Kevin S.
Paulius S.
Very Useful
Nothing to complain.
Paulius S.
Very Good
I like this cable and price very much.
Customers reviews - There are 19318 reviews.
Pas mal
produit bien fini comme le reste des produits viablue, et fait le boulot.
J'ai hésité avec les furutech, qui ont l'air supérieures mais pas le même prix.
Bon rendu sonore
C'est l'essentiel, je les préfère du coup aux neutrick nf2cb2 qui sont plus douce mais plus ternes, en association avec le stratos.
C'est naturel aéré, et pas fatigant.Les fiches sont plutôt réussies esthétiquement.
rendu naturel, sans agressivité, associé aux fiches viablue t6s.Celles-ci paraissent plus définies que les rca neutrick nf2cb2 montées sur le stratos aussi.
Krzysztof S.
I'm dissapointed. No volume control on volumio (version 2.x and 3.x). Huge problems with installing the power button. In Volumio 3.x, I was unable to get the button to work. Only the downgrade to 2.x helped. It gives 2 stars instead of 0 only because the sound quality generated by this DAC is very good.
Hi,
This DAC doesnt have an hardware built in volume control but you can always use the embedded to volumio software volume control.
This feature has been removed we are not responsible of that ...
Hermann B.
AMANERO COMBO384SE Digital interface USB 384kHz / SPDIF WM8804 to I2S / DSD Combo384SE version also incorporating a bidirectional S / PDIF WM8804 interface which can function as input or as output according to the needs of your project.
Excellent customer support
my request was resolved very quickly
Hermann B.
excellent customer support
customer service is fast and excellent
Poor clamp
I sent this back as the cable clamp did not grip a 12mm cable. Poorly designed.
Great connector
Build and finish is excellent. The cable clamping is very cable friendly, unlike Furutech and others that splay heavy gauge cables and I use 10AWG cables.
As plugs go, they impart great air and spaciousness to the sound.
Terrific cable
An excellent cable for the price. Have it paired with Furutech copper/rhodium plugs and sound is smooth, detailed and open.
Excellent cable
I paired this cable with Ramm silver/rhodium RCA plugs. Really gorgeous textured sound and not at all bright.
Tomas H.
Easy to work with
Nice quality-cable!
Straight forward and clean, straight sound - but IMHO not as musical as my Belden 8402 who plays a warmer sound with a bit more low´s and depth.
Remi B.
Jack haut de gamme
Produit de qualité contacts fermes et paraissent sûrs. Utilisé sur sortie de lecteurs cd, et oui, et dac externe les diffences sont clairement audibles entre appareils. Reste à savoir si le prix fait vraiment une différence avec les autres modèles sur le site à prix très inférieur ?
Cristian E.
MOGAMI W2524
Est parfait pour cable secteur. La qualité est au rdv!
Cristian E.
MOGAMI NEGLEX W2534
cable de calite! je recommand sans hesitation!
Venčeslav D.
AUNE X8 DAC FPGA Altera Max II 32bit 768kHz DSD512 XMOS Silver The Aune X8 is a high-performance DAC, compatible with high-resolution files up to 32bit PCM 768kHz and DSD512. The conversion is done using an Altera Max II FPGA chip,...
Venceslav
I solved the problem with the installation with the usb plug, it was tested on you tube, and at the moment via spotify, great sound, I am pleasantly surprised, great device :)
Bien meilleur que les cables de marque à ce tarif
J'utile ce cable depuis maintenant plus d'un an:relief de l'image stéreo (sur de bon enregistrement on est vraiment immergé par la musique),les timbres semblent réaliste,bref trés bon.
J'ai put comparer à du QED de même gamme tarifaire;atomisé littéralement,ou est passé le relief de l'imamage stéreo,c'est trop clair et limite agressif...si vous avez un budget serré à essayer absolument.
Excellent Dac a condition de soigner le cablage
Je poste cet avis,ayant eut l'opportunité d'en acquérir un d'occasion quasi neuf,le produit n'étant pas disponible pour le moment.
Utilistaion pc portable,foobar asio:les cales secteur et usb doivent obligatoirement être remplacés par des modèles plus qualitatifs(compter environ 100 euros)
Dans ce cas,trés belle image stéréo,sonorité trés detaillée mais pas agressive;si vous aimez un son plutôt rond et chaud,passez votre chemin.
Pour ma part,associé a un ampli Rega IO et des enceintes Q Acoustics Concept20;du pur bonheur sur du jazz/blues acoustique,c'est extremement vivant et enjoué.
