Jan S.
One step further!
The IPURIFIER PRO works well. Better separation, details and image. Not a huge step, but enough to recognize it and like it....
stephane e.
Son analogique
Petit appareil chinois exeptionnellement bien construit,les puce AKM font un travail du tonère pour rendre la musique stréamée...
Fidy R.
Étonnante enceinte pour le prix
En stock : livraison parfaite et ultra-rapide en 3 jours ouvrés. Merci Audiophonics.
Emballage parfait : double carton...
Customers reviews - There are 21082 reviews.
Miklos B.
I split my review into three chapter, 1, product and service, 2, sound quality, 3 power rating
1, I have ordered the amp. on a weekend, received the following Friday. At other sources you should calculate minimum 2-4 weeks lead times! So, the speed of delivery was absolute fantastic! Well done! Thank you! Everybody mentioning of the packaging, because there is no special hard paper box, but we get double box with filling material, which is safe enough. The product itself is very solid, nicely built and looks even better in reality than on pictures. Well done! Thanks a lot!
2, I had to wait with this review a week, because I had to find the right cabling. I made the change for this amp from an Emotiva XPA Gen2. When I simple changed them and used the same cables I have got quite week sound. So I started the big changing /fine tuning/ process. Making the long story short, I have changed each cable, selected them out from many alternatives, creating a formerly not used combo from the power cord trough out the USB cable, the RCA digital signal cable, the XLR analog cable and finally the speaker cable. By this process I finally arrived to a very capable, decent, detailed, extreme clean sound which I did not hear from my system so far. Thanks a lot for this!
3, Regarding the power level. The Emotiva papered 500 wpc at 4 ohms. The Purifi rated 425 wpc at 4 ohms. In real life that should not be felt so differently. But if I want to reach the same feeling of sound pressure with the Purifi like with the Emotiva, I need to turn up the DAC/Preamp volume controller from 50% to 75% and at the same time the Windows volume controller from 40% to 50%. ( the Tidal volume controller than can stand on the same place) . So according to my subjective feeling the wpc different is rather around 150 watt instead of 75 watt, which can mean that either the Emotiva delivers more or the Purifi less. ( or both at the same time )
Anyhow, this amplifier absolutely worth the money! Well done, thanks again!
Nils B.
C'est du tout bon
ce câble n'a pas besoin de mon avis. Mais en tout cas c'est un bonheur depuis qu'il est branché.
Génial !
Connecté avec des prises VIBORG or/argent et branché sur un vieux lecteur cd pionner ( décénnie 1990) ; un résultat d' un grand naturel une scéne sonore qui se déploie ; des détails intégrés de façon homogéne , on est pas loin de la réalité ; du bonheur ! bravo à audiophonics ( attendre une dizaine d'heure de rodage et ne pas hésiter à modifier les réglages de votre instalation : position des enceintes , position des piétements anti- vibratoire sous vos appareils si vous en posséder car ce nouveau venu pourra bouleverser votre instalation )
olivier r.
845 pas 845B
Les 845 B n'ont pas de top mica. Il s'agit donc la d'une 845 de base avec une embase décorée, c'est tout.
Raymond M.
Un peu moins dubitatif...
Un bémol à mon avis initial : j’ai déplacé le Clear Line du socle onduleur vers la multiprise située en amont. Résultat, l’aspect coloration-brillance a disparu, et j’ai retrouvé la ‘neutralité’ initiale de mon écoute, tout en ayant un peu plus de dynamique et d’ouverture. Donc c’est super, et je rajoute une étoile, mais pas deux, car je confirme, l’amélioration n’est pas à tomber à la renverse en ce qui me concerne. J’ai une super config, pas aussi top que Christophe L, mais il y a peut-être quelque chose qui ‘bloque’ le Clear Line. En plus du bloc onduleur, mon PC est un gros ‘transportable’ avec son ‘gros’ bloc alim. Il n’est pas directement sur le secteur. Est-ce tout cela qui s’accumule, pour donner un courant secteur déjà pas mal optimisé ? Mystère audio…
Dominique P.
Reçu rapidement et soigneusement emballé le produit semble de bonne facture et les mesures précises. Seul bémol: la notice entièrement en idéogrammes (chinois?) et le boîtier en plastique cassé dans un coin.
Théodore M.
