iouri C.
Au final déçu.
Antoine S.
CD Player Upgrader
Michel R.
Parfait pour mon usage
AUDIO BASTION REDLINE DAMPER Anti Vibration Damping Pads Aluminum / Silicone 41 x 17mm (Set x4) These stands for HiFi equipment and speakers effectively absorb the vibrations of your equipment. They are composed of a silicone pad, encased in a composite resin part, all...
efficace
Amélioration audible , libère beaucoup d'énergie et procure une musique vivante sur mon système , amélioration des détails . Ne pas hésiter à modifier la position de ces pieds sous vos appareils pour obtenir le son souhaité . Utiliser sous mes barrettes secteurs et sous l'ampli de ma chaine secondaire . Faire plusieurs essais et ne pas en mettre forcément partout en fonction du résultat désiré . Très bon rqp ; à essayer avant de vouloir remplacer un appareil , peut redonner un coup de jeunesse a votre système pour une somme modique .
Boris K.
GUSTARD X18 DAC ES9038PRO XMOS I2S CPLD Accusilicon Bluetooth 5.0 32bit 768kHz DSD512 MQA Silver Gustard offers with its X18 a versatile and extremely powerful DAC, capable of high quality digital/analog conversion for the most accurate and faithful sound reproduction.
Gustard X18 is a brilliant DAC!
I want to say right from the start that the Gustard X18 is a brilliant DAC! I am a fan of classical music and jazz and often attend classical music concerts. I've been using the cheap but fantastic Khadas Tone Board DAC for a few years now. My audio system consists of a PC, Khadas Tone Board DAC, Van Den Hul 3T The River interconnect cables, Marantz PM8006 amplifier, Canare 4S11 speaker cables and Graham Chartwell LS6 speakers. I've been looking for a replacement for Khadas lately, so I've been testing a few DACs in my system. They were the Cambridge Audio CXN V2 Network Player (sounds excessively fat, its stereo image is very blurry and lacks detail in the treble), Sound Carrier DAC Tube (sounds beautifully analog, but with muddy bass and veiled treble), SMSL D300 (has nice mids, but has shallow bass and veiled highs) and the TOPPING D90 III Sabre (has beautifully detailed mids, but the highs are very veiled, and the bass sounds very artificial, making a grand concert piano sound like an electric piano). Many of them were better in some ways than my favorite Khadas, but none of them reproduced the sound of acoustic instruments and large orchestras in a natural way.
And then, because of the reputation that Gustard has among my friends, I decided to try the Gustard X18 DAC. Already after the first beats of Stravinsky's Pulcinella, I knew that my Khadas had received a worthy replacement. The Gustard X18 sounds very neutral, has a very deep and authoritative bass, beautiful soft mids and detailed and open highs. A large orchestra sounds very natural, the stereo image is deep, clear and transparent, and the drum, cymbals and triangle sound clean and naturally sharp and have optimal volume. Brass instruments sound naturally shrill and raspy, while strings and woodwinds sound very faithful and have a great timbre. Orchestral highs sound powerful and authoritative with punches in the bass like I've never experienced before in my system.
I have no experience with expensive DACs like Chord Dave, Mola Mola Tambaqui, Nagra Tube DAC, DCS Bartok or Bricasti, but I know that the Gustard X18 sounds absolutely amazing for 669 EUR.
If you're a classical music fan and looking for a good but not too expensive DAC, grab the Gustard X18 while it's still on the market. Well done Gustard!
Boris K.
GUSTARD X18 DAC ES9038PRO XMOS I2S CPLD Accusilicon Bluetooth 5.0 32bit 768kHz DSD512 MQA Black Gustard offers with its X18 a versatile and extremely powerful DAC, capable of high quality digital/analog conversion for the most accurate and faithful sound reproduction.
André G.
Câble Mogami hpw3103
Câble plutôt bien équilibré utilisé dans le médium aigu et d un très bon rapport qualité prix. Merci (encore) à Audiophonics
Fabien M.
J'ai rajouté des ferrites
J'ai rajouté des ferrites aux 2 extrémitées
Fabien M.
Le bourdonnement des hautparleurs est passé de "Wouuuu" à un légé "chhhhhhhhh"
Réduction des pics de fréquence:
50Hz: -18 dB
105Hz: -20 dB
115Hz: -15 dB
David T.
Je suis parti pendant trois jours, j ai oublié D éteindre l amplificateur....