Multiprise de bonne qualité mais le montage du câble secteur n'est pas évident...j'ai bien mis 2 heures pour
monter cette satanée Multiprise !!
Un petit tutoriel serait le bienvenue
Bon cable
Bon câble a prix correct.
Fiche banane de qualité
Fiche banane de qualité, cependant le blocage sur mon ampli est presque insuffisant.
Cette fiche peut ne pas fonctionner avec toutes les fiches femelles.
C'est dommage, car la fiche est de bonne facture.
EXCELLENT UPGRADE
En remplacement de deux NE5532 sur ampli classe D, le résultat est impressionnant. Image stéréo véritablement tridimensionnelle, excellente transparence. Définition à l'avenant sans brillance dans l'aigu ni excès dans le grave. un AOP à retenir absolument.
Dimitar C.
Firstly I purchase another product mean chassis, but didn't receive the courier lost the goods. But thanks to the Audiophonics support everything finish with happy end, Thanks Audiophonics for your attention, accuracy and fast response.
Anyway they send to me this unit and I am very happy with it, according to the design it is fabulous, beauty and precise, now I am in the way to complete my mono power amplifier.
Thanks again Audiophonics!
Dimitar C.
Good quality, but need to inform that the fuse is not include.
For this price it is a shame for Furutech!
Yoann L.
Câble assez neutre dans le haut du spectre. Grave ferme sans manque d’information. Un câble qui donnerais des sueurs froides à bien plus chère …
Tester sur ampli et dac goldmund , streamer auralic femto ,et enceintes pylon diamond 30.
Mário Z.
A true killer amplifier
Amazing amplifier! Better than Sugden A21 SE and 14 times cheaper!!!
Ribamar A.
VIABLUE X-60 Silver Power Cable
Câble d'excellente qualité. Le son est devenu plus propre, cristallin. Je ne m'attendais pas à une amélioration aussi significative. Cela prouve une fois de plus qu'il n'est pas nécessaire de dépenser une fortune pour réaliser de réels gains de performances. Pour moi ça valait l'investissement.
Philippe A.
AUDIO-GD PRECISION 3 2020 EDITION Balanced Class A Amplifier ACSS 2x 70W 8 Ohm Audio-GD is upgrading its Audio-GD Precision 3 by offering this 2020 edition. It is based on the previous model, but with a modified circuitry and adjusted sound performance to...
bon appareil, utilisé dans le cadre d'une tri amplification active pour les médiums, j'ai gagné en clarté et en précision dans cette partie du spectre. son assez doux, pas agressif.
Philippe A.
commandé lundi soir reçu jeudi matin. pas encore utilisé mais produit apparemment de qualité.
Laurent W.
TOPPING P50 Regulated Linear Power Supply Ultra Low Noise 2x 5V 1A + 15V 1A Black This regular linear power supply Topping P50 offers excellent performance and allows a HiFi system to be powered properly and thus promotes the sound reproduction quality of the...
Excellent produit. M'a permis d'alimenter un 'vieux' dac nuprime udsd grâce au câble audiophonics usba mâle vers 2x USB femelle et en même temps y connecter un iphone ou un dap qui ne pouvaient alimenter le dac. J'ai l'impression que le son du DAC s'en trouve amélioré.
Robin L.
Marche très bien !
Renvoyé pour un problème de soudure, celui qui m'est revenu fonctionne à merveille depuis 6 mois avec le petit hp sub TANG BANG sur le même site, et une vieille paire d'enceinte de chaine hifi du commerce grand public.
Vraiment pratique, mode 2.1 ou sub uniquement. Différents réglages, bonnes connectiques etc... parfait pour une petite installation pas chère, fait maison rapidement, et avec des basses bien présentes !
Robin L.
Parfait, super puissant pour une petite pièce d'atelier
Vraiment excellent, j'en ai fait un sub basse reflexe, c'est très puissant pour une petite pièce de 10m², au dessus ça devient vite limité je pense, en extérieur c'est très faible aussi si on veux vraiment pousser le volume, mais suffisant pour une ambiance qui casse pas les oreilles
Robin L.
Très pratique
Très facile à installer grâce au filetage, suffit de percer, poser, visser et ça bouge pas. (Et souder de l'autre côté...)
Robin L.
Très content
Ravis par ce petit ampli, très efficace pour le prix. Aigues un peu fortes, je les baisse de 3 ou 4 dB dans le réglage, mais ça dépend des enceintes aussi (j'ai des klipsh).
