Thierry W.
Enfin de l or rapide ,transparent et neutre!!!!!
Bonjour ,schuko ETI avec un vondita et une iec 004 , sur mon alimentation ,resultat la ETI a une tonalité fine, tres rapide, tres transparente, detaillé, beau timbre du haut, vraiment differente des autres or ( fi38 or ,iego or, etc) Elle est plus neutre ! Je la conseille avec une 004 oyaide , pas trop sur une barette, une des meilleures schukos que j ai entendu avec la 004 oyaide . 004 ,ETI; FI38R mes fetiches
Excellent for the price
I swapped out my Isoacoustics Orea's today with these babies and the clarity and detail I was sorely missing has returned in spades. Save your money from Orea's and buy these. I'll be back for another 3 sets for my pre/power amps. Sadly the speaker spikes are too short for my required speaker height.
ISOACOUSTICS OREA BRONZE Vibrations Absorber Isolator Ø50x29mm (Unit) IsoAcoustics' Orea series of vibration absorbers eliminate unwanted vibrations and provide greater sound clarity and accuracy. The Orea is ideal for use with electronic devices...
Not great
Just my my Gaia's, these isolation devices are very expensive and after a long time trying to get used to them they serve, to me, to muddy the sound. I swapped them out with SuperSpike feet and the clarity I had missed from my music returned immediately.
ISOACOUSTICS GAIA I Vibrations Absorbers Isolators 100kg Ø62x49mm (Set x4) IsoAcoustics Gaia I vibration absorbers improve clarity and soundstaging for speakers or subwoofers weighing 100kg or less. They feature a machined stainless steel body with an...
Not great
Hi have spent about a year trying to get used to these devices and will be going back to spikes. The very subtle low level details are missing in my music and, for me, they offered very little over the €50 spikes I had used under my very heavy floor standers.
Željko N.
MUNDORF ACS1150GY ANGELIQUE Wiring Cable Copper / Silver / Gold 1.5mm² Grey Mundorf ACS1150GY ANGELIQUE is a high-end wiring cable with conductors made from a mix of copper, silver and gold for maximum conductivity. This model,...
One of the best conductors for DC power supply, despite being in PVC.
Željko N.
IAN CANADA LINEARPI PRO SOLO Ultra-Low Noise Linear Power Supply Module 12V / 5V / 3.3V 5A The LinearPi Pro, an evolution of the Linear Pi MKII, is an ultra-low-noise linear power supply capable of delivering high currents. This is the dual model corresponding to...
Perfection!
Tested on a router, 12V. An incredible improvement compared to the Ifi iPowerX. All aspects of the sound are noticeably enhanced. I can now hear details in many places that I didn't even know existed. Dynamics have improved, and the soundstage has expanded.
I strongly advise everyone who hasn't tried a good power supply on their router to do so immediately. They can thank me later. The improvement is comparable to a much larger investment in another component. (Of course, this all makes sense if the rest of your system is on a higher level.)
Christophe H.
Qualité, robustesse, praticité
J'ai branché mon Dynavox en "reverse" pour distribuer la source de ma platine CD sur 2 ampli différents, qui ont leurs enceintes respectives.
A l'oreille, le Dynavox semble quasiment transparent, je n'ai noté aucune perte de signal dans le spectre audio.
J'ai passer l'appareil au générateur BF afin de de récupérer le signal de sortie sur oscillo, tout est ok.
Le rotacteur est de très bonne qualité, il est très doux et les coupures des circuits sont nettes et franches, l'ensemble de cet appareil est bien construit et de bonne qualité.
Vous pouvez acheter les yeux fermés.
Dirk S.
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply 220V to 12V 1A 25VA Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply...
Excellent product, fast delivery
I am using the power supply to feed my turntable Thorens TD1500. Even I don‘t hear a significant improvement in sound, I am quite sure, the quality of the 12V DC output of this linear power supply is much better in comparison to the power quality of the plug-in switch mode power supply, which was in the scope of delivery of the turntable.
Matthieu B.
Produits conformes et de qualité, emballage au top, très protecteur des produits. Livraison rapide et bénéficiant d’un suivi précis. Bravo et merci !
Mathieu B.