5/5 rapport qualité prix écoute
Acheté pour remplacer du QED Ruby anniversary trop court suite à une nouvelle disposition. Reliés en bicablage avec des Furetech au niveau de l'ampli et des Hicon à mes enceintes (Elac bibliothèques). Sans vouloir rentrer trop dans les détails en comparaison moins de spacialisation (rodage ?) mais plus de précisions sur les petits signaux et des instruments plus fidèles. Également une dynamique plus fine au niveau de la séparation et l'aération entre pupitres ainsi que des prolongations de fin de notes plus longues dès qu'on prête l'oreille... Essayés chez un ami sur des petites colonnes Rodgers ces câbles se sont révélés là aussi très fidèles et précis. Pour avoir mieux il faut y mettre bien plus cher, on ne devrait pas être déçu sur une chaîne de moyenne gamme (3500 à 6000€) quelle qu'elle soit.
Théodore M.
Acheté pour remplacer 'IEC Elecaudio branchée sur ma barrette secteur Supra. Elle permet de monter facilement des câbles de plus grosse section (en l'occurrence Yarbo SP-8000PW de section 4,6 mm2). Par contre ne tiens pas assez fermement dans l'embase IEC de la barrette du fait de la rigidité du câble (je compte refaire l'embase en attendant de pouvoir acheter une meilleure barrette).
Théodore M.
10/10 !
Qualité des contacts excellente, coût raisonnable et super pratique pour le branchement du câble de la barrette secteur à la prise murale (Furetech) et derrière mon ampli.
Théodore M.
rapport qualité prix 5/5
Acheté avec des Schuko et IEC Elecaudio pour remplacer les câbles d'alimentation Supra (ampli, lecteur CD, Tuner). Amélioration immédiate sur tous les plans : rapidité sur les petits signaux qui apporte de la précision dans les attaques et fin de notes prolongées, meilleure spacialisation etc...
Je suis passé sur un Yarbo SP-8000PW sur mon ampli pour un gain encore meilleur sur l'ensemble de l'écoute (demande de courant supérieure car 1 transfo torique par voie + 1 pour la partie préamplificatrice à tube). Le tout en peaufinant les détails (prise murale Furetech pas donnée mais de grande qualité).
Raymond M.
Dubitatif et pas trop convaincu...
J’ai mis un peu de temps avant de donner mon avis, car je suis bien embarrassé et moins dithyrambique que les 6 autres avis postés (sans parler de l’annonce sur le site Furutech) …
L’écoute paraît un peu plus dynamique, un peu plus ouverte, mais aussi un peu plus colorée, moins neutre, et c’est cela qui me gêne, car cette ‘brillance’ annule quelque peu mes investissements en câbles (dual USB et Noir Hybrid de chez Forza Audioworks) pour connecter mon Dac-Ampli Audio GD R2R et mon casque HiFiMAN Sundara. Mon écoute se fait au casque sur mon PC avec Audirvana, où tout est déjà pas mal optimisé (2 JitterBug Audioquest pour l’USB, cordons secteur améliorés, le tout branché sur un bloc prises onduleur APC 700). Peut-être est-ce ce bloc onduleur qui rend ce Clear Line ‘peu spectaculaire’ ?
Mais je ne regrette nullement cet achat. Au vu des avis élogieux, j’aurais plus regretté d’être passé à côté d’une amélioration supplémentaire dans mon ‘mécano’ audio… Là au moins j’ai testé !
Je vais continuer les comparaisons et essayer de me convaincre de cette ‘dernière’ … amélioration, mais pour être franc, j’hésite à la conserver côté audio, et vais faire un essai sur la barrette secteur côté vidéo, histoire de finaliser son utilisation.
Anne b.
désoxydant
produit excellent pour beaucoup de contact je le conseille a tout les audiophile
Anne b.
fiche secteur
fiche secteur de bonne qualité je monte beaucoup plus dans les graves le médium est amélioré vraiment bien
Sandy Clémence B.
Sandy Clémence B.
borniers
très bonne qualité.
Robert V.
Robert V.
Composant comme décrit.
Robert V.
S'adapte parfaitement pour un potentiomètre ALPS, même pour un commutateur normalement utilisé pour des boutons à crans.
Très belle finition sur un panneau en alu éloxé naturel brossé.
Photos sur demande. . .
Sandy Clémence B.
IFI AUDIO IPOWER X Low Noise Switched Mode Power Supply 9V 2.5A iFi Audio offers with its iPower X power adapter a very low noise power supply, designed to cleanly power your HiFi modules and devices, contributing greatly to the quality of...
adaptateur secteurfaible bruit
sur une installation audio haut de gamme, j'ai de bien meilleurs résultats en utilisant le module AUDIOPHONICS, d'alimentation régulée linéaire, . très faible bruit peut être, mais pas intéressante pour un système audiophile. .
Sandy Clémence B.
