iouri C.
Au final déçu.
Antoine S.
CD Player Upgrader
Michel R.
Parfait pour mon usage
eric b.
ARYLIC UP2STREAM MINI V3 Bluetooth 5.0 WiFi Receiver Board DLNA UPnP AirPlay The Arylic Up2Stream Mini V3 is a WiFi and Bluetooth 5.0 receiver that will allow you to easily stream your music from any connected device. Practical, it allows you to limit...
très simple , plein de sorties possibles , numérique et analogiques.
eric b.
ARYLIC DAC BOARD ES9023 DAC Module I2S RCA 24bit 192kHz for Up2Stream V3 This tiny Arylic DAC Board digital-to-analog conversion module takes an I2S signal input and outputs it to stereo RCA. It is based on an ESS ES9023 chip, supporting PCM streams...
joli son
Jean Philippe L.
Nice product
Comparing the price it is a very good cable, nice definition comparing with expensive cable its worth to buy.
Jean Philippe L.
Very nice product
Well if you think for the price is worth and good definition overall, silver and copper combination very nice!
Mark G.
Well worth the investment
Definitely an improvement with my Chord Qutest when using with a linear power supply over the power from my iMac. Smoother mids & highs and no hash or artefacts. The Qutest requires constant 5V power to its USB port.
If your DAC only requires power for the initial USB handshake like my Topping D70, you can use any outside power source to make the connection then disconnect the power to this adapter after startup and leave the adapter in place, it will then only get data from your computer or other source.
Highly recommended!
Associées à de la soudure mundorff a 10% d’argent ces fiches sont sans concurrence.
Une petite gaine thermo pour renforcer et embellir le tout et vous avez un ensemble au RQP imbattable.
Je recommande sans limite
Bien mais
C’est vrai que pour le prix vous avez un bon câble qui fait le job.
Maintenant si on le compare avec des câbles haut de gamme, il ne peut pas rivaliser.
Naïvement, je me suis fié aux commentaires élogieux qui mettait ce câble sur un piédestal, écrasant la concurrence à plat de couture et j’ai eu tort.
Après un rodage de 30 heures il ne sait pas bonifié.
Je l’utilise en mono câblage avec des bananes cuivre argent comme recommandé dans les avis utilisateurs.
Il est agressif dans les aigus
Un médium pâlichon
Des basses correctes. sans plus.
Bref, Il ne tient pas la comparaison avec des câbles à 10/15€ le ml voir moins cher acheté sur ce site.
Je vais attendre encore 20/30 heures pour voir si ils se libèrent, mais j’ai un gros doute.
Par contre en modulation les câbles Canare sont excellent.
anael g.
DAYTON AUDIO PS220-8 Speaker Driver Full Range Paper 40W 8 Ohm 96dB 40Hz - 25kHz Ø22cm The Fountek PS220 full-range loudspeaker has the particularity of producing both bass and articulate, balanced midrange, as well as extended highs. The full-range concept...
belle surprise
achetai pour une 2 vois DIY se dayton ps 220 et une alternative intéressante à une compression 1.4 pouce !
le but étant de concevoir une enceintes simple en 2 vois avec le moins de composant possible .
grave 38 cm 18 sound
medium & haute fréquences dayton audio ps 220
coupure 380 / 12 db grave 6 DB large bande .
volume grave 160 litres bass reflex volume ps 220 25 litres clos .
autre large bande en ma possessions ( pour comparé au dayton ps 220 )
fostex fe 206 médium plus chaleureux mai plus compliquer à mètre en ouvre sonorité asses marquer .
supravox 215 version sans bicone !! médium bien en place sonorité naturel nécessite un tweeter ou un moteur 1 pouce !!
dayton audio ps 220 médium naturel bien en places un vrais large bande capable de travailler sans tweeter !! je le mesure jusque à 20 000 hz chez moi !! je le qualifierai de polyvalent même si je considère qu'il et presque indispensable de rajouter un renfort de grave comme moi avec un 38 cm à haut rendement pour relevé la coube en bas . ou l'utiliser tout seul avec un filtre bouchon et indispensable pour atténuer la monter de la courbe ! pour ma part je préfère l'option n 1 avec un 38 cm .
bref pour conclure se large bande et une belle surprise sa construction et sérieuse et de qualité la mesure et vraiment propre et il à rien à envier à un 215 ou fe 206 de fostex !!
le medium et propre en place rien et mie en avant ont peu se passer sans problème de tweeter au final se large bande me permet de construire une enceintes simple et vraiment audiophile à haut rendement avec un prix contenue !!