MUNDORF ACS1250GY ANGELIQUE Wiring Cable Copper / Silver / Gold 2.5mm² Grey Mundorf ACS1250GY ANGELIQUE is a high-end wiring cable with conductors made from a mix of copper, silver and gold for maximum conductivity. This model,...
Mieux qu'espéré!
Câble doublé pour faire des jumpers, aigu ni mou ni trop agressif, résultat parfait!
Eddy P.
Amélioration et aération
J'étais en RCA avec un octavio stream g1 sur un marantz pm 6003 et une paire de dittons 442 recapé. Le son était bien mais depuis que j'ai mis le topping e70 velvet en action ( câble optique sur l'octavio et USB sur le pc ) le son est plus aéré et la scène sonore plus précise avec une meilleure séparation des instrus . Très content de mon achat . Prochain upgrade l'ampli pour aller chercher plus de chaleur et dynamique. Certainement un pm 8006 ou un marantz ki .
Jean Luc V.
IBASSO KLEE Dynamic In Ear Monitor IEM Ø10mm 22Ohm 112dB 20Hz-40kHz Silver With the Klee, iBasso is offering dynamic in-ear earphones with a stainless steel body and a magnetic-lithium alloy membrane driver, a technology usually found in much more...
Incroyablement bon
Ces écouteurs sont super bien réglés et délivrent un son incroyable.
Pour moins de 70 € on a absolument rien à lui reprocher.
bruno j.
juste incroyable
Monté avec des connecteurs VE512R et VF512R . ce câble vous donne envies de réécouter toutes vos playlists , mes enceintes triangle élypse sont littéralement transformées , du 3 D chez moi ,es ce le Graphene ? Jai passé commande d, un deuxième câble avant rupture de stock. Pour résumer avec ce câble le volume sonore est plus fort ,parfait pour une écoute a bas volume sans perdre les micros détails, ou même l émotion qu' il donne (London Grammar ou Hanne Boel ) on a l 'impression que les artistes sont chez moi .Je n 'ose pas imaginer le résultat sur du matériel plus haut de gamme .Câbles très rigide ,merci pour les 15 cms en plus offert par Audiophonics
Gérard B.
Buffer Audio type YAQIN SD-CD3
Après des écoutes attentive et relaxante, pour bonifier votre source que ce soit un CD, une platine Vinyle ou un DAC Bluetooth ou autres sources.
Ce tube 6SN7EH est le digne héritier des « NOS Vintage » hors de prix et rarissime.
Comparé à Une paire de "Sovie t » estampillé avec l'étoile « B 477 P" et dans les clous...
L’Electro-Harmonix Gold à une écoute plus détaillé précise musicale, une voix magnifique très intelligible, des basses maitrisé mais bien présente. Il faut un petit rodage d’une vingtaine d’heures.
Sur un Buffer de marque Tekron Italia la paire d'Electro-Harmonix Gold fait des merveilles.
Sur un ampli HIFI ou Guitare je ne doute des mêmes résultats.
Ne vous prenez pas la tête achetez en neuf...
Rafa P.
Great for inside speaker wiring
Awesome cable. I am also very satisfied with the service from Audiophonics.
Marco R.
THINKYA JA-310 CD
The player looks quite nice considered the price.
It connects via toslink to a pair of Klipsch "the fives" and audio quality it's excellent for my taste, much better then the same songs played via BT from my phone to the same speakers.
I give 4 stars because after I have bought the player i discover that a newer version is already out (JA-310R) at same price and include an infrared remote
Rafa P.
Rafa P.
Great cable
I am very satisfied with this cable. The service from Audiophonics has been fantastic.
Dominique R.
Nette amélioration du son
Bonjour, j'ai acheté 2 câbles Pangea secteur, car ils étaient en promo et que je souhaitais depuis longtemps avoir des câbles secteur haut de gamme. Je n'ai pas été déçu et j'ai même, pour l'instant reporté le renouvellement de mon matériel au niveau Ampli, car le son est amélioré par ces câbles en précision, clarté et détourage. J'en achèterais deux autres car mon projet est : deux amplis mono de puissance et un préampli certainement le monocéros de chez Audiophonics. En attendant, j'ai un son super. Attention, la section de ces câbles est énorme, on est surpris au déballage et ravi par le son. Autre aspect, la prise femelle tient très bien sur les appareils, pas de jeu, donc une bonne connexion, donc un plus pour le son. Je recommande et à mon avis ce n'est pas forcément la peine d'acheter plus cher...
