Vraiment bon, surtout pour ce prix Vraiment une très bonne surprise : -très bon son ! très ample dans les graves sans aucune exagération et sans devoir ajuster...
Very good preamplifier for the money It is pretty transparent even with the stock OPAs (in my case LM49720). Highly recommended (for the money). It is difficult to...
The Ian Canada UcConditioner Pro 2025 5V is a supercapacitor signal conditioning module operating with a 5V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimising stability and maximum current delivery.
Aune's N7 is a powerful, discreet, fully balanced Class A headphone amplifier-preamplifier. It's based on a combination of JFET transistors for headphone amplification, an independent Class A preamplifier function and R2R volume control for optimal audio signal processing. The use of JFET transistors delivers a warm, smooth sound that will delight tube...
The Aune Evo N5 is a network player based on an architecture that favors signal processing using audiophile components. It features an ES9039Q2M DAC chip, an NXP Cortex-M7 processor, an Intel FPGA and a Qualcomm QCC5125 Bluetooth chip, as well as FIFO technology and a dual PLL internal clock for optimized jitter management.
This socket and circuit breaker tester allows you to test your installation safely. Among other things, this product can detect a lack of earth, phase reversal, or a lack of phase or neutral. This small tester can save lives and prevent fires, and should be included in every electrician's toolbox.
With its VIMI I, Silkline unveils a discrete integrated amplifier ideal for small to medium-sized rooms, being able to deliver 2x50W of power at 4Ω. This Class AB amplifier delivers a warm, delicate sound, and features a design incorporating Japanese Toshiba 2SC5198 and 2SA1941 transistors. Efficient and relatively compact, the VIMI I will fit...
The Dayton Audio DAX66 is a 12-channel Class D multiroom amplifier. It offers considerable output power for a wide range of spaces, with 12x 50W under 4 ohm and up to 100W under 8 ohm in bridged mono mode.
These high-quality aeco ASP-1935G spade plugs, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts, waved for better connection, are made of 99.9% pure copper with 10µ gold plating, ensuring both excellent conductivity and perfect resistance to oxidation.
These high-quality aeco ASP-1935R spade plugs, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts, waved for better connection, are made of 99.9% pure copper with rhodium plating, ensuring both excellent conductivity and perfect resistance to oxidation.
These high-quality aeco ASP-1935S spade plugs, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts, waved for better connection, are made of 99.9% pure copper with silver 120µ plating, ensuring both excellent conductivity and perfect resistance to oxidation.
These very high-quality aeco ASP-1956 spade plugs, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts, waved for better connection, are made of 99.99% pure silver, ensuring perfect conductivity.
This CCHD XO 9C adapter module from Ian Canada, precision-engineered and manufactured to the highest standards, features custom-made gold-plated SMT pins that are robust and durable, perfectly matched to XO sockets, with pre-mounted power cleaning capacitors and a fully assembled PCB ready for use, making integration simple and clean.
This SMT XO 22C adapter module from Ian Canada, precision-engineered and manufactured to the highest standards, features custom-made gold-plated SMT pins that are robust and durable, perfectly matched to XO sockets, with pre-mounted power cleaning capacitors and a fully assembled PCB ready for use, making integration simple and clean. This adapter is...
The UcPure Pro from IAN Canada is part of the third generation of supercapacitor power supplies designed by the brand. It makes use of the huge 3000F or higher capacitance ultracapacitor pack to achieve an ultimate power supply performance.
This Pangea Premier XL Balanced XLR to XLR modulation cable is exceptionally well made. It is composed of Cardas Grade One copper strands with PE tube insulation and Al Mylar aluminium foil shielding, silver-plated braided copper and carbon-filled PE tube. The triple-layer shielding provides this cable with effective protection against RFI noise and EMI...
The Aiyima T20 is a simple yet elegant balanced preamplifier. It features two ECC83 tubes combined with LME49720 and OPA1612 chips to deliver the warm, smooth sound typical of tube amplification. For further convenience, the T20 includes a 12V trigger input and output, allowing for seamless integration into your audio system.
The Meze Audio 105 Silva is a high-performance open-back circum-aural headphone. Tuned with a perfect balance of musicality and refinement, the 105 Silva delivers clear, rich and engaging sound effortlessly. Transients are fast and articulate, bringing out complex details with natural ease. Highs extend gracefully, soft but revealing, while bass remains...
This T3-CB11 cable from Tago Studio for headphones has a 3.5 mm jack connector on one end and two 3.5 mm jack connectors on the other. This cable is designed to replace the cable supplied with the brand's T3-01 headphones.
The STA-HI END from EarAcoustic are in-ear earphones based on two dynamic drivers to offer excellent performance at an affordable price. The combination of a 6mm polymer composite driver responsible for the upper part of the frequency spectrum and a 10mm beryllium driver assigned to the lower parts ensures detailed sound reproduction and neutral timbre,...
The Mundorf AMT25CM1.1-R tweeter has been developed for integration into 2-way bookshelf or 3-way column speakers. It combines strong vertical directivity with wide horizontal dispersion, making it ideal for rooms with reverberant ceilings and floors. It is also the tweeter in the AMT range with the lowest crossover frequency. The AMT25CM1.1-R delivers...
