Connector
Max sampling rate
DAC / ADC Chip
Amplifier chip
Class
Power (W)
5 - 165
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Connectic
Length
1 m - 2 m
Conductors material (Cable)
Contacts Plating (Connector)
Channel
Input
Output
Remote Control
Networking
Transmission / Reception protocol
Streaming services
Color
Conductors Plating (Cable)
Shielding
Sylvain H.
Headphone amplifier / Preamplifier
Découvrez notre gamme complète d'Amplificateur casque et de Préamplificateur audio. De l'ampli casque mobile à l'ampli casque sédentaire, vous trouverez l'appareil HiFi pour casque audio correspondant à vos attentes et vos besoins.
Soyez également certain de la qualité des Préamplificateurs HiFi que nous vous proposons, qui saurons sublimer et améliorer considérablement votre rendu sonore.
  • Mobile HP Amplifiers
    Discover our range of portable headphone amplifiers, designed for use both at home and on the move, thanks to a compact form factor and an adapted design. Enjoy the best sound quality, wherever and whenever you want.
  • Desktop headphone amplifiers
    Want to enjoy optimal headphone listening at home? Our range of sedentary headphone amplifiers is made for you. A wide selection of headphone amplifiers for both sensitive headphones and high-impedance models.
  • Preamplifiers & Volume Controllers
    Discover our selection of preamplifiers and volume controllers, powerful models to promote excellent sound reproduction for your audio system.
  • Vinyl Preamplifers
    Vinyl Preamplifers
    Do you want to go back to the roots of analog HiFi and enjoy the warm sound of your turntable? A phono preamplifier is then a must to provide your system with the necessary gain to enjoy your equipment at its best.