Daniel D.
contre pointe sous enceinte
Installés sous des grosses THIEL CS 3.7 munies de pointes avec en plus une petite plaque de liège de 1cm très souple posée sous la contre pointe. Agit(légèrement) sur la scène sonore, instrus mieux détourés, son globalement mieux posé donc efficace. Permet de gratter encore un peu sur le rendu... trés bon rapport qualité/prix.
Excellent en tous points
Acheté suite aux bonnes critiques et je ne suis pas déçu, il remplace très avantageusement un audioquest G2. Ma config est modeste, un yamaha as701, PI3 avec DAC HAT ES9018 couplé aux très méconnues Highland Aingels 3205.
Le G2 écourtait les aigus et surtout le registre du grave, avec un médium un peu scintillant.
Le CANARE 4S11 à tout remis à sa place, un grave plus présent, un médium chaleureux et ouvert, ainsi que des aigus plus fins et ciselés. Scène sonore plus large mais un poil moins transparente. Mais, vu le gain général, surtout quand on monte le son, le G2 devenait agressif alors que le 4S11, tout est SANS agressivité.
Que du bonheur, un cable naturel et un poil chaleureux dans les médiums!
La qualité de construction du cable est excellente... Avant le G2, j'ai eu du triangle opéra, le CANARE enterre, et de loin, l'opéra et le G2.
J'ai trouvé ce qu'ill me fallait et Audiophonics a été généreux dans sa coupe, merci à vous.
Prix contenu, qualité excellente, foncez !
Elom G.
NJR MUSES8820 Dual OPA DIP8 (Unit) The OPA MUSES8820 has been developed by the specialist manufacturer NJR. It is an operational amplifier optimized for high fidelity and professional uses, thus offering very...
Edit avis du 05/11/2024
Le muse 8920 est préférable à cet AOP: plus de précision, de transparence et de tenue dans les graves
Igor C.
the bananas fit perfectly into the rca connectors, the only complaint is that they are long, so they cannot be pushed all the way
olivier r.
Très bon mais pas neutre
bande passante très équilibrée, léger voile dans les aigus provenant d'une petite coloration, légère mais néanmoins identifiable sur un système qui privilégie une restitution naturelle.
FRANK D.
OYAIDE NRF-005T Noise Suppressor Adhesive Tape Pulshut 4m Oyaide NRF-005T is a noise suppression tape using PULSHUT® (high performance non-woven textile) material developed by Asahi Kasei Corporation. This is a revolutionary...
Produit mysterieux... Mais tant efficace.
Des fois il suffit juste d'essayer et voila que je confirme que ca fonctionne a merveille.
Faut juste ne pas en mettre de trop.
Cordons secteur sans blindage? Un pourtour de ce produit cote recepteur et le tour est joue.
FRANK D.
JANTZEN AUDIO SOLID CORE Speaker Cable Copper 2x1mm² 2x0.5mm² Ø6.85mm Jantzen Audio's Solid Core is the perfect speaker cable for cost-effective bi-wiring. It features four pure copper conductors divided into two 1mm² and 0.5mm²...
Impressionnant.
Solid core has always been a favourite of mine, be that for LS cable, interconnect or as a hook-up wire.
It simple sounds "better" in any way that matters.
The fact that 6N purity copper is used certainly helps.
I used silver "tube" connectors to finnish them but that too is worth a review all of its own.
Well done Jantzen.
Jukka M.
Very good banana plug
Easy to use, has two screws, very good contact with wire, good contact into socket. This is now my favorite banana plug!
Peter H.
Maybe the best at its price?
I can only compare it against a Supra Trico coax cable, and in comparison this Audiophonics Canare is better. It renders the soundstage bigger, with more detail, but also a more smooth sound and with more nuance. The difference was obvious, so I highly recommend this in its price point as it does nothing wrong to my ears.
Stéphane C.