La précision sonore de cet appareil est supérieur à un halcro dm66 .
Les dernières écoutes étaient :
- Jazz in thé pawnshop
- Pink Floyd ( meddle)
- Daft punk ( ram )
- Elton John ( lockdown session ) .
Nous connaissons souvent sur nos systèmes hifi , de temps à autre, de petites améliorations. La , c'est sur toute la bande passante. Testé bien-sûr avec une des meilleures paire d'enceintes mondiale. Audiophonics disent avoir testé leurs amplificateurs sur les haut-parleurs qu ils commercialisent.
Vous pouvez brancher tous les types D enceintes.
Des gens se plaignent de certains effets de loupes .
Si vous possédez des enceintes standards, achetées chez hypermedia, les effets indésirables seront bien présents, mais si vous branché du grand haut de gamme comme il existe peu , l ouverture sonore est sans doute la cure de jouvence la plus adaptée que vous pouvez donner à vos haut-parleurs !!!!
Les Wilson Audio sont des enceintes très riches, rapides et avec peu D égal sur le marché, vous me direz : des enceintes aussi chers avec un amplificateur à 1800 € . Non.... Et bien si !!!!
Jamais je n est entendu auparavant .
Le monde hifi a peur de la classD.
Vivre avec son temps.
Eemeli T.
Good overall quality
Bought these to replace Norsone Arran RCA cables. The quality seems very good - the cord is quite flexible and covered with thick braided polymer material. Connectors feel sturdy and make a very tight and secure connection.
Eemeli T.
Does the job
Works as supposed - simple and easy to use as atrigger device. There are a couple of setbacks, though - the device is quite bulky and needs a lot of space around it so be prepared to buy a IEC13-IEC14 male-femaleextension cord. Another con is the tolerances of the connectors - the plug side is tiny bit too small and tends to wobble when plugged in and the connection does not feel as secure as it should. Same goes with the input side which is a bit too loose.
Håkan W.
Den är av dom bästa diy steg som jag har testat och då har jag testat många...
Håkan W.
En av dom bästa slutsteg som jag har testat och jag har testat många diy steg
Excellent Dac reçu 24h après commande et aussitôt essayé
Excellent fait regretter l'achat de produits plus cher
merci Audiophonics
Excellent Dac
Reçu 24 h apres commande et aussitoy essayé
Siniša B.
Outstanding LPS
I previously upgraded to a switched power supply, but moving to this incredible LPS (TERADAK) linear power supply has been a game changer. The improvement is absolutely worth it. The soundstage has become wider and more spacious, with tighter, more defined bass. Overall, an impressive upgrade. 5 stars!
Bruno L.
DC 9V Jack Filter with Supercapacitor to Jack DC This DC 9V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 4 supercapacitors 5F - 3.0V and an...
Utilisé avec un DAC Aune X1s GT (BT) connecté en USB à un PC (Win 11) équipé de la carte Matrix "element H" (drivers natifs pour les deux).
Ce filtre a permis de révéler toutes les qualités de ce DAC.
Le son est maintenant naturel, la musique est là.
Merci à Audiophonics.
Alexandre S.
Excellent rapport QP
En remplacement des deux NE5532 des canaux gauche et droite dans un Fosi Za3, le bon en avant est immediat:
+ de clarté
+ de séparation horizontale des instruments
+ aigus beaucoup plus fins
+ de basses (attention sur des HP déjà boomy)
Pour le prix, c'est imbattable
Frederic A.
Ca marche !
Caler entre un Nuc N95 fanless et un nuprime dac 9 ... Constat 1 : L'USB des PC est pollué bien comme il faut . Constat 2 : Je le garde.
Jean-Hugues B.
Echec total
Peut-être que l'appareil est efficace, je ne le saurai jamais : impossible de le connecter à mon téléphone Android (pourtant dernière génération).
A ce stade, 80€ mis à la poubelle.
Il se pourrait que ça fonctionne mieux sous iPhone. Sinon, je ne peux que déconseiller fortement.
johan s.
TRES UTILE
Améliore les performances du smsl su-1.
johan s.
Du haut niveau!