Philippe S.
Bluffant !
Très satisfait de mon achat ; utilisé avec un Nad c316bee et des enceintes Cabasse Chaloupe et transport cd avec sortie coax sur le sud et un PC en Linux audiophile
Les oreilles ouvertes
Sans soucis.
Apparemment c'est moi qui ai eu le dernier bout !
y'en a plus pour le moment et ça se comprend. Je ne sais pas si ça améliore le son ; en tout cas ça respecte totalement. Il faut bien 290° pour souder et la soudure est mate... comme l'argent ! J'ai soudé en XLR un SommerCable ABEDO et j'ai bien le résultat promis, clarté Détails et douceur. Pour moi c'est la meilleure soudure pour le son.
Fred F.
Comme toujours, merci à M. David Aubert pour ses précieux conseils : cet ampli remplit toutes les cases de ce que je recherchais. Fonctionnalités, son, tout est bon dans ce petit (vraiment petit) appareil pour un rapport qualité/prix extraordinaire.
Gerard G.
Bien que je n'aie pas trouvé de différence à l'écoute avec le ES9028, ce DAC fonctionne bien.
A noter que je n'exploite pas encore toutes ses possibilités.
Seul reproche, le connecteur à 40 broches qui a été soudé complètement de travers, cela ne gêne pas le fonctionnement mais c'est très moche.
Gaetan P.
Avec des Triangle Lymna Plaisir le son est de haute qualité
Avec des Triangle Lymna Plaisir 90db le son est de haute qualité
J'ai un caisson de basse Canton 50/100w 85db
Et le tout s'exprime sans rien en retrait
La connectique est génial ainsi que la télécommande
L'USB est reconnu en plug and play
J'aime le réglage de la tonalité aigu et basse avec en plus des réglages prédéfinis
le seul point négatif est qu'il ne s'éteint pas automatiquement en cas d'oubli
Benjamin N.
impossible de retirer la SD un fois insérée
C'est n'importe quoi de sortir un appareil comme ça au 21eme siècle.
Une fois la carte insérée, c'est simplement impossible de la ressortir!
Sinon, pas d'images d'album dans les listes de mon coté (juste un logo M4A), alors qu'elles sont présentées en lecture - donc rechercher un titre d'un album, c'est compliqué ...
ergonomie à revoir de manière générale (idle, boutons sur le coté = fausse bonne idée, navigation liste ...)
Zeferino I.
Potentiometer
Everything as I imagined.
Fast delivery..
Thanks to the team for the support
Zeferino I.
Potentiometer
Fast delivery..
Zeferino I.
Potentiometer ALPS
Fast delivery..
Can only recommend it ..
Zeferino I.
3 Way Screw
Fast delivery..
Zeferino I.
PCB for ALPS
Fast delivery..
Zeferino I.
Knob black
Fast delivery..
Zeferino I.
OPA
Fast delivery..
Zeferino I.
Potentiometer ALPS
Fast delivery..
Alain L.
TUNG-SOL 12AU7 / ECC82 Tube (Unit) The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This one proposes an open...
tung sol 12au7
Excellent ! pas de bruit, même à niveau élevé, son parfaitement modulable en jouant sur le gain.
Alain K.
Câble coaxial 75 Ohm, 24 K
Ce n' est pas un câble haut de gamme certes, mais il fait parfaitement son travail. Le prix est abordable, la finition est parfaite et l' esthétique engageante. Assez long, blindé et pas trop rigide pour bien s' adapter aux endroits où il doit passer.
Reçu rapidement, merci Audiophonics.
Alain K.
FiiO K5 PRO.
Je me suis fié aux avis déjà émis sur differents sites au sujet de cet ampli casque/DAC et je ne suis pas déçu. Il est facile d' installation et on comprend très vite son fonctionnement. J' utilise des casques de 300 Ohm et il les drive facilement. Esthétiquement, c'est à l' appréciation de chacun mais électroniquement il est parfait. Mon achat a été envoyé rapidement. Commandé le jour A, reçu le jour C. Je mets donc Audiophonics dans mon carnet d' adresses.
Antonio C.
