iouri C.
Au final déçu.
Antoine S.
CD Player Upgrader
Michel R.
Parfait pour mon usage
Henri V.
Bons résultats à bon compte
Une alimentation linéaire qui remplace avantageusement 2 alimentations à découpage.
Les alimentations à découpage même les plus "silencieuses" ont tendance à polluer les appareils connectées sur le même réseau électrique.
Le résultat est variable d'un appareil à l'autre mais toujours positif.
Vivement conseillé !
Nnanna E.
XDUOO MT-604 Headphone Amplifier 4x 6J1 Tubes Transistors Class A Balanced The MT-604 from xDuoo is a headphone amplifier based on the use of 4 6J1 tubes to deliver a soft and warm sound. These tubes are associated with transistors for the Class A...
Cheap and cheerful tube amp
I’m surprised by the performance of this hybrid tube amp. Simple and powerful enough to drive my HE1000SE headphones. Would certainly recommend for any newbie tube enthusiasts
Nnanna E.
DD TC44A DAC CS43131 Male Lightning to Female Jack 4.4mm 32bit 384kHz DSD256 This TC44A DD adapter for smartphone is composed of a male Lightning connector and a female 4.4mm jack. It also includes a CS43131 DAC for efficient conversion of the audio...
Portable and high quality
Connects easily with my iPhone and with my 4.4mm balanced earphones. Decent sound quality
Nnanna E.
DD TC44A DAC CS43131 Male USB-C to Female Jack 4.4mm 32bit 384kHz DSD256 This TC44A DD adapter for smartphone is composed of a male USB-C connector and a female 4.4mm jack. It also includes a CS43131 DAC for efficient conversion of the audio signal...
Simple yet effective
Very portable DAC that connects to my iPad Air and my 4.4mm balanced earphones. Sound quality is decent. Happy customer here
Miroslav Z.
TOPPING LA90 Amplifier Class AB 2x90W 4 Ohm / 1x180W 8 Ohm Silver Topping offers with its LA90 a powerful and efficient amplifier, which can work both in stereo and mono mode. In the first case, it is capable of delivering a power of 2x90W...
Miro.
Very clean and detailed sound, really very nice and robust mechanical design. Superb. :)
Denis D.
Qualité de finition irréprochable. Le produit est solide, bien construit et bien fini. La navigation dans les menus est intuitive.
La qualité sonore est quant à elle vraiment top. C'est précis, détaillé, dynamique mais cela relativement transparent. Un excellent produit que je recommande (associé avec un WIIM pro).
Patrick J.
Petit mais puissant
Très utile quand on manque de place
Patrick J.
DAYTON AUDIO HDN-8 Speaker Driver Exciter Bodyshaker Full Range Weatherproof 50W 8 Ohm 40He - 15kHz Ø10.2cm A weatherproof electrodynamic exciter that can be placed virtually anywhere, Dayton Audio's HDN-8 literally makes any surface "ring". The product is...
Système de fixation un peu étonnant...
Mais bon, ca fait le job pour sonoriser une caisse de Pincab
Patrick J.
Grave puissant et profond
La connectique est soignée, parfait
Andrea F.
Sicuramente un buon prodotto
Ottimo il rapporto qualità prezzo. Suona davvero molto bene, è veloce con una buona risoluzione. Non pensavo di ottenere questa qualità sonora. Purtroppo mancano le istruzioni anche se il funzionamento è molto semplice. Unico neo il led di funzionamento rosso è molto forte se si posiziona l'apparecchio sul fronte. Per il resto un prodotto che funziona alla grande.
Andrea F.
E' un buon cavo
Niente da dire, ottimi connettori, la sensazione di qualità costruttiva è effettiva. Buon suono, molto neutro e veloce.
Jérôme E.
A voir dans la durée
Produit propre, contact franc, la gaine Thermo est un plus
Dimitar C.
Amazing result, exellent performance
I just finished with my project of speaker cables and the result is terrific, meaning the sound has abundant bass with a fine middle section and good hights without harsness.
But you didn't mention needing to remove the PE jacket of four cores in six conductors, also it would be fine to implement this info with pictures on your site. I will reassemble the termination of cables and fix that and then send to you again info according to the difference in sound.
Thanks to your attention again, wish you a good week!
Détrôné par la concurrence française
En complément et suite de mon premier avis du 15/01/2019.
