Pierre Marie S.
AVIS SUR QUALITÉ ET MONTAGE
Rien à dire sur la qualité des matériaux et l’usinage. La plaque inférieure du boîtier aurait pu être un peu plus...
Gregory O.
Not copper
Waste of money. No copper anywhere on this plug as I filed it down and no copper.
Guillaume D.
Oubliez tous les autres
Ayant récemment acquis une paire de Chario Aviator Nobile, j'étais à la recherche d'électroniques à la hauteur de...
Customers reviews - There are 21053 reviews.
Henrik H.
Good with moderate volume, after correction.
Bought 2 for simracing(under chair), but then I tried it with some music, and I use them for that since almost every day.
I like bass, had a big sub, but now I dont have the space and privacy, so I use headphones with shakers, and they really are can provide the same or even better feeling that a good subwoofer can do, but more shaking with almost no audible volume, combined with a good low extension headphone, its the best thing to have. I work from home with my partner sitting next to me, and I can hear and feel my music perfectly witout disturbing her.
Now, its all nice and good, but it has its flaws and limitations, got a faulty one with a broken spider (they have a plastic spring that holds the shaking weight) and got that replaced, had no faults since, but i heard others are getting their spiders snap too, so must be careful with them.
They are also not the strongest performers, having a huge resonance spike around 33hz, and not having any low end extension, because it starts rattling.
I have switched firmware on my 3D printer calibrator (accelerometer) and made some custom apps and code, so I can measure the frequency response on my chair, and generated some PEQ curves with REW based on those measurements, and managed to get the response mostly flat, and its like night and day! Not just the same frequency overpowering, but nice resolution, better low extension, but.. still has no power, so I'm getting the new bigger brother, the 300 to replace the 2 small one, and planning to measure and calibrate the hell out of that too, and will put these under my footrest/pedal plate.
So overall, if you can smooth the response, its good enough, just a little weak. Without EQ its meh, but okay for simhub if you dial in the effects optimized for its curve.
Henrik H.
Does its job.
Bought it for BST-1 bass shakers, (simracing/music) but it was too weak for them, so I use it for smaller (15W) exciters now (Sim pedals), there its okay.
Had a faulty one that went up in smoke, got it replaced.
Knob is a little noisy when used, but other than that its okay, for the price for low wattage stuff, with integrated USB DAC its good value.
Henrik H.
HIFIMAN SUNDARA V4 Planar magnetic Open Headphone High sensibility 94db The Sundara Hifiman offers many benefits with its lightweight diaphragm, 94dB efficiency and 32 Ohm impedance for a wide range of use for nomadic or sedentary High Fidelity...
Love it!
Bought it with a Topping DX3 Pro+, really nice combo.
My first planar, heard great things about it, expected great bass, but when I tried it stock, it was meh.. overall better than my K7XX, but lowend was nowhere.
Then I applied an Oratory PEQ and added the linear subbass extension & ~10db extra for the bass shelf, and wow.. there it was!
Very nice clean bass, much better low extension than my K7XX
(Note that I have an overall negative gain to compensate for the bass, so I sacrifice some max volume for better bass, but im nowhere near maxing the amp, so its fine.)
So sound is great, bass iw awesome, also very comfortable, love it.
Cannot think of anything bad to say, would buy it again.
Henrik H.
Great Price/Value
Bought it with a Hifiman Sundara, mostly use it with my daily AKG K7XX.
It is perfect for both, I use software EQ to aligh them, and ASIO for low latency. (Gaming/Shaker setup)
Sound is very good.
One flaw is some of the segments of the display went bad, but its not affecting anything, and they are mostly off anyway.
Super!
Et non ! ce n'est pas le câble ultime mais on en a vraiment pour son argent. Pensez, pour a peine plus que le prix d'une jolie gaine. Vous hésitez encore ? Ce câble est excellent pour les montages courants mariés avec des connecteurs Amphenol qui lui vont comme un gant on a un champion du RQP ! Des timbres respectés, de la profondeur, c'est rare a ce prix comme par exemple son petit frère le lt2s qui n'est pas aussi réussi je trouve. Après si l'on veut titiller le hdg pour un peu plus de 12 euros avec par exemple le feu NEOTECH NEI-3004 Câble de modulation symétrique UP-OCC on atteint d'autres sphères, du raffinement, de l'espace, de l'émotion...