Ça vaut le détour et l'investissement
Mon avis jusqu'à présent:
À propos du produit lui-même AZ910:
✓ Superposition plus distinctive de la musique
✓ Plus de facilité, d'air et d'énergie
✓ Meilleure clarté et transparence
✓ Neutre (ne donne pas de couleur artificiel)
✓ Une bien meilleure séparation
✓ Des basses agréables (très bien définie)
✓ Plus décontracté
✓ Beau son haut de gamme
Le son est dynamique, musical, rythmique et d'une résolution harmonique inégalée offrant aux mélomanes une nouvelle dimension dans le plaisir de la musique.
Ma configuration est:
• Amplificateur intégré - Rotel RA1592 (200w en 8Ω) +
• Lecteur de CD réseau / Super Audio Technics SL-G700,
⁃ connecté avec Oehlbach BALANCED NF AUDIO XLR CABLE XXL SERIES (remplacé par Oyaide).
⁃ Haut-parleurs Cabasse Altura Bahia (efficacité 94db, réponse en fréquence 50-25000Hz), impédance 8Ω avec minimum 3,2Ω) - (très difficile à maîtriser, le son peut facilement devenir un peu clinquant et trop incisif, difficile à soutenir trop longtemps) -
⁃ J'ai essayé avec des câbles Audioquest impossibles à entendre avec des enregistrements moins bons, ça devient clinquant et trop incisif), pour les haut-parleurs et les interconnexions mais ils ne se accorde pas très bien à ma configuration.
⁃ actuellement connecté par The Chord Company - Epic Speaker Cable.
Il existe des différences fondamentales entre les câbles d'alimentation utilisés. Actuellement essayé avec les câbles standards fournis (différence moins importante que dans ma conclusion); veuillez noter que Technics à un câble standard (avec terre) avec des conducteurs de 3 mm (notoire pour un cable standard).
J'ai pensé utiliser ici le câble d'alimentation OYAIDE TUNAMI GPX-R V2 (quelqu'un a-t-il une bonne entrée comment ils se mélangent avec AZ910?).
Pour le Rotel, c'est encore plus délicat car il fourni avec un cable standard de 1mm!. Incroyable pour un tel amplificateur d'avoir un tel câble!
L'idée ici est de passer au câble d'alimentation AC Viablue X-60 Silver (très beaux commentaires et avis sur celui-ci, et principalement très neutre).
Christian C.
Excellent préampli.
Rapport qualité/prix imbattable. Musicalement bien supérieur au L-PASS2 et largement aussi bon que le Audio-GD A2. Il redonne vie à deux amplis Rega Exon3 qui attaquent des enceintes 3 voies perso équipées d'un boomer 30cm, d'un médium à dôme Visaton et d'un tweeter également à dôme Athom.
Pour conclure, encore du très bon matériel Chinois.
Jean Louis A.
Canaré 4S11 en monocablage sur Cabasse Brick M8
Je doutais sur le rendu de ce cable , doute levé , tres bon Cable pour le prix .
Aéré , beaucoup de details dans les registres
apporte des graves plus prononcés sur les cabasses Brick M8 et secs , comme je les aime
Homogène et neutralité.
Exelent aes ebu XLR blindé. Équilibre tonal dynamique et surtout très musical. Même avec un dac r28. Écoute pleins de détails bonne image stéréo profonde et large. Du grave tendu et détaillé à l aigus filant haut sans dureté. Il se fait oublié. RQP exceptionnel. Essayé sais l adopté sans préjugé au vus de son petit prix. Comme le disent la plupart des commentaire se cable donne beaucoup de plaisirs. Attention tout de fois à l utiliser sur un système équilibré. Si non il mettra en avant les qualités et bien sûre les défauts même faible. Il révèle tous. Sur mon xray et mon dac il a mis en évidence le manque d équilibre entre grave et l aigus trop descendant.. J ai modifier le câble secteur en changeant les prises iec et schuko avec des Viborg rhodium et changer les fils de connexion de la sortie coax numeriqudu xray CD lecteur par un monobrins argent de 0,5mm. Tous est devenu plus musical et équilibré. Le grave est à nouveau bien à sa place et les hautes frequences bien intégrée.s etait une faible différence. Mais la tous et beau transparent et équilibré. Merci à audiophonics de proposer des petites perle rare avec se câble révélateur.
Romain P.