Je l'utilise (avec un bon adaptateur secteur payé 10 euros sur ce site) en coaxial entre mon lecteur cd DENON DCD-800NE et mon préampli Gustard P26 cela m'a dévoilé tout le potentiel de ce lecteur hifi sur les fichiers flac en lecture sur clé usb possible en façade du DENON. En comparaison lorsque je ne passe par le rca du denon les voix manquent de matières et le son de profondeur. Le dac intérieur du lecteur DENON n'est pas du tout à la hauteur et ce que je considérais comme hifi n'est plus qu'un son banal et la hifi je l'atteint grâce au Dac . Mes câbles rca sont des audiophonics à base de ELECAUDIO SC-221OCC, le son est mieux que celui obtenu avec des audioquest evergreen il est plus dynamique moins mate. il a plus de texture et d'aigue, aigue agréable naturel pas criard. Le audioquest manque d'aigue. Donc il ne faut rien laisser de côté pour profiter de son matériel comme la phase électrique et surtout l'acoustique!
Panos M.
SMSL RAW-MDA1 DAC 2xES9039Q2M Headphone amplifier Bluetooth 5.1 32bit 768kHz DSD512 MQA The SMSL RAW-MDA1 is a balanced DAC featuring two ESS ES9039Q2M chips and a USB XMOS XU316 interface. These high-quality components enable it to support high-resolution streams...
Excellent DAC
I am very pleased with the purchase, the DAC is very perfomant
Eugene G.
TOPPING EHA5 Electrostatic Headphone Amplifier Balanced 229Vrms Most electrostatic headphones offer excellent musical potential, but their performance is often limited by the associated headphone amplifier. The Topping EHA5 electrostatic...
Good entry-level electrostatic amplifier
This amp is a good match for my STAX Lambda SR-300 headphones. It drives the headphones effortlessly. Sound quality is outstanding, especially for classical music - every instrument is rendered with clarity and precision.
Janis S.
Bad connectors
Connectors ar to loose. Its a vaste of money.
pierre d.
FX-AUDIO DAC-A10 DAC ES9018K2M Tube Preamplifier 6N3 Bluetooth 5.1 aptX HD LDAC 24Bit 192kHz FX-Audio's DAC-A10 is a versatile, high-performance tube DAC/preamplifier with a relatively compact form factor. It is based on quality components such as an ESS ES9018K2M DAC...
Très bon et pratique
Préampli et récepteur bluetooth avec un son détaillée plutôt correct. Volume et contrôle tonalités font de ce petit appareil une tour de contrôle très pratique qui s'adapte très bien avec un ensemble hifi,même hétéroclite par exemple un lecteur cd, un ampli, un tuner et même un caisson de basse.
Voltage Display Voltmeter with Green LED 5-60VDC Ø22mm This voltmeter will allow you to monitor the voltage of a device. Its green LED display is easy to read. The voltmeter accepts voltages from 5VDC to 60VDC. Its...
Bonjour, les vis des deux contacts ont été serrées exagérément par le robot ou l'outil final, il faut de la poigne pour les desserrer avant de mettre les deux fils, et cela fait peur.
Poul T.
Banana Plugs Silver Plated Ø5mm (Pair) These low-cost banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers. The contacts are silver plated to ensure excellent signal...
Don't buy!
The spring loaded part sits completely loose on the connector, completely hopeless. This is not a bad product, it is an insult!
HIDIZS MS1 GALAXY Dynamic IEM In-Ear Monitors Ø10mm 32Ω 108dB 20Hz-40kHz Red Hidizs unveils its MS1 Galaxy in-ear monitors (IEMs), offering excellent value for money. They feature a dynamic driver with dual magnetic circuitry and a...
HIDIZS MS1 GALAXY
relatively decent headphones, performance-price ratio, completely sufficient for travel
Angelo P.
FOSI V3 MONO
I due ampli mono valgono molto di più del loro prezzo, sono potenti, trasparenti e silenziosissimi. Un vero affare.
Denis E.
Joli
C’est joli avec une apparence qualitative et ça transmet le courant… Bref ça fait le travail qu’on lui demande, mais de là à se lancer dans des envolées lyriques il y a un pas à éviter de franchir
Denis E.
AIYIMA TUBE-T3 Phono MM Tube Preamplifier 2x 6A2 Black The Aiyima Tube-T3 is a simple and affordable phono preamplifier for MM turntables. It features two 6A2 tubes and a three level gain control, 39dB, 42dB and 45dB, allowing it to...
Pas mieux que …
Cela fonctionne même si ça n’a rien de mieux que le préampli phono déjà présent dans mon ampli ROTEL A11 Tribute. Après pour le prix cela vaut l’expérience
Richard P.