Bien mais...
Connaissant et appréciant déjà le L-4E6S du même fabriquant j'ai essayé ce câble et l'ai monté avec des fiches Amphenol trouvée sur ce site et qui lui vont à merveille. Un peu déçu car c'est moins bon qu'avec le star quad, on a moins de profondeur et des timbres un peu quelconques. Du coup pour le même prix je reste sur le L-4E6S STAR QUAD qui reste mon champion des petits prix, avec le Goblin aussi, parfaits pour mes montages courants et les raccords din-rca possibles avec les 4 fils.
Michel P.
Mis en aval d'alimentations à découpage stabilisées sur toute la ligne Internet et Ethernet (box-switch-décodeur). Son : augmente la richesse des harmoniques sur toute la plage du médium, son plus "analogique"(Quobuz via Bluesound), toutes proportions gardées à ce que l'on peut ressentir en passant sur un ampli à tubes ; en 5.1 (Netflix) meilleure spatialisation et enveloppement. Image : beaucoup plus nuancée et riche dans les couleurs, exemple : sur une image basique (tv par fibre) raccords de maquillage du présentateur TV nettement perceptibles, films via Netflix : profondeur, réalisme des teintes. Toutefois l'appareil est très léger et j'obtiens un meilleur résultat en l'isolant des vibrations, fixé sur une plaque de bois bitumée.
Jean Emmanuel H.
DAYTON AUDIO DC28FS-8 Speaker Driver Dome Tweeter 50W 8 Ohm 89dB 1600Hz - 20kHz Ø2.9cm This Dayton Audio DC28FS-8 tweeter is an improved version of the brand's silk dome tweeters, benefiting here from motor structure shielding and ferrofluid cooling.
Excellents
Montés en remplacements des tweeters Dynaudio de mes ASA monitor pro qui avaient lâchés après 25 ans de bons et loyaux services...le résultat est bluffant, pas de différences flagrantes avec les Dynaudio...à part le prix
Rien a redire
Je suis passé de la FI-E12L (G) à la FI-e46 (g), il y a bien une différence...c'est plus aérien, plus précis, plus fin, et sans agressivité
J'étais septique et le prix laisse à réfléchir, mais je ne regrette pas, après avoir essayé la p004 d'oyaide (pas mal mais fatigante), je suis conquis, et le plaisir d'écouter de la musique acru.
Fabien B.
Pas trouvé mieux à ce jour!
Fabien B.
Fait bien le job. Plus précise que mon ancien pèse cellule
Fabien B.
1877PHONO Z-LITZ100 Phono Headshell Leads Litz Wire 24k Gold Plated OFHC Copper 40mm (Set x4) These 1877Phono Z-LITZ100 cables allow you to wire a phono headshell in an efficient way. Using Litz wire, each strand of each conductor is isolated from the others to limit the...
En remplacement des câbles d'origine de mon bras SME 3009 et raccordés sur une Shure V15 type 4.
Micael C.
DC 5V Jack Filter with Supercapacitor to Jack DC This DC 5V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 4 supercapacitors 20F - 3.0V and an...
Vastly improve Google TV 4K
I added this little thing after a 5v/3A SMPS and a DC2.1 to USB C cable to my Google TV 4K. It greatly improved both the sound and picture. Love it!
Jean-Pascal H.
FOSI AUDIO LC30 Audio Selector Switch for Amplifiers / Speakers vu-meter Yellow With its LC30, Fosi Audio unveils an amplifier and speaker selector. In other words, it allows you to switch easily and quickly between two power amplifiers and two pairs of...
Fosi LC30
Beau produit mais il faut trop de watts pour que ça bouge dommage ça restera en déco merci au service technique car ça fonctionne sur un ampli classe G réponse très rapide et ça c'est super merci .
Jeanphilippe c.
Eversolo.
Appareil très complet sonorité exceptionnel. Je recommande. Livraison rapide. Merci audiophonics.
Thierry S.
TUNG-SOL KT120 Power Tubes (Quad) The Tung-Sol KT120 has a 60W dissipation tray, making it the most powerful tube in the 6550/KT88/KT90 family. A pair of these tubes in push-pull configuration can deliver...
kt 120 quad
Délai 1 semaine, peut mieux faire, mais ça va.
plus important, si la logistique lit ce message.
