Discover our range of portable headphone amplifiers, designed for use both at home and on the move, thanks to a compact form factor and an adapted design. Enjoy the best sound quality, wherever and whenever you want.
The Hidizs XO is the ideal companion to accompany a smartphone and enjoy a high quality sound reproduction. Combo DAC and portable headphone amplifier, it benefits from very good performances and a neat design, perfect to listen to your music in the best conditions, especially on the move. It even provides a double balanced / single-ended output to fit...
The iBasso D17 Atheris is a high-end audiophile DAC and headphone amplifier based on a hybrid conversion architecture that strictly separates PCM and DSD processing. It combines a discrete R2R network of 284 resistors paired to 0.01% accuracy across four symmetrical channels with a 1-bit matrix composed of 64 PWM cells, achieving a THD+N of -104dB in PCM...
The Ibasso DC-Elite is the miniature version of the DX320 Max. In fact, the components and architecture of this portable DAC/headphone amplifier are inspired by the DAP DX320 Max. It incorporates a RHOM BD34301EKV DAC chip, FGPA and NDK femtosecond oscillator.
The DC07Pro is the new version of iBasso's portable DAC/headphone amplifier. This compact device is equipped with four CS43131 chips and a custom-built FPGA, enabling it to read files up to PCM 32bit 768kHz and DSD512. Its low power consumption and high output level of 2x430mW at 32Ω make it the perfect travel companion.
The DC07PRO is the new version of iBasso's portable DAC/headphone amplifier. This compact device is equipped with 4 CS43131 chips and a custom-built FPGA, enabling it to read files up to PCM 32bit 768kHz and DSD512. Its low power consumption and high output level of 430mW+430mW at 32Ω make it the perfect travel companion.
The iBasso Macchiato is a portable DAC with a built-in headphone amplifier, designed to convert and amplify digital sources in a mobile setting. It features a dual CS43131 DAC architecture capable of decoding up to 32bit 384kHz PCM and DSD256, whilst delivering 2x 580mW of power into a 32Ω load.
The iBasso Nunchaku is a balanced portable DAC and headphone amplifier based on two CS43198 chips coupled to an FPGA to handle signal conversion up to 32bit PCM and DSD512. As for the amplification stage, you can choose between operation using power tubes for a warm sound or more traditional Class AB operation for a more neutral sound with improved...
The iBasso PB5 is a portable analog headphone amplifier based on a balanced structure and the use of audiophile components. Its preamplification stage is based on Nutube 6P1 tubes, while its amplification stage uses OPA827 and VCEsat transistors. A hybrid design, it offers the smoothness and warmth of tubes coupled with the power of more modern components...
The iBasso PB6 Macaw is a portable tube headphone amplifier designed to provide high-power amplification for mobile sources. It features a balanced design incorporating JAN6418 tubes powered by 22.5V, to increase the dynamic range whilst maintaining stable performance with a variety of headphones, delivering up to 2300mW + 2033mW into 32Ω when using...
With the Go Bar Kensei, iFi Audio offers its most powerful USB DAC and ultraportable headphone amplifier. With its particularly compact format, it can accompany you on all your travels, providing high quality listening at all times, whether from a smartphone, tablet or computer.
The iFi Audio Go Blu is an ultra-portable DAC and headphone amplifier combo designed to give you the best sound quality anywhere, anytime! It offers both the best wired sound quality and the convenience of wireless with its Bluetooth 5.1 connectivity. With a particularly small size and a weight of only 26g, the Go Blu will be quickly forgotten, leaving...
With the iDSD Diablo 2, iFi Audio is offering a portable DAC and dual-mono headphone amplifier with an output power of up to 5180mW and which supports signals up to PCM 768kHz, DSD512 and MQA. The latter is equipped with a Qualcomm Bluetooth 5.4 chip supporting the new aptX Lossless codec and has been designed to be compatible with xMEMS driver technology.
The iFi Audio iDSD Valkyrie is a portable DAC with a built-in headphone amplifier, designed for high-resolution playback and driving demanding loads. It supports PCM streams up to 768kHz and native DSD up to DSD512, with internal upsampling to DSD1024 via FPGA, utilising a Burr-Brown quad DAC architecture to improve linearity and channel separation. This...
With the xDSD Gryphon, iFi Audio unveils an excellent balanced portable DAC and headphone amplifier combo, showing a careful design, capable of incredible sound performance. Its Ultra-Res digital stage includes a Burr-Brown MultiBit DAC and its PureWave analog power section, capable of developing no less than 1000mW!
The Ikko ITM05 is an ultra-portable balanced headphone amplifier and DAC combo, integrating high quality components in an extremely compact and lightweight format. It's the perfect companion for your smartphone to give you the best sound experience wherever you are. Practical, it slips easily into a pocket or bag.
The Ikko Zerda ITM01 is a headphone amplifier and portable DAC combo enjoying a beautiful design and playback quality. It has a 3.5mm jack output and a magnetic Lightning cable. Its conversion stage is based on a high performance ES9298 DAC chip.
The Khadas Tea is an ultra-compact, high-performance portable DAC headphone amplifier. Featuring an ES9281AC Pro DAC chip and a QCC5125 Bluetooth receiver chip, it is capable of supporting high-resolution PCM 32bit 384kHz, DSD256, Apple Lossless (ALAC) and MQA rendering via its USB-C input, as well as...