Shanling mini CD : une usine à gaz
Lecteur nomade Bluetooth bien construit et aux performances sonores excellentes. L’engin reste lourd et encombrant. Son gros défaut : de trop nombreux réglages et fonctions pas vraiment indispensables desservis par un ergonomie catastrophique. L’écran est minuscule et la navigation tactile hasardeuse entraine de très nombreuses prises de tête avant de pouvoir passer à l’écoute. Moins d’options et une petites télécommande basique aurait été bien plus fonctionnel. Prix finalement élevé pour un produit perfectible. Interface Eddict Player à l’avenant, c’est à dire inutilisable pour les non geeks.
Valery R.
LUNDAHL LL1544A Audio Transformer (Unit) This Lundhal LL1544A audio transformer is a general-purpose line input audio transformer that can be used for a wide range of applications. In particular, it can transform a...
Idéal pour installation home cinéma à tubes
J'ai utilisé ces transformateurs pour assurer une séparation galvanique entre un préamplificateur Harman Kardon™ Signature 1.0 et l'ensemble des étages de puissance à lampes.
Le résultat est impressionnant, plus de ronflement mais conservation d'une excellente dynamique. La bande passante de ces transformateurs dépasse largement celle de l’audio.
Søren Brolin T.
Mr.
Haves used this amplifier for 8 month now and upgraded today from LM4562 (this was the stock op amp at that time) to OPA1656 in the buffer stage. The amplifier got even better than before, especially voices has more natural sound and body. It’s a fantastic amplifier, it delivers plenty of clean power with 100% control and dynamics.
Janez G.
DYNAVOX TW-4 Digital Stylus Force Gauge 0.01g - 200g +/-0.01g This Dynavox TW-4 scale is designed to weigh your phono vinyl cells. Thus, it offers a high precision measurement over a range of 0.01g to 200g, with a tolerance of +/-0.01g. It...
Janezg
Beautifully made and easy to use.
Manuel Campos A.
MCA hifi
Son : Très détaillé, cool avec une bonne dynamique. Tombe articulée. Fait taper du pied... Parfait pour le câblage intérieur ou extérieur, l'interconnexion.
Antony C.
TANCHJIM ONE DSP In-Ear Monitors IEM Dynamic Ø10mm USB-C 126dB 16Ω 7Hz-45kHz These affordable Tanchjim ONE DSP in-ear monitors feature dynamic Ø10mm drivers and a low-frequency design.
Un son neutre et détaillé
Ces intras Tanchjim offrent 1 son neutre et détaillé des plus agréable tout comme leur port dans les oreilles. Ils ne conviendront pas aux amateurs de profil extraverti avec des basses et des aigus mis en avant.
3 étoiles car le câble semble fragile et a nécessité 1 retour au SAV. Hélas la deuxième paire montre aussi des signes de faiblesse. Le son se coupe parfois, de façon aléatoire ! Dommage … Pas pris en charge par le SAV, déçu par le produit.
Limite
Difficile au dessus de 2,2cm de diamètre.. les gaines rouge et blanche sont plus extensible
michel O.
commande et livraison et offre pour amateur audio
Merci à l équipe Audiophonic pour le sérieux; du traitement du suivie des des commandes et du délais rapide de livraison ...de vrai pro.
Très satisfait, également de votre ''catalogue de choix audio large et pertinent...Merci MO
laurent C.
excellente qualité
Finition et qualité du produit
laurent C.
utile ou pas ?
Personnellement, je n'ai pas noté d'amélioration concrète ou audible avec ce produit
Claus O.
The best purchase I've made in many years
I have heard many more expensive power cables and there has been an improvement in the sound, but this cable is to date the one that has given me the biggest improvement for the least money, in comparison to the Swedish SUPRA power cable which I have paid significantly more money for does not have the improvement in the sound at all, I immediately experienced an improvement in the bass, midrange and upper treble and 3D was fantastic, the only negative thing I can say is that it had a little emphasis in the upper treble, I could not hear that before... I do not hesitate to recommend this cable to others who may be skeptical about whether there is really anything to gain from power cables mounted cable with Oyaide plug P-046E & C-079. they were so fantastic that I compared it with the Power cable from LessLoss which costs 10 times the price, here LessLoss was a little better, but the tonal character was similar
regards Claus Olsen
Marc M.