Oyaide et moi avons divorcé avec cordialité et respect. Lol. Les trois câbles Tunami qui alimentaient ma barrette, mon ampli et mon lecteur ont été détrôné par trois autres câbles d'entrée de gamme (première lettre de l'alphabet grec) d'une marque française très "spirituelle" : plus de naturel et de sobriété, transparence et micro-dynamique très supérieures.
Les câbles Oyaide restent cependant très musicaux, mais en comparaison directe ils semblent lissés avec une luminosité systématique dans le haut-medium, un peu à la manière des électroniques nippones.
jean paul R.
1 ampli, 2 paires d'enceintes
Acheté pour faciliter les comparaisons entre 2 paires d'enceintes. Construit comme un tank, il fait particulièrement bien le job sans impact audible sur le son. Bref du sérieux, comme toujours chez Audiophonics
Romain B.
Bon module mais fixation au chassis peut pratique
Le modèle que j'ai reçu est différent de celui sur la photo. Un trou de fixation au lieu de deux sur la photo. Aussi il a été nécessaire de ressouder tous les condensateurs qui s'étaient dessoudés dans le transport.
Fonctionnement fluide et facile, bonne qualité sonore. Alimenté en AC par un transformateur 12V 5VA. C'est juste dommage qu'il n'y ait pas 1 trou de fixation par côté.
sander g.
Recommended
It works like a charm with plenty of power to drive a pair of 86 db 4 ohm tower speakers. The bluetooth connectivity was surprisingly good with fast reliable connection without drop-outs. Overall well built with satisfying knobs and buttons.
Only a few negatives comes to mind. One binding post was a little loose upon arrival, the volume was initially low but i have not had problems since the first day. Is it dependent on signal strength?
And a couple of extra inputs would be appreciated in an upcoming model.
In short, if you are in the market for a clean simple powerful integrated unit this is the one.
Pb de câblage / branchement / soudures
Si la barrette semble de bonne confection générale, certains éléments sont fort critiquables.
Sur le câblage interne :
- Les quelques centimètres de liaison entre la fiche IEC et les rails en laiton sont de faible section (env. 1,5 mm²),
- Soudés directement sur les rails, ils auraient pu être sertis avec une bague au niveau des vis de serrage
- Ils sont placée entre la première et la deuxième embase schuko, soit un montage en étoile pour les embases 1 et 2 puis un montage en ligne pour les embases 2, 3 et 4. Cela aurait pu être signalé.
Sur les rails en laiton :
- Ils ne sont pas d'un seul tenant. Un premier rail alimente les embases 1, 2 et 3 mais un second rail uniquement posé sur le premier alimente l'embase 4.
- il manque deux rondelles-frein entre les rails et les bagues de la dernière embase.
Résultat sonore : un son lent, rond et bouché, avec un effet lame de rasoir dans le haut du spectre.
- un bon point cependant : les bagues de connexion des embases schuko sont en contact direct avec les rails par serrage.
Vincent F.
Top Marque
toujours Top qualité avec Furutech, pas besoin d'aller chercher ailleurs
Vincent F.
Gaine Viablue
Produit conforme ca s'effiloche toujours de trop qd on coupe mais bon le tressage est ainsi fait.
Vincent F.
Top Marque
toujours Top qualité avec Furutech, pas besoin d'aller chercher ailleurs...
Vincent F.
Bel objet
Fait le job, joli mais cela reste toujours trop cher
Interconnect Cable Female XLR - Male XLR Gold Plated CANARE L-4E6S 1m Red This XLR male to XLR female modulation cable has a nice design quality, using a Canare L-4E6S cable. The cable has copper conductors insulated with PE jackets and is shielded...
Tres bien
Excellent câble sur mon système
Interconnect Cable Female XLR - Male XLR Gold Plated CANARE L-4E6S 1m Black This XLR male to XLR female modulation cable has a nice design quality, using a Canare L-4E6S cable. The cable has copper conductors insulated with PE jackets and is shielded...
Tres bien
2eme avis
Suite à mon avis du 14/10/22 basé sur l' écoute en bluethoot uniquement . Je me suis rendu compte qu' en installant un récepteur bluetooth extérieur aptx Qualcomm on atteint des sommets.Dommage que cet ampli ne soit pas équipé d'un bluthoot à la hauteur vu la qualité de l'amplification proposé. Mérite un câble de secteur de hdg ainsi que des câbles de modulation hdg. N hésiter pas à mettre plus cher en câble que le prix de l' ampli , il vous le rendra au delà de vos espérances .Allimente des panneaux magnepan mg 1.7 avec bonheur.