Puisque vous expédiez dans des cartons suffisamment larges pour mettre plein de garnissage de protection, autant mettre le produit fragile au milieu des protections. j'ai reçu le quad calé dans un coin sans protection sur 3 cotés.
c'est ballot et surtout risqué pour le produit.
Les tubes sont heureusement fonctionnels.
je rejoins un avis précédant sur la sonorité, pas top au début et qui s'améliore dès la 4éme heure.
grave bien présent mais plus propre, médium se calme et apparition d'un peu d'aigu. à suivre.
Ce qui est surprenant à ce stade c'est les détails qui apparaissent, jamais entendus avant. Je sort pourtant de GEKT 88 et 88 Z pourtant de très bon tubes fins et détaillés, mais là ça va un peu plus loin tout en gardant une tonalité "chaude".
seule réserve est justement sur la justesse des timbres
pour l'instant.
Techniquement, attention à bien vérifier que votre alim peut les supporter. Sur le cs 55 ça fonctionne bien mais ça chauffe le transfo.
il faut bien le dégager pour qu'il se ventile et même comme ça j'ai mesuré 50° sur le capot.
En tout cas, à ce stade, tout indique que c'est un très bon tube et pour la durabilité... on verra, et donc 4* pour cette raison.
Philippe s.
Je l’utilise pour connecter mon DAB sur le DAC de mon installation et c’est parfait. Merci Audiophonics pour le conseil et l’envoi très très rapide.
Philippe s.
Je l’utilise sur une platine Pro-ject et il a indéniablement amélioré ses performances : moins d’électricité statique, moins de bruit moteur. Le son me paraît également meilleur.
Frank j.
IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 5V The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply...
pure battery voltage
just as good battery thanks to the Ultra Capacitor
5 volts
equally good farad super 3 or ifi powerelite
Mika E.
MOONDROP PARA Planar Magnetic Circumaural Open-back Audio Headphone Ø100mm 101dB 8Ω 15Hz-53kHz The Moondrop Para is a high-quality headphone based on Planar Magnetic technology. It has inherited part of the structure of its predecessor, the Moondrop Venus.
Supraṇava
Ordering worked perfectly and delivery was superb fast to Finland. Ten points and a parrot badge:-)
Daniel D.
TINYSINE TSA7804B Class D Amplifier Module TPA3116D2 DSP Bluetooth 5.0 4x50W 4 Ohm The TinySine TSA7804B module is a four-channel Class D amplifier board with integrated DSP and Bluetooth receiver. Its TPA3116D2 chip is capable of developing 4x50W power at...
Nice, but needs noise reduction mod
I've built 2x 2-way active speakers with it and the result is awesome. The only issue was noise, which needed adjusting gain of TPA3116D2 by desoldering resistor 2 and replacing resistor 1 with 5.4kohm smd. They are under the heatsink. Would be nice if that was a default config or at least easy way of adjusting.
Pascal J.
IFI AUDIO ZEN PHONO 3 Phono Preamplifier MM/MC With the Zen Phono 3, Ifi Audio brings us the latest iteration of their renowned range of phono amplifiers. The Zen Phono 3 is a versatile, ultra-quiet phono amplifier with...
Suivi de mon 1er post
Je plussoie et même plus 1 étoile. Nouvel essai avec ma Technics sl-1500c et cellule Denon dl110, une MC haut niveau, le prépré sur le gain 2 : La grosse claque jamais entendu un vinyle sonner aussi bien, on retrouve la dynamique du cd , bien timbré de haut en bas, transparent à souhait, franchement les British ont fait un prépré au rapport Q/P imbattable . Pas étonnant qu'il soit déjà en rupture de stock, soyez patient il vous le rendra au centuple... Bonne écoute à tous...
FOSI AUDIO ZA3-48V Stereo / Mono Class D Amplifier TPA3255 2x150W 4 Ohm / 1x240W 4 Ohm This small, compact and powerful Fosi Audio ZA3 integrated amplifier has the particularity of being able to operate in both stereo and mono mode. It...
Incroyable à ce prix !!!
Vu les débats médiatiques sur cet appareil j’ai tenté l’achat pour un équipement de bureau. Je ne suis pas déçu du résultat avec des enceintes TRIANGLE COMÈTE 40TH.