SHANLING M1 PLUS DAP High Fidelity Digital Music Player DAC ES9069Q Bluetooth 5.2 LDAC 32bit 768kHz DSD512 Silver Shanling's M1 Plus is a technical and aesthetic evolution of the M1S high-fidelity digital music player. This Plus version benefits from an improved digital/analogue conversion...
Excellent DAP
Excellent DAP : neutre, belle image stéréo, tonailté parfaitement équilibrée, aucun bruit de fond, en bref, le nirvana tel que je l'imagine.. Je l'utilise avec un Moondrop Starfield et l'ensemble est magique . Egalement une fonctionnalité intéressante : arrêt programmable : idéal pour les utilisteurs qui, comme moi, s'endorment avec de la musique !!
Les bémols : autonomie un peu limitée (7 heures environ avec prise 3.5 mm), et prise casque semblant un peu "loose" : A voir dans le temps.
Marc M.
bien pour un DAP d'appoint
Ce DAP est parfait sauf sur un point : aigus assez prononcés et difficilement régalbles avec l'EQ. Fonctionne bien avec un casque Truthhear x crinacle Zero, ce casque ayant des aigus assez doux d'où un équilibre tonal correct. Donc attention au casque utilisé.
Je'utilise donc ce combo en ballades avec l'immpression de ne rien avoir en poche du fait de la taille de ce DAP.
olivier r.
Rendu très flatteur mais coloré
Monté par sertissage sur fiches Viablue, écouté pendant trois jours.
Système à moyen rendement enceintes 94db et amplification à triodes EC33C en SE. Source CD et streaming.
Premières écoutes un déconcertantes car rendu très flatteur dans l'aigu, avec beaucoup de présence, de détails et de relief dans le grave et le médium. C'est en passant plusieurs oeuvres de sonates pour violon et piano (CD labels Calliope, Paladino, Deutsche G et streaming) que je comprends que ce rendu fleuri dans l'aigu rend toutes les oeuvres semblables avec une sonorité des violons systématique et un peu "électronique". J'appelle cela une coloration, même si dans ce cas précis, plutôt discrète car on ne ressent pas de voile sur le médium, qui s'en retrouve pourtant un peu freiné, matifié. Plusieurs allers retours de cables sur l e long confirment mes impressions initiales, l'écoute me fatigue et m'agace. Cela pourra convenir à certains, mais pas à moi, je retire donc ce cable de mon système pour revenir à un rendu certe un chouilla plus cru, mais plus naturel et vivant.
super génial
Après avoir commander le cable hp Ludic carbon franchement c'est top que du bonheur allez y les yeux fermer sans regret année 2025 merci
Olivier B.
Étonnants !
Ils ont remplacé avec bonheur les aop d'origine dans mes blocs mono Fosi Audio V3 et dans mon DAC Topping D10s.
Grosse évolution de la qualité sonore dans les 2 cas, désormais je ne me pose plus de questions sur d'éventuels upgrades de ma chaîne hifi, j'écoute la Musique.
Olivier B.
Très étonnants !
Pour faire au plus simple, ils remplacent sans discussion mes blocs mono MC30 Mcintosh. Je redécouvre toute ma discothèque.
Karim M.
Excellent câble pour HP
Le câble Mogami 3082, que j'utilise pour mes câbles de modulation comme pour les HP, étant en rupture de stock temporaire sur notre site préféré, je me suis laissé tenter par le Neotech NES-5009 pour essayer ce cuivre breveté monocristallin qui m'intriguait. J'ai recâblé avec des Celestion Ditton 9 SE de 1995, recapées, puis l'ai comparé au câble français ELBAC HP225C (1.8e/m). La différence de prix (4 fois plus cher) est complètement justifiée.
Ce câble japonais est excellent et musical, équilibré, précis dans la séparation des instruments et leur timbre, très dynamique mais doux et offre une énorme image sonore qui efface les enceintes au profit d'une présence acoustique et une transparence enthousiasmantes.
Je partage donc ce coup de cœur avec d'éventuels audiophiles aventureux, curieux de découvrir ce brevet japonais de cuivre ultra pur qui ne me semble pas du tout marketing, pour le coup, et vais en recommander, avec du Mogami 3082, pour comparaison.
Il faut préciser qu'il est difficile à dénuder car très solidement fabriqué - et joli en bleu. Un coup de briquet sur la partie de gaine à enlever fera gagner du temps sans abîmer les micro-fils.