Fabrice j.
floating my boat
lift the whole system up, neutralize all kind of side effects ( even when not putting any under the speakers, only under each components - amp, cd, tape, record player, power block -)
more expensive version of other accoustic solutions but worth the investment
waiting for bigger speakers to complete the set
Gilles M.
Gilles M
Très bonne qualité. Très facile à monter et à souder.
A l'écoute, avec un câble de qualité à 30 euro le mètre sur ce site, l'amélioration sonore et vidéo est immédiate.
J'ai aussi eu un connecteur qui a coulissé vers l'extérieur, il suffit juste de le repousser avec le plat d'un couteau pour que les deux soient à fleur.
J'attend que ce site propose les embases de même niveau pour changer celles de mon LPSU200.
Jean-Yves F.
MUNDORF MRESIST ULTRA Resistor 30W 1 Ohm The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all wirewound resistors, this film offers...
Totalement neutre après rodage
Je l'utilise pour atténuer le signal dans les enceintes pour toutes fréquences au-dessus de 350 Hz.
Elle est monté sur le dissipateur recommandé par Audiophonics.
Il faut laisser à la résistance le temps de se roder ( environ 20h) après installation avant de porter un jugement sur sa transparence. Au premier abord elle me semblait peu neutre et maintenant je la trouve totalement transparente. Je suis ravi.
Baptiste B.
Si vous ne connaissez pas les rubans, c'est un bon candidat pour essayer :)
Hésitant sur ce type de membrane, j'ai tenté le coup !
Pour le tarif, c'est étonnant, très petit :)
Utilisé en voiture, pas besoin d'une amplification de titan, ça fonctionne parfaitement avec toute les sources avec lequel j'ai pu l'essayer.
Actuellement sur un Match DSP5 en filtrage actif, avec des woofer capable de monter proprement 18W4531G00, ça file haut et finement, néanmoins, si vous filtrez bas(pour ce genre de HP 4000/4500@12DB le niveau sonore disponible ne pourra pas être trop généreux. 8/9khz 6db peut être envisageable en fonction du placement.
Dans mon cas, ils sont fixés sur les montants de par-brise orienter directement à l'appuie tête conducteur. Les mediums en porte sont en passe bas à 3500khz@18db. Une petite atténuation d'équa sur les tweeter vers les 4/5khz les rendront plus doux(ou alors vous ajustez plus bas le niveau du tweeter...)
Niveau écoute, c'est très simple pour que cela place convenablement, on obtient quelque chose de très précis même avec une pente de filtrage à 6db, ce qui n'est pas le cas d'un dôme qui nécessite une pente à 18db pour un rendu aussi précis( mais qui en plus donnera une impression de perdre en de largeur de scène).
Niveau détail, en revanche, c'est là que l'on reviens à la réalité, même si j'ai trouvé que pour le prix... c'est clairement au dessus d'un XT25C90 niveau rendu général, finesse et placement le Dayton est devant, mais le woofer doit être disponible niveau medium pour rattraper son manque de descente en usage caraudio... ça complique les choses.
Dans une gamme de prix supérieur en petit format, un Seas 27TFFNC
sera plus polyvalent que les deux cité précédemment mais n'aura pas la finesse et la précision du ruban abordable de Dayton !
Si vous avez des attentes d'un certain niveau, passez directement à un modèle supérieur qui vous donnera la possibilité de descendre plus bas, de plus, comme un autre commentaire l'indique, c'est l'entrée de gamme monté à la va vite et le résultat doit clairement être impacté!
En car audio, il n'est pas assez grand. Si la taille compte, il y a d'autre réf très intéressante dans la gamme dôme de Dayton qui seront plus facile à mettre en œuvre et satisfaisantes.
Pieds pas chers et efficaces
Je recommande ces pieds, en particulier sous des lecteurs cd, lesquels peuvent parfois apparaître agressifs avec des pointes.
Ces pieds sont trés efficaces alors...
Arnas K.
Magnifiuqe sorry for my French
I used ifi reclocker, used pc as a source and was very unhappy with harsh and lifeless sound.
This bad boy makes music sound as good as from my phone and this means: Music full of life, depth and devoid of digital harshness.
Erick L.
Audiophonics HPA-S400ET SPARKOS
Aussitôt reçu, aussitôt installé.
Premièrement, merci à Audiophonics de ne pas avoir négligé le colis. Double carton, mousses et tout ce qui faut pour protéger au maximum l'électronique.
Deuxièmement, je dois dire en une phrase : cet ampli est une électronique de grande classe !