Pour en savoir un peu plus avec un ami nous l’avons connecté et essayé sur du matériel beaucoup plus cher (chacun jugera de la qualité de ces appareils) Préampli ACCUPHASE enceintes B&W série 800 D4 câblage AUDIOQUEST dans une pièce de 35m2 et le résultat est tout simplement impressionnant au regard du prix.
Une écoute très naturelle sur tout les registres pas de limitation de puissance ressentie . Évidemment le niveau d’écoute était modéré mais suffisant.
L’amplification numérique c’est l’avenir. Je serai curieux de tester les blocs mon dans les mêmes conditions. Bonnes écoutes à tous. Philippe.
Raphaël G.
Très bon potar
En remplacement d'un potar classique. Y a pas photo c'est le jour et la nuit. L'image sonore a retrouve sa place (plus besoin de balance) avec beaucoup plus de détails et une bonne séparation des instruments. Pour le prix c'est parfait.
Kai H.
Excellent quality / price ratio with linear power supply
If you want best possible sound from this player you should use a linear power supply. With a cheap sync mode power supply sound was nothing special. With Audiophonics` linear power supply sound was very good. There was like a night and day difference.
Martin K.
Martin Kunchev
I waited a long time, but it's worth it. Thank you Audiophonics. Excellent sound and sensitivity throughout the range. Good strength for its size. They fit perfectly in my quad system. However, a notch filter is needed to cut the frequencies between 900 and 6kHz. Even though they are mounted in a suspended ceiling they sound better than in a box. I strongly recommend
Christopher S.
A superb power amplifier
Purchasing this power amp has delighted and astounded me, with it's performance. Wonderful power with a complete lack of distortion drives my PMC Twenty5/23 floorstanders with ease, I have not heard them sound so good. I prviously used Quad Artera Stereo and Cyrus Stereo 200, this surpasses them both. It is very transparent and highly resolving which was an issue with some music, so I switched my speaker cables to DNM Reson which is a revelation with this amplifier. Clarity, power, with a capability far beyond it's price.
Un stradivarius électronique?
Pour une écoute en fichiers dématérialisés, maillon central du système, l'interface est le coeur de l'installation. A acheter d'urgence . Gustard a créer une électronique digne d'un Stradivarius ! incroyablement musical. Et toujours la performance Audiophonics, au rendez- vous.
EVERSOLO AMP-F2 Amplifier Class D 2x250W 4 Ohm / 1x450W 2 Ohm The AMP-F2, developed by EverSolo in collaboration with the Starke Sound team, is a Class D amplifier based on the integration of the latter's innovative NS600 module. As a...
Ça me convient parfaitement.
N'ayant jamais eu de setup "audiophile" auparavant - je viens d'un T-AMP90 - je trouve le son forcément excellent. Associé à des câbles 1877PHONO NOVA-SPK et des "petites" enceintes Elipson Prestige 2i (sans doute le maillon faible de la chaîne), prenant sa source d'un DAC Singxer SDA-6 PRO2 par l'intermédiaire de câbles XLR AUDIOPHONICS OBSIDIAN, j'obtiens un son clair, détaillé et chaleureux associé à une bonne réserve de puissance. Vraiment impressionnant !
À noter également, la présence du trigger et un ploc quasi inaudible à l'allumage.
Impécâble
Très bon câble ; impressionnant.
YANN P.
De la transparence…
Je confirme les commentaires précédents, ce câble de par sa conception UPOCC est hyper transparent, vous allez obtenir un son en 3D avec une scène sonore étagée. Compter une semaine de rodage. Bande passante énorme. À recommander…
Jean Paul T.
AUDIOPHONICS DAW-S250NC Class D Integrated Amplifier NCore NC252MP DAC ES9038Q2M WiFi Bluetooth 2x250W 4 Ohm 32bit 768kHz DSD Versatile and powerful, we offer you with the DAW-S250NC an integrated amplifier with digital inputs to which you can simply add speakers to enjoy your music in the best...
Bluffant
Ampli surprenant, puissance impressionnante, son équilibré, très détaillé. Présence des voix très réaliste, basses quasi sans limites.
Alimente des enceintes "maison" basses de 38 cm et médium aigus large bande de 21 cm, sans faiblir. Rapport qualité prix excellent.
Pascal J.
