAC.
Service Audiophonics toujours au top !
THIBAUT F.
INDISPENSABLE POUR CELUI QUI FAIT DU STREAMING
Pas envie de changer de dac? pas envie de changer d'ampli?
Commencez par acheter ceci. le gain est incroyable.
Jean-Marc F.
Sélecteur de source RCA
Ce sélecteur de source RCA est bien conçu. Il fait appel à des relais (donc des contacts "secs") pour la transmission du flux audio. Il n'est pas question de perte ou de coloration du signal, comme cela est bien souvent remarqué avec des commutateurs à transistors. De plus, cette technologie permet de faire transiter le signal dans les deux sens(1 entrée vers 3 sorties ou 3 entrées vers 1 sortie), suivant la configuration exigée. Pour le prix, il n'est pas question d'hésiter.
beau son, bel objet
objet audiophile sublime! merci Audiophonics!
Gaetan P.
FX-AUDIO D502BT Amplifier FDA TAS5342A Subwoofer Output Bluetooth 5.0 2x60W 4 Ohm Black The FX-Audio D502BT is, as its name suggests, the successor to the D502. The D502BT takes over its base and components, but this time it comes with a Bluetooth 5.0 receiver,...
la scène sonore est en retrait
- la télécommande est très bien pensée ... voire géniale
-les fonctions sont très bonnes
-l'usb sous Windows 10 est reconnu directement et la musicalité est bien meilleure qu'avec les autres sources
-le son porte loin d'un bon niveau de qualité
-pour le son de la TV... génial!!
-----Avec des enceintes EVA de Davis-----
j'ai utilisé précédemment un Alientek qui est nettement mieux pour la scène sonore
mais fatigant et moins pratique...
...que ce FX-AUDIO tout doux peut-être un peu trop
ce petit ampli qui reste très bien avec Equalizer et Tone pour corriger sérieusement le son sans que cela soit compliqué
Un prix très serré
KLEI CLASSIC HARMONY RCA Plugs Silver Plated Copper (Pair) The RCA KLEI Harmony Perfect RCA bases offer excellent design quality for enhanced performance, based on a certain know-how, the fruit of the brand's many years of experience....
superbe musicalité
monté sur l entrée de mon ampli et sur mon dac en sortie analogique. quel ouverture et quel clarté redoublée.. tous est a sa place avec un plus partout.. malgré le contact qui est qu' un pin de 2mm sur 1 mm touchant la pin de la prise rca point chaud.. le resultat est vraiment bluffant.. j ai monté des wbt argent pur en sortie de mon lecteur cd x ray..de 18 ans d Age et en entrée numérique de mon dac. audio gd.. quel claque.. déjà que sais excellent sans.. la sais superbe. .j ai même essayer une interface ifi digital ..et la je sens littéralement les personne les timbale les violons.. ils sont devant moi ..dans mon salon.. comme quoi un upgrade resonné et bien fait. améliore vraiment.. se qui est déjà bon.. sa deviens excellent.. pas pour tous bricoleur du dimanche. .mais avec un peut d adresse et de bon conseils. ont peut atteindre une sorte d excellence.. prochainement je craquerais pour une interface de chez audio gd. avec alimentation régénérative..
Guillaume L.
Pas trop mal
acquises pour remplacer des prises droite Merten installées sur des cables "Powertrans", gain esthétique et saillie moins importante permettant de rapprocher n meuble du mur.
A voir, le rapport prix/solidité.
Jérôme R.
Produit conforme, excellent rapport qualité prix.
Thomas J.
RASPTOUCH LVDS Streamer I2S HDMI Audio-GD Compatible IIS Audiophonics is back with a brand new version of its RaspTouch, designed for experienced audiophiles. It includes a Raspberry Pi 4, an Allo Kali reclocker and an I2S output...
The Definitive Squeezebox Touch Replacement?
Both my SBT and my DAC, a Geek Pulse, recently died. I tried a Volumio Primo, but the HDMI touch screen I added was much too slow, the functionality of Volumio software not up to the task of dealing with my large music library, and the Squeezelite plug-in problematic. I came to Audiophimics for a new DAC (the impressive Guatard A18) and found this by happenstance. Lucky day. The RaspTouch is fantastic. A better screen that is very responsive. A simple but well-built case. Setting it up with PiCorePlayer was far easier than the Volumio Primo, especially with the help of David, who was incredibly patient and helpful. Combined with the Gustard it sounds truly fantastic. I recommend both the hardware and Audiophonics without reservation.
Claude H.
Une réussite
L’Armature Hecate a été inséré entre la sortie USB d’un Mac Book et l’entrée S/PDIF d’un convertisseur Musical Fidelity X-DAC V8.