En bref, excellent câble pour câbler en interne et en externe des enceintes qui le méritent. Les Ditton 9 SE se sont réveillées de leur long coma et donnent tout, joyeusement, grâce à ce câble de première qualité.
Commandés mercredi, reçus vendredi en montagne. Merci à Audiophonics.
PS : pour les intéressés, détails de l'installation et du morceau test :
Lecteur CD Denon DCD685
câble de modulation en Mogami 3082 (20cms*2), âme centrale plus, tresse moins et fiche RCA or)
ampli vintage Luxman L215
câble HP Neotech NES-5009 en deux fois un mètre, sans fiches bananes
Frank Zappa and the Mothers of Invention - album One size fits all. Morceau Inca Road. Blues baroque survolté.
Appareils et câbles japonais, enceintes anglaises, musique américaine et auditeur français : la musique ne connaît aucune frontière!
Karim M.
Câble correct pour son prix
Acheté pour essai (prix : 1.80e/m, retours et marque française) ce câble, très facile à dénuder, est tout à fait correct pour son prix. Montés en un mètre de longueur derrière un lecteur CD Denon DCD685, un ampli vintage rénové Luxman L250, précis et puissant, et sur des enceintes Celestion Ditton 9 special edition, recapées et recâblées, ils m'ont semblé déséquilibrés au profit des basses fréquences, un peu grasses et trop peu définies à mon goût. L'image stéréo est cependant très bonne, ouverte et présente et les autres fréquences mieux rendues, avec un léger voile et un léger manque de précision. Pour le prix, ça sonne tout de même bien. Mais j'ai aussi acheté 2 mètres du câble Neotech NES-5009 (même section de 2.5mm, à 7.9e/m) pour comparer : la différence de prix est largement justifiée : le câble japonais, utilisant un cuivre monocristallin breveté qui m'intriguait, enterre le précédent de manière très sensible. Avec exactement le même montage et le même morceau très chargé et dynamique (Zappa and The Mothers of invention, inca road de l'album One size fits all), la dynamique est supérieure, l'image sonore homogène et très définie, les instruments parfaitement détourés (et ils sont nombreux) et les étagements sonores très précis, au profit d'une image stéréo ample et vivante, avec des basses tendues et chantantes, des médiums moins en avant et des aigus plus soyeux et plus du tout métalliques (tweeter à dôme en titane). C'est avec ce câble neotech que j'ai recâblé les Celestion Ditton 9 et j'ai bien fait car il est tout simplement beaucoup plus musical et agréable à écouter.
En bref, le câble Elbac HP225C est à réserver, d'après mon test, à une installation manquant de basses, par exemple de petites bibliothèques comme les Eva de Davis acoustics ou équivalentes et un ampli comme le Pioneer A-209R (assez sec) ou équivalent. Avec cet ensemble moins précis, ce câble est tout à fait satisfaisant et ses défauts corrigent ceux des autres éléments.
RICHARD L.
Le courant passe.
Prise très qualitative, c'est du sérieux et c'est aussi du lourd, ça pèse, la plaque frontale est très épaisse aidant probablement à une réduction des ondes électromagnétiques. L'arrière de la prise n'est pas plus profond qu'une prise Legrand standard. Les borniers sont assez grand pour accueillir chacun 2 fils de 2,5mm² (voir plus). Concernant le son, l'apport est indéniable, on perçoit une scène sonore plus profonde, la micro dynamique est améliorée, des micros informations apparaissent, les voix sont mieux incarnées. Il faut attendre quelques jours en laissant les appareils allumés pour que tout s'installe complètement. Je n'ai pas essayé les prises japonaises, mais le rapport qualité/prix de celle-ci est excellent. (Cable Furutech Empire, Furutech TP80ES NCF, Chrord Qutest, Primaluna Dialogue II, Cabasse Sampan 311/13.
Leandros B.
A real upgrade!
I use them at my triangle genese lyrr crossovers as an upgrade.
Simply excellent!
Leandros B.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 68µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Excellent vfm
I use 4 of them at 68μf as an upgrade for my triangle genese lyrr crossovers at the woofer and midrange section. The sound now its more natural, full, clear and dynamic then before. Worth every penny