Evaluation sur la série Cross-cap
Utilisées pour renover les filtres de mes vieilles Elipson Concept 1
dont les valeurs des condos chimiques avaient largement dérivées m'ont fait redécouvrir ces bonnes biblios . donc pour leur rendre justice j'ai remplacé le tweeter Audax par un Monacor
dt28n (en vente ici) = upgrade au top; du coup je refait les filtres de mes dynaudio emit 30 avec les Cross-caps & résistances Mox + câblage interne Canare 4s6 ( en vente ici).
je n'ai pas terminé, vos en dirait + une fois finies mais je n'ai aucun doute sur la qualité de l'upgrade. Merci à Audiophonics pour proposer tout ces composants très utiles pour faire évolué ces produits fabricants pas tout à fait aboutis afin de ne pas concurencer leurs gammes supérieures!!!
Pascal J.
6 étoiles si possible
Aussitôt reçu aussitôt installé avec platine audio technica at lp 120xusb et cellule at 95 basique une galette test que je connais très bien dans différentes configs : Chico Freeman: "The Search".
Effet Waouh! quelle transparence et la dynamique digne de mon lecteur cd (Denon 110 anniversaire). J'ai oublié de préciser que le pré-pré est alimenté sur une batterie Antec 5V,5A et non sur secteur. Cela sur ma platine la plus bas de gamme. Je me propose de l'écouter sur ma Thorens td 126mk3 centenial cellule Sumiko Oyster Pearl, galette Sassy & Quincy "you're mine you", Superbement silencieux ce pré-pré , défini, la merveilleuse voix de Sassie m'envoute. Pour faire court 10 stars et devrait faire de l'ombre à bien des pré-prés +++chers.
Me reste à essayer mes cell. Denon dl-110 & 160 Mc high.
Mille mercis à Audiophonics pour sa célérité d'envoi, 10 stars
pour eux, un vieux client qui a encore de l'oreille!
Vladimír S.
Aladar
Il ne convient qu'aux composants sources. En utilisation avec un amplificateur, on constate une légère diminution de la dynamique, une augmentation des fréquences aiguës et une présentation du chant plus dure (AVR/1000€). Branchez donc l'amplificateur directement sur la prise et utilisez cette multiprise pour les composants sources.
Vadim P.
Unique device
This is really a unique device, classic and solidly constructed, reminiscent of the Japanese from the 60s or 70s.
The sound quality is stunning, just as you would expect from a tube device, incredible resolution and dynamics, deep black in the breaks.
A secret type. I would just like a more stable cover (like the Cayin devices) for the tube and non-slip feet.
Martin K.
Ich bin sehr zu Frieden!
Bei der ersten Lieferung waren die Cinch nicht dabei. Nach dem ich 2 mal geschrieben habe, sind die Teile am nächsten Tag schon da (kann überall passieren, hier aber sehr schnell reagiert).
Die Cinch sind wirklich erstaunlich gut gefertigt. Ich hab in der Preisklasse noch nichts besseres gesehen (und gehört). Auch von den Toleranzen sehr gut gefertigt. Ich habe keinen Stecker gefunden der nicht passt.
Bis zur nächsten Bestellung
Alain C.
USB 5V Supercapacitor Filter USB-C to USB-C / USB-A This 5V USB filter allows you to obtain a clean power supply for your Hi-Fi devices thanks to two 20F - 3.0V capacitors as well as an intelligent buffer...
Sur Raspberry Pi 4 avec hat Hifiberry Digi + et tournant sous gentoo player : l'apport est notable. Indéniable même.
Le RP4 était déjà alimenté sur une alimentation linéaire Tomanek, mais en intercalant ce filtre, le gain est notable.
Éclaircissement de la scène, recul du bruit de fond, meilleure définition des instruments.
A conseiller donc, notamment pour ceux qui utilisent un RPi comme steamer.
seul bémol : tous les deux utilisant le même principe d'intercaler des condensateurs sur le flux DC, un peu cher en comparaison d'un filtre FX-Audio Susie, par exemple, qui embarque lui des condensateurs Nichicon pour 1/3 du prix.
Adam S.
NEOTECH NEI-3002 MKIII Interconnect Cable UP-OCC Copper Dual Shielded Ø10.7mm Neotech NEI-3002 MKIII is a twisted conductor cable combining UP-OCC single-crystal copper strands and silver-plated UP-OCC single-crystal copper strands. Each of the two...
wow this is brilliant
maybe the best interconnects i have tried yet ,very transparent and big musical sound ,lots of air and 3d
Bruno F.