Attention à la sortie sub, elle m'a semblé assez puissante pour une sortie non amplifiée par rapport à une sortie line d'ampli classique, donc monter très doucement le potard du caisson de basse amplifié !
Autre détail pas terrible c'est qu'il est tellement léger que suivant la disposition, tout les câbles à l'arrière peuvent soulever l'ampli vers l'arrière, ce qui le rend un peu ridicule...
Gabriel L.
Un must
Pas l'habitude de donner mon avis, mais c'est vraiment bluffant ce petit préampli au prix ridicule comparé à la HIFI des grandes marques. Après avoir dépensé des milliers d'euros je me suis tourné vers des produits moins ésotériques et c'est gagné à 100%. il faut vraiment remplacer rapidement les tubes d'origines par les GE 5654, le son n'est plus le même. Pour info je fonctionne avec un lecteur maison sous Daphile, un dac Dopping D70, le superbe ampli AUDIOPHONICS MPA-S125NC (extra avec le tube 03) et des enceintes Higland Audio Aingel 3205, dans une pièce de + de 40 m2 c'est juste incroyable.
David G.
FX-AUDIO D01 DAC Headphone Amplifier Bluetooth 5.0 ES9038Q2M TPA6120A2 XMOS CSR8675 32bit 768kHz DSD512 Featuring an excellent 32-bit ES9038Q2M digital-to-analog conversion chip, the DAC FX-Audio D01 offers excellent audio performance with a wide dynamic range, low distortion, and...
Nickel.
Bt reconnu immédiatement, pas besoin de pilote pour l'entrée usb sur pc windows 10.
Seul bémol, le volume un peu faible, je dois positionner le potard au delà de 60 %. Il faut un ampli avec de la pêche derrière.
David G.
Fiches pas tip top
Les fiches de ces câbles forcent beaucoup sur les entrées de mon technics su8044. Problème que je ne rencontre pas avec des câbles génériques. J'ai branché ces dynavox sur des appareils plus récents et ça passe.
Claudio c.
FIIO FD1 In-Ear Monitor IEM Beryllium Plated Dynamic Drivers With the FD1, Fiio offers high-quality in-ear headphones at a reduced price. They benefit from a careful design to offer a rich and immersive sound reproduction, as well as an...
Incroyable écouteur
Pour le prix c'est vraiment incroyable, ergonomie au top , le son très dynamique vraiment imbattable pour son prix. Il va droit au but , donner du plaisir à l"écoute.
Florent L.
Wow Viborg
hello, le TOP!
jean francois r.
FURUTECH FLUX-50 NCF (G) EMI AC-1501 (R) Main Filter Gold Plated The Flux-50 NCF (G) is a luxurious and ultra-sophisticated mains filter, which eliminates many problems caused by faulty upstream power lines and current. It protects against...
Filtre indispensable à avoir pour tout bons systèmes et oreilles qui se respectent ! sublime votre matériel !
henry N.
SIVGA ROBIN Dynamic Closed-Back Over-Ear Headphone Ø50mm 32Ω 105dB 20Hz-20kHz Zebrano Sivga offers with its Robin headphones a model that is both elegant and efficient, revealing a musical and dynamic sound reproduction within an ergonomic and modern design. The...
Très bon casque. Les finitions sont très belles. Faites attention, le bois est en réalité brun foncé légèrement plus clair que sur la photo. N'ayant pas testé d'autres casques dans la même gamme de prix ou plus chère, je ne peux pas vous donner un réel avis sur le son, pour moi il est juste très bon. Sinon le confort est juste parfait et le bois est traité avec un verni mat qui à l'air de bonne qualité.
Andre v.
Great chassis
Four points for this great chassis. Received in almost mint quality (few minor scratches) but incredible quality overall. One rating star was lost for that and two minor issues. 1. the top plate is not symmetrical and therefor cant be rotated to have the ventilation on the back of the unit which is strange. And 2. the amount of screws are exactly enough to build the chassis. so don't loose one screw or you are screwed. And why silver screws in a black chassis.. huh?? ohh okay..
Florent L.
Au top!!
Que dire de plus que woww!! superbe merci
Hervé C.
Etonnant rapport qualité prix.
Un équilibre tonal parfait (surprenant quand on sort d'amplis "classiques", toujours un peu typés), une dynamique "réaliste", une écoute très précise. Les basses sont percutantes et présentes sans abus mais manquent un peu de délié et de différenciation. Scène sonore très précise et focalisée mais manquant un peu profondeur et d'"enveloppement".