The Kiwi Ears Allegro Mini portable DAC / headphone amplifier is a small device that can support high-resolution streams up to PCM 32bit 384kHz and DSD128, and is capable of delivering up to 30mW under 32Ω. This means you can enjoy high-resolution files and drive a wide range of headphones and earphones available on the market.
The Kiwi Ears Allegro Pro portable DAC / headphone amplifier is a small device based on the use of two ES9603 headphone amp chips. It supports high-resolution streams up to PCM 32bit 384kHz and DSD128, and is capable of delivering up to 170mW under 32Ω. This means you can enjoy high-resolution files and drive a wide range of headphones and earphones...
An evolution of the famous Dawn Pro, the Moondrop Dawn Pro 2 balanced portable DAC headphone amplifier benefits from numerous improvements. In particular, it features two new CS32198 DAC chips and a HiFi USB interface that supports high-definition sampling rates up to PCM 32Bit 384kHz and DSD256.
The Muse HiFi M5 Ultra is a portable DAC with a hybrid headphone amplifier, designed for the conversion and amplification of high-resolution audio streams on the go. It is based on a customised ES9038Q2M architecture, compatible with PCM up to 32-bit 768kHz and DSD512, and combined with JAN6418 tubes, allowing for a combination of conversion precision and...
The Questyle M15C DAC headphone amplifier is a high-end-looking device based on audiophile components. It is based on a CS43198 DAC chip and its proprietary “Current Mode Amplification”.
The Questyle M15i is a DAC headphone amplifier featuring an ES9281AC DAC chip with integrated class G headphone amplifier, enabling it to support sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. This DAC chip is coupled with two CMA (Current mode amplification) circuits, i.e. transistors that extend frequency response and reduce...
Shanling unveils its Onix Alpha XI1, a balanced portable DAC featuring high-quality components. It incorporates 2 CS43198 DAC chips, enabling it to support high-resolution sampling rates up to PCM 32bit 384kHz and native DSD up to DSD256 via its USB input.
With the Onix Beta XI2, Shanling presents the new version of their successful portable DAC. This new iteration retains the dual CS43198 DAC architecture that made its predecessor famous and combines it with JAN6418 tube amplification for a warm and smooth sound, typical of analogue.
Shanling's Mystic XP1 is a state-of-the-art portable amplifier and DAC capable of converting signals up to PCM 32 bit 768kHz and DSD512. It has been designed to follow you everywhere and adapt to every situation, from driving small earphones when you're on the move to more demanding headphones for sedentary use.
With the UP6, Shanling presents a portable balanced headphone DAC and amplifier based on two ESS ES9069Q chips and two SGM8262 OPAs to offer conversion up to PCM 32bit 768kHz and DSD512 and an output power of 195mW at 32Ω single-ended and 626mW at 32Ω balanced.
The SMSL D10 is a high-performance portable headphone amplifier/DAC. It is based on the use of two Cirrus Logic CS43131 chips, enabling it to support sampling rates up to PCM 32bit 384kHz and DSD256. These chips also provide substantial headphone amplification, with output power up to 500mW @ 32 ohm and a dynamic range of 121dB.
The SMSL DS20 is a portable DAC and headphone amplifier distinguished by its cutting-edge audiophile performance and singular aesthetics. It is based on an advanced architecture incorporating four CS43131 DAC chips and an XMOS XU316 USB interface. This combination enables it to handle high-resolution audio streams up to PCM 32bit 768kHz, DSD256, and MQAx8...
The Tanchjim Space Pro is a DAC with a built-in headphone amplifier based on a dual Cirrus Logic CS43198 DAC architecture, designed to handle the conversion and playback of high-resolution audio streams. It supports PCM signals up to 32bit 768kHz as well as DSD256, whilst utilising a dual-mono topology that isolates the channels to improve separation and...
The Tanchjim Stargate 2 is a portable DAC and headphone amplifier with USB-C male and Jack 3.5mm female connectors. It's ideal for enjoying high-quality listening on a smartphone without a 3.5mm headphone output.
Topping presents with the G5 a compact and powerful portable headphone amplifier and DAC. This one integrates a powerful NFCA amplifier stage, a powerful DAC chip ES9068AS and allows a wireless connection via Bluetooth.
Particularly compact to accompany you in all your movements, the xDuoo Link2 BAL also offers very beautiful sound performances, thanks to a carefully balanced architecture and quality components. It will allow you to enjoy a rich and precise sound during your headphone listening.
The new XDUOO XD05 BAL 2 portable DAC headphone amplifier is a device capable of delivering excellent performance for a highly enjoyable listening experience. It relies on no less than two ES9038Q2M DAC chips and an XMOS XU316 interface for its conversion stage, while its preamplification stage features two...
The xDuoo XD05 BAL is an enhanced version of the portable headphone amplifier XD05 PLUS. Its digital/analog conversion stage has been updated, its Bluetooth wireless connectivity is now directly integrated and it now benefits from a balanced output.
With the XD05 Pro, xDuoo unveils a high-performance, robust and versatile portable DAC / headphone amplifier. It features high-quality components such as an ESS ES9039SPRO DAC chip and two dual TI OPA1612A. The XD05 Pro's design allows these components to be replaced to provide a listening experience tailored to your preferences. Thanks to its Class A...
The xDuoo XD05T portable DAC and headphone amplifier is a high-performance device where cutting-edge technology meets vintage. Indeed, it's based on the use of tubes machined in the 60s, coupled with transistors for its amplification circuitry, while the digital-to-analog conversion stage uses two ES9039Q2M DAC chips, an XMOS XU316 USB interface and an FPGA.