AUDIOPHONICS PSU S4-HP Linear Power supply Module DC Micrel29752 Adjustable 5–24 V The Audiophonics PSU S4-HP power supply module has been designed to provide a clean DC voltage supply to an amplifier or other audio circuit. Its particularly rigorous design,...
alimentation linéaire
j'utilise cette alimentation pour alimenter un l streamer de réseau de haut performance (3DLAB.nanoplayer).en remplacement de l'alim d'origine (un vulgaire boitier 220v/9v, polluant à fond..!.
le résultat est saisissant , lors d'une écoute "audiophile". (j'ai une installation avec un ampli a tube 845, et des baffles en supravox, de conception maison.) . SUPER RESULTAT. bravo.
Damien M.
Elle en pince pour les embouts cuivre plaqués argent !
Simple , pratique et efficace pour du travail soigné , elle permet d'optimiser de façon directe et rapide les connexions enceintes /ampli. Indispensable !
Damien M.
Elles n'aiment pas qu'on les appelle bananes !
Elles ont tout fait pour s'en différencier , nues sans le traditionnel capuchon , exhibant une peau d'argent qui dissimule le cuivre de leur âme , elles sont les plus performantes de ce type de connexion en audio ( la matière conjuguée à la surface de contact qu'elles offrent ) et portant on continuera à les appeler bananes.
Franchement belle trouvaille ! leur simplicité alliée à une redoutable efficacité , tout cela à un prix imbattable devrait les rendre incontournables. Pour les enceintes par exemple , on masquera la connexion soudée câble /fiche avec un manchon caoutchouc ou un bout de gaine rétractable. Bien sûr ces fiches seront à privilégier sur les appareils qui ne demandent pas à être déconnectés de façon récurrente.
Daniel E.
Attention! N'accepte pas les rouleaux larges!
Arnaud F.
Apporte de la sérénité à mon ensemble
Grâce à l'alimentation, mon ensemble avec Evo-sabre a un rendu sonore plus doux, avec des silences plus vrais.
Les attaques de sons et également leurs fins sont plus définis.
Tout cela permet un meilleur rendu des graves tout comme des médiums et aigus.
L'alimentation semble très bine fabriquée et donne une belle impression de qualité dommage que la diode soit si lumineuse.
Damien M.
plaquées avec votre argent !
Petite boutade pour rappeler le plaquage dont est doté le tout cuivre de ces fiches.
la coque assure une bonne robustesse à l'accessoire , la place pour effectuer la soudure du câble de modulation est suffisante ; au moment de l'opération j'oriente le câble de manière à ce que la tresse de masse soit au même niveau que le fil de point chaud et non en dessous , afin que celui-ci ne me gène pas , puis je la soude sur le côté. Question fil de soudure, préférer du fil d'étain Sn62 Pb36 Ag2 5/10 qui dès 185° assure une très belle soudure. Avec soudure sans plomb, la température de fusion étant d'une quarantaine de degrés plus élevée le plot PTFE du Pin central à tendance à se déformer. Sinon , le capuchon d' aluminium anodisé assure une bonne prise en main de la fiche qui garantit une connexion franche et robuste. Seul petit regret , la bague de couleur rouge ou blanche me semble un peu discrète.
Bon produit globalement , même si le prix me semble un peu au- dessus du raisonnable.
Excellent.
Aucune altération du son avec un Sennheiser HD650 et excellente qualité de la fiche jack femelle , pas le moindre jeu et donc pas le moindre faux contact , désagrément fréquent avec des prises de qualité inférieure ... Audiophonics pourrait proposer une longueur intermédiaire entre 2,5 m (un peu juste) et 5 m (un peu long) disons 3,5 m se serait parfait !
Richard s.
Améliore la dynamique des couleurs le grain et le son.Mais câble rigide et fiches HDMI plastique un peu légères .
RS
Très surpris de ces petits HP large bande. Un son bien remplis et largement fidèle pour le cout.
je recommande...pour enceinte portable ou petites enceintes de bibliothèque ou tout autre projet...
Richard s.
Le meilleur RQP
Excellent câble procure une restitution tendue sans agressivité dans une très large bande sonore de l'extrême grave à l'aigu totalement libre avec beaucoup d'air entre les pupitres avec une grande dynamique monté avec des RCA KLEI HARMONY SILVER c'est parfait.Bien meilleur que le Stratos Sommer que j'utilisai avant.
RS
Laurent N.
Utilisé pour connecté un DAC en I2S sur une carte mère RASPBERRY PI 1B, tout est conforme et bien dimensionné, ca tombe pile poil.
Par contre j'ai attrapé des sueurs au moment de souder, comme c'est très petit et étriqué, il vous faut une pointe très fine et une soudure elle aussi très fine, ce que je n'avais pas... sachez le
Laurent N.
Bon produit utilisé pour connecté un DAC en I2S, RAS
Laurent N.
Bonne qualité mais qui fait le CQ ?