Naturel
Tout est dit dans le titre.
Un Bonheur sur mon système.
fabio M.
IAN CANADA LINEARPI MKII DUAL Ultra-Low Noise Linear Power Supply Module 2x +/-12V +/-5V +/-3.3V 2.5A The Ian Canada Linear Pi MKII Dual is an ultra low noise power supply module delivering high quality, high current, versatile and scalable. It is one of the best linear...
10 e lode
Una ovzaione per questo prodotto.
Ho provato e dupgradato molte alimentazioni lineari, ma questa le batte tutte.
Non importa cosa gli diamo in pasto e dove lo poniamo, da il suo contributo sempre e comunque. Il servizio Ian Canada è ottimo e l'assistenza pure.
Li uso uniti agli ultracondensatori venduti sempre da audiophonics. Sia su dac RMA adi 2 liscio e pro, sched eusb audio, router, switch. Le collego ad alimentatori lineari da 5mv per portare il segnale a ripple a 0,8uV. 5mV sono ben 5000uV (questa è l'unita di misura).
Indifferentemente se uso un triplo lt3045 con 0.8uV di altre marche che costano anche tre volte tanto (in autocostrzione) Ian canada linerapi mkII da i risultati migliori.
Inutile pensare molto, prendete un alimentatore lineare e fat convertire il tutto a IAN canada linerpi mkII ed avrete il riultato sperato, anzi, sopra le vostre aspettative. Ho fatto molte prove, trasformatori, alimentatori lineari costosi, medi, da telefoia. Ian canada porta il sengale dove ha deciso.
Ecco che ora uso un alimentator elineare da 45ampere sui 15V per il mio pc auio video gaming, prendo i 15 volt da questo super alimentatore (dato per ripple 5mV sui 45 ampere massimi) li converto in 12 volt grazie a ian canada, passo per gli ultracondensatori audiophonics ed entro nel dac.
Prendo dal mio convertitore DC atx a(limentato in lineare dai 45ampere sui 15 volt) la usa uscita rail lineare di 12V e 5mV ripple massimo ed entro in ian canada linearpi mkII e pacco ultacondensaotri ed entro nella scheda usb audio del pc.
10 e lode.
Uso ovunque ian canada linerpi mk II.
Cestinato gli altri alimentaori lineaei anche da 1000 euro.
E' una autocostruzione, ma vale la pena. Per cambiere l'uscita dai 12 ai 5 volt i ponticelli posteriori vanno dissaldati con stagntore. Non da tutti ma fi fa.
Per erogare i 12 volt va benissimo anch un alimentatore lineare d 13,8 di stampo telefonico.
fabio M.
Ottimo risultato
Consigliatissimi.
Usati su alimentatore lineare IAN canada linearpi mk II con uscita a 12 volt per alimentare dac RME adi 2, dac RME adi 2 pro be fe. Per alimentare in 5 volt tramite ian canada linearpi mk II scheda audio usb da pc.
Per alimentare router e switch tramite alimentaotri lineari con lt3045, per alimentae nas con alimentatore lineare da 15 ampere con 5mV di ripple massimo ed ogni volta che sono stati inseriti è migliorata la resa.
Tolti e messi dal Ian canada linerpi mk II han fatto la differenza, anche il altre situazioni.
Portano l'mpianto ad una maggiore risoluzione.
Consigliati anche nel nas, router, switch! Per assurdo posizionati anhe solo li migliorano sia l'audio che il video del pc!
fabio M.
Buon Connettore.
Connettore dedicato alla scheda usb afx100.
Il connetore a primo avviso risulta economico, piccolo. Non ne ho trovati altri su audiophonics così ne ho presi più di uno.
Usato cavi alimentazioni neotech da 16agw singoli, passato per ian canada linerpi mkII e ultracondensatori, il tutto sempre audiophonics, il risultato apportato è ottimo. Molto meglio di spellare il cavo originale axf100 e collegarlo al linerpi mkII. Dundue l'abbinamento cavo neotech agw16 e questo connettore si è fatto apprezzare. Di chi sia la lode? Non si sa. Però è l'unico modo per potenziare l'alimentazione di axf100 e ne vale la pena.
fabio M.
ELFIDELITY AXF-107 Power Filter PCI Express / PCI Express 16x The AXF-107 module from Elfidelity is a switch mode power supply filter for computers connected in PCI Express or PCI Express 16x and designed to provide cleaner power to all...