ARYLIC UP2STREAM AMP 2.1 Amplifier Module 2.1 WiFi Bluetooth 5.0 Tone Control 2x50W + 100W The Arylic Up2Stream Amp 2.1 is a 2.1 channel amplifier with full wireless connectivity. It will allow you to use a subwoofer while enjoying the convenience of audio streaming....
Good sound, unstable Wi-Fi, both with Wi-Fi and cable. Volume changes on its own, I didn't understand why, I change volume and it's never instantaneous, the device appears and disappears on the iPhone's Airplay even when connected by cable, I have to turn it off and on to make it appear, there is no anti-pop function, it pops when it is turned on and off power supply, lots of bugs just consult the forum, good for those who like to look for problems.
lionel l.
Une tres belle qualité de fiches Banane
Bonjour ,
Très content de ces fiches dont le rapport qualité / Prix est plus que raisonnable.
Salutations.
lionel l.
Une tres belle finition de cable
Bonjour ,
Vous recherchez un embout séparateur pour vos câbles , audiophonics là.
Très content de mon achat.
Salutations.
Nathan B.
magique !!
j'ai le premier modèle depuis 1 ans et ceului là est sorti ....arrivé a la maison je le branche et constate effectivement une belle amélioration et pis le premier modèle je le range et ...par curiosité au bout d'un moment ....je rebranche le premier avec celui là ( pour voir ) ....bennnn ....ça marche encore mieux ducoup exactement comme les purificateur de secteur d' iFi trop bien
iFi c'est super comme marque ...ultra quali et leur produit son très efficace
Nathan B.
LITTLE DOT MKIII SE Tube Balanced Class A Headphone Amplifier The Little Dot MKIII SE, the successor to the MKIII, is a tube headphone amplifier that offers excellent audio performance with a signature specific to tube devices, namely a...
Méchant !! ^^
Mdr au début je voulais le refourgué car c'étais vraiment pas terrible et pis je me suis fais une raison ( patience du rodage ) au moins 150 / 200 h et pfiouf ( avec de bon tube (gold lion dans mon cas )
Mon intérêt pour cet ampli l'a emporter en comparaison avec le Xduoo ta 20 plus dans les paramètre de fourchette de prix , puissance , lampe , hybride , full symétrique ; sinon LD meilleur en réponse de fréquence ; meilleur thd et surtout dans mon cas .....pouvoir profité de merveilleux intra ( j'aime pas les casque ) parceque cet ampli gère incroyablement bien avec même une impédance de 16 hom ....ok y'a un peu de bruit mais dés que je monte le son na pu de bruit....mais un orgasme auditif ^^
donc dans mon cas il est couplé avec un fiio k9 ess pro en symétrique lol banché sur audirvana et dans les oreilles un merveilleux fiio fh9 plus tout un tas d'accessoire occulte d'audiophile histoire de bonifier ça ;)
pis c'est la claque ..y'a un peu plus de vie et de chaleur avec les lampes mais c'est gentil ....rien a voir avec les ampli full lampe donc ...par contre il envoi méchamment la purée et y'a rien de mou pour les style de son électro de fou furieux ( quand le kick tape je suis entre l'enclume et le marteaux c'est du pur délire )
meilleur imagerie espacement de la sène sonore ...puissance général incroyable il est trés clair rien rédhibitoire en terme de saturation disto sur les intra et pis par contre omg cette basse et se son générale saturé... plein...beaucoup de corp il amène une super texture et définition du son... vive la classe a
et merci a l'équipe d'auiophonics
Jacques T.
Ce produit est très bien conçu, performant et améliore nettement les performances de mon preamplificateur phono Musical Fidelity V90 LPS, par rapport au petit adaptateur secteur fourni d'origine. Le souffle est diminué, la scène sonore plus large, c'est un plaisir. Je recommande ce produit.
Cordialement.
Jacques
Thibault G.
Quelle efficacité !
Un ampli très compact pour la puissance qu’il délivre. Quel plaisir d’avoir un amplificateur en classe D.
Les entrées sont forcements numériques.