Remplace 2 câbles HS, la qualité semble au RDV, les câbles sont un peu rigides, de bonne épaisseur et le gros embout métallique parait solide.
Par contre une des fiches n'est pas du tout dans l'axe de l'embout carré ce qui fait que celui ci se retrouve de biais une fois monté, de fait cote à cote sur 2 entrées TOSLINK proches les miens passent tout juste vu la taille de l'embout.
Prendre en compte la rigidité du câble si votre passage de câble est sinueux.
Laurent N.
Utile mais pas indispensable (lire)
Commandés pour compléter l'autre bout de mes câbles HP montés avec des BANANA PLUG OEHLBACH, produits de qualité équivalente.
Montés comme suit : sertissage du câble, soudure à l'étain / argent puis maintien grâce à 2 épaisseurs de gaine thermorétractable pour l'isolation, l'orientation (rouge / noir) et l'esthétique.
C'est utile si vous voulez tester différentes configurations d'amplification (double pour moi), que vous changer régulièrement un de éléments votre couple ampli / enceintes ou que vous disposez de connectiques bizarres sur un de ces éléments (mon bornier home cinéma CAMBRIDGE AUDIO par exemple).
Si votre installation est stationnaire et ne sera plus touchée une fois connectée, vous pouvez vous contenter d'un sertissage direct du câble sur le bornier, à votre guise.
Laurent N.
Utile
Semble de bonne qualité, utilisé pour transformer une sortie numérique SPDIF BNC en SPDIF RCA.
Laurent N.
Le jour et la nuit...
Acheté pour transformer un vieux RASPBERRY PI 1B (2011) en lecteur mp3 et numérique sédentaire pilotable à distance.
Fonctionne parfaitement, pas de bruits de fond, de clics ou parasites, bon niveau de sortie ligne.
En comparaison de mon IPOD CLASSIC 160Go qui me servait précédemment pour cet usage, c'est le jour et la nuit, graves plus présents et surtout mieux maitrisés, des aigus plus détaillés sans être agressifs ni sibilants, des voix bien détachées et présentes, la dynamique d'ensemble est elle aussi nettement supérieure, la scène sonore est mieux établie, bref je suis comblé et je ne pensais pas pouvoir avoir cette qualité de rendu sur du simple mp3.
Non testé sur des formats CD et au delà, je penses que c'est là où le DAC montrerait ses limites face à mes lecteurs CD et DAC audiophiles autonomes ...
J'aurais juste souhaité un schéma de montage papier joint au DAC ou au moins une explication plus détaillée sur la fiche produit car j'ai monté le DAC sans être trop certain de ce que je faisais.
Note : utilisé sur une installation audio entrée de gamme avec double amplification CAMBRIDGE AUDIO et des enceintes colonnes JBL très dynamiques.
Daniel E.
Il existe bien des versions du JC-2, plus ou moins fidèle au schéma d'origine de John Curl.
J'en ai déjà un, un peu différent, il ils sonnent très proches.
Le pré Audiophonics est d'une très bonne facture, et disons le haut et fort: très très bon! Le rapport qualité est ce qu'il y a de mieux sur le marché. Petit astuce: j'ai remplacé le condensateur de sortie par par un Mundorf EVO Silver.Gold.Oil, qui est assez cher mais booste le pré beaucoup. Dans certains cas, ce condo n'est même pas nécessaire (si l'ampli de puissance a un condo à son entrée), alors on peut simplement le bypasser.
L'emplacement du potard permet de le remplacer par un motorisé et installer un circuit de pilotage, on aura alors le confort d'une télécommande...
Je serai prêt à payer une peu plus si ce préampli venait directement avec cet accessoire!
On trouve exactement le même produit en Chine, non-estampillé Audiophonics, mais au même prix, alors autant le commander en France avec un délai de livraison bien plus court.
5 étoiles!
Daniel E.
Bon produit, mais...
Comme d'habitude les transfos spécifiques Audiophonics ont les deux fils du primaire une gaine de la même couleur. Il est connus depuis des lustres que le primaire de l'enroulement (donc le début) doit être impérativement connecté à la phase du secteur, le secondaire au neutre. Les inverser à un impact sur le rendu sonore. Mais avec deux fils de la même couleur, comment savoir? Bien sûr, de écoutes peuvent définir comment brancher le primaire, mais c'est compliqué (et pas toujours évident à déceler).
Sinon, bon produit.
Daniel E.
Sinon, bon produit.
F M.
Damien M.
Théodore M.
Super rapport qualité prix
Panagiotis K.
Smsl su9
Dominique F.
Tero S.
Winner!
Pedro B.
Stephane B.
Just WOW
Dumitrescu M.
comme je l'attendais
Dumitrescu M.
Emmanuel l.
top pour le prix