Ottimo risultato
L'ho integrata in un contesto importante di pc alimentato in lineare con 45 ampere sui 15Vm, scheda usb AFX100, Ian canada linearpi mkII ed ultra condensatori per schda usb e per dac.
Montato a monte anche della scheda video l'intero pc già ottimizzato ha dato il risultato sperato.
Lo consiglio. Ne ha guadagnato anche il risultato video.
Mai avrei pensato che axf107 unito a afx100 potesse rendere così tanto.
fabio M.
Ottimo risultato
Devo ammettere che non ho fatto un up-grade singolo ma ho lavorato su più punti in un colpo solo ma il risultato è stato strabiliante. Ho un impianto veramente di livello.
Ho unito un alimentatore lineare da 45 ampere a 15 volt per il mi pc audio gaming, entro nel pc con un ripple a massima potenza sui 45 ampere con 5mV.
Ho un convertitore DC ATX che prende energia da questo alimentatore lineare e smista la corrente nelle varie tensioni sempre con un ripple massimo di 5mV sui vari rail. Ecco che il pc è alimentato con 5mV massimi di ripple.
Così grazie ad Audiophonics uso Ian Canada linearpi mkII più il pacco ultracondesnatori di Audiophonics uscendo dal rail dal DC ATX a 12Volt per alimentare a 5 Volt questa stupenda schedina USB.
Uso axf-107-power-filter-pci-express-pci-express-16x- di audiophonics a monte anche della scheda video
Sempre grazie all'alimentatore lineare da 45 ampere uso i 15 volt verso Ian Canada linerpi mkII (di audiophonics) ed il loro pacco di ultracondensatori verso il dac RME adi 2 pro.
Ho un gruppo amplificatore da 20 mila euro e questa scheda usb insieme al resto pronunciato ha alzato il livello di qulità in modo impressionante. Ciò mi ha permesso di tolgiere tutto il "digitale" dalla catenae la fatica di ascolto. Tutto scorre più fluido musicale, rifinito, apmio, trasparente, silenzioso.
Così ho potuto aumentare pure il finetuning nei cavi segnale, usb, potenza e alimentazioni in modo molto importante. 100 e lode per questa schedina.
fabio M.
MONACOR MDM-2 Speaker Damping Polyester 130g 63x33x3.5cm (Set x2) This environmentally friendly damping material for thermal and sound insulation is made of 100% Polyester fibres. It is therefore ideal as a sound absorber to be installed...
Ottimo smorzatore
Ne ho usato moltissimo in varie mie costruzioni, premio questo prodotto e contino ad usarlo in tutti i diffuosori e sub hi end costruiti. Come smorzamente, durate e pulizia del prodotto è ottima, come risultato pure. La difficoltà sta nello stabilire solo la quantità ed il posizionamento.
fabio M.
MUNDORF SUPREME SILVERGOLD OIL Capacitor 1000V 0.33μF The metallization of the MCap Supreme SilverGold capacitor foil is composed of pure Silver mixed with 1% very pure Gold. Gold modifies the crystal structure of silver and...
Il Re
Il Re dei condensatori, unito ad altri anche come bypass si fa sentire. Trasparente, aperto, musicale.
Cosa volete di più? Questa serie è la mia preferita.
fabio M.
Fantastici
Ne possiedo diversi per diversi ambiti, li recupero una volta usati e dismessi e tengono la loro parte adesiva. Non sporcano e si rincollano. Che dire. Ottimo prodotto dalle mille fruizioni.
Consigliato.
fabio M.
MUNDORF SUPREME SILVERGOLD OIL Capacitor 5.6µF The metallization of the MCap Supreme SilverGold capacitor foil is composed of pure Silver mixed with 1% very pure Gold. Gold modifies the crystal structure of silver and...
Il top
Quello che per me è il massimo, l'ho accoppiato a Duelund ed il risultato nel tweeter scanpsecak revelator è fantastico. Non potete bettere SGOIL, il resto sono sfumature e dipende dal contesto.
fabio M.
Ottima linea condensatori
Questo condensatore l'ho usato per il filtraggio di un medio di qualità, ma la stessa linea è stata usata da me sia in amplificatori valvolari che in serie al tweeter e nel segnale dello stesso.
Consigliatissimo, trasparente, aperto, definito.
fabio M.