Juste pour répondre à un avis, le 3103 sera parfait dans un système moyen de gamme, mais vous vous rendrez compte avec un système plus transparent, qu'il rajoute des harmoniques, avec un son légèrement coloré, manquant de vitesse et de précision face au 3082, qui lui, peut sembler trop dégraissé suivant le système, en fait il ne l'est pas, le problème est ailleurs...
Je ne donnerais pas les modèles mais voici les marques qui se sont effondrés face à lui (athom, viard audio, atelier acoustik, audioquest, atlas, elecaudio et j'en oublie tant d'autres...
jean michel G.
TX C2 I2S to I2S LVDS HDMI interface module This small module will allow you to retrieve an I2S signal and then output to HDMI I2S LVDS. The interface supports DSD to enjoy very high resolution files.
Acheté pour faire un simple test en I2S, module excellent, très bonne qualité. Je vais le passé en 3,3v pour encore l'améliorer.
Thierry O.
conforme à la description
rien n'a dire joli petit cable
Thierry O.
tres bon produis
fonctionne très bien et livre avec un cable jack
Thierry C.
Très pratique !
Très pratique pour rallonger des cables audio sans les repasser comlplètement. Isolé, de bonne facture, c'est parfait.
Commande traitée ultra rapidement par Audiophonics, merci !
Pascal A.
Deoxit
J'utilise depuis trente ans
je n'ai jamais trouvé mieux pour nettoyer et refaire les contacts, le très grand plus est qu il n'est nécessaire de refaire le nettoyage après trois mois comment beaucoup d'autres produits qui refont le contact au premier coup de bombe , mais au bout de 3 mois il faut recommencer , si (l'interrupteur) n'est pas mort mécaniquement , ressort de maintien cassé par le coup de bombe "***" qui a dissous la graisse du mécanisme ) - seul reproche un peu cher !
Joscha O.
MONACOR SPH-200KE Speaker Driver Midbass 80W 8 Ohm 90dB This SPH-200KE speaker from MONACOR is a low-midrange driver with a Kevlar fiber cone. Its nominal impedance is 8 ohms and its power handling rating is 80W.
Perfect chassis
I bought them a couple of weeks ago and now inserted them into my speakers. They do a fantastic job!
Jean-Paul C.
cable
Cable au look sympa , dommage que usb-a flotte un peu sur le port micro . Livraison et traitement commande au top .
Franklin N.
Very good cable, soft move, thick, perfect for what I needed.
Franklin N.
Perfect top
Top all good, good material and works perfect. Was with some issues what to do and this product solve my problem. Many thanks. Very quick shipping!
Patrick d.
Great little Headphone Amp
I'm using this Amp with my 'PSB M4U 1 32 Ohm' and it sounds fantastic, never harsh but always a very good wel placed and smooth sound. The build is very sturdy and good parts where used. For the price this is a very good amp and even compared to more expensive amps I've heard ... well it's just a very good Headphone Amp d(-_-)b
Jean-Claude E.
Le branchement des deux cosses Ph & N n'est pas très génial et empêche de remettre la prise la plus proche. J'ai préféré souder ces deux fils au milieu de chaque barrette. Une fois cette modif faite, bon produit.
Jean-Benoit K.
Excellent petit Dac
En plus il est autoalimenté, pas besoin de transfo !
Philippe A.
l'écoute est plus sereine, plus naturelle.
je pense en prendre un autre pour mon zappiti one 4K hdr.
je recommande,
Attila S.
Antonio M.
Domanda
Deve essere collegato nel seguente modo ?
Spina RCA all'estremità del preamplificatore: schermo + conduttori blu a terra RCA. Conduttori rossi al segnale RCA.
Spina RCA all'estremità dell'amplificatore: conduttori blu - messa a terra RCA (schermo tagliato corto, non collegato). Conduttori rossi al segnale RCA
Pedro Antonio C.
Useful
Good balance between price and quality. Delivery really fast, customer service very good.
Pedro Antonio C.
Working with Piano 2.1 the sound is really good. I recommend it
Pedro Antonio C.
Delivery and the customer service were really good. Working with Kali Reclocker is a really gamechanger.
Pedro Antonio C.
I bought it by mistake because I have a Raspberry Pi 3 but it was easy to adapt it.
The delivery was really fast
Albert R.
Produit non complet
Je tiens à félicité l'équipe d'audiophonics pour leur réactivité. J'ai reçu le produit non complet et ils me l'ont renvoyés rapidement. Merci encore.