Ce qui frappe dès les premières notes (en comparaison de mon Parasound A23 fonctionnant en classe AB), c'est l'absence totale de bruit. Le silence est d'or avec cette électronique.
En terme de linéarité, de transparence, de niveau de détails, mais aussi de musicalité, tout y est.
L'ampli alimente magistralement mes Martin Logan.
Ce que je pouvais reprocher à la classe D, et plus particulièrement Devialet, était le côté mat et plat de la restitution. Il n'est en rien avec le HPA-S400ET.
Je ne peux que dire bravo Monsieur Putzeys (Purifi) et l'équipe Audiophonics, pour nous avoir concocté ce sublime ampli.
OYAIDE DST-75R V2 Coaxial Cable RCA SPDIF 75 Ohm 102SSC Rhodium Plated 1m The OYAIDE DST-75R V2 cable is a very high quality 75Ω RCA coaxial cable with a unique architecture and assembled with high-end connectors. These RCA...
très bon câble
je viens de brancher le câble donc aucun rodage.....
il y a de la matière, une bonne scène sonore,une bonne définition et surtout tout est bien en place....c'est très droit sans froideur comme j'ai pu le constater en écoutant les électroniques accuphase...c'est délicat comme écoute à l'opposé du démonstratif....il faut dire que j'écoute principalement de la musique de chambre et de petites formations de jazz....
mais ce n'est pas le câble ultime,ce n'est que l'entrée de gamme,il a des limites comme les timbres qui pourraient être plus riches ou des basses plus profondes et des aigus filant plus haut...sa dynamique n'est pas très explosive et il se peut que sur de la musique qui demande de la pèche,il soit un peu trop sage....attention cela ne veut pas dire qu'il soit mou;il est juste posé comme une personne d'âge mûr....
mais son médium est envoutant !!!
vous pourrez écouter votre système durant de longues heures sans aucune fatigue toujours avec une grande délicatesse....
christophe t.
LINDY ANTHRA LINE Male USB-C to Male Micro USB 2.0 Cable Gold Plated 0.5m Lindy's Anthra Line cables are high quality products, ideal for professional installations. This is a USB-C male to Micro USB male cable with 2.0 standard and transfer rates up...
mauvais contact
je m'en suis servi pour un clavier midi, mais 6 mois aprés le coté micro usb ne tient plus, dés que l'on bouge le clavier, il ya un faux contact, pas facile pour jouer des notes. pourtant il n'a jamais quitter mon home studio.
Fabien M.
D03
Merci Monsieur Aubert pour vos conseils, à l'origine de l'achat de cet intégré avec une paire de câble HP Canare 4S11. Le tout alimente 1 paire d'enceintes bibliothèque Wharfedale D220 dans une pièce de 25m2 pour des écoutes de musiques classique, Opéra, Jazz et musique du monde.
ATTENTES : prolonger à domicile les écoutes lors des concerts auxquels j'assiste (sans micro nin sono).
NB 0 pour les câbles CANARE 4S11, fiches bananes obligatoires car tout ne rentrera pas et ne tiendra pas derrière l'intégré.
NB 1 cet intégré n'a pas de sortie casque.
NB 2 entrée bluetooth et entrée RCA correctes mais pas au niveau de la partie numérique. Je n'utilise pas, j'ai juste vérifié-écouté leur bon fonctionnement.
NB 3 À notre époque, l'apport musical subtil complémentaire, quand il y a avec des systèmes très onéreux (xx.xxx€), se paie vraiment très cher. Tant mieux pour les bourses peu fournies et merci aux passionnés fortunés par leur quête de tirer tout le monde vers le haut.
RÉSULTAT après 60H00 de rodage : Ne vous posez plus de questions et écoutez la Musique. Tout y est !
CONTREPARTIE : quand le message d'origine est de piètre qualité, la restitution le sera. Pour les autres styles de musique, souvent trafiqué en studio, le résultat sera donc à l'avenant.
Stratos X.
Quick shiiping...5 stars sellers!!
Excellent cable
Excellent câble, il fait très bien son travail ; je recommande
Reçu en un temps records.
Merci Audiophonics
Xavi V.
muy bonita
da pena tener que taladrar esta belleza,merci
Patrick C.