Ottimo condensatore
Usato a pacco per un medio per passare dai elettrolitici di prova ai definitivi, 10 e lode. Il pacco è abbastanza importante visto che si tratta di circa 1200uf. L'ingombro non è dei minori ma se il vostro medio ed impianto vale, fate questo upgrade.
Usato la stessa linea in linea al tweeter ed il risultato è ottimo. Consigliatissimi.
fabio M.
MUNDORF MRESIST ULTRA Resistor 30W 1.5 Ohm The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all wirewound resistors, this film offers...
fantastica resistenza
Ho usato di tutto, anch ele mundorf supreme.
ma qui siamo al top del top.
Abbianoto al proprio radiatorino presu su audiophonics ha una resa incredibile. Nulla di più preciso, trasparente, perfetto.
Evidenzierà ogni particolare della riproduzione sonora senza filtri. Evidenzierà i limite del vostro impianto ma vi esorterà a trarne più benefici.
Nel mio caso è comparsa dopo il suo uso una leggera fitica d'ascolto rispetto la serie Supreme Mresit.
Da fare una colpa? NO! Il limite dell'impianto e la risoluzione ne ha giovato. Ho Migliorato l'impianto aggiunggendo alimentaotre lineari (grazie audiophonics), uso Ian canada su DAC, scheda USB, pc, router, switch nas. Il risultato ora grazie a queste resistenze è formidabile! Dopo le alimentazioni lineari ho potuto pure aumentare il livello di fine tuning, cavi segnale, usb potenza, alimentazione in modo molto spinto godendo di una riproduzione nel tempo sempre migiorata.
Le consiglio, prima di loro a volte certi upgrade erano vani. Mi hanno aperto la strada verso il paradiso.
fabio M.
Ottimo condensatore
Serie Supreme Evo oil, si fa notare per la presenza di oil per la sua maggiore fluidità, usato per i medi ha dato quel tocco che senza olio manca. Ottimo rapporto prezzo qualità, sopra la media ed evidenzia che più si spende in Mundorf più si ottiene.
fabio M.
Ottim condensatore
Personalmente l'ho usato in un medio non diretto al segnale, ma fa il suo lavoro egragiamente, ottimo rapporto prezzo qualità, come sempre Mundorf conferma che alla salita del prezzo ci siano pi aspettative. Sopra la media in raporto qualità prezzo rispetto altre marche. Pulito, trasparente come ci si aspetta.
fabio M.
Ottimo condensatore
usato per un medio in un sistema di medio alto livello risulta sempre sopra le aspettative, Mundorf tiene sempre ben presente il rapporto prezzo-resa. Da capire il contesto dove va inserito, chiaramente la serie con olio rende di pi ma non è detto che in sistemi morbidi gradiscano l'oiio sempre.
fabio M.
Indispensabile
Unito alle Mundorf Mresist per la gestione del mio medio e tweeter anche posizionando due resistenze nello stesso dissipatore è molto tempo che convivo felicemente. Ho un impianto hi end con componenti importanti, uso come amplificazione un Hegel H30A dedicato solo a medio e tweeter, prima avevo u hypex Nc2k. Mai un problema di affidabilità anche a volumi sostenuti per tutto il giorno.
fabio M.
MUNDORF MRESIST SUPREME MRES20-22 Resistor 20W 22 Ohm The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer...
Trasperenza
La miglior trasparenza ad un prezzo ed ingombro contenuto, tra le mie resistenza preferite. Chiara.
fabio M.
MUNDORF MCAP SUPREME EVO SILVERGOLD Capacitor 1000V 0.47µF Since 2015, the MCap Supreme EVO SilverGold capacitors have been the undisputed top-of-the-line product from Mundorf. It combines all of the brand's technical strengths, such as...
Ottimo Condensatore
Si potrebbe quasi definire un bypass, ma in agigunta ad altri condensatori può modellare il suono a nostro piacimento. è una certezza.
fabio M.
Ottimo microfono
Ho usato questo microfono in sieme a programmi di misura per i migliori impianti audio che conosco fra i miei amici. Ottimo risultato ed ottima affdabilità nel tempo. Il miglio impianto settago è con diffusori Avalon Saga, 4 subwoofer da 15hz e 130db con fine tuning importante ed impianto nel suo insieme estremamente curato. Ottimi risultati, chi non ha un microfono e non seta il suo impianto non sa cosa può fare e dove può arrivare anche lavorando in passivo oltre che in attivo.