Un ampli de qualité qui rivalise et dépasse, en termes de qualité sonore, avec des amplis 2,5 fois plus chers (CAMBRIDGE EVO 150 par exemple).
L’ampli n’est pas spécialement beau, mais sobre et très efficace. Utilisé avec des Focal ARIA 936.
Audiophonics a su écouter les utilisateurs, le firmware a été mis à jour et la façade a été changée. Il n’y a donc plus de problème de « clac » (firmware) ni de son très aigu provenant de la façade lorsqu’elle était allumée (remplacement de la façade gratuitement que j’ai pu faire moi-même sans renvoyer l’ampli).
Un produit qui est simple, efficace et fonctionnel.
Pour les bricoleurs il est possible de prendre la version DA-S250NC (sans wifi) et d’y accoler un Raspberry Pi.
Je recommande ce produit et le service d’Audiophonics. C’est vraiment très agréable d’avoir un service support qui fait confiance à ses clients.
Excellente alimentation
Connectée sur un streamer WIIM à la place d'une alimentation 5v type smartphone, le résultat est bien supérieur. C'est plus doux, mieux articulé, plus naturel sur tout le spectre.
Très efficace immédiatement !!
J'ai déménagé d'une maison vers un appartement en résidence.
Mon ensemble hifi est donc devenu trop puissant pour mes voisins.
Je pensais acheter un préampli passif Khozmo pour calmer la dynamique de mon ampli à tubes Octave V40 avec son alim black box intégrée.
Le changement des tubes KT88 pour des EL34 n'a pas suffit.
Ni même en plaçant des tubes 6V6 de 15 watts, toujours trop puissant, trop de dynamique.
Mes enceintes sont des Cabasse Caravelle d'un rendement élevé de 94 db.
Mon préampli phono est un clone Audio Note à tubes et mon lecteur CD un Sonic Frontiers SF-CD1 à tubes aussi.
Après recherche, je suis tombé sur ces atténuateurs passifs à petit prix.
Et ben, je vais économiser l'achat de l'excellent Khozmo !!
Placés 2 paires directement sur les entrées de mon ampli RCA phono et RCA CD, réglés à -10db le changement est instantané.
Je peux désormais manipuler le bouton de volume avec une amplitude plus importante.
Peut-être le réglage se fera finalement sur -15db.
Le plus important : le son, aucune perte de qualité, pas de ronflement, pas de perte de bande passante ni de dynamique.
Pas d'altération du timbre, c'est exactement ce qu'il me fallait.
Bravo à Audiophonics de proposer de tels articles, petit prix et livraison éclair comme d'habitude.
David C.
TINYSINE TSA3118B SMA Amplifier Module TPA3116D2 Bluetooth aptX TWS 2x50W This amplifier module from TinySine is based on a TPA3116D2 amplifier chip that can deliver up to 2x50W while offering very good efficiency thanks to its Class D architecture....
Petit mais costaud!
J'en possède 2 pour utilisation différentes et j'ai fais plusieurs test avec des systemes stéréo très différents. Ce petit ampli est difficile a mettre en défaut.
Klipsch r41m, parfait.
Focal SIB, parfait.
Focal aria 905, parfait.
Focal opal 8ti, parfait.
En gros il ira parfaitement avec n'importe quelle enceinte de type bibliothèque.
Maintenant on passe aux colonnes.
Klipsch r28-f, la encore parfait! Sur ces colonnes a au rendement (98db), il fait le même boulot que mon Denon x3700h.
Cabasse baltic Evo, la encore extrêmement surpris du résultat sur ces colonnes haut de gamme, le rendu est au moins identique a des ampli de plusieurs milliers d'euros qui doivent habituellement ces colonnes!
Le dernier essai et le seul décevant à été effectué sur des Focal chorus 826V W, modèle particulier comportant des membranes très rigides de la gamme electra, difficiles a driver pour ce petit ampli, mais ne lui n'en voulons pas.
Aucun des ces test n'a fait chauffer l'ampli, il reste quasiment a température ambiante en permanence.
J'ai monté mes 2 amplis dans des boîtes aluminium, l'un alimenté sur secteur par une alim 24v achetée ici, et l'autre avec une batterie de ma confection 21v 5000mah, je suis extrêmement ravis de ces petites bestioles! Le son est précis et toute la dynamique de vos enceintes sera mis en valeur.
Son rapport prix/performances est imbattable!