Le périphérique est identifié automatiquement par le MAC, il n’y a rien a faire.
Le résultat est immédiatement probant, pas de rodage des oreilles nécessaire…..
Net amélioration de la profondeur, de la dynamique de la reproduction des détails.
Le progrès technologique est passé par la, produit très recommandable.
Gerard S.
Améliorer l'inertie
Parfait pour apporter une isolation et masse complémentaire suivant l'épaisseur choisie à une platine vinyle, un laser, un ampli ou même des enceintes.
Gérard.S
Gerard S.
Couvre plateau posé sur une Thorens TD166 modifiée. je le préfère de loin au modèle caoutchouc pour filtrer les bruits. Excellent rapport qualité prix.
Gérard.S
Gerard S.
Aération et superbe scène sonore
CES 2 tubes JJ ECC82 sont placés dans un Mélody SP3. Après avoir réalisé plusieurs comparaisons, la première qualité de ce tube est pour moi la transparence. La scène sonore est très aérée avec des basses biens présentes et des aigues d'une grande finesse. Elle me semble avoir une courbe de réponse très légèrement creusé dans le médium. Ce sont mes ECC82 préférées. Toute la magie réside dans l'association des tubes de caractéristiques différentes pour arriver au Graal.
Gérard.S
Gerard S.
Excellent tube
J'ai mis 2 tubes 6922 EH dans un Mélody SP3 à la place des JJ dont je trouvais le haut médium en avant sur mon système. je suis étonné et satisfait du résultat. je trouve que les EH ont une courbe de réponse plus linéaire avec une dynamique étendue sur tout le spectre sonore, des basses tendues, des bas médium bien définies, des médium présent sans aucune agressivité, et des aigues fins et déliés. De plus j'ai trouvé une nette amélioration sur le placement des instruments augmentant la profondeur de la scène sonore.
Gérard.S
PIERRE R.
fil argent 1 mm en audio
Ce fil d'argent de 1 mm gainé de téflon avec le fil de retour plaqué contre la gaine pour le bifilaire et le tout entouré d'une gaine téflon plus large réalisent le meilleur câble de liaison entre le lecteur et le préampli à ce jour dans mes réalisations . En câblage interne il est remarquable en fluidité et précision !
Klaus B.
Impressing SPDIF-source at low price
I use this Interface combined with a RPi 3B and Volumio (which I already used before). My DAC is the AK4495SEQ-Board from Audiophonics.
This Interface is absolutely astonishing: very tight bass, nice voices and superb positioning of the Musicians. I didn't await this quality for that price!
Nicolas Rafail P.
Solid, goodlooking, professional
I immediately loved it, a piece of equipment that complements every desk! Clear sound that perfectly matches my SMSL SP200. I really like the display depicting audio format (PCM or DSD) and sampling rate of the track playing.
Nicolas Rafail P.
POWER and THX quality combined!
This is trully an afordable, serious piece of equipment capable of producing the cleanest of sounds with enough power to drive ANYTHING you give it.
Nicolas Rafail P.
Really good quiality and looks nice on my desk!
Apart from the quaity i really valued the fact that 75cm version exists, that 100% suits my needs.
Nico V.
Great DAC !
Excellent DAC ! All in one - Amplifier with volume control incl. Remote control and working fine ! If you use a UP-OCC self made USB power cord it is even better in performance. Toslink is working fine.
Nyirö F.
fast shipping!
I'm still testing the sound.
Volker E.
Incredibly good DAC: Fantastic sound, stylish and very affordable!
First of all I would like to praise the support here, who answered all my (partly senseless) questions before and after the purchase.
To the initial situation: I have Adam active loudspeakers, which are controlled by an Abacus preamplifier. My old DAC was getting on in years. I have been thinking for a long time about which new DAC to buy. The only thing that was clear was, that it should be a Sabre, because I love its timbre. So I came to this product, which sounds at least five times more expensive than priced here. The room expands dramatically, both in width and depth. And even if it sounds like a cliché, you can now hear details that were previously imperceptible. At the same time the sound remains harmonious, because it does not dissolve in the manifold details, but wins through this in harmony - in my opinion a quality of the Sabre-Chips, which was perfectly staged here. The bass range plays much more nuanced. The highs are now even faster but silky smooth - The Adam performs very well with this DAC.
The assembly was easy, Volumio explains itself and the speaker looks stylish with the display. The remote control is a real asset, because you don't have to constantly reach for the iPad to control the playback.
I can only recommend the DAC all around. Thank you very much for this cheap and great device and many greetings from Berlin, Volker