The Dayton Audio HDN-8B will add a dynamic sound source to almost any surface or object. Exciter technology offers a universal and cost-effective alternative to conventional drivers, enabling sound reproduction virtually anywhere. Issues such as weather conditions, space constraints, vandalism, or visibility can be avoided or minimised through the use of...
EarAcoustic's SPA-PRO are in-ear earphones based on a dynamic driver with a dual N52 magnetic circuit and an ultra-thin, rigid graphene membrane, enabling fast transient response across a wide frequency range for consistent, dynamic and detailed reproduction across the entire frequency band. This results in neutral sound reproduction designed to cause...
Neotech's NES-3005G is a speaker cable incorporating 2 G-UPOCC composite conductors, a combination of OCC copper and graphene with a total cross-section of 2.62mm². This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at...
PSVane 845-T-MII/2 tubes are high-quality triode power tubes that can be used in class A, B and C. The MKII range of tubes uses a PTFE base, ensuring high stability and excellent insulation. The amber-coloured anodised aluminium collar surrounding the PTFE base prevents corrosion and fingerprints while giving this tube a prestigious design. The tube also...
With its N7 DAC EDITION, Aune offers us a versatile device that doubles as a DAC as well as a powerful, discreet, fully balanced Class A headphone amplifier-preamplifier. It's based on a combination of JFET transistors for headphone amplification, an independent Class A preamplifier function and R2R volume control for...
The Eversolo DMP-A6 Gen 2 is a HiFi network player that seamlessly combines outstanding sound quality with cutting-edge technology. More than just an audio device, it's a new way of connecting to the world of music. From hardware design to audio processing, every detail of the DMP-A6 Gen 2 has been meticulously designed for audiophiles seeking the...
This Viablue braided sleeve is suitable for cables with a diameter of 2 mm to 6 mm. It is ideal for protecting your high-quality cables against mechanical wear, tearing, twisting and the effects of prolonged exposure to light. Slide the sleeve onto the cables to be covered before assembling the connectors. Use heat-shrink tubing or an adhesive suitable...
This Viablue braided sleeve is suitable for cables with a diameter of 5 mm to 13 mm. It is ideal for protecting your high-quality cables against mechanical wear, tearing, twisting and the effects of prolonged exposure to light. Slide the sleeve onto the cables to be covered before assembling the connectors. Use heat-shrink tubing or an adhesive suitable...
This Viablue braided sleeve is suitable for cables with a diameter of 13 mm to 26 mm. It is ideal for protecting your high-quality cables against mechanical wear, tearing, twisting and the effects of prolonged exposure to light. Slide the sleeve onto the cables to be covered before assembling the connectors. Use heat-shrink tubing or an adhesive suitable...
This Viablue LS-2 Silver speaker cable has two conductors, each composed of 192 silver-plated OFC copper strands, ensuring maximum conductivity. The conductors are insulated with a PE sheath, offering the advantage of significantly lower electrostatic charge than PVC. Each conductor has a cross-section of 1.5mm² for a cable size of 3.5mm thick by...
This Viablue LS-2 Silver speaker cable has two conductors, each composed of 318 silver-plated OFC copper strands, ensuring maximum conductivity. The conductors are insulated with a PE sheath, offering the advantage of significantly lower electrostatic charge than PVC. Each conductor has a cross-section of 2.5mm² for a cable size of 4.5mm thick by...
This Viablue LS-2 Silver speaker cable has two conductors, each composed of 504 silver-plated OFC copper strands, ensuring maximum conductivity. The conductors are insulated with a PE sheath, offering the advantage of significantly lower electrostatic charge than PVC. Each conductor has a cross-section of 4mm² for a cable size of 5.6mm thick by...
With the Pure, Truthear offers high-performance in-ear earphones, direct descendants of the Hexa. Like their predecessors, they are equipped with a combination of four drivers, combining dynamic and balanced armature technology to effectively cover the frequency range, offering balanced sound reproduction with natural timbre and exceptional precision.
Designed specifically for the Eversolo DMP-A6 GEN 1 (Standard and Master Edition versions), the LHY Audio LPS-A6 MKII linear power supply stands out thanks to its high-end architecture, which is entirely hand-assembled. It incorporates a 30VA Multicomp Pro extremely linear voltage with low drop and reduced modulation, even under heavy load.
With the LD230TDR08, Atohm presents a high-quality subwoofer driver. The result of proven know-how and all the expertise acquired during the development and production of previous versions since the LD210, this latest generation LD230 ‘TDR’ embodies excellence in covering the 20Hz-300Hz band. Thanks to its advanced technologies, this 23cm...
With the LD230TDR08M, Atohm presents a high-quality subwoofer driver. The result of proven know-how and all the expertise acquired during the development and production of previous versions since the LD210, this latest generation LD230 ‘TDR’ embodies excellence in covering the 20Hz-200Hz band. Thanks to its advanced technologies, this 23cm...
The Moondrop PARA II is a planar magnetic headphones featuring Full Drive Technology (FDT) and large 100mm-diameter diaphragms. The result is rich, precise and dynamic sound reproduction, combined with a wide soundstage for a refined, immersive listening experience. Particular care has been taken to ensure exceptional sound performance in a modern design.