Pour l'instant associé en direct à un SMSL Su-9 avec des XLR Mogami 2549 et alimentant des Acoustic Energy Aegis Evo3 (colonnes 2,5 voies), je songe tout de même à intercaler un préampli ou essayer un autre câble pour gagner un peu en densité et améliorer la rondeur des basses.
Rapport qualité prix quand même particulièrement étonnant.
Vincenzo C.
Parfait pour radio anciennes
Utilisé sur trois radios à tubes pour les transformer en caisson bluetooth avec un très bon résultat: très petit, on peut le placer dans le meuble sans éliminer le cadre avec le circuit originel. Puissant et avec un bon tmbre.
john p.
Relaxed sound
This product lies outside the general rule “you get what you pay for”. As a standalone dac tested with optical ,coaxial, usb inputs sounds really good. I am not afraid to say it stands close to far more expensive R2R dacs I had the chance to listen to. My ongoing concern with digital has always been the listening fatigue ,this bombarding and exaggeration of microdetails that messes with your brain. This dac is a different story.
The RPI4 is a fantastic streamer transport and with the I2S connection to the dac sounds fantastic. Tidal HiFi in most cases sounds really good. (MQA is not my thing)
I have tested standard 16/44.1, higher sampling rates and DSD. My preference remains standard 16/44.1 and DSD through Volumio.
Being a vinyl fan from my early days and having accepted the pros and cons of this format I got lucky to run into this “desktop” sreamer-dac that gives me 4-6 hours of daily music listening without any fatigue. XLR output to a Luxman L550axII feeding a pair of heavily modified old Klipschorns and there you are !!!
A great combo from the Audiophonics guys!!
Rémi L.
HIFI 2000 GALAXY GX147 Aluminium Case 124 x 170 x 40mm 3mm Front Panel Silver This HIFI 2000 Galaxy GX147 all-aluminium case will allow you to create and dress your DIY creations. Strong, it will prove to be durable and will perfectly protect all the...
Fait le job mais jour de presque 1mm entre la façade avant et la façade supérieur/inférieur. Découpes des façades avant/arrière assez moyennes via cisaillement. Finition brossée sur ces façades - Beau rendu global mais il ne faut pas allé dans le détail.
Utilisé pour monter une alim SMPS 300RS 24V pour un petit ampli FDA.
TRES BON SUBSTITUT AU NE5532
En remplacement de deux NE5532 dans ampli classe D TPA 3255 de 3E audio alimenté en 44 volts. Le résultat est meilleur sur la majorité des critères. Grave bien maîtrisé sans traînage, aigu très raffiné et image stéréo plus profonde, excellente résolution également. Une option à prendre en considération aux cotés d'autres très bons AOP.
Christophe T.
FGG 2 Pins Connector for Focal Utopia Headphone This high quality connector has a specific format with 2 pins, adapted for the design of cables for Focal Utopia headphones. Its contacts are gold plated to ensure a very good...
Que du bon
Utilisé pour faire des câbles pour mon casque Focal Utopia. En effet, Focal sait fabriquer de très bon casques, mais n’est pas foutu de faire des câbles qui dure. Très bon connecteur. De la mécanique de précision. Les pins sont tous petits. Il faut un fer à souder avec une panne pointue, et avec la température réglable. J’ai soudé à 300°C. Je pense qu’une certaine expérience de la soudure à l’étain n’est pas de trop. J’ai utilisé le câble SOMMERCABLE ONYX 2025 MKII, que je trouve bien adapté à cet usage. Du coté de mon ampli AUDIO-GD R-28, j’ai mis une XLR mâle 4 broches NEUTRIK NC4MXX-B pour le câble symétrique, et un jack TRS 3,5mm avec filetage pour visser l’adaptateur jack 6,35, référence 10374, pour le câble asymétrique. Tous cela fonctionne très bien. La qualité et la solidité en plus.
Vincent M.
Très bon connecteur antenne coudé
ayant cassé mon connecteur de mon câble antenne audioquest forest, je l'ai remplacé par celui ci alors là bluffé par la qualité de fabrication et de la qualité de l'image de la TNT.
Le contraste a été amélioré sans changé de réglage de la TV :
le noir est plus profond
plus de perte de signal TNT
conclusion : que du plus
jean luc L.
https://www.audiophonics.fr/index.php?id_product=5071&controller=product