DAC Topping DX1
Cette "petite boite noire" fonctionne à merveille, immédiatement reconnue sous Android et win 10 (le pilote ne sert à rien), après instal nécessaire du pilote sous Win 7 (oui j'uilide encore W7). Avoir un DAC "direct" et un ampli casque avec volume dans la même boite qui tiendrait dans une poche ! Les 2 sorties fonctionnent simultanément et indépendamment. Reconnue aussi par equalizer APO. Le son est très clair et aéré, pas trop "sec", plutôt "moelleux", très agréable, peut-être pas hyper analytique ou dynamique dans le grave, mais précis et détaillé dans le reste de les fréquences. Elle mérite un test avec une alimentation linéaire classique (pas à découpage) indépendante, pour voir si la complication d'installation en vaut le coup.
jevgenijs S.
New connectors look really nice on my new QED interconnects cable. Kind regards to Audiophonics.
jevgenijs S.
New rca sockets look great on my modified NAD C320 amplifier. Haven't had a chance to test a SQ yet.
Fabien M.
Pas assez cher ! Je plaisante bien sûr
Pour le prix, il va falloir dépenser beaucoup, beaucoup,beaucoup plus pour très très très peu.
Simplement musical. N'enlève rien, ne cache rien, ne change rien.
NB fiches bananes coté intégré obligé si vous avez peu de place car la section est importante.
NB1 rodage impératif avant d'en profiter pleinement.
VASILEIOS K.
Excellent value.
The build quality and the design are very impressive. A beautiful cable, solid core 6N. The sound of this cable is very full-bodied, i would say quite heavy. It's not the most airy or the most transparent cable out there, but it's very musical, very smooth and with good stereo image and soundstage. For a more neutral sound buy the thinner gauge 0.5. This should be your reference cable before you decide to pay tons of money for a high-end cable. The price is astonishing low for this quality and performance.
David D.
SMSL SD-9 Streamer WiFi DLNA AirPlay Bluetooth 32bit 384kHz DSD256 MQA SMSL's SD-9 is an affordable and versatile network drive. It supports indeed many file formats and has a complete connectivity. The wireless transmission can be done in...
SMSL SD-9
Fantastic mediaplayer. Top plate is glass. Luxury feeling. Very convenient ( control via Bluetooth with HibyMusic app on android.
Alot of connections like Bluetooth, Spdif coax and fiber optical and I2S.
David D.
Topping M50
Fantastic mini player ( much smaller than the SMSL SD-9). Alot of connections. Full metal body. Same footprint as the Topping D50S. Works very convenient with the app HibyMusic on android phone (connected with bluetooth you can control the player).
David D.
Topping D50S dac
Fantastic sound quality, selectable filters, extremely compact but also full metal body.
excellent RQP !!!!
je viens de réceptionner les fiches qui m'attendaient depuis samedi au bureau de poste.commande envoyée jeudi....
certains m'ont dit que je ne percevrais aucune amélioration et bien ils se trompaient....meilleur équilibre des registres,profondeur de la scène sonore accrue....
je suis extrêmement satisfait de mon achat !!!!
ne vous ennuyez pas à acheter sur aliexpress !!!les tarifs d'audiophonics sont souvent plus avantageux et de plus vous permettrez à de petits frenchy de gagner leur croûte
Laurent C.
C'est le Bon !
Une nouvelle fois je vais tirer mon chapeau à Audiophonic pour le choix et la qualité de leurs produits. Après avoir essayé divers câbles de toutes marques et prix différents, j'ai terminé mon installation avec ce Mogami 3103 que je trouve parfait avec un rqp imbattable. Aujourd'hui toutes mes Connections sont exclusivement assurées par des produits Audiophonic. Câble s secteur Elecaudio cs-361b et Phono Legion, Rca Canare Star Quad... que du bonheur pour mes oreilles. Merci Messieurs pour mon porte monnaie et votre professionnalisme.
Patrick b.
FURUTECH GT2 Pro USB-A Male / USB-B Cable Male 2.0 OCC 0.6m This USB cable is assembled with non-magnetic 24k gold-plated connectors and α (Alpha) silver-plated OCC conductors. The GT2 Pro is a USB 2.0 cable beautifully designed...
Un vrai plus
Utilisé pour relier un Dac Audio GD AS-1T au streamer Volumio Rivo qui au passage semblait guère plus performant qu'un USBridge signature avec se câble la qualité audio à été magnifiquement améliorée dans toutes les fréquences, c'est vrai que sa fait cher du mètre mais la qualité gagner est vraiment à la hauteur, seul bémol la connexion côté usb.A est un peu trop libre et bouge un peu une fois connectée. Bravo et Merci à Audiophonics pour votre site fabuleux qui fait rêver chaque à fois.
Gorazd K.
Excellent for the money, the sound and quality of production are as expected. The only thing is that it drains the phone battery a little more than expected.
